Arik brought us his AF bike last year for a electrical problem.
As it turns out the crank and case bearing bosses were bad so it turned into a full rebuild..
I pulled the engine and took it apart.
Then I sent it Jason at JT Engine Works for a full rebuild.
Arik Swans KX500AF
Arik Swans KX500AF
Re: Arik Swans KX500AF
As you can see, Jason did his usual super clean engine build.
Jason did his super MX port work, balanced the crank, adjusted the compression and she will be a MX destruction machine...
Users browsing this forum: No registered users and 16 guests
