KX500 Service Specifications page
Re: KX500 Service Specifications page
Post by Sandblaster » Tue Mar 11, 2014 6:44 pm
KX500 crank comparison 85-04
Here is the interchange info from Kawasaki.
85-86 KX500 - 86MM STD STROKE - 13031-1182
1987 - 86MM STD STROKE - 13031-1231
1988 – 86MM STD STROKE - 13031-1260
89-91 - 86MM STD STROKE – 13031-1285
92-04 - 86MM STD STROKE - 13031-1340
The crank bearings and seals are the same from 83-04.
The fly wheel taper and 12mm nuts are the same from 83-04.
The only differences I can find is the weight and the clutch side shaft.
The 85-87 used a key and a nut to hold the primary crank gear to the shaft.
88 and up used a snap ring to hold the primary crank gear to the shaft with no nut.
Kawasaki rods had different part numbers over the years but, the after market rods and rod kits are the same as well as the stroke at 86mm.
Here is a pic of the 85-86 kx500 clutch side of crank.
1986 KX500 CRANK SHAFT.JPG (122.51 KiB) Viewed 13920 times
Here is a pic of the 1987 KX500 crank.
1987 KX500 CRANK SHAFT.JPG (81.79 KiB) Viewed 13920 times
Here is a pic of the 1988 KX500 crank.
1988 KX500 CRANK SHAFT.JPG (75.94 KiB) Viewed 13920 times
Post by Sandblaster » Tue Mar 11, 2014 6:56 pm
The pic below looks just like a 89-04 KX500 crank.
This pic is of a 1992-2004 KX500 crank.
Trying to determine the difference between the 89-91 and the 92-04.
I have heard that the 89-91 kx500 crank shaft is lighter then the 92-04.
But, that will require some verification.
92-04 KX500 CRANK SHAFT.JPG (58.79 KiB) Viewed 13922 times
Post by Sandblaster » Tue Mar 11, 2014 8:09 pm
From what I can see, 85-87 kx500 crank shafts look identical.
From what I can see, 88 is the only kx500 crank shaft where it uses the snap ring on the primary crank gear but has the holes in the crank halves..
From what I can see, 89-04 crank shafts look identical.
So my best prognostication is that 85-04 can all be swapped as long as you have the correct primary crank gear asy to match the crank you are using.
Post by Sandblaster » Wed May 14, 2014 5:56 am
5-13-14 added jetting specs..
The following chart is from Team Green.
I have found that it is a bit conservative.
Your not going to burn your bike up using them as long as your bike is in good condition.
However, for 0-1500 ft, stock engine, after market pipe, 92 octane fuel running 40:1 Motul 800, use 55 pilot, 168 main, stock needle at the 3rd position, 1.5 turns on the air screw and your rockin.
I use this on my Super moto and my Dunes/desert bike..
kx500 jetting.jpg (113.71 KiB) Viewed 13901 times
Post by Sandblaster » Tue Aug 26, 2014 7:56 pm
FMF JETTING RECOMMENDATIONS FOR SEA LEVEL AT 65-80F, 32:1 OIL/FUEL MIXTURE, UNLEADED PUMP FUEL, STOCK ENGINE
Then there is a whole bunch of disclaimers.
Basically, do pulg chops and watch your temps...
1988 KX500
MAIN JET: 175
PILOT JET: 62
NEEDLE: STOCK
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
1989 KX500
MAIN JET: 175
PILOT JET: 62
NEEDLE: STOCK
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
1990 KX500
MAIN JET: 170
PILOT JET: 62
NEEDLE: N82L
CLIP POSITION: 2ND
AIR SCREW: 1.5 OUT
1991 KX500:
MAIN JET: 168
PILOT JET: 58
NEEDLE: N82M
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
1992 KX500:
MAIN JET: 168
PILOT JET: 60
NEEDLE: N82M
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
1993 KX500:
MAIN JET: 168
PILOT JET: 58
NEEDLE: N82M
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
1994 KX500:
MAIN JET: 175
PILOT JET: 58
NEEDLE: STOCK
CLIP POSITION: 2ND
AIR SCREW: 1.5 OUT
1995 KX500:
MAIN JET: 168
PILOT JET: 62
NEEDLE: STOCK
CLIP POSITION: 2ND
AIR SCREW: 1.5 OUT
1996 KX500:
MAIN JET: 168
PILOT JET: 55
NEEDLE: STOCK
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
1997 KX500:
MAIN JET: 165
PILOT JET: 58
NEEDLE: STOCK
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
1998 KX500:
MAIN JET: 165
PILOT JET: 58
NEEDLE: STOCK
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
1999 KX500:
MAIN JET: 170
PILOT JET: 55
NEEDLE: STOCK
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
2000 KX500:
MAIN JET: 165-168
PILOT JET: 52
NEEDLE: STOCK
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
2001 KX500:
MAIN JET: 165-168
PILOT JET: 52
NEEDLE: STOCK
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
2002 KX500:
MAIN JET: 165-168
PILOT JET: 52
NEEDLE: STOCK
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
2003 KX500:
MAIN JET: 165-168
PILOT JET: 52
NEEDLE: STOCK
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
2004 KX500:
MAIN JET: 165-168
PILOT JET: 52
NEEDLE: STOCK
CLIP POSITION: 3RD
AIR SCREW: 1.5 OUT
Post by Sandblaster » Fri Oct 23, 2015 7:42 pm
From Motorrads list of bearings...
Main bearings.
KIPS bearings
Water Pump
Clutch Pressure plate
Shift Drum bearing
Transmission LEFT CASE
Transmission RIGHT CASE
(special note on this bearing... ALOT of the ones out there now have a Plastic cage... Request a metal one, and CHECK IT before you leave
I Just don't trust plastic cages in transmissions....)
Post by Sandblaster » Tue Jul 19, 2016 2:04 pm
Compression Range in PSI
Kawasaki says the usable range is 105psi-164psi.
After a full rebuild ours are generally 190+
Anything below 140 and we rebuild the top end.
