KX500 Crank shaft interchange information
Bottom end tips and mods
Post by Sandblaster » Fri Mar 01, 2013 2:25 am
1985 - 2004 Kawasaki KX 500
Connecting Rod:
Big End Bearing (mm): 26x33x22
Big End Bore (mm): 33.00
Big End Width (mm): 21.97
Center To Center (mm): 145.00
Pin Diameter (mm): 26.00
Pin Length (mm): 54.40
Small End Bearing (mm): 19x24x25
Small End Bore (mm): 24.00
Small End Width (mm): 21.97
Washer Thickness (mm): 1
Re: KX500 Service Specifications page
Post by Sandblaster » Tue Mar 11, 2014 6:44 pm
KX500 crank comparison 85-04
Here is the interchange info from Kawasaki.
85-86 KX500 - 86MM STD STROKE - 13031-1182
1987 - 86MM STD STROKE - 13031-1231
1988 – 86MM STD STROKE - 13031-1260
89-91 - 86MM STD STROKE – 13031-1285
92-04 - 86MM STD STROKE - 13031-1340
The crank bearings and seals are the same from 83-04.
The fly wheel taper and 12mm nuts are the same from 83-04.
The only differences I can find is the weight and the clutch side shaft.
The 91 and earlier cranks have holes in the crank that make them lighter then the 92-04.
The 85-87 used a key and a nut to hold the primary crank gear to the shaft.
88 and up used a snap ring to hold the primary crank gear to the shaft with no nut.
Kawasaki rods had different part numbers over the years but, the after market rods and rod kits are the same as well as the stroke at 86mm.
Here is a pic of the 85-86 kx500 clutch side of crank.
1986 KX500 CRANK SHAFT.JPG (122.51 KiB) Viewed 16218 times
Here is a pic of the 1987 KX500 crank.
1987 KX500 CRANK SHAFT.JPG (81.79 KiB) Viewed 16218 times
Here is a pic of the 1988 KX500 crank.
1988 KX500 CRANK SHAFT.JPG (75.94 KiB) Viewed 16218 times
Post by Sandblaster » Tue Mar 11, 2014 6:56 pm
The pic below looks just like a 89-04 KX500 crank.
This pic is of a 1992-2004 KX500 crank.
Trying to determine the difference between the 89-91 and the 92-04.
I have heard that the 89-91 kx500 crank shaft is lighter then the 92-04.
But, that will require some verification.
92-04 KX500 CRANK SHAFT.JPG (58.79 KiB) Viewed 16217 times
Post by Sandblaster » Tue Mar 11, 2014 8:09 pm
From what I can see, 85-87 kx500 crank shafts look identical.
From what I can see, 88 is the only kx500 crank shaft where it uses the snap ring on the primary crank gear but has the holes in the crank halves..
From what I can see, 89-04 crank shafts look identical.
So my best prognostication is that 85-04 can all be swapped as long as you have the correct primary crank gear asy to match the crank you are using.
Luckydogfab
Re: KX500 Crank shaft interchange information
Post by Luckydogfab » Tue Feb 19, 2019 3:25 pm
I’m wondering if you have moved beyond prognostication? Just wondering because I have trashed my second crankshaft this winter, supplies are starting to run low, need a back up, nothing available on eBay for my 2003
Post by Sandblaster » Wed Feb 20, 2019 1:25 am
At this point we have not made any cranks although we should.
It's just another project to get involved in :shock:
We do get a lot of our cranks rebuilt.
What is wrong with yours?
A lot can be repaired, bearing journals, threads, ect...
Let me know.
Return to “Bottom end”
