MSV Racing KX500 impeller review
Post by Sandblaster » Sun Jul 28, 2019 7:45 pm
To contact MSV here is their Facebook page:
https://www.facebook.com/MSVRacingCR500 ... tion=group
First... here is the advertisement:
MSV Racing KX500 IMPELLERS FOR SALE NOW! $99 with gasket and button head fastener plus cheap fast shipping!
Mike Weir of KX GURU RACING has provided the first round of consistent on road impeller testing. More KX GURU RACING testing coming in the near future. We have off road and desert/sand dunes next! The harder you run your bike the better the MSV Racing OptiFlo KX500 "phi" Impeller cools!
When MSV Racing applied their highly successful OptiFlo CR500 “phi” Impeller design technology to help cool the ’85-’04 KX500, the result was an Impeller that easily out performed OEM, Mino, Frank’s MX and AS3 Impellers.
The KX500 “phi” impeller vanes are computer designed using “Golden Ratio” proportions based on the KX500’s H2O pump housing. This as well as closer tolerances between impeller and housing offer +1.2 average GPM more coolant flow and cooler coolant temps when you need it most! This increase in flow reduces the cycle time between the engine and the radiators allowing more heat removal quicker, lowering head and coolant temperatures.
Remember, horsepower = heat. Preventing your engine from heat soak is KEY to building and maintaining maximum engine performance. The more efficient the engine’s cooling system, the more heat (horsepower) it can handle.
Whether you’re racing Outlaw Karts, GNCC, Hill Climb, Sand Drags, Super Moto, or MX. Railing tight single track, sand dunes or just love the latest enhancement for your KX500, trust MSV Racing’s KX “phi” Impeller to help put you at the head of the pack!
The MSV Racing KX500 “phi” Impeller comes with the main pump cover gasket and button head impeller fastener for a seamless install.
$99 plus cheap, fast shipping! PM us your shipping address for a quote.
Re: MSV Racing KX500 impeller review
Post by Sandblaster » Sun Jul 28, 2019 8:19 pm
From left to right.. Stock, MSV, and AS3.
KX GURU RACING KX500 IMPELLER TEST 101.jpg (446.87 KiB) Viewed 8559 times
Test bed.
2001 KX500.
The engine is stock.
The exhaust is stock with the addition of a arrestor added to the end of the stock muffler.
KX GURU RACING KX500 IMPELLER TEST 102.jpg (407.7 KiB) Viewed 8559 times
The head temp is a under the spark plug style from Trail Tech, Vapor..
KX GURU RACING KX500 IMPELLER TEST 103.jpg (276.44 KiB) Viewed 8559 times
The water temp was taken where it exits the head on the left side.
It is a Trail Tech TTO
Lol... Yes, it is mounted temporarily.
I wanted to get this testing done ASAP and the making of a new mounting plate for the key and gauge would have delayed me for another week.
KX GURU RACING KX500 IMPELLER TEST 104.jpg (151.83 KiB) Viewed 8559 times
Post by Sandblaster » Sun Jul 28, 2019 8:39 pm
To try and maintain the same conditions for each test I rode at a steady 55mph over a 7 mile road course.
3.5 miles out and 3.5 miles back.
Neighbors love me :shock:
No hard starts.
Just smooth easy riding.
Except for the elevation changes not exactly a difficult road :D
STARTING ELEVATION 412 FT
.5 MILES 442 FT
1.8 MILES 484 FT
2.4 MILES 779 FT
3.5 MILES 551 FT
KX GURU RACING KX500 IMPELLER TEST 105.jpg (170.08 KiB) Viewed 8553 times
Post by Sandblaster » Sun Jul 28, 2019 8:55 pm
Here is a pic of the stock impeller
KX GURU RACING KX500 IMPELLER TEST 106.jpg (183.11 KiB) Viewed 8552 times
Here is a pic of the AS3
KX GURU RACING KX500 IMPELLER TEST 107.jpg (206.72 KiB) Viewed 8552 times
Here is a pic of the MSV PHI impeller
KX GURU RACING KX500 IMPELLER TEST 108.jpg (178.07 KiB) Viewed 8552 times
Post by Sandblaster » Sun Jul 28, 2019 9:01 pm
Installation...
The MSV installs the same way as stock except that you need the impeller bolt which is included in the kit.
The AS3 is so tall that it requires a water pump spacer, longer bolt, additional gasket, and longer alignment pins.
So far, my impression is that the MSV PHI impeller is superior in just about every way to the stock and AS3 impellers.
Under the testing parameters, it cools better and is easier to install then the AS3.
I will be doing additional testing in the fall in desert/dune conditions so stay tuned 8-)
One other thought before I go... I bet that dyno results will show that the AS3 robs more power than the PHI but I will let the dyno runs speak for themselves.
Post by Sandblaster » Tue Jul 30, 2019 1:18 am
Further testing info on the bike.
150/60-R17 rear wheel
15-43 sprockets.
We ran at 55mph at approx 4500 rpm.
Up hill, down hill... Trying to be a smooth as possible.
Later testing will be done with full throttle runs at low speeds.
Grill it baby :-)
Post by Sandblaster » Sun Aug 11, 2019 4:40 pm
Here is some independent testing done by Alex Ward which further confirms my own testing..
KX GURU RACING KX500 IMPELLER TEST 106.jpg (58.35 KiB) Viewed 8409 times
Post by Sandblaster » Mon Aug 12, 2019 12:12 am
Here is some additional independent testing from Ben Deckert.
KX GURU RACING KX500 IMPELLER TEST 109.jpg (61.69 KiB) Viewed 8406 times
Return to “Product Review”
