OEM-CYCLE
OEM-CYCLE HOME
About Us
Contact Us
Site Map
Used Dirt Bike Parts
ATK Used Parts
Bultaco Used Parts
Honda Used Parts
Husaberg Used Parts
Husqvarna Used Parts
Kawasaki Used Parts
KTM Used Parts
Maico Used Parts
Suzuki Used Parts
Yamaha Used Parts
Misc Used Parts
Bike Identification
What year is my dirt bike
WORLD WIDE PICS CR125
WORLD WIDE PICS CR500
World Wide Pics Of KX500
WORLD WIDE PICS KX450F
WORLD WIDE PICS KX250
WORLD WIDE PICS RM250
WORLD WIDE PICS YZ250
Building our new shop
KX500 JETTING GUIDE
CRANK BEARING REMOVAL
SPLITTING YOUR CASES
BIKES IN DISASSEMBLY
Employees wasting time
Misc Parts
2006 Tundra rear brake re
Picture for 1998 Yamaha YZ400F
Specs for 1998 Yamaha YZ400F
Engine type Liquid cooled 4-stroke, DOHC, 5-valve
Displacement 399 cc
Bore x stroke 92.0 x 60.1 mm
Compression ratio 12.5 : 1
Lubrication system Dry sump
Fuel System Carburettor (FCR39H)
Clutch type Wet, multiple disc
Ignition system C.D.I.
Starter system Kickstarter
Transmission system Constant mesh, 5 speed
Primary reduction ratio 2.952
Secundary reduction ratio 3.500
Final transmission Chain
Ratios gearbox 1st 1.929
Ratios gearbox 2nd 1.563
Ratios gearbox 3rd 1.278
Ratios gearbox 4th 1.091
Ratios gearbox 5th 0.952
Front suspension system Telescopic fork, USD
Front wheel travel 300 mm
Rear suspension system Swingarm (Link suspension)
Rear wheel travel 315 mm
Caster angle 27.8°
Trail 123 mm
Front brake Single disc, Ø 245 mm
Rear brake Single disc, Ø 220 mm
Front tyre 80/100-21 51M
Rear tyre 110/90-19 57M
Overall length 2,176 mm
Overall width 827 mm
Overall height 1,303 mm
Seat height 991 mm
Wheelbase 1,495 mm
Minimum ground clearance 373 mm
Service weight (incl. liquids) 115 kg
Fuel tank capacity (reserve) 8 L
Engine oil tank capacity 1.7 L
