Bottom end identification
Bottom end tips and mods
borntworide
Post by borntworide » Sun Feb 07, 2021 5:26 pm
I am looking at used bottom end for my 97 kx 250 , its on eBay is there any way to tell what year without the side cover with vin?
Re: Bottom end identification
Post by Sandblaster » Mon Feb 08, 2021 4:32 am
Cylinder ID and carb ID
borntworide
Post by borntworide » Fri Feb 12, 2021 4:07 pm
It's just a lower end ,no cylinder , head or side cover! That's why i was wondering if there was a way to determine what year it was from actually.
Post by Sandblaster » Fri Feb 12, 2021 7:02 pm
It can be narrowed down to a year range.
97-04 USE A LARGER SHIFT FORK PIN & 1 LESS CASE BOLT & NARROWER SHIFT DRUM
Is the engine apart?
borntworide
Post by borntworide » Fri Feb 12, 2021 7:11 pm
No the cases are not separated yet. Where is the case bolt missing from?
borntworide
Post by borntworide » Wed Feb 24, 2021 5:38 pm
Finally got the lower half after all that the engine is on it. For some reason I had it stuck in my head engine number was on the side cover not the case.
KX250KE017363
Post by Sandblaster » Thu Feb 25, 2021 4:30 am
95-98
If you had the cylinder or carb we could nail the year.
SHIFT FORK ROD GUIDE SHAFTS 1995 9.98MM OD
SHIFT FORK ROD GUIDE SHAFTS 1996-1998 11.89MM OD
Return to “Bottom end”
