KX500 SUB FRAME IS MISSING ALL THE INSERTS!!!
A look at your chassis
Post by Sandblaster » Mon Apr 08, 2019 9:30 pm
So, your KX500 Sub Frame is missing all it's threaded inserts?
You want to drill a hole all the way through and run the bolts all the way through???
THROW THE DRILL AWAY!!!!!! :shock: :shock: :shock: :o :oops: :oops: :oops:
More to come...
Re: KX500 SUB FRAME IS MISSING ALL THE INSERTS!!!
Post by Sandblaster » Tue Apr 09, 2019 4:07 am
Nutserts! Rivnuts!
Whatever you want to call them, they are the answers.
KX500 01 PLAY BIKE 122.jpg (420.58 KiB) Viewed 4399 times
KX500 01 PLAY BIKE 123.jpg (206.3 KiB) Viewed 4399 times
Post by Sandblaster » Wed Apr 10, 2019 5:58 pm
I was asked if the M8 inserts would fit into the sub frame.
My knee jerk reaction was yes but I wanted to be sure so...
I had a sub frame that had a hole so wallered out that a M6 insert fell through the hole :o
Obviously that wasn't gonna work :lol:
Looking at the next pic it appears as if there is enough room.
KX GURU RACING KX500 SUB FRAME REPAIR 101.jpg (244.51 KiB) Viewed 4393 times
KX GURU RACING KX500 SUB FRAME REPAIR 102.jpg (186.85 KiB) Viewed 4393 times
Perfect... The big drawback is the oddball size bolt but better that than some of the back yard repairs I have seen employed 8-)
KX GURU RACING KX500 SUB FRAME REPAIR 103.jpg (180.95 KiB) Viewed 4393 times
Return to “Chassis”
Users browsing this forum: No registered users and 4 guests
