Yamaha YZ125 1996:
1996 Yamaha YZ125 Specs
Engine
Configuration: Single cylinder watercooled two stroke
Bore & Stroke: 54 x 54.5mm
Capacity: 125 cc
Fuel: TMX36SS
Lubrication: Gear driven autolube oilpump 0.7 litre (0.6 imp. qt.)
Ignition: CDI
Charging system
Starter: Kick starter
Transmission: Gear driven primary drive
Gearbox: 6-speed
Clutch: Cable operated multi plate wet clutch
Chassis
Frame
Dimensions
Weight: 87.5kg (192.5 lbs) dry
Wheelbase: 1,452mm (57.2")
Length: 2,149mm (84.6")
Seat Height: 998mm (39.3")
Front Suspension: 46mm inverted fork, 300mm (11.8") travel
Rear suspension: Monocross with 315mm (12.4") travel
Wheels
Tyres
Front: 80/100-21
Rear: 110/90-19
Brakes: Disc front and rear
Fuel Capacity: 8 litre (1.7 imp.gal.)
Engine
Capacity: 125 cc
Fuel: TMX36SS
Ignition: CDI
Charging system
Gearbox: 6-speed
Chassis
Frame
Dimensions
Wheels
Tyres
Front: 80/100-21
Rear: 110/90-19
This page last modified: Thursday, 09-Aug-2012 22:51:30 PDT
