How to get nutty with a KX450F rear brake caliper
Post by Sandblaster » Tue Jun 06, 2017 4:20 pm
As some of you know I built the rear brake caliper for Sean Collier's new bike.
I learned several things the first time around so while some of this is a rehash, some of it is new.
First things first you will need a KX450F rear brake caliper... Any year will do up to at least 2012 :o
Next, strip it bare..
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 101.jpg (357.92 KiB) Viewed 743 times
{TIP} Use a air nozzle to blow the seals out... Most of the time you can re-use them.
Or just buy new ones as they are cheap..
Re: How to get nutty with a KX450F rear brake caliper
Post by Sandblaster » Tue Jun 06, 2017 5:37 pm
Put it in there..
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 102.jpg (399.61 KiB) Viewed 740 times
Use some of this on it..
Then some of that..
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 103.jpg (417.44 KiB) Viewed 740 times
It starts looking like this..
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 104.jpg (453.49 KiB) Viewed 740 times
Post by Sandblaster » Tue Jun 06, 2017 5:38 pm
No fancy mills or lathes.
I haven't even measured anything... All eyeball :shock:
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 105.jpg (349.93 KiB) Viewed 739 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 106.jpg (365.35 KiB) Viewed 739 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 107.jpg (343.4 KiB) Viewed 739 times
Post by Sandblaster » Tue Jun 06, 2017 5:39 pm
It's starting to take shape..
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 108.jpg (252.7 KiB) Viewed 738 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 109.jpg (212.54 KiB) Viewed 738 times
Post by Sandblaster » Tue Jun 06, 2017 5:41 pm
A little grinder work and..
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 111.jpg (280.45 KiB) Viewed 737 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 112.jpg (244.37 KiB) Viewed 737 times
KX GURU RACING MODIFIED KX450F REAR BRAKE CALIPER 113.jpg (247.85 KiB) Viewed 737 times
Ready for weld...
I've left a message with my welder..
We will see how long it will take for him to get back to me...
Post by Sandblaster » Wed Jun 14, 2017 11:19 pm
I received it back from the welder and started the clean up..
It's real rough right now but give it some time :-)
KX GURU RACING rebuilding the beast 122.jpg (311.74 KiB) Viewed 702 times
KX GURU RACING rebuilding the beast 123.jpg (262.77 KiB) Viewed 702 times
Post by Sandblaster » Thu Jun 15, 2017 5:19 am
A little more progress..
KX GURU RACING rebuilding the beast 124.jpg (168.1 KiB) Viewed 699 times
KX GURU RACING rebuilding the beast 125.jpg (162.89 KiB) Viewed 699 times
Return to “Brakes”
