OEM-CYCLE
OEM-CYCLE HOME
About Us
Contact Us
Site Map
Used Dirt Bike Parts
ATK Used Parts
Bultaco Used Parts
Honda Used Parts
Husaberg Used Parts
Husqvarna Used Parts
Kawasaki Used Parts
KTM Used Parts
Maico Used Parts
Suzuki Used Parts
Yamaha Used Parts
Misc Used Parts
Bike Identification
What year is my dirt bike
WORLD WIDE PICS CR125
WORLD WIDE PICS CR500
World Wide Pics Of KX500
WORLD WIDE PICS KX450F
WORLD WIDE PICS KX250
WORLD WIDE PICS RM250
WORLD WIDE PICS YZ250
Building our new shop
KX500 JETTING GUIDE
CRANK BEARING REMOVAL
SPLITTING YOUR CASES
BIKES IN DISASSEMBLY
Employees wasting time
Misc Parts
2006 Tundra rear brake re
Pictures for Yamaha YZ250F 2004
Yamaha 2004 YZ250F Specs:
ENGINE: Liquid-cooled, 5-valve, DOHC, 4-stroke w/titanium valves
DISPLACEMENT: 249cc
BORE X STROKE: 77 x 53.6mm
COMPRESSION RATIO: 12.5:1
CARBURETION: 37mm Keihin FCR flat-slide w/throttle position sensor
CLUTCH: Multi-plate wet clutch
IGNITION: Digital CDI
DIMENSIONS
LENGTH: 85.1 in.
WIDTH: 32.6 in.
HEIGHT: 51.3 in.
WEIGHT: 208 lbs.
GROUND CLEARANCE: 15.0 in.
WHEELBASE: 58.0 in.
FUEL CAPACITY: 1.8 gal.
SEAT HEIGHT: 39.2 in.
DRIVETRAIN
TRANSMISSION: 5-speed
FINAL DRIVE: #520 chain
SUSPENSION: Front: 48mm Kayaba inverted cartridge fork w/adj. compression & rebound damping; 11.8 in. travel
Rear: Kayaba single shock w/adj. preload, compression & rebound damping & separate hi/lo-speed compression adjuster; 12.4 in. travel
BRAKES/WHEELS/TIRES
BRAKES Front: 250mm floating disc
Rear: 245mm disc
TIRES Front: 80/100-21 Dunlop
Rear: 100/90-19 Dunlop
