KX GURU Racing kx500 Engine in a 2016 KTM 250 SX PUMPKIN SEEDS BUILD
Post by Sandblaster » Wed Aug 01, 2018 11:27 pm
Got the crank back :-)
KX GURU RACING KTX500E CRANKSHAFT 101.jpg (345.97 KiB) Viewed 800 times
KX GURU RACING KTX500E CRANKSHAFT 102.jpg (340.71 KiB) Viewed 800 times
Post by Sandblaster » Wed Sep 05, 2018 10:28 pm
Finally... A part that I can put on the bike and not have to worry about taking it off again :lol:
This is a Samco Husqvarna 2016 205 sxf T radiator hose.
I pulled the stock unit out to powder coat the frame and I just didn't trust the stock part after the abuse of getting it apart.
KX GURU RACING KTX500E SAMCO RADIATOR T HOSE 101.jpg (248.05 KiB) Viewed 728 times
KX GURU RACING KTX500E SAMCO RADIATOR T HOSE 102.jpg (299.74 KiB) Viewed 728 times
Post by Sandblaster » Sat Sep 29, 2018 2:34 pm
Ok... I had a real hard time getting some good shift forks.
I actually took a set to the Industrial Hard Chrome plater and had them built back up to stock specs.
Well... the guy didn't listen and he did not plate the pins on the forks... That's one of them main area's where the plating is mandatory...
Anyhow I drove over 4000 miles to buy out a collection of KX500 bikes and parts.
There was 12 sets of forks in the batch and only one set was close to new specs...
So.... I'm in the process of getting ready to build the bottom end...
Pics with be coming soon.
Next, the suspension is ordered and being set up for the average riding weight and ability of the Motorcross Action Magazine wrecking crew...
Oscar Cota is negotiating with some triple clamp guys to get some triple clamps and a GPR dampener.
Daryl at Motor Cross Action is negotiating with a few more benders to get some oversized rotor kits and some brake lines.
So stay tuned.. More fun filled action is headed your way :lol:
Post by Sandblaster » Tue Oct 02, 2018 11:13 pm
Hmmm... These might work...
Post by Sandblaster » Fri Oct 12, 2018 6:40 pm
Beautiful parts from Moto Master.
These should help slow the beast 8-)
MOTO MASTER BRAKE KtX500e KX GURU RACING BUILD 101.jpg (423.09 KiB) Viewed 515 times
MOTO MASTER BRAKE KtX500e KX GURU RACING BUILD 102.jpg (613.63 KiB) Viewed 515 times
MOTO MASTER BRAKE KtX500e KX GURU RACING BUILD 103.jpg (580.07 KiB) Viewed 515 times
MOTO MASTER BRAKE KtX500e KX GURU RACING BUILD 104.jpg (600.17 KiB) Viewed 515 times
MOTO MASTER BRAKE KtX500e KX GURU RACING BUILD 105.jpg (563.93 KiB) Viewed 515 times
Thanks Moto Master!!!
Post by Sandblaster » Sat Nov 03, 2018 2:49 am
I finally have my hands on the forks.... Now I need my triple trees, shock, and GPR dampener and I should be ready to go...
KX GURU RACING KTX500E BUILD OHLINS FORKS 101.jpg (407.31 KiB) Viewed 461 times
Yes, you are seeing it right... These are used forks with some wear...
Oh well... That's what photoshop is suppose to be for :lol:
KX GURU RACING KTX500E BUILD OHLINS FORKS 102.jpg (173.88 KiB) Viewed 461 times
Titanium axle
KX GURU RACING KTX500E BUILD TITANIUM AXLE 101.jpg (404.2 KiB) Viewed 461 times
Post by Sandblaster » Wed Nov 07, 2018 8:40 pm
I finally got the KTM muffler pulled completely apart...
In case you don't know, I'm coring it for a KX500
KX GURU RACING FMF TITANIUM MUFFLER CONVERSION TO A KX500 101.jpg (78.79 KiB) Viewed 451 times
KX GURU RACING FMF TITANIUM MUFFLER CONVERSION TO A KX500 102.jpg (518.05 KiB) Viewed 451 times
KX GURU RACING FMF TITANIUM MUFFLER CONVERSION TO A KX500 103.jpg (358.78 KiB) Viewed 451 times
KX GURU RACING FMF TITANIUM MUFFLER CONVERSION TO A KX500 104.jpg (288.24 KiB) Viewed 451 times
KX GURU RACING FMF TITANIUM MUFFLER CONVERSION TO A KX500 105.jpg (310.01 KiB) Viewed 451 times
Post by Sandblaster » Sun Nov 11, 2018 11:09 pm
I'm putting the races back in the frame.
I don't have any special tooling :(
But, I do have a old 2" trailer hitch ball that is a nice fit :lol:
KX GURU RACING TRIPLE BEARING RACE INSTALLATION 101.jpg (220.5 KiB) Viewed 440 times
Good old ACME 8-)
KX GURU RACING TRIPLE BEARING RACE INSTALLATION 102.jpg (103.21 KiB) Viewed 440 times
Post by Sandblaster » Mon Nov 12, 2018 4:48 pm
Ah... one other point.
I actually pushed in the races and then later decided that I should take some pics...
I put a rag between the bearing race and the ball before I started driving it in.
Also, look at the hammer I used, it is tiny... And I don't wack it... small taps drove the races in with no issues.
After I was done I inspected the bearing surface and there was no damage at all.
I have used this same procedure many times in the past with no issues.
It would have been better to put it into a press and use a socket or a slightly ground down race to press it ini.
But I knew I could do this and it was quick and easy 8-)
The top clamp is being replaced as soon as I get it.
I put this top clamp on to hold it together :lol:
Also, I'm replacing the bolts with Ti ;)
KX GURU RACING KTX500E BUILD.jpg (232.96 KiB) Viewed 433 times
Post by Sandblaster » Sun Nov 25, 2018 10:51 pm
Mocking up the front end..
KX GURU RACING KTX500E 200.jpg (247.37 KiB) Viewed 360 times
KX GURU RACING KTX500E 201.jpg (370.88 KiB) Viewed 360 times
