KX500 HEAVY CLUTCH PULL, WHAT CAN BE DONE
Post by Sandblaster » Thu Oct 11, 2018 2:13 am
By now I'd say most of you guys know what is being done to lesson clutch pull.
1. Straighten the cable a bit where the metal shield is at. And make sure the cable is new.
2. Cool aftermarket clutch perches.
3. Extended clutch puller arms.
4. Hydraulic clutch.
5. Basket and hub in good condition.
6. Use a OEM Clutch cable. (One lb lighter pull than a Motion Pro cable).
The other day Jason Tanner finally confided in me some ideas he has.... I think each one has merit but we need to be able to test each one out. Out of respect for Jason's idea's I can't post pics of what he came up with. But I will be posting results from each experiment to see what can be done.
Any idea's you may have would be welcome. We are looking for simple effective idea's that can be done by most guys with limited tools. (Like me).
The first thing we did was put together a mock up testing stand.. Nothing better the genuine Kawi parts :-)
Once we get this together we will be doing some really cool testing so stay tuned..
Re: KX500 HEAVY CLUTCH PULL, WHAT CAN BE DONE
Post by Sandblaster » Thu Oct 11, 2018 2:29 am
Travis Saturley: I move the clutch (and brake) perch in towards the middle of the bars. This causes me to only use the end of the lever, increasing my leverage. I have long fingers, so that may not work for everyone.
Post by Sandblaster » Thu Oct 11, 2018 10:23 pm
What I need is a very accurate test fixture..
So, I grabbed my best engine cases and set about gettin it done :lol:
JT ENGINE WORKS AND KX GURU RACING KX500 CLUTCH PULL MADE EASIER 101.jpg (465.11 KiB) Viewed 388 times
Hello MR. Sawsall
JT ENGINE WORKS AND KX GURU RACING KX500 CLUTCH PULL MADE EASIER 102.jpg (493.67 KiB) Viewed 388 times
JT ENGINE WORKS AND KX GURU RACING KX500 CLUTCH PULL MADE EASIER 103.jpg (415.39 KiB) Viewed 388 times
JT ENGINE WORKS AND KX GURU RACING KX500 CLUTCH PULL MADE EASIER 104.jpg (411.59 KiB) Viewed 388 times
Post by Sandblaster » Thu Oct 11, 2018 10:24 pm
JT ENGINE WORKS AND KX GURU RACING KX500 CLUTCH PULL MADE EASIER 105.jpg (370.34 KiB) Viewed 387 times
JT ENGINE WORKS AND KX GURU RACING KX500 CLUTCH PULL MADE EASIER 106.jpg (342.54 KiB) Viewed 387 times
JT ENGINE WORKS AND KX GURU RACING KX500 CLUTCH PULL MADE EASIER 107.jpg (414.76 KiB) Viewed 387 times
Well... let's get rid of that pesky casing that covers the bottom bearing.
This will help later on during testing... 8-)
JT ENGINE WORKS AND KX GURU RACING KX500 CLUTCH PULL MADE EASIER 108.jpg (394.68 KiB) Viewed 387 times
Post by Sandblaster » Thu Oct 11, 2018 10:26 pm
Something like this....
JT ENGINE WORKS AND KX GURU RACING KX500 CLUTCH PULL MADE EASIER 109.jpg (383.21 KiB) Viewed 385 times
JT ENGINE WORKS AND KX GURU RACING KX500 CLUTCH PULL MADE EASIER 110.jpg (444.13 KiB) Viewed 385 times
Post by Sandblaster » Sat Oct 13, 2018 5:17 am
I have a few more parts ready to go.
As soon as my new digital pull scale I should be able to start testing.
Post by Sandblaster » Mon Feb 18, 2019 10:02 pm
Another thing that can be done is get a new OEM clutch cable.
A new OEM clutch cable pulls one pound lighter than a new Motion Pro clutch cable... Yeah... get a OEM 8-)
Return to “Clutch”
