Jonathon Bell sold me this beautiful pipe a while back and I finally got around to testing it. So far it is making more HP and more torque than the stock pipe, Pro Circuit 2, and a FMF Gnarly Desert pipe. Here is the setup. Chad Cadnum
's beautiful all Stock 01 KX500, VF2 reed at the low tension setting, 92 pump gas. That's it.
49.71 ft/lb or torque
59.18 hp.
Drop in some c12 and you'll be over 60 at the rear wheel.
While the HP is impressive considering the setup the Torque is amazing...
This series of tests would not be possible with out Jason Tanner, Chad Cadnum, Moto Gear Speed Shop, and of course Jonathon Bell
- 116010488_3303968339649589_2801290389944576438_o.jpg (215.24 KiB) Viewed 8114 times
- 116176769_3303967782982978_5946184914479943845_o.jpg (63.12 KiB) Viewed 8114 times
- 116792574_3303968282982928_658645272203584204_o.jpg (197.42 KiB) Viewed 8114 times
- 117170354_3303968219649601_4712635262599942870_o.jpg (176.58 KiB) Viewed 8114 times
