In an effort to help fellow bikers
properly ID their bike I have provided the following information on VIN (
Vehicle Identification Number ) , Engine ID and part identification.
All the information provided is to the best of my
knowledge correct.
As we part more bikes out we will add more
information to this chart.
If you find something that is not accurate, please
let us know and we will fix it.
This information is not intended for use outside of
this web site or for publication.
In other words, use this information at your own
risk.
Please scroll to the right as there is a lot of data
**Need parts for your YZ125? Click here **
YEAR | TYPE |
ENGINE ID | ENGINE CASE LEFT | ENGINE CASE RIGHT | VIN FRAME USA | YEAR | TYPE | AIR BOX | YEAR | TYPE | AIR BOX CAGE | AIR BOX TO CARBURETOR BOOT | CABLE CLUTCH | YEAR | CABLE FRONT BRAKE | CABLE THROTTLE | YEAR | CARBURETOR | YEAR | TYPE | CARBURETOR BOOT | YEAR | CDI | CHAIN GUIDE | CHAIN GUIDE PLASTIC INSERT (CHAIN SUPPORT) | YEAR | CHAIN PULLER BLOCKS | CHAIN SLIDER | CLUTCH BASKET | CLUTCH COVER | CLUTCH COVER INNER | YEAR | CLUTCH BOSS INNER | CLUTCH PRESSURE PLATE OUTER | CLUTCH PLATES FRICTION | CLUTCH PLATES METAL | COIL | CRANK SHAFT | YEAR | CRANK SHAFT (HOT RODS) | CYLINDER | YEAR | ENGINE MOUNTS UPPER | ENGINE MOUNTS LOWER | EXHAUST ARRESTOR (FMF TURBINE 2) | EXHAUST PIPE | YEAR | EXHAUST PIPE FMF RACING FATTY | EXHAUST PIPE PRO CIRCUIT PLATINUM | YEAR | EXHAUST VALVE | YEAR | EXHAUST VALVE COVER FRONT | EXHAUST VALVE COVER RIGHT | EXHAUST VALVE HOLDER LEFT | YEAR | EXHAUST VALVE HOLER RIGHT | EXHAUST VALVE LINKAGE (PUSH ROD ASY) | YEAR | FLY WHEEL ROTOR | FOOT PEGS | YEAR | FORK INFO | FORK SEAL SIZES | FORK CAP | FORK INTERNAL DAMPENER CYLINDER | FORK GUARDS | FORK GUARDS ACERBIS | YEAR | FORK GUARD MOUNTS | FORK OUTER TUBE ALUMINUM | FRONT AXLE | FRONT BRAKE BACKING PLATE | FRONT BRAKE CALIPER | YEAR | FRONT BRAKE CALIPER MOUNT | FRONT BRAKE HOSE | FRONT BRAKE MASTER CYLINDER | YEAR | FRONT BRAKE ROTOR | FRONT FENDER | YEAR | FRONT FENDER ACERBIS | FRONT HUB | YEAR | FRONT RIM | GAS CAP | GAS TANK | GOVERNOR PUSH ROD | GOVERNOR SHAFT AND GEAR | HEAD | YEAR | KICK IDLER GEAR | KICK LEVER | KICK LEVER SHAFT | KICK LEVER SHAFT GEAR | YEAR | KILL SWITCH | YEAR | MUD FLAP | NUMBER PLATE | NUMBER PLATE ACERBIS | OIL CAPACITY | PRIMARY CRANK GEAR | RADIATOR LEFT | RADIATOR RIGHT | YEAR | RADIATOR HOSE SETS | RADIATOR SHROUD LEFT | RADIATOR SHROUD RIGHT | YEAR | RADIATOR SHROUD LEFT ACERBIS | RADIATOR SHROUD RIGHT ACERBIS | RADIATOR SCREEN LEFT | RADIATOR SCREEN RIGHT | REAR AXLE | YEAR | REAR AXLE SPACERS COLLARS | REAR BRAKE BACKING PLATE | REAR BRAKE CALIPER | YEAR | REAR BRAKE CALIPER GUARD | YEAR | REAR BRAKE CALIPER MOUNT | REAR BRAKE CALIPER MOUNT | REAR BRAKE LEVER | REAR BRAKE LEVER BOLT | REAR BRAKE MASTER CYLINDER | REAR BRAKE TENSION BAR | REAR FENDER | REAR FENDER ACERBIS | YEAR | REAR HUB | YEAR | REED VALVE | SEAT | SHIFT FORK ALIGNMENT GUIDES RODS SHAFTS | YEAR | SHOCK | SHOCK ARM (RELAY ARM) | SHOCK ARM LINKAGE (CONNECTING ROD ) | YEAR | SHOCK SPRING | SIDE COVER LEFT | SIDE COVER RIGHT | YEAR | SIDE COVER LEFT ACERBIS | SIDE COVER RIGHT ACERBIS | SHIFT DRUM (CAM) | SHIFT FORKS | SHIFT LEVER | YEAR | SHIFT SHAFT | SHOCK | YEAR | SHOCK ARM | SHOCK ARM LINKAGE | YEAR | STATOR | STATOR COVER | SUB FRAME | SWING ARM | YEAR | SWING ARM PIVOT PIN | THROTTLE | YEAR | THROTTLE CABLE | TRANSMISSION | TRANSMISSION MAIN SHAFT | YEAR | TRANSMISSION MAIN SHAFT 2ND GEAR | TRANSMISSION MAIN SHAFT 3RD GEAR | TRANSMISSION MAIN SHAFT 4TH GEAR | YEAR | TRANSMISSION MAIN SHAFT 5TH GEAR | TRANSMISSION MAIN SHAFT 6TH GEAR | TRANSMISSION COUNTER (DRIVE) SHAFT | TRANSMISSION DRIVE SHAFT 1ST GEAR | YEAR | TRANSMISSION DRIVE SHAFT 2ND GEAR | TRANSMISSION DRIVE SHAFT 3RD GEAR | TRANSMISSION DRIVE SHAFT 4TH GEAR | YEAR | TRANSMISSION DRIVE SHAFT 6TH GEAR | TRANSMISSION DRIVE SHAFT 5TH GEAR | YEAR | TRIPLE TREE – LOWER | TRIPLE TREE - UPPER (CROWN) | YEAR | WATER PUMP COVER | WATER PUMP SHAFT | WATER PUMP IMPELLER | WIRE HARNESS | YEAR |
1974 | YZ125A | 453-000101 | FITS 74 YZ125, 74-75 MX125 MX175 401-15111-03-00 | 1974 | YZ125A | 1974 | YZ125A | 1974 | 1974 | 1974 | YZ125A | 1974 | FITS 74-79 YZ125, 74-75 YZ250 YZ360 - 364-85540-13-00 | 1974 | 1974 | FITS 74-77 YZ125, 74-75 YZ250 YZ360 - 322-82310-10-00 | 1974 | 453 - FITS 74-77 YZ125 - 453-11311-00-00 - AIR COOLED | 1974 | 1974 | 1974 | 1974 | 1974 | AIR COOLED NO VALVE | 1974 | 1974 | CONVENTIONAL – 30MM CHROME OD | 30MM X 40.5MM | N/A | 1974 | DRUM BRAKE | 1974 | DRUM BRAKE | 1974 | DRUM BRAKE | YELLOW - 74-77 YZ125, 75-76 YZ250, 76 YZ400 - 453-21511-01-00 | 1974 | N/A | 1974 | FITS 74 YZ125, 74-75 MX125 453-11111-00-00 | 1974 | 1974 | 1974 | AIR COOLED | AIR COOLED | 1974 | AIR COOLED | AIR COOLED | AIR COOLED | 1974 | AIR COOLED | AIR COOLED | AIR COOLED | AIR COOLED | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | N/A | N/A | 1974 | 1974 | 1974 | FITS 74-77 YZ125 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | 1974 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1975 | YZ125B | 453-100101 | 1975 | YZ125B | 1975 | YZ125B | 1975 | 1975 | 1975 | YZ125B | 1975 | FITS 74-79 YZ125, 74-75 YZ250 YZ360 - 364-85540-13-00 | 1975 | 1975 | FITS 74-77 YZ125, 74-75 YZ250 YZ360 - 322-82310-10-00 | 1975 | 453 - FITS 74-77 YZ125 - 453-11311-00-00 - AIR COOLED | 1975 | 1975 | 1975 | 1975 | 1975 | AIR COOLED NO VALVE | 1975 | 1975 | CONVENTIONAL – 30MM CHROME OD | 30MM X 40.5MM | N/A | 1975 | DRUM BRAKE | 1975 | DRUM BRAKE | 1975 | DRUM BRAKE | YELLOW - 74-77 YZ125, 75-76 YZ250, 76 YZ400 - 453-21511-01-00 | 1975 | N/A | 1975 | 1975 | 1975 | 1975 | AIR COOLED | AIR COOLED | 1975 | AIR COOLED | AIR COOLED | AIR COOLED | 1975 | AIR COOLED | AIR COOLED | AIR COOLED | AIR COOLED | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | N/A | N/A | 1975 | 1975 | 1975 | FITS 74-77 YZ125 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | 1975 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1976 | YZ125C | 537-000101 | 1976 | YZ125C | 1976 | YZ125C | 1976 | 1976 | 1976 | YZ125C | 1976 | FITS 74-79 YZ125, 74-75 YZ250 YZ360 - 364-85540-13-00 | 1976 | 1976 | 1976 | 453 - FITS 74-77 YZ125 - 453-11311-00-00 - AIR COOLED | 1976 | 1976 | 1976 | 1976 | 1976 | AIR COOLED NO VALVE | 1976 | 1976 | CONVENTIONAL – 34MM CHROME OD | 34MM X 46MM X 10.5 | N/A | 1976 | DRUM BRAKE | 1976 | DRUM BRAKE | 1976 | DRUM BRAKE | YELLOW - 74-77 YZ125, 75-76 YZ250, 76 YZ400 - 453-21511-01-00 | 1976 | N/A | 1976 | 1976 | 1976 | 1976 | AIR COOLED | AIR COOLED | 1976 | AIR COOLED | AIR COOLED | AIR COOLED | 1976 | AIR COOLED | AIR COOLED | AIR COOLED | AIR COOLED | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | N/A | N/A | 1976 | 1976 | 1976 | FITS 74-77 YZ125 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | 1976 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1976 1/2 | YZ125X | 1G8-000101 | 1976 1/2 | YZ125X | 1976 1/2 | YZ125X | 1976 1/2 | 1976 1/2 | 1976 1/2 | YZ125X | 1976 1/2 | FITS 74-79 YZ125, 74-75 YZ250 YZ360 - 364-85540-13-00 | 1976 1/2 | 1976 1/2 | 1976 1/2 | 453 - FITS 74-77 YZ125 - 453-11311-00-00 - AIR COOLED | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | AIR COOLED NO VALVE | 1976 1/2 | 1976 1/2 | CONVENTIONAL – 34MM CHROME OD | 34MM X 46MM X 10.5 | N/A | 1976 1/2 | DRUM BRAKE | 1976 1/2 | DRUM BRAKE | 1976 1/2 | DRUM BRAKE | YELLOW - 74-77 YZ125, 75-76 YZ250, 76 YZ400 - 453-21511-01-00 | 1976 1/2 | N/A | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | AIR COOLED | AIR COOLED | 1976 1/2 | AIR COOLED | AIR COOLED | AIR COOLED | 1976 1/2 | AIR COOLED | AIR COOLED | AIR COOLED | AIR COOLED | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | N/A | N/A | 1976 1/2 | 1976 1/2 | 1976 1/2 | FITS 74-77 YZ125 | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | 1976 1/2 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1977 | YZ125D | 1W1-000101 | FITS 77-79 YZ100, 77-78 YZ125, 80-81 IT125 - 1W1-15111-02-00 | FITS 77-81 YZ100, 77-78 YZ125, 80-81 IT125 - 1W1-15121-02-00 | 1977 | YZ125D | 1977 | YZ125D | 1977 | FITS 77-79 YZ125 YZ400, 77-80 YZ250, 80 YZ465 | 1977 | 1977 | YZ125D | 1977 | FITS 74-79 YZ125, 74-75 YZ250 YZ360 - 364-85540-13-00 | 1977 | 1977 | FITS 77-82 YZ125, 82-83 YZ100, 77-83 IT175, 80-81 IT125, 84-86 IT200, 78-81 DT175, 79-81 MX175, 90-98 RT180 - 1W1-16351-00-00 | 1977 | 453 - FITS 74-77 YZ125 - 453-11311-00-00 - AIR COOLED | 1977 | 1977 | 1977 | 1977 | 1977 | AIR COOLED NO VALVE | 1977 | 1977 | CONVENTIONAL – 36MM CHROME OD | 36MM X 48MM X 10.5/11 | N/A | 1977 | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | DRUM BRAKE | 1977 | DRUM BRAKE | 1977 | DRUM BRAKE | YELLOW - FITS 77-79 82-83 YZ100, 77-80 82-84 YZ125, 77 79 82-84 YZ250, 77 79 YZ400, 82 84 YZ490 - 5X6-21511-01-00 | 1977 | N/A | 1977 | 1977 | FITS 77-79 IT175, 77-81 YZ100, 77-80 YZ125, 79 AND 80 MX175, 80-81 IT125 - 1W1-15620-01-00 | 1977 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1977 | AIR COOLED | AIR COOLED | 1977 | AIR COOLED | AIR COOLED | AIR COOLED | 1977 | AIR COOLED | AIR COOLED | AIR COOLED | AIR COOLED | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | N/A | N/A | 1977 | 1977 | 1977 | FITS 74-77 YZ125 | 1977 | 1977 | FITS 77-79 YZ125, 77-80 YZ250, 77-79 YZ400, 80 YZ465 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | 1977 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1978 | YZ125E | 2K6-000101 | FITS 77-79 YZ100, 77-78 YZ125, 80-81 IT125 - 1W1-15111-02-00 | FITS 77-81 YZ100, 77-78 YZ125, 80-81 IT125 - 1W1-15121-02-00 | 1978 | YZ125E | 1978 | YZ125E | 1978 | FITS 77-79 YZ125 YZ400, 77-80 YZ250, 80 YZ465 | 1978 | 1978 | YZ125E | 1978 | FITS 74-79 YZ125, 74-75 YZ250 YZ360 - 364-85540-13-00 | 1978 | 1978 | FITS 77-82 YZ125, 82-83 YZ100, 77-83 IT175, 80-81 IT125, 84-86 IT200, 78-81 DT175, 79-81 MX175, 90-98 RT180 - 1W1-16351-00-00 | FITS 77-83 YZ100, 77-82 YZ250, 78-81 YZ125 79-82 YZ80 - 2X6-82310-10-00 - CM61-20 | 1978 | 2X3 2K6 3R3 - FITS 78-80 YZ125 - 3R3-11311-00-00 - 2X3-11311-00-00 - 2K6-11311-00-00 AIR COOLED | 1978 | 1978 | 1978 | 1978 | 1978 | AIR COOLED NO VALVE | 1978 | 1978 | CONVENTIONAL – 36MM CHROME OD | 36MM X 48MM X 10.5/11 | N/A | 1978 | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | DRUM BRAKE | 1978 | DRUM BRAKE | 1978 | DRUM BRAKE | YELLOW - FITS 77-79 82-83 YZ100, 77-80 82-84 YZ125, 77 79 82-84 YZ250, 77 79 YZ400, 82 84 YZ490 - 5X6-21511-01-00 | 1978 | N/A | 1978 | 1978 | FITS 77-79 IT175, 77-81 YZ100, 77-80 YZ125, 79 AND 80 MX175, 80-81 IT125 - 1W1-15620-01-00 | 1978 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1978 | AIR COOLED | AIR COOLED | 1978 | AIR COOLED | AIR COOLED | AIR COOLED | 1978 | AIR COOLED | AIR COOLED | AIR COOLED | AIR COOLED | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | N/A | N/A | 1978 | 1978 | 1978 | FITS 78-80 YZ125 - 2X6-85510-11-00 | 1978 | 1978 | FITS 77-79 YZ125, 77-80 YZ250, 77-79 YZ400, 80 YZ465 | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | 1978 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1979 | YZ125F | 2X3-000101 | 1979 | YZ125F | 1979 | YZ125F | 1979 | FITS 77-79 YZ125 YZ400, 77-80 YZ250, 80 YZ465 | 1979 | 1979 | YZ125F | 1979 | FITS 74-79 YZ125, 74-75 YZ250 YZ360 - 364-85540-13-00 | 1979 | 1979 | FITS 77-82 YZ125, 82-83 YZ100, 77-83 IT175, 80-81 IT125, 84-86 IT200, 78-81 DT175, 79-81 MX175, 90-98 RT180 - 1W1-16351-00-00 | FITS 77-83 YZ100, 77-82 YZ250, 78-81 YZ125 79-82 YZ80 - 2X6-82310-10-00 - CM61-20 | 1979 | 2X3 2K6 3R3 - FITS 78-80 YZ125 - 3R3-11311-00-00 - 2X3-11311-00-00 - 2K6-11311-00-00 AIR COOLED | 1979 | 1979 | 1979 | 1979 | 1979 | AIR COOLED NO VALVE | 1979 | 1979 | CONVENTIONAL – 36MM CHROME OD | 36MM X 48MM X 10.5/11 | N/A | 1979 | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | DRUM BRAKE | 1979 | DRUM BRAKE | 1979 | DRUM BRAKE | YELLOW - FITS 77-79 82-83 YZ100, 77-80 82-84 YZ125, 77 79 82-84 YZ250, 77 79 YZ400, 82 84 YZ490 - 5X6-21511-01-00 | 1979 | N/A | 1979 | 1979 | FITS 77-79 IT175, 77-81 YZ100, 77-80 YZ125, 79 AND 80 MX175, 80-81 IT125 - 1W1-15620-01-00 | 1979 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1979 | AIR COOLED | AIR COOLED | 1979 | AIR COOLED | AIR COOLED | AIR COOLED | 1979 | AIR COOLED | AIR COOLED | AIR COOLED | AIR COOLED | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | N/A | N/A | 1979 | 1979 | 1979 | FITS 78-80 YZ125 - 2X6-85510-11-00 | 1979 | 1979 | FITS 77-79 YZ125, 77-80 YZ250, 77-79 YZ400, 80 YZ465 | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | 1979 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1980 | YZ125G | 3R3-000101 | FITS 80 YZ125, 80-81 IT175 - 3R3-15111-02-00 | FITS 80 YZ125, 80-81 IT175 - 3R3-15121-02-00 | 1980 | YZ125G | 1980 | YZ125G | 1980 | 1980 | MIKUNI | 1980 | YZ125G | FITS 80 YZ125, 80-81 IT175 – 3R3-13565-00-00 | 1980 | HITACHI TYPE TIAO-37 3R3-11 | 1980 | 1980 | FITS 77-82 YZ125, 82-83 YZ100, 77-83 IT175, 80-81 IT125, 84-86 IT200, 78-81 DT175, 79-81 MX175, 90-98 RT180 - 1W1-16351-00-00 | FITS 77-83 YZ100, 77-82 YZ250, 78-81 YZ125 79-82 YZ80 - 2X6-82310-10-00 - CM61-20 | 1980 | 2X3 2K6 3R3 - FITS 78-80 YZ125 - 3R3-11311-00-00 - 2X3-11311-00-00 - 2K6-11311-00-00 AIR COOLED | 1980 | 1980 | 1980 | 1980 | 1980 | AIR COOLED NO VALVE | 1980 | 1980 | CONVENTIONAL – 36MM CHROME OD | 36MM X 48MM X 10.5/11 | N/A | 1980 | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | DRUM BRAKE | 1980 | DRUM BRAKE | 1980 | DRUM BRAKE | YELLOW - FITS 80-81 YZ100 YZ125, 80 YZ250, 80-81 YZ465 - 3R2-21511-01-00 | 1980 | N/A | 1980 | 1980 | FITS 77-79 IT175, 77-81 YZ100, 77-80 YZ125, 79 AND 80 MX175, 80-81 IT125 - 1W1-15620-01-00 | 1980 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1980 | AIR COOLED | AIR COOLED | 1980 | AIR COOLED | AIR COOLED | AIR COOLED | 1980 | AIR COOLED | AIR COOLED | AIR COOLED | AIR COOLED | 1980 | 1980 | 1980 | 1980 | LOW GLOSS BLACK - FITS 81-83 IT175, 80-81 YZ125, 82-83 YZ100 - 3R3-25311-02-98 | 1980 | SET FITS 80-85 YZ125, 80-87 YZ250, 84-90 YZ490, 92-93 WR500 - 5X5-18535-01-00 & 5X5-18531-01-00 | 1980 | 1980 | 1980 | N/A | N/A | 1980 | 1980 | 1980 | FITS 80-81 YZ125 - 3R3-85510-11-00 | 1980 | 1980 | 1980 | 1980 | 1980 | 1980 | 1980 | 1980 | 1980 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1981 | YZ125H | 4V2-000101 | FITS 81 YZ125 - 4V2-15111-00-00 | FITS 81 YZ125, 82-83 IT175 YZ100 - 4V2-15121-00-00 | 1981 | YZ125H | 1981 | YZ125H | 1981 | 1981 | MIKUNI | 1981 | YZ125H | fits 80 yz125 - 4V2-13565-00-00 | 1981 | 1981 | 1981 | FITS 77-82 YZ125, 82-83 YZ100, 77-83 IT175, 80-81 IT125, 84-86 IT200, 78-81 DT175, 79-81 MX175, 90-98 RT180 - 1W1-16351-00-00 | FITS 77-83 YZ100, 77-82 YZ250, 78-81 YZ125 79-82 YZ80 - 2X6-82310-10-00 - CM61-20 | 1981 | 4V2 - FITS 81 YZ125 - 4V2-11311-00-00 | 1981 | 1981 | 1981 | 1981 | 1981 | N/A | 1981 | 1981 | CONVENTIONAL – CHROME OD 38MM - C/L 37" | 38MM X 50MM X 8 | N/A | 1981 | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | DRUM BRAKE | 1981 | DRUM BRAKE | 1981 | DRUM BRAKE | YELLOW - FITS 80-81 YZ100 YZ125, 80 YZ250, 80-81 YZ465 - 3R2-21511-01-00 | 1981 | N/A | 1981 | 1981 | 1981 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1981 | ONE RADIATOR SYSTEM FITS 81-82 YZ125 - 4V2-12460-01-00 | ONE RADIATOR SYSTEM FITS 81-82 YZ125 - 4V2-12460-01-00 | 1981 | SINGLE RADIATOR NO SHROUD, USES A NUMBER PLATE FITS 81 YZ125 - 4V2-23485-00-00 | SINGLE RADIATOR NO SHROUD, USES A NUMBER PLATE FITS 81 YZ125 - 4V2-23485-00-00 | 1981 | N/A | N/A | SINGLE RADIATOR NO SHROUD, USES A NUMBER PLATE FITS 81 YZ125 - 4V2-23472-00-00 | SINGLE RADIATOR NO SHROUD, USES A NUMBER PLATE FITS 81 YZ125 - 4V2-23472-00-00 | 1981 | 1981 | 1981 | 1981 | LOW GLOSS BLACK - FITS 81-83 IT175, 80-81 YZ125, 82-83 YZ100 - 3R3-25311-02-98 | 1981 | SET FITS 80-85 YZ125, 80-87 YZ250, 84-90 YZ490, 92-93 WR500 - 5X5-18535-01-00 & 5X5-18531-01-00 | 1981 | 1981 | 1981 | N/A | N/A | 1981 | 1981 | 1981 | FITS 80-81 YZ125 - 3R3-85510-11-00 | 1981 | 1981 | 1981 | 1981 | 1981 | 1981 | 1981 | 1981 | FITS 81 YZ125 - 4V2-12422-01-00 | IMPELLER AND SHAFT FITS 81-82 YZ125 - 4V2-12450-00-00 | IMPELLER AND SHAFT FITS 81-82 YZ125 - 4V2-12450-00-00 | 1981 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1982 | YZ125J | 5X4-000101 | FITS 82 YZ125 - 5X4-15111-00-00 | FITS 82 YZ125 - 5X4-15121-00-00 | 1982 | YZ125J | 1982 | YZ125J | 1982 | 1982 | 1982 | YZ125J | 1982 | 1982 | 1982 | FITS 82 YZ125 - 5X4-16371-00-00 | FITS 77-82 YZ125, 82-83 YZ100, 77-83 IT175, 80-81 IT125, 84-86 IT200, 78-81 DT175, 79-81 MX175, 90-98 RT180 - 1W1-16351-00-00 | 1982 | 5X4 - FITS 82 YZ125 - 5X4-11311-00-00 | 1982 | 1982 | 1982 | 1982 | 1982 | FITS 82-87 YZ125, 86-98 YZ250, 91-97 WR250 – 5X4-Y113F-10-00 | FITS 82-85 YZ125 24X-11990-00-00 | 1982 | 1982 | CONVENTIONAL – 38MM CHROME OD | 38MM X 50MM X 8 | N/A | 1982 | FITS 80-85 YZ250, 80-81 YZ465, 82-85 YZ125 & YZ490 – 3R4-25181-01-00 | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | DRUM BRAKE | 1982 | DRUM BRAKE | 1982 | DRUM BRAKE | YELLOW - FITS 77-79 82-83 YZ100, 77-80 82-84 YZ125, 77 79 82-84 YZ250, 77 79 YZ400, 82 84 YZ490 - 5X6-21511-01-00 | 1982 | N/A | 23X00 15MM AXLE DIA - BRG TO BRG 94MM - FITS 82-84 YZ250 & 125, 82 IT465, 82 TT250, 82 IT175, 83-84 TT600, 83 YZ490 | 1982 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | 1982 | 1982 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1982 | ONE RADIATOR SYSTEM FITS 81-82 YZ125 - 4V2-12460-01-00 | ONE RADIATOR SYSTEM FITS 81-82 YZ125 - 4V2-12460-01-00 | 1982 | SINGLE RADIATOR NO SHROUD, USES A NUMBER PLATE FITS 82 YZ125 YZ250 - 5X4-23485-00-00 | SINGLE RADIATOR NO SHROUD, USES A NUMBER PLATE FITS 82 YZ125 YZ250 - 5X4-23485-00-00 | 1982 | N/A | N/A | SINGLE RADIATOR NO SHROUD, USES A NUMBER PLATE FITS 82 YZ125 YZ250 - 5X4-23485-00-00 | SINGLE RADIATOR NO SHROUD, USES A NUMBER PLATE FITS 82 YZ125 YZ250 - 5X4-23485-00-00 | 1982 | 1982 | 1982 | 1982 | 1982 | SET FITS 80-85 YZ125, 80-87 YZ250, 84-90 YZ490, 92-93 WR500 - 5X5-18535-01-00 & 5X5-18531-01-00 | 1982 | 1982 | 1982 | N/A | N/A | 1982 | 1982 | 1982 | FITS 82-84 YZ125 - 5X4-85510-10-00 | 1982 | 1982 | 1982 | 1982 | 1982 | 1982 | 1982 | 1982 | IMPELLER AND SHAFT FITS 81-82 YZ125 - 4V2-12450-00-00 | IMPELLER AND SHAFT FITS 81-82 YZ125 - 4V2-12450-00-00 | 1982 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1983 | YZ125K | 24X-000101 | 24X-15111-00-00 FITS 83-85 YZ125 | 24X-15121-00-00 FITS 83-84 YZ125 | 1983 | YZ125K | FITS 83-85 YZ125 | 1983 | YZ125K | FITS 83-84 YZ125, 83 YZ250 – 23X-14458-00-00 | 1983 | FITS 82-84 YZ490, 83-84 YZ125, 83 YZ250 5X6-26341-00-00 | 1983 | MIKUNI 24X - 43M-14101-00-00 | 1983 | YZ125K | 1983 | FITS 83-84 YZ125 - 24X-10 209 TYPE T1A01-44 - 24X-85540-10-00 | 1983 | FITS 83-85 YZ125 - 39W-16150-00-00 | 1983 | FITS 83-85 YZ125 - 24X-16371-00-00 | FITS 83-85 YZ125 - 24X-16351-00-00 | CM61-29 - FITS 83-89 YZ125 YZ250 - 24X-82310-10-00 | fits 83-89 yz125 - 24X-82310-10-00 | 1983 | 24X 39W - FITS 83-84 YZ125 - 24X-11311-00-00 - 39W-11311-00-00 | 1983 | FITS 83-84 YZ125 - 24X-14610-00-00 AND 39W-14610-00-00 | 1983 | 1983 | 1983 | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1983 | FITS 82-87 YZ125, 86-98 YZ250, 91-97 WR250 – 5X4-Y113F-10-00 | FITS 82-85 YZ125 24X-11990-00-00 | 1983 | FITS 83-87 YZ125 YZ250, 84-87 YZ490, 83 IT 250, 83-84 IT490, 84-86 IT200 - L) 23X-27411-02-00 R) 23X-27421-03-00 | 1983 | CONVENTIONAL – 38MM CHROME OD | 38MM X 50MM X 8 | N/A | 1983 | FITS 80-85 YZ250, 80-81 YZ465, 82-85 YZ125 & YZ490 – 3R4-25181-01-00 | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | DRUM BRAKE | 1983 | DRUM BRAKE | 1983 | DRUM BRAKE | YELLOW - FITS 77-79 82-83 YZ100, 77-80 82-84 YZ125, 77 79 82-84 YZ250, 77 79 YZ400, 82 84 YZ490 - 5X6-21511-01-00 | 1983 | N/A | 23X00 15MM AXLE DIA - BRG TO BRG 94MM - FITS 82-84 YZ250 & 125, 82 IT465, 82 TT250, 82 IT175, 83-84 TT600, 83 YZ490 | 1983 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 24X – FITS 83-84 YZ125 – 24X-11111-00-00 | 1983 | 1983 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1983 | 1983 | 1983 | N/A | N/A | 17MM – FITS 83-85 YZ125 – 24X-25381-00-00 | 1983 | 24X00 - 130 MM DRUM SIZE – 17MM AXLE – FITS 83-85 YZ125 - 24X-25321-00-98 | 1983 | 1983 | 1983 | 24X00 - PATENT 585876 - BLACK - DRUM BRAKE - 17MM AXLE - OUTSIDE OF BEARINGS 134MM - 130MM DRUM - SPROCKET 6 ON A 175MM BC - FITS 83-85 YZ125 | 1983 | SET FITS 80-85 YZ125, 80-87 YZ250, 84-90 YZ490, 92-93 WR500 - 5X5-18535-01-00 & 5X5-18531-01-00 | 1983 | 1983 | 1983 | N/A | N/A | 1983 | 1983 | 1983 | FITS 82-84 YZ125 - 5X4-85510-10-00 | 1983 | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1983 | 1983 | 1983 | 1983 | 1983 | 1983 | FITS 83-86 YZ125, 83-87 YZ250, 84-86 IT200 - 39W-23435-01-98 | 1983 | 1983 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1984 | YZ125L | 39W-000101 | 24X-15111-00-00 FITS 83-85 YZ125 | 24X-15121-00-00 FITS 83-84 YZ125 | 1984 | YZ125L | FITS 83-85 YZ125 | 1984 | YZ125L | FITS 83-84 YZ125, 83 YZ250 – 23X-14458-00-00 | 1984 | FITS 82-84 YZ490, 83-84 YZ125, 83 YZ250 5X6-26341-00-00 | 1984 | MIKUNI 37W | 1984 | YZ125L | 1984 | FITS 83-84 YZ125 - 24X-10 209 TYPE T1A01-44 - 24X-85540-10-00 | 1984 | FITS 83-85 YZ125 - 39W-16150-00-00 | 1984 | FITS 83-85 YZ125 - 24X-16371-00-00 | FITS 83-85 YZ125 - 24X-16351-00-00 | CM61-29 - FITS 83-89 YZ125 YZ250 - 24X-82310-10-00 | fits 83-89 yz125 - 24X-82310-10-00 | 1984 | 24X 39W - FITS 83-84 YZ125 - 24X-11311-00-00 - 39W-11311-00-00 | 1984 | FITS 83-84 YZ125 - 24X-14610-00-00 AND 39W-14610-00-00 | 1984 | 1984 | 1984 | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1984 | FITS 82-87 YZ125, 86-98 YZ250, 91-97 WR250 – 5X4-Y113F-10-00 | FITS 82-85 YZ125 24X-11990-00-00 | 1984 | FITS 83-87 YZ125 YZ250, 84-87 YZ490, 83 IT 250, 83-84 IT490, 84-86 IT200 - L) 23X-27411-02-00 R) 23X-27421-03-00 | 1984 | CONVENTIONAL – 43MM CHROME OD | 43MM X 54MM X 11 | N/A | 1984 | FITS 80-85 YZ250, 80-81 YZ465, 82-85 YZ125 & YZ490 – 3R4-25181-01-00 | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | DRUM BRAKE | 1984 | DRUM BRAKE | 1984 | DRUM BRAKE | YELLOW - FITS 77-79 82-83 YZ100, 77-80 82-84 YZ125, 77 79 82-84 YZ250, 77 79 YZ400, 82 84 YZ490 - 5X6-21511-01-00 | 1984 | N/A | 23X00 15MM AXLE DIA - BRG TO BRG 94MM - FITS 82-84 YZ250 & 125, 82 IT465, 82 TT250, 82 IT175, 83-84 TT600, 83 YZ490 | 1984 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | FITS 83-84 YZ125 – 24X-11111-00-00 | 1984 | 1984 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1984 | 1984 | 1984 | N/A | N/A | 17MM – FITS 83-85 YZ125 – 24X-25381-00-00 | 1984 | 24X00 - 130 MM DRUM SIZE – 17MM AXLE – FITS 83-85 YZ125 - 24X-25321-00-98 | 1984 | 1984 | 1984 | 24X00 - PATENT 585876 - BLACK - DRUM BRAKE - 17MM AXLE - OUTSIDE OF BEARINGS 134MM - 130MM DRUM - SPROCKET 6 ON A 175MM BC - FITS 83-85 YZ125 | 1984 | SET FITS 80-85 YZ125, 80-87 YZ250, 84-90 YZ490, 92-93 WR500 - 5X5-18535-01-00 & 5X5-18531-01-00 | 1984 | 1984 | 1984 | N/A | N/A | 1984 | 1984 | 1984 | FITS 82-84 YZ125 - 5X4-85510-10-00 | 1984 | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1984 | 1984 | 1984 | 1984 | 1984 | 1984 | FITS 83-86 YZ125, 83-87 YZ250, 84-86 IT200 - 39W-23435-01-98 | 1984 | 1984 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1985 | YZ125N | 55Y-000101 | 24X-15111-00-00 FITS 83-85 YZ125 | 1985 | YZ125N | FITS 83-85 YZ125 | 1985 | YZ125N | 1985 | 1985 | MIKUNI | 1985 | YZ125N | 1985 | HITACHI TIA01-51 55Y-10 - fits 85-86 yz125 - 55Y-85540-10-00 - WHITE RED/BLACK 217 | BLACK/WHITE RED 217 | brown/black white 5 - these are not official numbers | 1985 | FITS 83-85 YZ125 - 39W-16150-00-00 | 1985 | FITS 83-85 YZ125 - 24X-16371-00-00 | FITS 83-85 YZ125 - 24X-16351-00-00 | CM61-29 - FITS 83-89 YZ125 YZ250 - 24X-82310-10-00 | fits 83-89 yz125 - 24X-82310-10-00 | 1985 | 55Y - FITS 85 YZ125 - 55Y-11311-00-00 | 1985 | 1985 | 1985 | FITS 1985 YZ125 | 1985 | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1985 | FITS 82-87 YZ125, 86-98 YZ250, 91-97 WR250 – 5X4-Y113F-10-00 | FITS 82-85 YZ125 24X-11990-00-00 | 1985 | M100-39 55Y - FITS 85 YZ125 - 55Y-85550-10-00 | FITS 83-87 YZ125 YZ250, 84-87 YZ490, 83 IT 250, 83-84 IT490, 84-86 IT200 - L) 23X-27411-02-00 R) 23X-27421-03-00 | 1985 | CONVENTIONAL - Y111-R SA-1 Y111-L SA-1 - CHROME OD 43MM - C/L 36 3/4" - BRAKE MOUNT C/L 85MM - AXLE 20MM & 15MM | 43MM X 54MM X 11 | N/A | 1985 | FITS 80-85 YZ250, 80-81 YZ465, 82-85 YZ125 & YZ490 – 3R4-25181-01-00 | HYDRAULIC | FITS 85-88 YZ125 YZ250, 85-90 YZ490 - 2HH-2580T-00-00 | 1985 | FITS 85-86 YZ125 YZ490, 85 YZ250 - 56A-25870-01-00 | 1985 | 240MM OD - ID 117.5MM - BOLTS 4 ON BC ON 130MM - FITS 85 YZ125, 250, 490 | FITS 85-90 YZ125 490, 85-88 YZ250, 80-81 IT250 IT175 IT250, 80 IT400, 81 IT465 - 5X6-21511-11-00 - 55MM C/L WIDTH, 65MM C/L LENGTH | 1985 | N/A | 56A00 15MM AXLE DIA - BRG TO BRG 94MM - ROTOR BOLTS 4 ON BC ON 130MM - FITS 1985 YZ250 & 125 | 1985 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 55Y FITS 85 YZ125 55Y-11111-00-00 | 1985 | 1985 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1985 | 1985 | 1985 | N/A | N/A | 17MM – FITS 83-85 YZ125 – 24X-25381-00-00 | 1985 | 24X00 - 130 MM DRUM SIZE – 17MM AXLE – FITS 83-85 YZ125 - 24X-25321-00-98 | 1985 | 1985 | 1985 | 24X00 - PATENT 585876 - BLACK - DRUM BRAKE - 17MM AXLE - OUTSIDE OF BEARINGS 134MM - 130MM DRUM - SPROCKET 6 ON A 175MM BC - FITS 83-85 YZ125 | 1985 | SET FITS 80-85 YZ125, 80-87 YZ250, 84-90 YZ490, 92-93 WR500 - 5X5-18535-01-00 & 5X5-18531-01-00 | 1985 | 1985 | 1985 | N/A | N/A | 1985 | 1985 | 1985 | FITS 85-86 YZ125 - 55Y-85510-11-00 | 1985 | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1985 | 1985 | 1985 | 1985 | 1985 | 1985 | FITS 83-86 YZ125, 83-87 YZ250, 84-86 IT200 - 39W-23435-01-98 | 1985 | 1985 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1986 | YZ125S | 1LX-00 FITS 86-87 | FITS 86-87 YZ125 – 99999-01806-00 SET NUMBER | FITS 86-87 YZ125 - 1LX-15121-02-00 | 1986 | YZ125S | 1986 | YZ125S | 1986 | 1986 | 1986 | YZ125S | 1986 | HITACHI TIA01-51 55Y-10 - fits 85-86 yz125 - 55Y-85540-10-00 - WHITE RED/BLACK 217 | BLACK/WHITE RED 217 | brown/black white 5 - these are not official numbers | 1986 | FITS 86-88 YZ125, 85-88 YZ250, 85-89 YZ490 - 56A-25388-01-00 | 1986 | FITS 86-87 YZ125 - 1LX-16371-00-00 (OUTER) | FITS 86-87 YZ125 - 1LX-16351-00-00 (INNER) | CM61-29 - FITS 83-89 YZ125 YZ250 - 24X-82310-10-00 | fits 83-89 yz125 - 24X-82310-10-00 | 1986 | 8104 - ROD - FITS 86-96 YZ125 | 1LX - FITS 86 YZ125 - 1LX-11311-00-00 | 1986 | 1986 | FITS 86 YZ125 - PY86125P | 1986 | 1986 | FITS 86-87 YZ125 - 1LX-11992-00-00 | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1986 | FITS 82-87 YZ125, 86-98 YZ250, 91-97 WR250 – 5X4-Y113F-10-00 | FITS 86-87 YZ125 1LX-11990-00-00 | 1986 | FITS 83-87 YZ125 YZ250, 84-87 YZ490, 83 IT 250, 83-84 IT490, 84-86 IT200 - L) 23X-27411-02-00 R) 23X-27421-03-00 | 1986 | CONVENTIONAL – 43MM CHROME OD | 43MM X 55MM X 9.5/10.5/11 | N/A | 1986 | FITS 86-91 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 91-92 WR250, 85-86 TT600, 86 IT200, 86-87 TT350, 90-95 XT600 - 55U-25181-01-00 | HYDRAULIC | FITS 85-88 YZ125 YZ250, 85-90 YZ490 - 2HH-2580T-00-00 | 1986 | FITS 85-86 YZ125 YZ490, 85 YZ250 - 56A-25870-01-00 | 1986 | 220MM OD, 86.1MM ID, 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - FITS 86-87 YZ125 YZ490, 87 YZ250 - 1LX-25831-00-00 | FITS 85-90 YZ125 490, 85-88 YZ250, 80-81 IT250 IT175 IT250, 80 IT400, 81 IT465 - 5X6-21511-11-00 - 55MM C/L WIDTH, 65MM C/L LENGTH | 1986 | N/A | FITS 86 YZ125 YZ250 YZ490 - 1LX-25111-00-98 | 1986 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | FITS 86-88 YZ125 – 1LX-24110-00-00 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | FITS 86-89 YZ125 | 1986 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1986 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1986 | FITS 83-95 YZ250, 86-95 YZ125, 84-90 YZ490, 91-97 WR250, 92-93 WR500, 92 WR200 - 39X-21642-00-00 | FITS 86-91 YZ125, 87-91 YZ250, 85-90 YZ490, 91 WR250. 92-93 WR500 - 3XJ-23485-01-00 | FITS 86-88 YZ125, 86-87 YZ250 - 1LX-12460-00-00 | FITS 86-92 YZ125, 92 WR200 | 1986 | 1986 | N/A | N/A | BLACK – FITS 83-89 YZ250, 86-89 YZ125, 89 YZ250WR - 24Y-2172A-01-00 | BLACK – FITS 83-89 YZ250, 86-89 YZ125, 89 YZ250WR - 24Y-2172A-01-00 | 1986 | 1986 | 1986 | FITS 83-87 YZ250, 86 YZ125, 83-90 YZ490 - 23X-25371-00-00 | FITS 86-90 YZ125 YZ250 YZ490 - 1LX-21611-00-00 | 1986 | BLACK - DRUM BRAKE - 20MM AXLE - FITS 86-87 YZ125 - 1LX-25311-01-98 | 1986 | 5X6 – FITS 86-88 YZ125, YZ250, YZ490 1LX-24770-10-00 | 1986 | FITS 86-90 YZ490, 86 YZ125, 87 YZ250 | 1986 | LEFT 1LX-21711-01-98 - FITS 86-88 YZ125, 86-87 YZ250, 86-90 YZ490 | RIGHT - 99999-01787-00 - FITS 86-87 YZ125 YZ250 YZ490 | 1986 | N/A | N/A | FITS 86-95 YZ125 | 1986 | FITS 86-90 YZ125 | 1986 | 1986 | FITS 85-86 YZ125 - 55Y-85510-11-00 | 1986 | FITS 86-97 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 97-97 WR250 - 1LX-22141-00-00 | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1986 | 1986 | 1986 | 1986 | 1986 | 1986 | FITS 86 YZ 125 YZ250 YZ490 - 1LX-23340-L0-00 | FITS 83-86 YZ125, 83-87 YZ250, 84-86 IT200 - 39W-23435-01-98 | 1986 | 1986 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1987 | YZ125T | 2HG-00 FITS 86-87 | FITS 86-87 YZ125 – 99999-01806-00 SET NUMBER | FITS 86-87 YZ125 - 1LX-15121-02-00 | 1987 | YZ125T | FITS 87-88 YZ125, 86-87 YZ250, 87-90 YZ490 - 1LU-W1441-00-00 | 1987 | YZ125T | FITS 87-88 YZ125, 86-87 YZ250, 87-90 YZ490 - 2HH-14458-00-00 | FITS 87-88 YZ125 | 1987 | 1987 | 1987 | YZ125T | 1987 | 1987 | FITS 86-88 YZ125, 85-88 YZ250, 85-89 YZ490 - 56A-25388-01-00 | 1987 | FITS 86-87 YZ125 - 1LX-16371-00-00 (OUTER) | FITS 86-87 YZ125 - 1LX-16351-00-00 (INNER) | CM61-29 - FITS 83-89 YZ125 YZ250 - 24X-82310-10-00 | fits 83-89 yz125 - 24X-82310-10-00 | 1987 | 8104 - ROD - FITS 86-96 YZ125 | 2HG - FITS 87 YZ125 - 2HG-11311-00-00 | 1987 | 1987 | FITS 87-88 YZ125 - PY87125P | 1987 | 1987 | FITS 86-87 YZ125 - 1LX-11992-00-00 | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1987 | FITS 82-87 YZ125, 86-98 YZ250, 91-97 WR250 – 5X4-Y113F-10-00 | FITS 86-87 YZ125 1LX-11990-00-00 | 1987 | FP8167 FITS 87 YZ125 - 2HG-85550-K0-00 | FITS 83-87 YZ125 YZ250, 84-87 YZ490, 83 IT 250, 83-84 IT490, 84-86 IT200 - L) 23X-27411-02-00 R) 23X-27421-03-00 | 1987 | KAYABA - CONVENTIONAL - Y1LX-R - Y1LX-L - CHROME OD 43MM - C/L 36 3/4" - BRAKE MOUNT C/L 85MM - AXLE 20MM & 15MM | 43MM X 55MM X 9.5/10.5/11 | N/A | 1987 | FITS 86-91 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 91-92 WR250, 85-86 TT600, 86 IT200, 86-87 TT350, 90-95 XT600 - 55U-25181-01-00 | HYDRAULIC | FITS 85-88 YZ125 YZ250, 85-90 YZ490 - 2HH-2580T-00-00 | 1987 | FITS 87-88 YZ125 YZ250, 87-90 YZ490 - 1RG-25872-10-00 | FITS 87-88 yz125 yz250, 87-90 YZ490, 87-92 YZ80 - 2VN-25870-00-00 | 1987 | 220MM OD, 86.1MM ID, 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - FITS 86-87 YZ125 YZ490, 87 YZ250 - 1LX-25831-00-00 | FITS 85-90 YZ125 490, 85-88 YZ250, 80-81 IT250 IT175 IT250, 80 IT400, 81 IT465 - 5X6-21511-11-00 - 55MM C/L WIDTH, 65MM C/L LENGTH | 1987 | N/A | 2HH00 - LOW GLOSS BLACK - 15MM AXLE DIA - BRG TO BRG 86.7MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - 36 SPOKES - FITS 87-89 YZ125, YZ250 & 87-90 YZ490 - 2HH-25111-00-98 | 1987 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | FITS 86-88 YZ125 – 1LX-24110-00-00 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 1LX FITS 86-89 YZ125 | 1987 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1987 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1987 | FITS 83-95 YZ250, 86-95 YZ125, 84-90 YZ490, 91-97 WR250, 92-93 WR500, 92 WR200 - 39X-21642-00-00 | FITS 86-91 YZ125, 87-91 YZ250, 85-90 YZ490, 91 WR250. 92-93 WR500 - 3XJ-23485-01-00 | FITS 86-88 YZ125, 86-87 YZ250 - 1LX-12460-00-00 | FITS 86-92 YZ125, 92 WR200 | 1987 | FITS 87-88 YZ125 2HG-21731-00-00 | FITS 87-88 YZ125 2HG-21741-00-00 | 1987 | N/A | N/A | BLACK – FITS 83-89 YZ250, 86-89 YZ125, 89 YZ250WR - 24Y-2172A-01-00 | BLACK – FITS 83-89 YZ250, 86-89 YZ125, 89 YZ250WR - 24Y-2172A-01-00 | 1987 | FITS 83-87 YZ250, 87 YZ125, 83 YZ490 | 1987 | 1987 | FITS 86-90 YZ125 YZ250 YZ490 - 1LX-21611-00-00 | 1987 | BLACK - DRUM BRAKE - 20MM AXLE - FITS 86-87 YZ125 - 1LX-25311-01-98 | 1987 | 5X6 – FITS 86-88 YZ125, YZ250, YZ490 1LX-24770-10-00 | 1987 | 1987 | LEFT 1LX-21711-01-98 - FITS 86-88 YZ125, 86-87 YZ250, 86-90 YZ490 | RIGHT - 99999-01787-00 - FITS 86-87 YZ125 YZ250 YZ490 | 1987 | N/A | N/A | FITS 86-95 YZ125 | 1987 | FITS 86-90 YZ125 | 1987 | 1987 | FITS 87 YZ125 - 2HG-85510-K0-00 | FITS 87-88 YZ125 | 1987 | FITS 86-97 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 97-97 WR250 - 1LX-22141-00-00 | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1987 | 1987 | 1987 | 1987 | 1987 | 1987 | FITS 88 YZ250, 87-88 YZ125 - 2HG-23435-00-98 | 1987 | 1987 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1988 | YZ125U | 2VN-00 | FITS 88-91 YZ125 – 1LX-15111-12-00 | FITS 88-90 YZ125 – 1LX-15121-11-00 | 1988 | YZ125U | FITS 87-88 YZ125, 86-87 YZ250, 87-90 YZ490 - 1LU-W1441-00-00 | 1988 | YZ125U | FITS 87-88 YZ125, 86-87 YZ250, 87-90 YZ490 - 2HH-14458-00-00 | FITS 87-88 YZ125 | 1988 | 1988 | MIKUNI TM 35MM | 1988 | YZ125U | FITS 88 YZ125 – 2VN-13565-00-00 – C/L TO C/L HORIZONTAL 71MM, VERTICAL 57.5MM | 1988 | 1988 | FITS 86-88 YZ125, 85-88 YZ250, 85-89 YZ490 - 56A-25388-01-00 | FITS 88 YZ125 | 1988 | FITS 88 YZ125 - 2VN-16371-00-00 (OUTER) | FITS 88 YZ125 - 2VN-16351-00-00 (INNER) | CM61-29 - FITS 83-89 YZ125 YZ250 - 24X-82310-10-00 | fits 83-89 yz125 - 24X-82310-10-00 | 1988 | 8104 - ROD - FITS 86-96 YZ125 | 2VN - FITS 88 YZ125 - 2VN-11311-00-00 | 1988 | 1988 | FITS 87-88 YZ125 - PY87125P | 1988 | FITS 1988 YZ125 | 1988 | FITS 88-90 YZ125 - 3JD-11992-00-00 | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1988 | FITS 88-91 YZ125 - 2VN-Y113F-00-00 | FITS 88 YZ125 2VN-11990-00-00 | 1988 | 2VN FP5147 - fits 88 YZ125 - 2VN-85550-K0-00 | FITS 88-89 YZ125 YZ250, 88-90 YZ490 L) 2VN-27411-00-00 R) 2VN-27421-00-00 | 1988 | CONVENTIONAL – 43MM CHROME OD | 43MM X 55MM X 9.5/10.5/11 | N/A | 1988 | FITS 86-91 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 91-92 WR250, 85-86 TT600, 86 IT200, 86-87 TT350, 90-95 XT600 - 55U-25181-01-00 | HYDRAULIC | FITS 85-88 YZ125 YZ250, 85-90 YZ490 - 2HH-2580T-00-00 | 1988 | FITS 87-88 YZ125 YZ250, 87-90 YZ490 - 1RG-25872-10-00 | FITS 87-88 yz125 yz250, 87-90 YZ490, 87-92 YZ80 - 2VN-25870-00-00 | 1988 | OD 230MM - ID 86MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - 88 YZ125 YZ250 - 88-90 YZ490 - 2VN-25831-00-00 | FITS 85-90 YZ125 490, 85-88 YZ250, 80-81 IT250 IT175 IT250, 80 IT400, 81 IT465 - 5X6-21511-11-00 - 55MM C/L WIDTH, 65MM C/L LENGTH | 1988 | N/A | 2HH00 - LOW GLOSS BLACK - 15MM AXLE DIA - BRG TO BRG 86.7MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - 36 SPOKES - FITS 87-89 YZ125, YZ250 & 87-90 YZ490 - 2HH-25111-00-98 | 1988 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | FITS 86-88 YZ125 – 1LX-24110-00-00 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | FITS 86-89 YZ125 | 1988 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1988 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1988 | FITS 83-95 YZ250, 86-95 YZ125, 84-90 YZ490, 91-97 WR250, 92-93 WR500, 92 WR200 - 39X-21642-00-00 | FITS 86-91 YZ125, 87-91 YZ250, 85-90 YZ490, 91 WR250. 92-93 WR500 - 3XJ-23485-01-00 | FITS 86-88 YZ125, 86-87 YZ250 - 1LX-12460-00-00 | FITS 86-92 YZ125, 92 WR200 | 1988 | FITS 87-88 YZ125 2HG-21731-00-00 | FITS 87-88 YZ125 2HG-21741-00-00 | 1988 | N/A | N/A | BLACK – FITS 83-89 YZ250, 86-89 YZ125, 89 YZ250WR - 24Y-2172A-01-00 | BLACK – FITS 83-89 YZ250, 86-89 YZ125, 89 YZ250WR - 24Y-2172A-01-00 | 1988 | 1988 | 1988 | 2VN-27200-01-00 FITS 88 YZ125 | FITS 86-90 YZ125 YZ250 YZ490 - 1LX-21611-00-00 | 1988 | 2VN00 LOW GLOSS BLACK - 20MM AXLE DIA - OUTSIDE OF BRGS 131MM - ROTOR DIA 220MM - ROTOR 6 BOLTS ON A 133MM BOLT CIRCLE - SPROCKET 6 ON 175MM BC - 36 SPOKES - FITS 88-89 YZ125 & 250 - 2VN-25311-00-98 | 1988 | FITS 88-92 YZ125 – 2VN-13610-00-00 – C/L TO C/L HORIZONTAL 71MM, VERTICAL 57.5MM | 5X6 – FITS 86-88 YZ125, YZ250, YZ490 1LX-24770-10-00 | 1988 | 1988 | LEFT 1LX-21711-01-98 - FITS 86-88 YZ125, 86-87 YZ250, 86-90 YZ490 | 1988 | N/A | N/A | FITS 86-95 YZ125 | 1988 | FITS 86-90 YZ125 | 1988 | 1988 | FITS 88 YZ125 - 2VN-85510-K0-00 | FITS 87-88 YZ125 | 1988 | FITS 86-97 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 97-97 WR250 - 1LX-22141-00-00 | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1988 | SHAFTS AND GEARS FIT 88 YZ125 | 1988 | 1988 | 1988 | 1988 | 1988 | FITS 88 YZ250, 87-88 YZ125 - 2HG-23435-00-98 | 1988 | 1988 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1989 | YZ125W | 3JD-00 | FITS 88-91 YZ125 – 1LX-15111-12-00 | FITS 88-90 YZ125 – 1LX-15121-11-00 | JYA3JDW02KA00XXXX | 1989 | YZ125W | 1989 | YZ125W | FITS 89-96 YZ125 YZ250 - 3JD-14458-00-00 | FITS 89 YZ250, 89-90 YZ250 - 3JD-26335-00-00 | 1989 | FITS 89-94 YZ125 YZ250, 91 WR250 - 4EW-26311-00-00 | 1989 | MIKUNI TM | 1989 | YZ125W | 3JD - FITS 89 YZ125 - 3JD-13565-00-00 | 1989 | FITS 89-92 YZ125 YZ250 - 3JD-22199-00-00 - 3JD-22147-00-00 - 3JD-22128-00-00 | 1989 | FITS 89-92 YZ125 YZ250, 90-93 WR250, 92-93 WR500 - 3JD-22151-00-00 | FITS 89-90 YZ125 | 3JD00 T-1 FITS 89-93 | 1989 | FITS 89-90 YZ125 - 3JD-16371-00-00 | FITS 89-90 YZ125 – 3JD-16371-00-00 | CM61-29 - FITS 83-89 YZ125 YZ250 - 24X-82310-10-00 | fits 83-89 yz125 - 24X-82310-10-00 | 1989 | 8104 - ROD - FITS 86-96 YZ125 | 3JD - FITS 1989 YZ125 - 3JD-11311-00-00 | 1989 | 1989 | FITS 89 YZ125 - PY89125P | 1989 | FITS 1989 YZ125 | 1989 | FITS 88-90 YZ125 - 3JD-11992-00-00 | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1989 | FITS 88-91 YZ125 - 2VN-Y113F-00-00 | FITS 89 YZ125 3JD-11990-00-00 | 1989 | 3JD FP5211 81 - FITS 89 YZ125 - 3JD-85550-00-00 | FITS 88-89 YZ125 YZ250, 88-90 YZ490 L) 2VN-27411-00-00 R) 2VN-27421-00-00 | 1989 | USD - 3S-L 3S-R - CHROME OD IS 41MM - RED UPPERS - C/L 37" - UPPER 49.9MM - LOWER 55.6MM - C/L OF CALIPER 78MM - AXLE 15MM & 20MM | 41MM X 53MM X 8/9.5/10.5 | N/A | 1989 | FITS 86-91 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 91-92 WR250, 85-86 TT600, 86 IT200, 86-87 TT350, 90-95 XT600 - 55U-25181-01-00 | HYDRAULIC | FITS 89 YZ125 YZ250 YZ250WR - 3JD-25810-00-00 | 1989 | FITS 89 YZ125 YZ250 YZ250WR - 3JD-25870-00-00 | 1989 | OD 230MM - ID 86MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - FITS 89 YZ 125 YZ250 YZ250WR - 3JD-25810-00-00 | FITS 85-90 YZ125 490, 85-88 YZ250, 80-81 IT250 IT175 IT250, 80 IT400, 81 IT465 - 5X6-21511-11-00 - 55MM C/L WIDTH, 65MM C/L LENGTH | 1989 | N/A | 2HH00 - LOW GLOSS BLACK - 15MM AXLE DIA - BRG TO BRG 86.7MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - 36 SPOKES - FITS 87-89 YZ125, YZ250 & 87-90 YZ490 - 2HH-25111-00-98 | 1989 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | FITS 89-92 YZ125 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | FITS 86-89 YZ125 | 1989 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1989 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1989 | FITS 83-95 YZ250, 86-95 YZ125, 84-90 YZ490, 91-97 WR250, 92-93 WR500, 92 WR200 - 39X-21642-00-00 | FITS 86-91 YZ125, 87-91 YZ250, 85-90 YZ490, 91 WR250. 92-93 WR500 - 3XJ-23485-01-00 | 650 CM3 | FITS 89 YZ125 - 3JD-16111-00-00 | FITS 86-92 YZ125, 92 WR200 | 1989 | FITS 88-89 YZ250, 89 YZ250WRA YZ125 - 2VM-21731-00-00 | FITS 88-89 YZ250, 89 YZ250WRA, 89-90 YZ125 - 2VM-21741-00-00 | 1989 | N/A | N/A | BLACK – FITS 83-89 YZ250, 86-89 YZ125, 89 YZ250WR - 24Y-2172A-01-00 | BLACK – FITS 83-89 YZ250, 86-89 YZ125, 89 YZ250WR - 24Y-2172A-01-00 | 20MM - FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F - 3JD-25381-01-00 | 1989 | 1989 | 1989 | FITS 86-90 YZ125 YZ250 YZ490 - 1LX-21611-00-00 | 1989 | 2VN00 LOW GLOSS BLACK - 20MM AXLE DIA - OUTSIDE OF BRGS 131MM - ROTOR DIA 220MM - ROTOR 6 BOLTS ON A 133MM BOLT CIRCLE - SPROCKET 6 ON 175MM BC - 36 SPOKES - FITS 88-89 YZ125 & 250 - 2VN-25311-00-98 | 1989 | FITS 88-92 YZ125 – 2VN-13610-00-00 – C/L TO C/L HORIZONTAL 71MM, VERTICAL 57.5MM | 5X6 - FITS 1989 YZ125 YZ250 - 3JD-24770-00-00 | 1989 | 3JD-2 89-90 YZ125, 90 YZ250 & YZ250WR | 1989 | FITS 88-90 YZ250 89-90 YZ125 | 1989 | N/A | N/A | 3JD – 2VN | FITS 86-95 YZ125 | 1989 | FITS 86-90 YZ125 | 1989 | FITS 89-90 YZ125 YZ250 – 3JD-2217A-00-00 | FITS 89-90 YZ125 YZ250 - 3JD-2217F-00-00 | 1989 | 9F - FITS 89 YZ125 - 3JD-85510-01-00 | 1989 | FITS 86-97 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 97-97 WR250 - 1LX-22141-00-00 | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1989 | 1989 | 1989 | 1989 | 1989 | 1989 | FITS 89-90 YZ125 YZ250 YZ250WR - UPPER 49.9MM - LOWER 55.6MM - C/L 185MM - 3JD-23340-L0-00 | 1989 | 1989 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1990 | YZ125A1 | 3SR-00 | FITS 88-91 YZ125 – 1LX-15111-12-00 | FITS 88-90 YZ125 – 1LX-15121-11-00 | 1990 | YZ125A1 | FITS 90 YZ125 YZ250 YZ250WR - 3SP-W1441-00-00 | 1990 | YZ125A1 | FITS 89-96 YZ125 YZ250 - 3JD-14458-00-00 | FITS 89 YZ250, 89-90 YZ250 - 3JD-26335-00-00 | 1990 | FITS 89-94 YZ125 YZ250, 91 WR250 - 4EW-26311-00-00 | 1990 | MIKUNI TM | 1990 | YZ125A1 | 1990 | FITS 89-92 YZ125 YZ250 - 3JD-22199-00-00 - 3JD-22147-00-00 - 3JD-22128-00-00 | 1990 | FITS 89-98 YZ250, 90-98 YZ125, 91 WR250, 89-90 YZ250WR, 98 WR400F - 3SP-25388-00-00 | FITS 89-92 YZ125 YZ250, 90-93 WR250, 92-93 WR500 - 3JD-22151-00-00 | FITS 89-90 YZ125 | FITS 89-93 | 1990 | FITS 89-90 YZ125 - 3JD-16371-00-00 | FITS 89-90 YZ125 – 3JD-16371-00-00 | FITS 90-93 YZ125 YZ250 - 3SR-82310-10-00 - F6T537 | FITS 90 YZ125 - 3SR-11400-00-00 | 1990 | 8104 - ROD - FITS 86-96 YZ125 | 3SR - FITS 90 YZ125 - 3SR-11311-00-00 | 1990 | 1990 | 1990 | 1990 | FITS 88-90 YZ125 - 3JD-11992-00-00 | FITS 89-94 96-98 YZ250, 90-91 YZ125, 91-97 WR250 | 1990 | FITS 88-91 YZ125 - 2VN-Y113F-00-00 | FITS 90-93 YZ125 3SR-11990-00-00 | 1990 | F3T81671 - FITS 90-91 | FITS 90-91 YZ125 YZ250, 91 WR250, 92 WR200 - 3SP-27411-00-00 - 3SP-27421-00-00 | 1990 | USD - 3S-L 3S-R - CHROME OD IS 41MM - RED UPPERS - C/L 37" - UPPER 49.9MM - LOWER 55.6MM - C/L OF CALIPER 78MM - AXLE 15MM & 20MM | 41MM X 53MM X 8/9.5/10.5 | N/A | 1990 | FITS 90-91 YZ125 YZ250. 92-93 WR500, 92 WR200, 91 WR250 - 3SP-2314F-L0-00 - 3SP-2314G-L0-00 | FITS 86-91 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 91-92 WR250, 85-86 TT600, 86 IT200, 86-87 TT350, 90-95 XT600 - 55U-25181-01-00 | HYDRAULIC | FITS 90-92 YZ125 YZ250, 91-93 WR250 - 3SP-2580T-00-00 | 1990 | FITS 90-92 YZ125 YZ250, 91-92 WR250, 92-93 WR500 - 3SP-2580T-00-00 | FITS 90-91 YZ125 YZ250, 91 WR250, 92-93 WR500 - 3SP-25872-00-00 | FITS 90-95 YZ125 YZ250, 91-96 WR250 - 3SP-25870-01-00 | 1990 | ROTOR OD 245MM, ID 86MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - FITS 90-91 YZ125 & YZ250, 91-93 WR250 - 3SP-2580T-00-00 | FITS 85-90 YZ125 490, 85-88 YZ250, 80-81 IT250 IT175 IT250, 80 IT400, 81 IT465 - 5X6-21511-11-00 - 55MM C/L WIDTH, 65MM C/L LENGTH | 1990 | N/A | 2HH00- GRAY - 15MM AXLE DIA - BRG TO BRG 86-87MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - FITS 90-91 YZ125 YZ250, 91 WR250, 92-93 WR500 - 3SP-25111-00-00 | 1990 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | FITS 89-92 YZ125 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | FITS 86-89 YZ125 | 1990 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1990 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1990 | FITS 83-95 YZ250, 86-95 YZ125, 84-90 YZ490, 91-97 WR250, 92-93 WR500, 92 WR200 - 39X-21642-00-00 | FITS 86-91 YZ125, 87-91 YZ250, 85-90 YZ490, 91 WR250. 92-93 WR500 - 3XJ-23485-01-00 | FITS 86-92 YZ125, 92 WR200 | 1990 | FITS 88-89 YZ250, 89 YZ250WRA, 89-90 YZ125 - 2VM-21741-00-00 | 1990 | N/A | N/A | FITS 90 YZ125 YZ250 YZ250WRA - 3SP-2172A-01-00 | FITS 90 YZ125 YZ250 YZ250WRA - 3SP-2172A-01-00 | 20MM - FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F - 3JD-25381-01-00 | 1990 | FITS 90 YZ125 YZ250, 91 WR250 - 3SP-2580W-01-00 | 1990 | 1990 | FITS 90-02 YZ125 YZ250 - 3SP-2583V-00-00 | FITS 86-90 YZ125 YZ250 YZ490 - 1LX-21611-00-00 | 1990 | FITS 90-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 - 3SP-25311-00-00 | 1990 | FITS 88-92 YZ125 – 2VN-13610-00-00 – C/L TO C/L HORIZONTAL 71MM, VERTICAL 57.5MM | 5X6 - FITS 1990 YZ125 YZ250 - 3JD-24770-10-00 | 1990 | Spring thickness: 11.2MM OD - Spring Diameter: 87.5MM - Spring length as mounted: 254MM - Upper mount tab thickness: 25.8MM - Upper mount tab hole ID: 10MM - Lower mount Width: 19.6MM - Lower mount hole ID: 10MM - Eye to Eye: 490MM | 3JD-2 89-90 YZ125, 90 YZ250 & YZ250WR | 1990 | FITS 88-90 YZ250 89-90 YZ125 | 1990 | N/A | N/A | FITS 86-95 YZ125 | 1990 | FITS 86-90 YZ125 | SPRING THICKNESS: 11.2MM OD - SPRING DIAMETER: 87.5MM - SPRING LENGTH AS MOUNTED: 254MM - UPPER MOUNT TAB THICKNESS: 25.8MM - UPPER MOUNT TAB HOLE ID: 10MM - LOWER MOUNT WIDTH: 19.6MM - LOWER MOUNT HOLE ID: 10MM - EYE TO EYE: 490MM | 1990 | FITS 89-90 YZ125 YZ250 – 3JD-2217A-00-00 | FITS 89-90 YZ125 YZ250 - 3JD-2217F-00-00 | 1990 | FITS 90-91 YZ125 - 3SR-85510-10-00 | FITS 90 YZ125 YZ250 YZ250WR - 3JD-21123-01-UJ | 1990 | FITS 86-97 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 97-97 WR250 - 1LX-22141-00-00 | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1990 | 13T - FITS 90 YZ125 - 3JD-17411-00-00 | 1990 | 1990 | FITS 90 YZ125 - 3JD-17421-00-00 | 1990 | FITS 90-02 YZ125 - 3SR-17231-00-00 | 1990 | 1990 | FITS 89-90 YZ125 YZ250 YZ250WR - UPPER 49.9MM - LOWER 55.6MM - C/L 185MM - 3JD-23340-L0-00 | 1990 | 1990 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1991 | YZ125B1 | 3XJ-00 | FITS 88-91 YZ125 – 1LX-15111-12-00 | FITS 91-92 YZ125 – 1LX-15121-12-00 | JYA3XJW06MA40XXXX | 1991 | YZ125B1 | FITS 91-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 - 3XJ-W1441-01-00 | 1991 | YZ125B1 | FITS 89-96 YZ125 YZ250 - 3JD-14458-00-00 | 1991 | FITS 89-94 YZ125 YZ250, 91 WR250 - 4EW-26311-00-00 | 1991 | MIKUNI TM | 1991 | YZ125B1 | 1991 | FITS 89-92 YZ125 YZ250 - 3JD-22199-00-00 - 3JD-22147-00-00 - 3JD-22128-00-00 | 1991 | FITS 89-98 YZ250, 90-98 YZ125, 91 WR250, 89-90 YZ250WR, 98 WR400F - 3SP-25388-00-00 | FITS 89-92 YZ125 YZ250, 90-93 WR250, 92-93 WR500 - 3JD-22151-00-00 | FITS 91-92 YZ125 - 3XJ-16150-00-00 | FITS 89-93 | 1991 | FITS 91-92 YZ125 - 3XJ-16371-00-00 | FITS 91-92 YZ125 - 3XJ-16351-00-00 | FITS 90-93 YZ125 YZ250 - 3SR-82310-10-00 - F6T537 | FITS 91-92 YZ125 - 3XJ-11400-00-00 - 50.7mm stroke | 1991 | 8104 - ROD - FITS 86-96 YZ125 | 3XJ - FITS 91 YZ125 - 3XJ-11311-00-00 | 1991 | FITS 91 YZ125 3XJ-14610-00-00 | 1991 | FITS 91 YZ125 PY91125P | 1991 | 1991 | FITS 91 YZ125 - 3JD-11992-10-00 | FITS 89-94 96-98 YZ250, 90-91 YZ125, 91-97 WR250 | 1991 | FITS 88-91 YZ125 - 2VN-Y113F-00-00 | FITS 90-93 YZ125 3SR-11990-00-00 | 1991 | F3T81671 - FITS 90-91 | FITS 90-91 YZ125 YZ250, 91 WR250, 92 WR200 - 3SP-27411-00-00 - 3SP-27421-00-00 | 1991 | USD - 3S-L 3S-R - USD - 43MM CHROME OD - C/L 37 1/4" - UPPER 51.85MM - LOWER 56.6MM - BRAKE MOUNT C/L 78MM - AXLE CLAMP 20MM – M14 X 1.5 | 43MM X 55MM X 9.5/10.5/11 | FITS 91 YZ125 YZ250 WR250, 92-93 WR500 - 3XJ-2314J-L0-00 - 3XJ-2314H-L0-00 | N/A | 1991 | FITS 90-91 YZ125 YZ250. 92-93 WR500, 92 WR200, 91 WR250 - 3SP-2314F-L0-00 - 3SP-2314G-L0-00 | FITS 86-91 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 91-92 WR250, 85-86 TT600, 86 IT200, 86-87 TT350, 90-95 XT600 - 55U-25181-01-00 | HYDRAULIC | FITS 90-92 YZ125 YZ250, 91-93 WR250 - 3SP-2580T-00-00 | 1991 | FITS 90-92 YZ125 YZ250, 91-92 WR250, 92-93 WR500 - 3SP-2580T-00-00 | FITS 90-91 YZ125 YZ250, 91 WR250, 92-93 WR500 - 3SP-25872-00-00 | FITS 90-95 YZ125 YZ250, 91-96 WR250 - 3SP-25870-01-00 | 1991 | ROTOR OD 245MM, ID 86MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - FITS 90-91 YZ125 & YZ250, 91-93 WR250 - 3SP-2580T-00-00 | 1991 | N/A | 2HH00- GRAY - 15MM AXLE DIA - BRG TO BRG 86-87MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - FITS 90-91 YZ125 YZ250, 91 WR250, 92-93 WR500 - 3SP-25111-00-00 | 1991 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | FITS 89-92 YZ125 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 3XJ | 1991 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1991 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1991 | FITS 83-95 YZ250, 86-95 YZ125, 84-90 YZ490, 91-97 WR250, 92-93 WR500, 92 WR200 - 39X-21642-00-00 | FITS 86-91 YZ125, 87-91 YZ250, 85-90 YZ490, 91 WR250. 92-93 WR500 - 3XJ-23485-01-00 | FITS 91-92 94-03 YZ125 - 3XJ-16111-00-00 | FITS 86-92 YZ125, 92 WR200 | 1991 | FITS 91-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 - 3XJ-21711-01-00 | 1991 | N/A | N/A | FITS 91-92 YZ125 YZ250, 91-93 WR250 - 3XJ-2172A-00-00 | FITS 91-92 YZ125 YZ250, 91-93 WR250 - 3XJ-2172A-00-00 | 20MM - FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F - 3JD-25381-01-00 | 1991 | FITS 91-92 YZ125 YZ250 - 4DA-2580W-00-00 | 1991 | 1991 | FITS 91-92 YZ125 YZ250 WR250, 92-93 WR500 - 3XJ-25920-00-00 | FITS 90-02 YZ125 YZ250 - 3SP-2583V-00-00 | FITS 91 YZ125 YZ250 WR250, 92 WR500 - 3XJ-21611-01-00 | 1991 | FITS 90-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 - 3SP-25311-00-00 | 1991 | FITS 88-92 YZ125 – 2VN-13610-00-00 – C/L TO C/L HORIZONTAL 71MM, VERTICAL 57.5MM | FITS 91-92 YZ125 YZ250 - 3XJ-24770-00-00 | 1991 | 1991 | FITS 91-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 - 3XJ-21711-01-00 | FITS 91-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 - 3XJ-21721-01-00 | 1991 | N/A | N/A | FITS 86-95 YZ125 | 1991 | FITS 91-93 YZ125 | 1991 | FITS 91-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 - 3XJ-2217A-00-00 | 1991 | FITS 90-91 YZ125 - 3SR-85510-10-00 | FRAME STAY FITS 91 YZ125 YZ250 WR250 - 3XK-21123-00-UJ | 3SP - FITS 91-92 YZ125 YZ250, 91 WR250 - 3XJ-22110-01-00 | 1991 | FITS 86-97 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 97-97 WR250 - 1LX-22141-00-00 | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1991 | FITS 91-96 YZ125 - 3XJ-17411-00-00 | 1991 | 1991 | FITS 91-96 YZ125 - 3XJ-17421-00-00 | 1991 | FITS 90-02 YZ125 - 3SR-17231-00-00 | 1991 | 1991 | UPPER 51.9MM - LOWER 56.6MM - C/L 185MM | FITS 91 YZ250 – 3XK-23435-00-00 | 1991 | 1991 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1992 | YZ125D1 | 4DB-00 | FITS 92 YZ125 – 4DB-15111-00-00 | FITS 91-92 YZ125 – 1LX-15121-12-00 | 1992 | YZ125D1 | FITS 91-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 - 3XJ-W1441-01-00 | 1992 | YZ125D1 | FITS 89-96 YZ125 YZ250 - 3JD-14458-00-00 | 1992 | FITS 89-94 YZ125 YZ250, 91 WR250 - 4EW-26311-00-00 | 1992 | MIKUNI TM | 1992 | YZ125D1 | 1992 | FITS 89-92 YZ125 YZ250 - 3JD-22199-00-00 - 3JD-22147-00-00 - 3JD-22128-00-00 | 1992 | FITS 89-98 YZ250, 90-98 YZ125, 91 WR250, 89-90 YZ250WR, 98 WR400F - 3SP-25388-00-00 | FITS 89-92 YZ125 YZ250, 90-93 WR250, 92-93 WR500 - 3JD-22151-00-00 | FITS 91-92 YZ125 - 3XJ-16150-00-00 | FITS 89-93 | 1992 | FITS 91-92 YZ125 - 3XJ-16371-00-00 | FITS 91-92 YZ125 - 3XJ-16351-00-00 | FITS 90-93 YZ125 YZ250 - 3SR-82310-10-00 - F6T537 | FITS 91-92 YZ125 - 3XJ-11400-00-00 - 50.7mm stroke | 1992 | 8104 - ROD - FITS 86-96 YZ125 | 4DB - FITS 92 YZ125 - 4DB-11311-00-00 | 1992 | FITS 92 YZ125 - 4DB-14610-00-00 | 1992 | FITS 92 YZ125 - PY92125P | 1992 | 1992 | FITS 92-93 YZ125 - 4DB-11992-01-00 | 1992 | FITS 90-93 YZ125 3SR-11990-00-00 | 1992 | F4T800 - FITS 92-93 YZ125 - 4DB-85550-00-00 | 1992 | USD - CHROME OD 43MM - C/L 37 1/4" - AXLE CLAMP 22MM – M16 X 1.5 | 43MM X 55MM X 9.5/10.5/11 | N/A | 1992 | FITS 92-94 YZ125 YZ250 - 4DA-2314F-L0-00 - 4DA-2314G-L0-00 | FITS 92-97 WR250, 92-95 YZ125 YZ250 | HYDRAULIC | FITS 90-92 YZ125 YZ250, 91-93 WR250 - 3SP-2580T-00-00 | 1992 | FITS 90-92 YZ125 YZ250, 91-92 WR250, 92-93 WR500 - 3SP-2580T-00-00 | FITS 90-95 YZ125 YZ250, 91-96 WR250 - 3SP-25870-01-00 | 1992 | ROTOR OD 245MM ID 118.5MM - ROTOR 6 ON A 134MM BOLT CIRCLE - FITS 92-93 YZ125, YZ250, WR250 - 4EW-2582T-00-00 | FITS 92-95 YZ125, 92-96 YZ250 WR250 - 4DA-21511-00-00 | 1992 | FITS 92-99 YZ125 YZ250 | FITS 92 YZ125 YZ250, 92-93 WR250 - 4DA-25111-00-94 | 1992 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | FITS 89-92 YZ125 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 4DB FITS 92 YZ125 4DB-11111-00-00 | 1992 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1992 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1992 | FITS 83-95 YZ250, 86-95 YZ125, 84-90 YZ490, 91-97 WR250, 92-93 WR500, 92 WR200 - 39X-21642-00-00 | FITS 92-99 YZ125 YZ250 | FITS 91-92 94-03 YZ125 - 3XJ-16111-00-00 | FITS 86-92 YZ125, 92 WR200 | 1992 | FITS 91-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 - 3XJ-21711-01-00 | 1992 | N/A | N/A | FITS 91-92 YZ125 YZ250, 91-93 WR250 - 3XJ-2172A-00-00 | FITS 91-92 YZ125 YZ250, 91-93 WR250 - 3XJ-2172A-00-00 | 20MM - FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F - 3JD-25381-01-00 | 1992 | FITS 91-92 YZ125 YZ250 - 4DA-2580W-00-00 | 1992 | 1992 | FITS 91-92 YZ125 YZ250 WR250, 92-93 WR500 - 3XJ-25920-00-00 | FITS 90-02 YZ125 YZ250 - 3SP-2583V-00-00 | FITS 92 YZ125 YZ250, 92-93 WR250, 93 WR500 - 3XJ-21611-02-00 | 1992 | FITS 90-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 - 3SP-25311-00-00 | 1992 | FITS 88-92 YZ125 – 2VN-13610-00-00 – C/L TO C/L HORIZONTAL 71MM, VERTICAL 57.5MM | FITS 91-92 YZ125 YZ250 - 3XJ-24770-00-00 | 1992 | 1992 | FITS 91-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 - 3XJ-21711-01-00 | FITS 91-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 - 3XJ-21721-01-00 | 1992 | N/A | N/A | FITS 86-95 YZ125 | 1992 | FITS 91-93 YZ125 | 1992 | FITS 91-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 - 3XJ-2217A-00-00 | 1992 | FITS 92 YZ125 - 4DB-85510-00-00 | FRAME STAY FITS 92 YZ125 YZ250, 92-93 WR250 - 3XK-21123-00-T9 | 3SP - FITS 91-92 YZ125 YZ250, 91 WR250 - 3XJ-22110-01-00 | 1992 | FITS 86-97 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 97-97 WR250 - 1LX-22141-00-00 | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1992 | FITS 91-96 YZ125 - 3XJ-17411-00-00 | 1992 | 1992 | FITS 91-96 YZ125 - 3XJ-17421-00-00 | 1992 | FITS 90-02 YZ125 - 3SR-17231-00-00 | 1992 | 1992 | 1992 | 1992 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1993 | YZ125E1 | 4EX-00 | FITS 93 YZ125 – 4EX-15111-00-00 | FITS 93 YZ125 – 4EX-15121-00-00 | 1993 | YZ125E1 | FITS 93-94 YZ125 YZ250 -4EW-14411-02-00 | 1993 | YZ125E1 | FITS 89-96 YZ125 YZ250 - 3JD-14458-00-00 | 3XJ01 - FITS 92 YZ125 - 3XJ-14453-01-00 | 1993 | FITS 89-94 YZ125 YZ250, 91 WR250 - 4EW-26311-00-00 | 1993 | 1993 | YZ125E1 | 1993 | FITS 93 YZ125 - 4EX-85540-00-00 | 1993 | FITS 89-98 YZ250, 90-98 YZ125, 91 WR250, 89-90 YZ250WR, 98 WR400F - 3SP-25388-00-00 | FITS 93 YZ125 | FITS 89-93 | 1993 | FITS 93-01 YZ125 - 4EX-16371-00-00 | FITS 93-99 YZ125 - 4EX-16351-00-00 | FITS 90-93 YZ125 YZ250 - 3SR-82310-10-00 - F6T537 | FITS 93 YZ125 - 3XJ-11400-01-00 | 1993 | 8104 - ROD - FITS 86-96 YZ125 | 4EX - FITS 93 YZ125 - 4EX-11311-20-00 | 1993 | FITS 93 YZ 125 - 4EX-21425-00-00 | FITS 93 YZ125 - 4EX-21427-00-00 | FITS 93 YZ125 - 4EX-14610-01-00 | 1993 | FITS 93 YZ125 - PY93125P | 1993 | DRUM STYLE FITS 93 YZ125 - 4EX-1131A-00-00 | 1993 | FITS 92-93 YZ125 - 4DB-11992-01-00 | 1993 | FITS 90-93 YZ125 3SR-11990-00-00 | 1993 | F4T800 - FITS 92-93 YZ125 - 4DB-85550-00-00 | 1993 | USD – CHROME OD 43MM – LEFT 4EX-23102-L0-00, RIGHT 4EX-23103-L0-00 - AXLE CLAMP 22MM – M16 X 1.5 | 43MM X 55MM X 9.5/10.5/11 | N/A | 1993 | FITS 92-94 YZ125 YZ250 - 4DA-2314F-L0-00 - 4DA-2314G-L0-00 | FITS 92-97 WR250, 92-95 YZ125 YZ250 | HYDRAULIC | FITS 93 YZ125 YZ250 - 4EW-2580T-00-00 | 1993 | FITS 90-95 YZ125 YZ250, 91-96 WR250 - 3SP-25870-01-00 | 1993 | ROTOR OD 245MM ID 118.5MM - ROTOR 6 ON A 134MM BOLT CIRCLE - FITS 92-93 YZ125, YZ250, WR250 - 4EW-2582T-00-00 | FITS 92-95 YZ125, 92-96 YZ250 WR250 - 4DA-21511-00-00 | 1993 | FITS 92-99 YZ125 YZ250 | 145-FR - AXLE OD 17MM - BRG TO BRG 69-70MM - ROTOR BC 6 ON 133MM - FITS 93-95 YZ125 & YZ250, 94-97 WR250 - 36 SPOKES - 4EW-25111-00-00 | 1993 | 1.6 X 21 - FITS 93-98 YZ125 YZ250, 94-96 WR250, 98 YZ400F WR400F - 94416-21509-00 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | FITS 93-95 YZ125 YZ250 - 4EW-24110-00-00 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 4EX FITS 93 YZ125 4EX-11111-00-00 | 1993 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 93 YZ125 4DB-15620-02-00 | FITS 93 YZ125 1LX-15660-01-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1993 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1993 | FITS 83-95 YZ250, 86-95 YZ125, 84-90 YZ490, 91-97 WR250, 92-93 WR500, 92 WR200 - 39X-21642-00-00 | FITS 92-99 YZ125 YZ250 | FITS 93 YZ125 - 4EX-16111-00-00 | FITS 93 YZ125 YZ250 WR250 - 4EW-1240A-00-00 | 1993 | FITS 93-95 YZ125 YZ250, 94-95 WR250 - 4EW-21731-00-00 | FITS 93-95 YZ125 YZ250, 94-95 WR250 - 4EW-21741-00-00 | 1993 | N/A | N/A | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | 20MM - FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F - 3JD-25381-01-00 | 1993 | 1993 | 1993 | FITS 93 YZ125, 90-93 YZ250, 91-92 WR250, 92-93 WR500 - 3SP-27200-00-00 | FITS 90-02 YZ125 YZ250 - 3SP-2583V-00-00 | FITS 93-95 YZ125 YZ250, 94-97 WR250 - 4EW-21611-00-00 | FITS 93-95 YZ125 YZ250 | 1993 | 2VN00 - SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR BC 6 BOLTS ON A 132MM DIA - SPROCKET BC 6 ON A 175MM DIA - FITS 93-98 YZ125 & YZ250, 94-97 WR250, 98 YZ400F WR400F - 4EW-25311-00-00 | 1993 | FITS 93 YZ125 YZ250, 4EW-24770-10-00 | FITS 93-03 YZ125 -4EX-18531-00-00 4EX-18535-00-00 | 1993 | FITS 93-95 YZ125 YZ250, 94-97 WR250 - 4EW-2217A-00-00 | 4EW-2217F-00-00 - FITS 93-95 YZ125 YZ250, 94-97 WR250 - | 1993 | FITS 93-94 YZ125 YZ250, 94 WR250 - 4EW-21711-00-00 | FITS 93-94 YZ125 YZ250, 94 WR250 - 4EW-21721-00-00 | 1993 | N/A | N/A | FITS 86-95 YZ125 | 1993 | FITS 91-93 YZ125 | 1993 | 1993 | FITS 93 YZ125 - 4EX-85510-00-00 | 1993 | FITS 86-97 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 97-97 WR250 - 1LX-22141-00-00 | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1993 | FITS 91-96 YZ125 - 3XJ-17411-00-00 | 1993 | 1993 | FITS 93-02 YZ125 - 4EX-17151-00-00 | FITS 91-96 YZ125 - 3XJ-17421-00-00 | 1993 | FITS 90-02 YZ125 - 3SR-17231-00-00 | FITS 93-02 YZ125 - 4EX-17241-00-00 | 1993 | 1993 | 1993 | 1993 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1994 | YZ125F1 | 4JY-00 | FITS 94-95 YZ125 – 4JY-15111-00-00 | FITS 94-95 YZ125 – 4JY-15121-00-00 | 1994 | YZ125F1 | FITS 93-94 YZ125 YZ250 -4EW-14411-02-00 | 1994 | YZ125F1 | FITS 89-96 YZ125 YZ250 - 3JD-14458-00-00 | 4EX02 | 1994 | FITS 89-94 YZ125 YZ250, 91 WR250 - 4EW-26311-00-00 | 1994 | MIKUNI TM - FITS 94 YZ125 - 4JY-14101-00-00 | 1994 | YZ125F1 | 1994 | FITS 94 - 95 YZ125 - 4JY-85540-00-00 4PE-85540-00-00 | 1994 | FITS 89-98 YZ250, 90-98 YZ125, 91 WR250, 89-90 YZ250WR, 98 WR400F - 3SP-25388-00-00 | FITS 94-97 YZ125 YZ250 WR250 - 4EW-22151-01-00 | FITS 94-95 YZ125 - 4JY-16150-00-00 | FITS 94-97 YZ125 - 4JY-15431-00-00 | 1994 | FITS 93-01 YZ125 - 4EX-16371-00-00 | FITS 93-99 YZ125 - 4EX-16351-00-00 | FITS 94 YZ125 - 4JY-11400-00-00 - 54.5mm stroke | 1994 | 8104 - ROD - FITS 86-96 YZ125 | 4JY - FITS 94 YZ125 - 4JY-11311-00-00 | 1994 | FITS 94 YZ125 - 4JY-14610-00-00 | 1994 | FITS 94-95 YZ125 - PY94125P | 1994 | FITS 94 YZ125 LEFT 4JY-1131A-00-00, RIGHT 4JY-1132A-00-00 | 1994 | FITS 94-97 YZ125 - 4JY-11991-00-00 | 1994 | FITS 94-95 YZ125 4JY-11990-00-00 | 1994 | F4T806 FITS 94-95 YZ125 - 4JY-85550-00-00 | 1994 | KYB - USD - CHROME OD 43MM - C/L 36 3/4" - UPPER 51.9MM - LOWER 56.6MM - C/L OF BRAKE MOUNT 78MM - AXLE CLAMP 22MM – M16 X 1.5 | 43MM X 55MM X 9.5/10.5/11 | N/A | 1994 | FITS 92-94 YZ125 YZ250 - 4DA-2314F-L0-00 - 4DA-2314G-L0-00 | FITS 92-97 WR250, 92-95 YZ125 YZ250 | HYDRAULIC | NISSIN 3SP - FITS 94 YZ125 YZ250 WR250 - 4EW-2580T-01-00 | 1994 | FITS 90-95 YZ125 YZ250, 91-96 WR250 - 3SP-25870-01-00 | 1994 | ROTOR OD 245MM ID 118.5MM - ROTOR 6 ON A 134MM BOLT CIRCLE - FITS 94-96 YZ125 YZ250 WR250 - 4JX-2582T-00-00 | FITS 92-95 YZ125, 92-96 YZ250 WR250 - 4DA-21511-00-00 | 1994 | FITS 92-99 YZ125 YZ250 | 145-FR - AXLE OD 17MM - BRG TO BRG 69-70MM - ROTOR BC 6 ON 133MM - FITS 93-95 YZ125 & YZ250, 94-97 WR250 - 36 SPOKES - 4EW-25111-00-00 | 1994 | 1.6 X 21 - FITS 93-98 YZ125 YZ250, 94-96 WR250, 98 YZ400F WR400F - 94416-21509-00 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | FITS 93-95 YZ125 YZ250 - 4EW-24110-00-00 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 4JY FITS 94-95 YZ125 - 11111-00-00 | 1994 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 94-96 YZ125 1LX-15660-02-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1994 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1994 | FITS 83-95 YZ250, 86-95 YZ125, 84-90 YZ490, 91-97 WR250, 92-93 WR500, 92 WR200 - 39X-21642-00-00 | FITS 92-99 YZ125 YZ250 | FITS 91-92 94-03 YZ125 - 3XJ-16111-00-00 | FITS 94-95 YZ125 YZ250, 94-97 WR250 - 4EW-1240A-01-00 | 1994 | FITS 94-95 YZ125 | FITS 93-95 YZ125 YZ250, 94-95 WR250 - 4EW-21731-00-00 | FITS 93-95 YZ125 YZ250, 94-95 WR250 - 4EW-21741-00-00 | 1994 | N/A | N/A | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | 20MM - FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F - 3JD-25381-01-00 | 1994 | FITS 94 YZ125 YZ250, 94-97 WR250 - 4GY-2580W-00-00 | 1994 | 1994 | FITS 94-95 YZ125 YZ250, 94-97 WR250 - 4JX-27200-00-00 | FITS 90-02 YZ125 YZ250 - 3SP-2583V-00-00 | FITS 93-95 YZ125 YZ250, 94-97 WR250 - 4EW-21611-00-00 | FITS 93-95 YZ125 YZ250 | 1994 | 2VN00 - SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR BC 6 BOLTS ON A 132MM DIA - SPROCKET BC 6 ON A 175MM DIA - FITS 93-98 YZ125 & YZ250, 94-97 WR250, 98 YZ400F WR400F - 4EW-25311-00-00 | 1994 | FITS 94 YZ125, 250 4JX-24770-00-00 | FITS 93-03 YZ125 -4EX-18531-00-00 4EX-18535-00-00 | 1994 | SPRING THICKNESS: 11.2MM OD – SPRING OD 88.7MM – LENGTH AS MOUNTED 251MM – BODY OD 55.7MM – CHROME OD 16MM – UPPER TAB WIDTH 26MM (NO BUSHINGS) – HOLE ID 10MM – LOWER MOUNT WIDTH 23.3MM – HOLE ID 10MM – EYE TO EYE 492MM (19.375”) - 4JY-22210-10-00 – FITS 94 YZ125 | FITS 93-95 YZ125 YZ250, 94-97 WR250 - 4EW-2217A-00-00 | 4EW-2217F-00-00 - FITS 93-95 YZ125 YZ250, 94-97 WR250 - | 1994 | FITS 93-94 YZ125 YZ250, 94 WR250 - 4EW-21711-00-00 | FITS 93-94 YZ125 YZ250, 94 WR250 - 4EW-21721-00-00 | 1994 | N/A | N/A | FITS 86-95 YZ125 | 1994 | FITS 94-95 YZ125 | 1994 | 1994 | FITS 94-95 YZ125 - 4JY-85510-00-00 - BROWN TO RED 324-396 - WHITE TO GREEN 16-19 - WHITE GREEN TO WHITE RED 446-545 | PA6 GF45 - FITS 94-03 YZ125 - 4JY-15411-00-00 | FITS 94-95 YZ125, 94 YZ250 - 4EW-22110-02-00 | 1994 | FITS 86-97 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 97-97 WR250 - 1LX-22141-00-00 | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1994 | FITS 91-96 YZ125 - 3XJ-17411-00-00 | 1994 | 1994 | FITS 93-02 YZ125 - 4EX-17151-00-00 | FITS 91-96 YZ125 - 3XJ-17421-00-00 | 1994 | FITS 90-02 YZ125 - 3SR-17231-00-00 | FITS 93-02 YZ125 - 4EX-17241-00-00 | 1994 | 1994 | 4JX - FITS 94-95 YZ125, 94 YZ250, 94-97 WR250 - 4JX-23435-00-00 | 1994 | 1994 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
YEAR | TYPE | ENGINE ID | ENGINE CASE LEFT | ENGINE CASE RIGHT | VIN FRAME USA | YEAR | TYPE | AIR BOX | YEAR | TYPE | AIR BOX CAGE | AIR BOX TO CARBURETOR BOOT | CABLE CLUTCH | YEAR | CABLE FRONT BRAKE | CABLE THROTTLE | YEAR | CARBURETOR | YEAR | TYPE | CARBURETOR BOOT | YEAR | CDI | CHAIN GUIDE | CHAIN GUIDE PLASTIC INSERT (CHAIN SUPPORT) | YEAR | CHAIN PULLER BLOCKS | CHAIN SLIDER | CLUTCH BASKET | CLUTCH COVER | CLUTCH COVER INNER | YEAR | CLUTCH BOSS INNER | CLUTCH PRESSURE PLATE OUTER | CLUTCH PLATES FRICTION | CLUTCH PLATES METAL | COIL | CRANK SHAFT | YEAR | CRANK SHAFT (HOT RODS) | CYLINDER | YEAR | ENGINE MOUNTS UPPER | ENGINE MOUNTS LOWER | EXHAUST ARRESTOR (FMF TURBINE 2) | EXHAUST PIPE | YEAR | EXHAUST PIPE FMF RACING FATTY | EXHAUST PIPE PRO CIRCUIT PLATINUM | YEAR | EXHAUST VALVE | YEAR | EXHAUST VALVE COVER FRONT | EXHAUST VALVE COVER RIGHT | EXHAUST VALVE HOLDER LEFT | YEAR | EXHAUST VALVE HOLER RIGHT | EXHAUST VALVE LINKAGE (PUSH ROD ASY) | YEAR | FLY WHEEL ROTOR | FOOT PEGS | YEAR | FORK INFO | FORK SEAL SIZES | FORK CAP | FORK INTERNAL DAMPENER CYLINDER | FORK GUARDS | FORK GUARDS ACERBIS | YEAR | FORK GUARD MOUNTS | FORK OUTER TUBE ALUMINUM | FRONT AXLE | FRONT BRAKE BACKING PLATE | FRONT BRAKE CALIPER | YEAR | FRONT BRAKE CALIPER MOUNT | FRONT BRAKE HOSE | FRONT BRAKE MASTER CYLINDER | YEAR | FRONT BRAKE ROTOR | FRONT FENDER | YEAR | FRONT FENDER ACERBIS | FRONT HUB | YEAR | FRONT RIM | GAS CAP | GAS TANK | GOVERNOR PUSH ROD | GOVERNOR SHAFT AND GEAR | HEAD | YEAR | KICK IDLER GEAR | KICK LEVER | KICK LEVER SHAFT | KICK LEVER SHAFT GEAR | YEAR | KILL SWITCH | YEAR | MUD FLAP | NUMBER PLATE | NUMBER PLATE ACERBIS | OIL CAPACITY | PRIMARY CRANK GEAR | RADIATOR LEFT | RADIATOR RIGHT | YEAR | RADIATOR HOSE SETS | RADIATOR SHROUD LEFT | RADIATOR SHROUD RIGHT | YEAR | RADIATOR SHROUD LEFT ACERBIS | RADIATOR SHROUD RIGHT ACERBIS | RADIATOR SCREEN LEFT | RADIATOR SCREEN RIGHT | REAR AXLE | YEAR | REAR AXLE SPACERS COLLARS | REAR BRAKE BACKING PLATE | REAR BRAKE CALIPER | YEAR | REAR BRAKE CALIPER GUARD | YEAR | REAR BRAKE CALIPER MOUNT | REAR BRAKE CALIPER MOUNT | REAR BRAKE LEVER | REAR BRAKE LEVER BOLT | REAR BRAKE MASTER CYLINDER | REAR BRAKE TENSION BAR | REAR FENDER | REAR FENDER ACERBIS | YEAR | REAR HUB | YEAR | REED VALVE | SEAT | SHIFT FORK ALIGNMENT GUIDES RODS SHAFTS | YEAR | SHOCK | SHOCK ARM (RELAY ARM) | SHOCK ARM LINKAGE (CONNECTING ROD ) | YEAR | SHOCK SPRING | SIDE COVER LEFT | SIDE COVER RIGHT | YEAR | SIDE COVER LEFT ACERBIS | SIDE COVER RIGHT ACERBIS | SHIFT DRUM (CAM) | SHIFT FORKS | SHIFT LEVER | YEAR | SHIFT SHAFT | SHOCK | YEAR | SHOCK RELAY ARM | SHOCK ARM LINKAGE | YEAR | STATOR | STATOR COVER | SUB FRAME | SWING ARM | YEAR | SWING ARM PIVOT PIN | THROTTLE | YEAR | THROTTLE CABLE | TRANSMISSION | TRANSMISSION MAIN SHAFT | YEAR | TRANSMISSION MAIN SHAFT 2ND GEAR | TRANSMISSION MAIN SHAFT 3RD GEAR | TRANSMISSION MAIN SHAFT 4TH GEAR | YEAR | TRANSMISSION MAIN SHAFT 5TH GEAR | TRANSMISSION MAIN SHAFT 6TH GEAR | TRANSMISSION COUNTER (DRIVE) SHAFT | TRANSMISSION DRIVE SHAFT 1ST GEAR | YEAR | TRANSMISSION DRIVE SHAFT 2ND GEAR | TRANSMISSION DRIVE SHAFT 3RD GEAR | TRANSMISSION DRIVE SHAFT 4TH GEAR | YEAR | TRANSMISSION DRIVE SHAFT 5TH GEAR | TRANSMISSION DRIVE SHAFT 5TH GEAR | YEAR | TRIPLE TREE – LOWER | TRIPLE TREE - UPPER (CROWN) | YEAR | WATER PUMP COVER | WATER PUMP SHAFT | WATER PUMP IMPELLER | WIRE HARNESS | YEAR |
1995 | YZ125G1 | 4PE-00 | FITS 94-95 YZ125 – 4JY-15111-00-00 | FITS 94-95 YZ125 – 4JY-15121-00-00 | 1995 | YZ125G1 | FITS 95 YZ125 YZ250 - 4PE-14411-00-00 | 1995 | YZ125G1 | FITS 89-96 YZ125 YZ250 - 3JD-14458-00-00 | 1995 | FITS 95 YZ125 YZ250 - 4MX-26311-00-00 | 1995 | MIKUNI TM | 1995 | YZ125G1 | FITS 95-98 YZ125 - 71.5MM W X 58MM H | 1995 | FITS 94 - 95 YZ125 - 4JY-85540-00-00 4PE-85540-00-00 | 1995 | FITS 89-98 YZ250, 90-98 YZ125, 91 WR250, 89-90 YZ250WR, 98 WR400F - 3SP-25388-00-00 | FITS 94-97 YZ125 YZ250 WR250 - 4EW-22151-01-00 | FITS 94-95 YZ125 - 4JY-16150-00-00 | FITS 94-97 YZ125 - 4JY-15431-00-00 | 1995 | FITS 93-01 YZ125 - 4EX-16371-00-00 | FITS 93-99 YZ125 - 4EX-16351-00-00 | FITS 95 YZ125 - 4PE-11400-00-00 | 1995 | 8104 - ROD - FITS 86-96 YZ125 | 4PE - FITS 95 YZ125 - 4PE-11310-00-00 | 1995 | FITS 95 YZ125 - 4PE-14610-00-00 | 1995 | FITS 94-95 YZ125 - PY94125P | 1995 | 1995 | FITS 94-97 YZ125 - 4JY-11991-00-00 | 1995 | FITS 94-95 YZ125 4JY-11990-00-00 | 1995 | F4T806 FITS 94-95 YZ125 - 4JY-85550-00-00 | 1995 | KYB - USD - CHROME OD 43MM - C/L 36 7/8" - UPPER 51.9MM LOWER 57.4MM - C/L OF BRAKE MOUNT 78MM - AXLE CLAMP 22MM – M16 X 1.5 | 43MM X 55MM X 9.5/10.5/11 | N/A | 1995 | FITS 92-97 WR250, 92-95 YZ125 YZ250 | HYDRAULIC | FITS 95 YZ125 YZ250, 95-97 WR250 - 4MX-2580T-00-00 | 1995 | FITS 90-95 YZ125 YZ250, 91-96 WR250 - 3SP-25870-01-00 | 1995 | ROTOR OD 245MM ID 118.5MM - ROTOR 6 ON A 134MM BOLT CIRCLE - FITS 94-96 YZ125 YZ250 WR250 - 4JX-2582T-00-00 | FITS 92-95 YZ125, 92-96 YZ250 WR250 - 4DA-21511-00-00 | 1995 | FITS 92-99 YZ125 YZ250 | 145-FR - AXLE OD 17MM - BRG TO BRG 69-70MM - ROTOR BC 6 ON 133MM - FITS 93-95 YZ125 & YZ250, 94-97 WR250 - 36 SPOKES - 4EW-25111-00-00 | 1995 | 1.6 X 21 - FITS 93-98 YZ125 YZ250, 94-96 WR250, 98 YZ400F WR400F - 94416-21509-00 | FITS 82-95 YZ125 YZ250, 82-90 YZ490, 92-93 WR500 - 5X7-24611-01-00 | FITS 93-95 YZ125 YZ250 - 4EW-24110-00-00 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 4JY FITS 94-95 YZ125 - 11111-00-00 | 1995 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 94-96 YZ125 1LX-15660-02-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1995 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1995 | FITS 83-95 YZ250, 86-95 YZ125, 84-90 YZ490, 91-97 WR250, 92-93 WR500, 92 WR200 - 39X-21642-00-00 | FITS 92-99 YZ125 YZ250 | FITS 91-92 94-03 YZ125 - 3XJ-16111-00-00 | FITS 94-95 YZ125 YZ250, 94-97 WR250 - 4EW-1240A-01-00 | 1995 | FITS 94-95 YZ125 | FITS 93-95 YZ125 YZ250, 94-95 WR250 - 4EW-21731-00-00 | FITS 93-95 YZ125 YZ250, 94-95 WR250 - 4EW-21741-00-00 | 1995 | N/A | N/A | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | 20MM - FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F - 3JD-25381-01-00 | 1995 | FITS 95-96 YZ125 YZ250 - 4MX-2580W-00-00 | 1995 | FITS 95-02 YZ125 YZ250, 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 95-97 WR250, 98-00 WR400F, 01-02 WR250F WR426F - 4GY-27491-00-00 | 1995 | 4GY - FITS 95-97 YZ125 YZ250, 98 YZ400F WR400F - 4XL-2580W-00-00 - ONLY SOLD WITH THE CALIPER | FITS 94-95 YZ125 YZ250, 94-97 WR250 - 4JX-27200-00-00 | FITS 90-02 YZ125 YZ250 - 3SP-2583V-00-00 | FITS 93-95 YZ125 YZ250, 94-97 WR250 - 4EW-21611-00-00 | FITS 93-95 YZ125 YZ250 | 1995 | 2VN00 - SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR BC 6 BOLTS ON A 132MM DIA - SPROCKET BC 6 ON A 175MM DIA - FITS 93-98 YZ125 & YZ250, 94-97 WR250, 98 YZ400F WR400F - 4EW-25311-00-00 | 1995 | FITS 95 YZ125 YZ250 – 4MX-24770-00-00 | FITS 93-03 YZ125 -4EX-18531-00-00 4EX-18535-00-00 | 1995 | FITS 93-95 YZ125 YZ250, 94-97 WR250 - 4EW-2217A-00-00 | 4EW-2217F-00-00 - FITS 93-95 YZ125 YZ250, 94-97 WR250 - | 1995 | FITS 95 YZ125 YZ250, 95-97 WR250 - 4EW-21711-01-00 | FITS 95 YZ125 YZ250, 95-97 WR250 - 4EW-21721-01-00 | 1995 | N/A | N/A | FITS 86-95 YZ125 | 1995 | FITS 94-95 YZ125 | 1995 | 1995 | FITS 94-95 YZ125 - 4JY-85510-00-00 - BROWN TO RED 324-396 - WHITE TO GREEN 16-19 - WHITE GREEN TO WHITE RED 446-545 | PA6 GF45 - FITS 94-03 YZ125 - 4JY-15411-00-00 | FITS 94-95 YZ125, 94 YZ250 - 4EW-22110-02-00 | 1995 | FITS 86-97 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 97-97 WR250 - 1LX-22141-00-00 | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1995 | FITS 91-96 YZ125 - 3XJ-17411-00-00 | 1995 | 1995 | FITS 93-02 YZ125 - 4EX-17151-00-00 | FITS 91-96 YZ125 - 3XJ-17421-00-00 | 1995 | FITS 90-02 YZ125 - 3SR-17231-00-00 | FITS 93-02 YZ125 - 4EX-17241-00-00 | 1995 | 1995 | 4JX - FITS 94-95 YZ125, 94 YZ250, 94-97 WR250 - 4JX-23435-00-00 | 1995 | 1995 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1996 | YZ125H1 | 4SS-00 E101E-00XXXX | FITS 96 YZ125 - 4SS-15111-00-00 | FITS 96 YZ125 - 4SS-15121-00-00 | 1996 | YZ125H1 | FITS 96 YZ125 YZ250 - 4SS-14401-00-00 | 1996 | YZ125H1 | FITS 89-96 YZ125 YZ250 - 3JD-14458-00-00 | FITS 96-98 YZ125, 96-97 YZ250 | 1996 | FITS 96-98 YZ125 YZ250 - 4SS-26311-01-00 | 1996 | MIKUNI TMX FITS 96 YZ125 - 36MM | 1996 | YZ125H1 | FITS 95-98 YZ125 - 71.5MM W X 58MM H | 1996 | FITS 96 YZ125 | 1996 | FITS 89-98 YZ250, 90-98 YZ125, 91 WR250, 89-90 YZ250WR, 98 WR400F - 3SP-25388-00-00 | FITS 94-97 YZ125 YZ250 WR250 - 4EW-22151-01-00 | FITS 96-97 YZ125 - 4JY-16150-01-00 | FITS 96-01 YZ125 - 4JY-15415-00-00 | FITS 94-97 YZ125 - 4JY-15431-00-00 | 1996 | FITS 93-01 YZ125 - 4EX-16371-00-00 | FITS 93-99 YZ125 - 4EX-16351-00-00 | FITS 96-01 YZ125, 98 YZ80 - 3XJ-16324-00-00 | FITS 96-03 YZ125 - 4SS-82310-00-00 | FITS 96 YZ125 - 4SS-11400-00-0 | 1996 | 8104 - ROD - FITS 86-96 YZ125 | 4SS - FITS 96 YZ125 YZ80 - 4SS-11311-00-00 | 1996 | 1996 | FITS 96-98 YZ125 - PY96125P | 1996 | FITS 96-98 YZ125 | 1996 | FITS 96-04 YZ125 - 4SS-1131M-00-00 | FITS 94-97 YZ125 - 4JY-11991-00-00 | 1996 | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | 1996 | F4SS 00 7X7 FITS 96-01 YZ125, 02-09 YZ85 | 1996 | Y4SS-L Y4SS-R - USD - CHROME OD 46MM - C/L 36 3/4" - UPPER 53.9MM - LOWER 58.9MM - C/L OF BRAKE MOUNT 78MM - AXLE 20MM & 25MM | 46MM X 58MM X 10.5 | FITS 96-04 YZ125-YZ250 YZ250F-YZ450 | 1996 | FITS 96-03 YZ125 YZ250, 01-03 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 4SS-2314G-L0-00 5DH-2314F-L0-00 | FITS 96-98 YZ125 & YZ250 | HYDRAULIC | FITS 96-97 YZ125 YZ250 - 4SS-2580T-00-00 | 1996 | ASSEMBLY FITS 96-97 YZ125 YZ250 - 4SS-2580T-00-00 | FITS 96-99 YZ125 YZ250, 97 WR250, 97-98 YZ80, 98-99 YZ400F - 4SS-W2587-00-00 | 1996 | ROTOR OD 245MM ID 118.5MM - ROTOR 6 ON A 134MM BOLT CIRCLE - FITS 94-96 YZ125 YZ250 WR250 - 4JX-2582T-00-00 | 1996 | FITS 92-99 YZ125 YZ250 | 140 R-Y - 145-FR Y - AXLE OD 20MM - BRG TO BRG 68MM - ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 96-00 YZ125 YZ250, 98-99 YZ400F, 00 YZ426F - 4SS-25111-00-00 | 1996 | 1.6 X 21 - FITS 93-98 YZ125 YZ250, 94-96 WR250, 98 YZ400F WR400F - 94416-21509-00 | FITS 96 YZ125 YZ250 - 4SS-24110-00-00 - CLARKE MFG 96-01 YZ125 YZ250 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 4SS FITS 96-97 YZ125 - 4SS-11111-00-00 | 1996 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 94-96 YZ125 1LX-15660-02-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1996 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1996 | FITS 96-00 YZ125 YZ250, 93-01 YZ80, 02-11 YZ85, 00-04 TTR125 - 4ES-21642-00-00 | FITS 92-99 YZ125 YZ250 | FITS 91-92 94-03 YZ125 - 3XJ-16111-00-00 | FITS 96-01 YZ125 – 4SS-1240A-00-00 | FITS 96-01 YZ125 – 4SS-12461-00-00 | 1996 | FITS 96-97 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-97 YZ125 YZ250 - 4SS-21721-00-00 | 1996 | FITS 96-01 YZ125 YZ250 | FITS 96-01 YZ125 YZ250 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | 20MM - FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F - 3JD-25381-01-00 | 1996 | FITS 95-96 YZ125 YZ250 - 4MX-2580W-00-00 | 1996 | FITS 95-02 YZ125 YZ250, 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 95-97 WR250, 98-00 WR400F, 01-02 WR250F WR426F - 4GY-27491-00-00 | 1996 | 4GY - FITS 95-97 YZ125 YZ250, 98 YZ400F WR400F - 4XL-2580W-00-00 - ONLY SOLD WITH THE CALIPER | FITS 96-00 YZ125 YZ250, 98-99 YZ400F, 98-99 WR400F - 4SS-27217-00-00 | FITS 90-02 YZ125 YZ250 - 3SP-2583V-00-00 | FITS 96-97 YZ125 YZ250 - 4SS-21611-00-00 | FITS 95-01 YZ125 YZ250 | 1996 | 2VN00 - SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR BC 6 BOLTS ON A 132MM DIA - SPROCKET BC 6 ON A 175MM DIA - FITS 93-98 YZ125 & YZ250, 94-97 WR250, 98 YZ400F WR400F - 4EW-25311-00-00 | 1996 | FITS 96-99 YZ125 - 4SS-13610-00-00 - CLICK HERE FOR MEASUREMENTS | 4SS - FITS 96-97 YZ125 YZ250 - 4SS-24770-00-00 - SDG 96-01 YZ125 AND YZ250 | FITS 93-03 YZ125 -4EX-18531-00-00 4EX-18535-00-00 | 1996 | FITS 96-97 YZ125 YZ250 - 4SS-2217A-00-00 | FITS 96-97 YZ125 YZ250 - 4SS-2217F-00-00 | 1996 | FITS 96-01 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-01 YZ125 YZ250 - 4SS-21721-00-00 | 1996 | FITS 96-01 YA125 YZ250 | FITS 96-01 YA125 YZ250 | FITS 96-01 YZ125 | FITS 96-03 YZ125, 96-98 YZ250, 96-97 WR250 - 4SS-18110-00-00 | 1996 | 1996 | 1996 | 4SS-00 FITS 96-04 YZ125 - white/red white/blued 248-372 black/red green/white 720-1080, green/blue black 44-66 - 4SS-85560-02-00 | PA6 GF45 - FITS 94-03 YZ125 - 4JY-15411-00-00 | FITS 96 YZ125 - 4SS-21190-00-UJ | 1996 | FITS 86-97 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 97-97 WR250 - 1LX-22141-00-00 | 1996 | FITS 91-96 YZ125 - 3XJ-17411-00-00 | 1996 | 1996 | FITS 93-02 YZ125 - 4EX-17151-00-00 | FITS 91-96 YZ125 - 3XJ-17421-00-00 | 1996 | FITS 90-02 YZ125 - 3SR-17231-00-00 | FITS 93-02 YZ125 - 4EX-17241-00-00 | 1996 | 1996 | FITS 96-99 YZ125 YZ250, 98-99 YZ400F - 4SS-23435-00-00 | 1996 | 1996 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
1997 | YZ125J1 | 4XM-00 | FITS 97 YZ125 – 4XM-15111-00-00 | FITS 97 YZ125 – 4XM-15121-00-00 | JYA4XMW07VA00XXXX | 1997 | YZ125J1 | FITS 97 YZ125 YZ250 - 4SS-14401-01-00 | 1997 | YZ125J1 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | FITS 96-98 YZ125, 96-97 YZ250 | 1997 | FITS 96-98 YZ125 YZ250 - 4SS-26311-01-00 | 1997 | MIKUNI TMX | 1997 | YZ125J1 | FITS 95-98 YZ125 - 71.5MM W X 58MM H | 1997 | FITS 97-99 YZ125 | FITS 97-02 YZ125, YZ250, 98-00 WR400F, 98-99 YZ400F, 00-02 YZ426F, 01-02 WR426F | 1997 | FITS 89-98 YZ250, 90-98 YZ125, 91 WR250, 89-90 YZ250WR, 98 WR400F - 3SP-25388-00-00 | FITS 94-97 YZ125 YZ250 WR250 - 4EW-22151-01-00 | FITS 96-97 YZ125 - 4JY-16150-01-00 | FITS 96-01 YZ125 - 4JY-15415-00-00 | FITS 94-97 YZ125 - 4JY-15431-00-00 | 1997 | FITS 93-01 YZ125 - 4EX-16371-00-00 | FITS 93-99 YZ125 - 4EX-16351-00-00 | FITS 96-01 YZ125, 98 YZ80 - 3XJ-16324-00-00 | FITS 96-03 YZ125 - 4SS-82310-00-00 | FITS 97 YZ125 - 4XM-11400-00-00 | 1997 | 4035 - CRANK - FITS 97-00 YZ125 | 4SS - FITS 97 YZ125 - 4SS-11311-01-00 | 1997 | FITS 97-01 YZ125 | 1997 | FITS 96-98 YZ125 - PY96125P | 1997 | FITS 96-98 YZ125 | 1997 | FITS 96-04 YZ125 - 4SS-1131M-00-00 | FITS 94-97 YZ125 - 4JY-11991-00-00 | 1997 | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | 1997 | F4SS 00 - 75MM OD - 61.4MM ID FITS 96-01 YZ125, 02-09 YZ85 - 4SS-85550-00-00 4SS-85550-11-00 | 1997 | USD - CHROME OD 46MM - C/L 36 3/4" - UPPER 53.9MM - LOWER 58.9MM - C/L OF BRAKE MOUNT 78MM - AXLE 20MM & 25MM | 46MM X 58MM X 10.5 | FITS 96-04 YZ125-YZ250 YZ250F-YZ450 | 1997 | FITS 96-03 YZ125 YZ250, 01-03 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 4SS-2314G-L0-00 5DH-2314F-L0-00 | FITS 96-98 YZ125 & YZ250 | HYDRAULIC | FITS 96-97 YZ125 YZ250 - 4SS-2580T-00-00 | 1997 | ASSEMBLY FITS 96-97 YZ125 YZ250 - 4SS-2580T-00-00 | FITS 96-99 YZ125 YZ250, 97 WR250, 97-98 YZ80, 98-99 YZ400F - 4SS-W2587-00-00 | 1997 | ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 97-01 YZ125 YZ250, 97 WR250Z, 98-99 YZ400F, 99-00 WR400F, 00 YZ426F - 4XM-2582T-00-00 | FITS 97 YZ125 YZ250 WR250 - 4DA-21511-10-00 | 1997 | FITS 92-99 YZ125 YZ250 | 140 R-Y - 145-FR Y - AXLE OD 20MM - BRG TO BRG 68MM - ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 96-00 YZ125 YZ250, 98-99 YZ400F, 00 YZ426F - 4SS-25111-00-00 | 1997 | 1.6 X 21 - FITS 93-98 YZ125 YZ250, 94-96 WR250, 98 YZ400F WR400F - 94416-21509-00 | FITS 97 YZ125 YZ250 - 4SS-24110-01-00 - CLARKE MFG 96-01 YZ125 YZ250 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 4SS FITS 96-97 YZ125 - 4SS-11111-00-00 | 1997 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1997 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1997 | FITS 96-00 YZ125 YZ250, 93-01 YZ80, 02-11 YZ85, 00-04 TTR125 - 4ES-21642-00-00 | FITS 92-99 YZ125 YZ250 | FITS 91-92 94-03 YZ125 - 3XJ-16111-00-00 | FITS 96-01 YZ125 – 4SS-1240A-00-00 | FITS 96-01 YZ125 – 4SS-12461-00-00 | 1997 | FITS 96-97 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-97 YZ125 YZ250 - 4SS-21721-00-00 | 1997 | FITS 96-01 YZ125 YZ250 | FITS 96-01 YZ125 YZ250 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | 20MM - FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F - 3JD-25381-01-00 | 1997 | FITS 97 YZ125 - 4XM-2580W-00-00 | 1997 | FITS 95-02 YZ125 YZ250, 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 95-97 WR250, 98-00 WR400F, 01-02 WR250F WR426F - 4GY-27491-00-00 | 1997 | 4GY - FITS 95-97 YZ125 YZ250, 98 YZ400F WR400F - 4XL-2580W-00-00 - ONLY SOLD WITH THE CALIPER | FITS 97-04 YZ125 YZ250, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F, 01-04 YZ250F WR250F - 4XM-27200-00-00 | FITS 96-00 YZ125 YZ250, 98-99 YZ400F, 98-99 WR400F - 4SS-27217-00-00 | FITS 90-02 YZ125 YZ250 - 3SP-2583V-00-00 | FITS 96-97 YZ125 YZ250 - 4SS-21611-00-00 | FITS 95-01 YZ125 YZ250 | 1997 | 2VN00 - SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR BC 6 BOLTS ON A 132MM DIA - SPROCKET BC 6 ON A 175MM DIA - FITS 93-98 YZ125 & YZ250, 94-97 WR250, 98 YZ400F WR400F - 4EW-25311-00-00 | 1997 | FITS 96-99 YZ125 - 4SS-13610-00-00 - CLICK HERE FOR MEASUREMENTS | 4SS - FITS 96-97 YZ125 YZ250 - 4SS-24770-00-00 - SDG 96-01 YZ125 AND YZ250 | FITS 93-03 YZ125 -4EX-18531-00-00 4EX-18535-00-00 | 1997 | FITS 96-97 YZ125 YZ250 - 4SS-2217A-00-00 | FITS 96-97 YZ125 YZ250 - 4SS-2217F-00-00 | 1997 | FITS 96-01 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-01 YZ125 YZ250 - 4SS-21721-00-00 | 1997 | FITS 96-01 YA125 YZ250 | FITS 96-01 YA125 YZ250 | FITS 96-01 YZ125 | FITS 96-03 YZ125, 96-98 YZ250, 96-97 WR250 - 4SS-18110-00-00 | 1997 | 1997 | 1997 | 4SS-00 FITS 96-04 YZ125 - white/red white/blued 248-372 black/red green/white 720-1080, green/blue black 44-66 - 4SS-85560-02-00 | PA6 GF45 - FITS 94-03 YZ125 - 4JY-15411-00-00 | FITS 97 YZ125 & YZ250 - 4XM-21190-00-2F | FITS 97 YZ125 - 4XM-22110-00-00 | 1997 | FITS 86-97 YZ125 YZ250, 86-90 YZ490, 92-93 WR500, 97-97 WR250 - 1LX-22141-00-00 | 1997 | FITS 97-02 YZ125 - 4XM-17411-00-00 | 1997 | FITS 97-02 YZ125 - 4XM-17121-00-00 | FITS 97-02 YZ125 - 4EX-17131-01-00 | 1997 | FITS 93-02 YZ125 - 4EX-17151-00-00 | FITS 97-02 YZ125 - 4XM-17161-00-00 | FITS 97-98 YZ125 - 4XM-17421-00-00 | FITS 97-00 YZ125 - 4XM-17211-00-00 | 1997 | FITS 92-02 YZ125 - 4XM-17221-00-00 | FITS 90-02 YZ125 - 3SR-17231-00-00 | FITS 93-02 YZ125 - 4EX-17241-00-00 | 1997 | FITS 97-99 YZ125 - 4EX-17251-01-00 | FITS 97-99 YZ125 - 4XM-17261-00-00 | 1997 | FITS 96-99 YZ125 YZ250, 98-99 YZ400F - 4SS-23435-00-00 | 1997 | 1997 | |||||||||||||||||||||||||||||||||||||||||
1998 | YZ125K1 | 5DH-00 E101E-0000XX | FITS 98 YZ125 – 5DH-15111-00-00 | FITS 98 YZ125 – 5DH-15121-00-00 | JYACE01CWA000XXXX | 1998 | YZ125K1 | FITS 98-99 YZ125 YZ250 - 4SS-14401-02-00 | 1998 | YZ125K1 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | FITS 96-98 YZ125, 96-97 YZ250 | 1998 | FITS 96-98 YZ125 YZ250 - 4SS-26311-01-00 | 1998 | MIKUNI TMX - FITS 98 YZ125 - 36MM ID - 5DH-14101-10-00 - CLICK HERE FOR MEASUREMENTS | 1998 | YZ125K1 | FITS 95-98 YZ125 - 71.5MM W X 58MM H | 1998 | FITS 97-99 YZ125 | FITS 97-02 YZ125, YZ250, 98-00 WR400F, 98-99 YZ400F, 00-02 YZ426F, 01-02 WR426F | 1998 | FITS 89-98 YZ250, 90-98 YZ125, 91 WR250, 89-90 YZ250WR, 98 WR400F - 3SP-25388-00-00 | FITS 98-01 yz125 - 4JY-16150-02-00 | FITS 96-01 YZ125 - 4JY-15415-00-00 | FITS 98-04 YZ125 - 4JY-15431-14-00 | 1998 | FITS 93-01 YZ125 - 4EX-16371-00-00 | FITS 93-99 YZ125 - 4EX-16351-00-00 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | FITS 96-01 YZ125, 98 YZ80 - 3XJ-16324-00-00 | FITS 96-03 YZ125 - 4SS-82310-00-00 | FITS 98-00 YZ125 - 5DH-11400-00-00 | 1998 | 4035 - CRANK - FITS 97-00 YZ125 | 4SS - FITS 98 YZ125 YZ80 - 4SS-11311-10-00 | 1998 | FITS 97-01 YZ125 | 1998 | FITS 96-98 YZ125 - PY96125P | 1998 | FITS 96-98 YZ125 | 1998 | FITS 96-04 YZ125 - 4SS-1131M-00-00 | FITS 98-04 YZ125 - 4JY-11991-01-00 | 1998 | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | 1998 | F4SS 00 - 75MM OD - 61.4MM ID FITS 96-01 YZ125, 02-09 YZ85 - 4SS-85550-00-00 4SS-85550-11-00 | 1998 | KYB - Y5DH-L Y5DH-R – USD - CHROME OD 46MM - 36 7/8" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE MOUNT HOLES 102MM – AXLE CLAMPS 20 & 25MM | 46MM X 58MM X 10.5 | FITS 96-04 YZ125-YZ250 YZ250F-YZ450 | 1998 | FITS 96-03 YZ125 YZ250, 01-03 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 4SS-2314G-L0-00 5DH-2314F-L0-00 | FITS 96-98 YZ125 & YZ250 | HYDRAULIC | FITS 98-00 YZ125 YZ250 WR400F, 98-99 YZ400F, 00 YZ426F - 5DH-2580T-00-00 | 1998 | NISSIN - 555 - 98-00 YZ125 YZ250 WR400F, 98-99 YZ400F, 00 YZ426F - 5DH-2580T-00-00 | FITS 96-99 YZ125 YZ250, 97 WR250, 97-98 YZ80, 98-99 YZ400F - 4SS-W2587-00-00 | 1998 | ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 97-01 YZ125 YZ250, 97 WR250Z, 98-99 YZ400F, 99-00 WR400F, 00 YZ426F - 4XM-2582T-00-00 | FITS 98-99 YZ125 YZ250 YZ400F - 4DA-21511-20-00 | 1998 | FITS 92-99 YZ125 YZ250 | 140 R-Y - 145-FR Y - AXLE OD 20MM - BRG TO BRG 68MM - ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 96-00 YZ125 YZ250, 98-99 YZ400F, 00 YZ426F - 4SS-25111-00-00 | 1998 | 1.6 X 21 - FITS 93-98 YZ125 YZ250, 94-96 WR250, 98 YZ400F WR400F - 94416-21509-00 | FITS 98-00 YZ125, 98 YZ250 - 4SS-24110-10-00 - CLARKE MFG 96-01 YZ125 YZ250 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 4JY - FITS 98-00 YZ125 - 11111-01-00 | 1998 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1998 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1998 | FITS 96-00 YZ125 YZ250, 93-01 YZ80, 02-11 YZ85, 00-04 TTR125 - 4ES-21642-00-00 | FITS 92-99 YZ125 YZ250 | FITS 91-92 94-03 YZ125 - 3XJ-16111-00-00 | FITS 96-01 YZ125 – 4SS-1240A-00-00 | FITS 96-01 YZ125 – 4SS-12461-00-00 | 1998 | 1998 | FITS 96-01 YZ125 YZ250 | FITS 96-01 YZ125 YZ250 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | 20MM - FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F - 3JD-25381-01-00 | 1998 | FITS 98 YZ125 YZ250 - 5DH-2580W-00-00 | 1998 | FITS 95-02 YZ125 YZ250, 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 95-97 WR250, 98-00 WR400F, 01-02 WR250F WR426F - 4GY-27491-00-00 | 1998 | 5DH - FITS 98 YZ125 YZ250 - 5DH-2580W-00-00 - ONLY SOLD WITH THE CALIPER | FITS 97-04 YZ125 YZ250, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F, 01-04 YZ250F WR250F - 4XM-27200-00-00 | FITS 96-00 YZ125 YZ250, 98-99 YZ400F, 98-99 WR400F - 4SS-27217-00-00 | FITS 90-02 YZ125 YZ250 - 3SP-2583V-00-00 | FITS 98-01 YZ125 YZ125, 98-02 YZ250, 98-99 YZ400F, 00-02 YZ426F | FITS 95-01 YZ125 YZ250 | 1998 | 2VN00 - SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR BC 6 BOLTS ON A 132MM DIA - SPROCKET BC 6 ON A 175MM DIA - FITS 93-98 YZ125 & YZ250, 94-97 WR250, 98 YZ400F WR400F - 4EW-25311-00-00 | 1998 | FITS 96-99 YZ125 - 4SS-13610-00-00 - CLICK HERE FOR MEASUREMENTS | 4SS - FITS 98-00 YZ125 YZ250 - 5DH-24770-00-00 - SDG 96-01 YZ125 AND YZ250 | FITS 93-03 YZ125 -4EX-18531-00-00 4EX-18535-00-00 | 1998 | FITS 98 YZ125 YZ250 YZ400F WR400F - 5DH-2217A-00-00 | FITS 98-99 YZ125 YZ250 YZ400F WR400F - 5DH-2217F-00-00 | 1998 | FITS 96-01 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-01 YZ125 YZ250 - 4SS-21721-00-00 | 1998 | FITS 96-01 YA125 YZ250 | FITS 96-01 YA125 YZ250 | FITS 96-01 YZ125 | FITS 96-03 YZ125, 96-98 YZ250, 96-97 WR250 - 4SS-18110-00-00 | 1998 | 1998 | FITS 98-99 YZ125 YZ250 YZ400F WR400F - 5DH-2217F-00-00 | 1998 | 4SS-00 FITS 96-04 YZ125 - white/red white/blued 248-372 black/red green/white 720-1080, green/blue black 44-66 - 4SS-85560-02-00 | PA6 GF45 - FITS 94-03 YZ125 - 4JY-15411-00-00 | FITS 98-99 YZ125 YZ250 - 5DH-21190-00-P0 | 5ET - FITS 98 YZ125 YZ250 - 5DH-22110-00-00 | 1998 | FITS 98-01 YZ125 YZ250, 01 YZ250F WR250F WR426F, 98-99 YZ400F, 00-01 YZ426F, 98-00 WR400F 5DH-22141-00-00 | 1998 | FITS 97-02 YZ125 - 4XM-17411-00-00 | 1998 | FITS 97-02 YZ125 - 4XM-17121-00-00 | FITS 97-02 YZ125 - 4EX-17131-01-00 | 1998 | FITS 93-02 YZ125 - 4EX-17151-00-00 | FITS 97-02 YZ125 - 4XM-17161-00-00 | FITS 97-98 YZ125 - 4XM-17421-00-00 | FITS 97-00 YZ125 - 4XM-17211-00-00 | 1998 | FITS 92-02 YZ125 - 4XM-17221-00-00 | FITS 90-02 YZ125 - 3SR-17231-00-00 | FITS 93-02 YZ125 - 4EX-17241-00-00 | 1998 | FITS 97-99 YZ125 - 4EX-17251-01-00 | FITS 97-99 YZ125 - 4XM-17261-00-00 | 1998 | FITS 96-99 YZ125 YZ250, 98-99 YZ400F - 4SS-23435-00-00 | 1998 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 98-01 YZ125 | 1998 | ||||||||||||||||||||||||||||||||||||||||
1999 | YZ125L1 | 5ET-00 E105E-00XXXX | FITS 99-00 YZ125 – 5ET-15111-00-00 | FITS 99-00 YZ125 – 5ET-15121-00-00 | JYACE03C2XA00XXXX | 1999 | YZ125L1 | FITS 98-99 YZ125 YZ250 - 4SS-14401-02-00 | 1999 | YZ125L1 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | 1999 | 1999 | MIKUNI 36MM | 1999 | YZ125L1 | 5ET - 2 3/4" X 2 3/8" | 1999 | FITS 97-99 YZ125 | FITS 97-02 YZ125, YZ250, 98-00 WR400F, 98-99 YZ400F, 00-02 YZ426F, 01-02 WR426F | 1999 | FITS 99-01 YZ250 YZ125, 99 YZ400F, 99-00 WR400F, 00-01 YZ426F, 01 WR426F - 5ET-25388-00-00 5ET-25389-00-00 | FITS 98-01 yz125 - 4JY-16150-02-00 | FITS 96-01 YZ125 - 4JY-15415-00-00 | FITS 98-04 YZ125 - 4JY-15431-14-00 | 1999 | FITS 93-01 YZ125 - 4EX-16371-00-00 | FITS 93-99 YZ125 - 4EX-16351-00-00 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | FITS 96-01 YZ125, 98 YZ80 - 3XJ-16324-00-00 | FITS 96-03 YZ125 - 4SS-82310-00-00 | FITS 98-00 YZ125 - 5DH-11400-00-00 | 1999 | 4035 - CRANK - FITS 97-00 YZ125 | 5ET – FITS 99 YZ125 - 5ET-11311-00-00 | 1999 | FITS 97-01 YZ125 | 1999 | 20150 | 1999 | FITS 1999 YZ125 | 1999 | FITS 96-04 YZ125 - 4SS-1131M-00-00 | FITS 98-04 YZ125 - 4JY-11991-01-00 | 1999 | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | 1999 | F4SS 00 - 75MM OD - 61.4MM ID FITS 96-01 YZ125, 02-09 YZ85 - 4SS-85550-00-00 4SS-85550-11-00 | FITS 99-03 YZ125 YZ250, 99 YZ400F, 00-02 YZ426F, 03 YZ450F, 01-06 WR250F, 99-00 WR400F, 01-02 WR426F, 03-06 WR450F - 5ET-27411-00-00 5ET-27421-00-00 | 1999 | KYB - Y5DH-L Y5DH-R – USD - CHROME OD 46MM - 36 7/8" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE MOUNT HOLES 102MM – AXLE CLAMPS 20 & 25MM | 46MM X 58MM X 10.5 | FITS 96-04 YZ125-YZ250 YZ250F-YZ450 | 1999 | FITS 96-03 YZ125 YZ250, 01-03 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 4SS-2314G-L0-00 5DH-2314F-L0-00 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 YZ250F WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | HYDRAULIC | FITS 98-00 YZ125 YZ250 WR400F, 98-99 YZ400F, 00 YZ426F - 5DH-2580T-00-00 | 1999 | NISSIN - 555 - 98-00 YZ125 YZ250 WR400F, 98-99 YZ400F, 00 YZ426F - 5DH-2580T-00-00 | FITS 96-99 YZ125 YZ250, 97 WR250, 97-98 YZ80, 98-99 YZ400F - 4SS-W2587-00-00 | 1999 | ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 97-01 YZ125 YZ250, 97 WR250Z, 98-99 YZ400F, 99-00 WR400F, 00 YZ426F - 4XM-2582T-00-00 | FITS 98-99 YZ125 YZ250 YZ400F - 4DA-21511-20-00 | 1999 | FITS 92-99 YZ125 YZ250 | 140 R-Y - 145-FR Y - AXLE OD 20MM - BRG TO BRG 68MM - ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 96-00 YZ125 YZ250, 98-99 YZ400F, 00 YZ426F - 4SS-25111-00-00 | 1999 | FITS 99-04 YZ125 YZ250, 01-04 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 98-00 WR400F, 01-02 WR426F - 5BE-25181-00-00 | FITS 98-00 YZ125, 98 YZ250 - 4SS-24110-10-00 - CLARKE MFG 96-01 YZ125 YZ250 | FITS 99-05 YZ250 – 5CU-11990-00-00 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 4JY - FITS 98-00 YZ125 - 11111-01-00 | 1999 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 1999 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 1999 | FITS 96-00 YZ125 YZ250, 93-01 YZ80, 02-11 YZ85, 00-04 TTR125 - 4ES-21642-00-00 | FITS 92-99 YZ125 YZ250 | FITS 91-92 94-03 YZ125 - 3XJ-16111-00-00 | FITS 96-01 YZ125 – 4SS-1240A-00-00 | FITS 96-01 YZ125 – 4SS-12461-00-00 | 1999 | FITS 98-01 YZ250 YZ125 - 5ET-21730-10-00 | FITS 99-01 YZ125 YZ250 - 5ET-21740-10-00 | 1999 | FITS 96-01 YZ125 YZ250 | FITS 96-01 YZ125 YZ250 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 1999 | FITS 99-01 YZ125 YZ250, 99 YZ400F, 00-01 YZ426F, 99-00 WR400F, 01 YZ250F WR250F WR426F - 5ET-25383-00-00 | FITS 99-01 YZ125 YZ250, 99 YZ400F, 00-01 YZ426F, 99-00 WR400F, 01 YZ250F WR426F - 5GR-2580W | 1999 | FITS 95-02 YZ125 YZ250, 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 95-97 WR250, 98-00 WR400F, 01-02 WR250F WR426F - 4GY-27491-00-00 | 1999 | FITS 99-01 YZ125 YZ250, 99 YZ400F, 00-01 YZ426F, 99-00 WR400F, 01 YZ250F WR250F WR426F - SOLD W/ CALIPER - 5GR-2580W-00-00 | FITS 97-04 YZ125 YZ250, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F, 01-04 YZ250F WR250F - 4XM-27200-00-00 | FITS 96-00 YZ125 YZ250, 98-99 YZ400F, 98-99 WR400F - 4SS-27217-00-00 | FITS 90-02 YZ125 YZ250 - 3SP-2583V-00-00 | FITS 98-01 YZ125 YZ125, 98-02 YZ250, 98-99 YZ400F, 00-02 YZ426F | FITS 95-01 YZ125 YZ250 | 1999 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 1999 | FITS 96-99 YZ125 - 4SS-13610-00-00 - CLICK HERE FOR MEASUREMENTS | 4SS - FITS 98-00 YZ125 YZ250 - 5DH-24770-00-00 - SDG 96-01 YZ125 AND YZ250 | FITS 93-03 YZ125 -4EX-18531-00-00 4EX-18535-00-00 | 1999 | FITS 98-99 YZ125 YZ250 YZ400F WR400F - 5DH-2217F-00-00 | 1999 | FITS 96-01 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-01 YZ125 YZ250 - 4SS-21721-00-00 | 1999 | FITS 96-01 YA125 YZ250 | FITS 96-01 YA125 YZ250 | R 4SS 6 - L 4SS 5 - 2VN 2 FITS 96-01 YZ125 | FITS 96-03 YZ125, 96-98 YZ250, 96-97 WR250 - 4SS-18110-00-00 | 1999 | 1999 | FITS 99-01 YZ125 YZ250, 99 YZ400F, 00-01 YZ426F, 01 YZ250F WR250F WR426F, 99-00 WR400F - 5ET-2217A-00-00 | FITS 98-99 YZ125 YZ250 YZ400F WR400F - 5DH-2217F-00-00 | 1999 | 4SS-00 FITS 96-04 YZ125 - white/red white/blued 248-372 black/red green/white 720-1080, green/blue black 44-66 - 4SS-85560-02-00 | PA6 GF45 - FITS 94-03 YZ125 - 4JY-15411-00-00 | FITS 98-99 YZ125 YZ250 - 5DH-21190-00-P0 | 5ET - FITS 99 YZ125 YZ250 - 5ET-22110-00-00 | 1999 | FITS 98-01 YZ125 YZ250, 01 YZ250F WR250F WR426F, 98-99 YZ400F, 00-01 YZ426F, 98-00 WR400F 5DH-22141-00-00 | 1999 | FITS 97-02 YZ125 - 4XM-17411-00-00 | 1999 | FITS 97-02 YZ125 - 4XM-17121-00-00 | FITS 97-02 YZ125 - 4EX-17131-01-00 | 1999 | FITS 93-02 YZ125 - 4EX-17151-00-00 | FITS 97-02 YZ125 - 4XM-17161-00-00 | FITS 97-00 YZ125 - 4XM-17211-00-00 | 1999 | FITS 92-02 YZ125 - 4XM-17221-00-00 | FITS 90-02 YZ125 - 3SR-17231-00-00 | FITS 93-02 YZ125 - 4EX-17241-00-00 | 1999 | FITS 97-99 YZ125 - 4EX-17251-01-00 | FITS 97-99 YZ125 - 4XM-17261-00-00 | 1999 | FITS 96-99 YZ125 YZ250, 98-99 YZ400F - 4SS-23435-00-00 | 1999 | FITS 02-03 YZ85, 99-04 YZ125 - 5DH-12459-01-00 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 98-01 YZ125 | 1999 | |||||||||||||||||||||||||||||||||||||
2000 | YZ125M1 | 5HD-00 E109E-00XXXX | FITS 99-00 YZ125 – 5ET-15111-00-00 | FITS 99-00 YZ125 – 5ET-15121-00-00 | JYACE05C8YA00XXXX | 2000 | YZ125M1 | FITS 00-01 YZ125 YZ250 - 4SS-14401-10-00 | 2000 | YZ125M1 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | 2000 | 2000 | MIKUNI 5HD FITS 00 YZ125 | 2000 | YZ125M1 | 2000 | FITS 2000 YZ125 | FITS 97-02 YZ125, YZ250, 98-00 WR400F, 98-99 YZ400F, 00-02 YZ426F, 01-02 WR426F | 2000 | FITS 99-01 YZ250 YZ125, 99 YZ400F, 99-00 WR400F, 00-01 YZ426F, 01 WR426F - 5ET-25388-00-00 5ET-25389-00-00 | FITS 98-01 yz125 - 4JY-16150-02-00 | FITS 96-01 YZ125 - 4JY-15415-00-00 | FITS 98-04 YZ125 - 4JY-15431-14-00 | 2000 | FITS 93-01 YZ125 - 4EX-16371-00-00 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | FITS 96-01 YZ125, 98 YZ80 - 3XJ-16324-00-00 | FITS 96-03 YZ125 - 4SS-82310-00-00 | FITS 98-00 YZ125 - 5DH-11400-00-00 | 2000 | 4035 - CRANK - FITS 97-00 YZ125 | 5HD - FITS 00 YZ125 | 2000 | FITS 97-01 YZ125 | 2000 | stamped 1112-024041 - P/N 24041 - FITS 00-04 YZ125 | FITS 00 YZ125 - PY00125P | 2000 | FITS 00 YZ125 LEFT 5HD-1131D-00-00 - RIGHT 5HD-1132D-00-00 | 2000 | FITS 96-04 YZ125 - 4SS-1131M-00-00 | FITS 98-04 YZ125 - 4JY-11991-01-00 | 2000 | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | 2000 | F4SS 00 - 75MM OD - 61.4MM ID FITS 96-01 YZ125, 02-09 YZ85 - 4SS-85550-00-00 4SS-85550-11-00 | FITS 99-03 YZ125 YZ250, 99 YZ400F, 00-02 YZ426F, 03 YZ450F, 01-06 WR250F, 99-00 WR400F, 01-02 WR426F, 03-06 WR450F - 5ET-27411-00-00 5ET-27421-00-00 | 2000 | KYB - Y5DH-L Y5DH-R – USD - CHROME OD 46MM - 36 7/8" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE MOUNT HOLES 102MM – AXLE CLAMPS 20 & 25MM | 46MM X 58MM X 10.5 | FITS 96-04 YZ125-YZ250 YZ250F-YZ450 | 2000 | FITS 96-03 YZ125 YZ250, 01-03 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 4SS-2314G-L0-00 5DH-2314F-L0-00 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 YZ250F WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | HYDRAULIC | FITS 98-00 YZ125 YZ250 WR400F, 98-99 YZ400F, 00 YZ426F - 5DH-2580T-00-00 | 2000 | NISSIN - 555 - 98-00 YZ125 YZ250 WR400F, 98-99 YZ400F, 00 YZ426F - 5DH-2580T-00-00 | FITS 00 YZ125 YZ250 YZ426F WR400F YZ80 - 4SS-W2587-01-00 | 2000 | ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 97-01 YZ125 YZ250, 97 WR250Z, 98-99 YZ400F, 99-00 WR400F, 00 YZ426F - 4XM-2582T-00-00 | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2000 | FITS 00-05 YZ125 YZ250 | 140 R-Y - 145-FR Y - AXLE OD 20MM - BRG TO BRG 68MM - ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 96-00 YZ125 YZ250, 98-99 YZ400F, 00 YZ426F - 4SS-25111-00-00 | 2000 | FITS 99-04 YZ125 YZ250, 01-04 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 98-00 WR400F, 01-02 WR426F - 5BE-25181-00-00 | FITS 98-00 YZ125, 98 YZ250 - 4SS-24110-10-00 - CLARKE MFG 96-01 YZ125 YZ250 | FITS 99-05 YZ250 – 5CU-11990-00-00 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 4JY - FITS 98-00 YZ125 - 11111-01-00 | 2000 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 2000 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 2000 | FITS 96-00 YZ125 YZ250, 93-01 YZ80, 02-11 YZ85, 00-04 TTR125 - 4ES-21642-00-00 | FITS 00-04 YZ125, 01-04 YZ250F - 5HD-23485-10-00 | 00-05 YZ125 YZ250 YZ250F | FITS 91-92 94-03 YZ125 - 3XJ-16111-00-00 | FITS 96-01 YZ125 – 4SS-1240A-00-00 | FITS 96-01 YZ125 – 4SS-12461-00-00 | 2000 | FITS 98-01 YZ250 YZ125 - 5ET-21730-10-00 | FITS 99-01 YZ125 YZ250 - 5ET-21740-10-00 | 2000 | FITS 96-01 YZ125 YZ250 | FITS 96-01 YZ125 YZ250 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2000 | FITS 99-01 YZ125 YZ250, 99 YZ400F, 00-01 YZ426F, 99-00 WR400F, 01 YZ250F WR250F WR426F - 5ET-25383-00-00 | FITS 99-01 YZ125 YZ250, 99 YZ400F, 00-01 YZ426F, 99-00 WR400F, 01 YZ250F WR426F - 5GR-2580W | 2000 | FITS 95-02 YZ125 YZ250, 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 95-97 WR250, 98-00 WR400F, 01-02 WR250F WR426F - 4GY-27491-00-00 | 2000 | FITS 99-01 YZ125 YZ250, 99 YZ400F, 00-01 YZ426F, 99-00 WR400F, 01 YZ250F WR250F WR426F - SOLD W/ CALIPER - 5GR-2580W-00-00 | FITS 97-04 YZ125 YZ250, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F, 01-04 YZ250F WR250F - 4XM-27200-00-00 | FITS 96-00 YZ125 YZ250, 98-99 YZ400F, 98-99 WR400F - 4SS-27217-00-00 | FITS 90-02 YZ125 YZ250 - 3SP-2583V-00-00 | FITS 98-01 YZ125 YZ125, 98-02 YZ250, 98-99 YZ400F, 00-02 YZ426F | FITS 95-01 YZ125 YZ250 | 2000 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2000 | 4SS - FITS 98-00 YZ125 YZ250 - 5DH-24770-00-00 - SDG 96-01 YZ125 AND YZ250 | FITS 93-03 YZ125 -4EX-18531-00-00 4EX-18535-00-00 | 2000 | 2000 | FITS 96-01 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-01 YZ125 YZ250 - 4SS-21721-00-00 | 2000 | FITS 96-01 YA125 YZ250 | FITS 96-01 YA125 YZ250 | FITS 96-01 YZ125 | FITS 96-03 YZ125, 96-98 YZ250, 96-97 WR250 - 4SS-18110-00-00 | 2000 | FITS 2000 YZ125 - 5HD-22210-00-00 - CLICK HERE FOR MEASUREMENTS | 2000 | FITS 99-01 YZ125 YZ250, 99 YZ400F, 00-01 YZ426F, 01 YZ250F WR250F WR426F, 99-00 WR400F - 5ET-2217A-00-00 | 5DH####XX - FITS 00-01 YZ125 YZ250 YZ426F, 00 WR400F, 01 WR426F YZ250F - 5DH-2217F-01-00 | 2000 | 4SS-00 FITS 96-04 YZ125 - white/red white/blued 248-372 black/red green/white 720-1080, green/blue black 44-66 - 4SS-85560-02-00 | PA6 GF45 - FITS 94-03 YZ125 - 4JY-15411-00-00 | FITS 00-01 YZ125 YZ250 - 5HC-21190-00-P0 | FITS 00 YZ125 YZ250 YZ426F, 99 YZ400F, 99-00 WR400F - 5CU-22110-00-00 | 2000 | FITS 98-01 YZ125 YZ250, 01 YZ250F WR250F WR426F, 98-99 YZ400F, 00-01 YZ426F, 98-00 WR400F 5DH-22141-00-00 | 2000 | FITS 97-02 YZ125 - 4XM-17411-00-00 | 2000 | FITS 97-02 YZ125 - 4XM-17121-00-00 | FITS 97-02 YZ125 - 4EX-17131-01-00 | 2000 | FITS 93-02 YZ125 - 4EX-17151-00-00 | FITS 97-02 YZ125 - 4XM-17161-00-00 | FITS 97-00 YZ125 - 4XM-17211-00-00 | 2000 | FITS 92-02 YZ125 - 4XM-17221-00-00 | FITS 90-02 YZ125 - 3SR-17231-00-00 | FITS 93-02 YZ125 - 4EX-17241-00-00 | 2000 | 2000 | 2000 | FITS 02-03 YZ85, 99-04 YZ125 - 5DH-12459-01-00 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 98-01 YZ125 | 2000 | ||||||||||||||||||||||||||||||||||||||||
2001 | YZ125N1 | 5MV-00 E111E-00XXXX | FITS 01 YZ125 – 5MV-15111-00-00 | FITS 01 YZ125 – 5MV-15121-00-00 | 2001 | YZ125N1 | FITS 00-01 YZ125 YZ250 - 4SS-14401-10-00 | 2001 | YZ125N1 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | 2001 | 2001 | 5MV - MIKUNI - 36MM - FITS 01 YZ125 | 2001 | YZ125N1 | FITS 01 YZ125 - 5MV-13565-00-00 | 2001 | FITS 01 YZ125 - 5MV-85540-00-00 | FITS 97-02 YZ125, YZ250, 98-00 WR400F, 98-99 YZ400F, 00-02 YZ426F, 01-02 WR426F | 2001 | FITS 99-01 YZ250 YZ125, 99 YZ400F, 99-00 WR400F, 00-01 YZ426F, 01 WR426F - 5ET-25388-00-00 5ET-25389-00-00 | FITS 01-02 YZ250 YZ250 YZ250F YZ426F WR250F WR426F - 5MV-22151-00-00 | FITS 98-01 yz125 - 4JY-16150-02-00 | FITS 96-01 YZ125 - 4JY-15415-00-00 | FITS 98-04 YZ125 - 4JY-15431-14-00 | 2001 | FITS 93-01 YZ125 - 4EX-16371-00-00 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | FITS 96-01 YZ125, 98 YZ80 - 3XJ-16324-00-00 | FITS 96-03 YZ125 - 4SS-82310-00-00 | FITS 01-04 YZ125 - 5MV-11400-00-00 | 2001 | 4036 - CRANK - FITS 01-04 YZ125 | 5MV FITS 01 YZ125 | 2001 | FITS 97-01 YZ125 | 20362 | 2001 | stamped 1112-024041 - P/N 24041 - FITS 00-04 YZ125 | 2001 | FITS 01-02 YZ125 - LEFT 5HD-1131D-10-00 RIGHT 5HD-1132D-10-00 | 2001 | FITS 96-04 YZ125 - 4SS-1131M-00-00 | FITS 98-04 YZ125 - 4JY-11991-01-00 | 2001 | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | 2001 | F4SS 00 - 75MM OD - 61.4MM ID FITS 96-01 YZ125, 02-09 YZ85 - 4SS-85550-00-00 4SS-85550-11-00 | FITS 99-03 YZ125 YZ250, 99 YZ400F, 00-02 YZ426F, 03 YZ450F, 01-06 WR250F, 99-00 WR400F, 01-02 WR426F, 03-06 WR450F - 5ET-27411-00-00 5ET-27421-00-00 | 2001 | KYB - Y5DH-L Y5DH-R – USD - CHROME OD 46MM - 36 7/8" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE MOUNT HOLES 102MM – AXLE CLAMPS 20 & 25MM | 46MM X 58MM X 10.5 | FITS 96-04 YZ125-YZ250 YZ250F-YZ450 | 2001 | FITS 96-03 YZ125 YZ250, 01-03 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 4SS-2314G-L0-00 5DH-2314F-L0-00 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 YZ250F WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | HYDRAULIC | FITS 01-02 YZ125 - 5MV-2580T-00-00 - TYPICALLY SOLD WITH THE CALIPER MOUNT | 2001 | FITS 01-02 YZ125 - 5MV-2580T-00-00 - TYPICALLY SOLD WITH THE CALIPER | FITS 01 YZ125 YZ250 YZ250F YZ426F WR250F WR426F YZ80 - 5MV-W2587-00-00 | 2001 | ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 97-01 YZ125 YZ250, 97 WR250Z, 98-99 YZ400F, 99-00 WR400F, 00 YZ426F - 4XM-2582T-00-00 | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2001 | FITS 00-05 YZ125 YZ250 | 2001 | FITS 99-04 YZ125 YZ250, 01-04 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 98-00 WR400F, 01-02 WR426F - 5BE-25181-00-00 | FITS 01 YZ125 - 5MV-24110-00-00 - CLARKE MFG 96-01 YZ125 YZ250 | FITS 99-05 YZ250 – 5CU-11990-00-00 | FITS 83-01 YZ125, 88-01 YZ250, 91-97 WR250 | 5MV - FITS 01-02 YZ125 - 5MV-11111-00-00 | 2001 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 2001 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 2001 | FITS 00-04 YZ125, 01-04 YZ250F - 5HD-23485-10-00 | 00-05 YZ125 YZ250 YZ250F | FITS 91-92 94-03 YZ125 - 3XJ-16111-00-00 | FITS 96-01 YZ125 – 4SS-1240A-00-00 | FITS 96-01 YZ125 – 4SS-12461-00-00 | 2001 | FITS 98-01 YZ250 YZ125 - 5ET-21730-10-00 | FITS 99-01 YZ125 YZ250 - 5ET-21740-10-00 | 2001 | FITS 96-01 YZ125 YZ250 | FITS 96-01 YZ125 YZ250 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | FITS 93-01 YZ125 YZ250 YZ80, 94-95 WR250 - 4EW-2172A-00-00 | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2001 | FITS 99-01 YZ125 YZ250, 99 YZ400F, 00-01 YZ426F, 99-00 WR400F, 01 YZ250F WR250F WR426F - 5ET-25383-00-00 | FITS 99-01 YZ125 YZ250, 99 YZ400F, 00-01 YZ426F, 99-00 WR400F, 01 YZ250F WR426F - 5GR-2580W | 2001 | FITS 95-02 YZ125 YZ250, 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 95-97 WR250, 98-00 WR400F, 01-02 WR250F WR426F - 4GY-27491-00-00 | 2001 | FITS 99-01 YZ125 YZ250, 99 YZ400F, 00-01 YZ426F, 99-00 WR400F, 01 YZ250F WR250F WR426F - SOLD W/ CALIPER - 5GR-2580W-00-00 | FITS 97-04 YZ125 YZ250, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F, 01-04 YZ250F WR250F - 4XM-27200-00-00 | FITS 90-02 YZ125 YZ250 - 3SP-2583V-00-00 | FITS 98-01 YZ125 YZ125, 98-02 YZ250, 98-99 YZ400F, 00-02 YZ426F | FITS 95-01 YZ125 YZ250 | 2001 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2001 | 4SS - FITS 01 YZ125 YZ250 - 5MV-24770-00-00 - SDG 96-01 YZ125 AND YZ250 | FITS 93-03 YZ125 -4EX-18531-00-00 4EX-18535-00-00 | 2001 | 2001 | FITS 96-01 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-01 YZ125 YZ250 - 4SS-21721-00-00 | 2001 | FITS 96-01 YA125 YZ250 | FITS 96-01 YA125 YZ250 | FITS 96-01 YZ125 | FITS 96-03 YZ125, 96-98 YZ250, 96-97 WR250 - 4SS-18110-00-00 | 2001 | 5MV-22210-00-00 - YAMAHA MAN SAYS 01-03 ARE THE SAME, THIS IS NOT VERIFIED - CLICK HERE FOR MEASUREMENTS | 2001 | FITS 99-01 YZ125 YZ250, 99 YZ400F, 00-01 YZ426F, 01 YZ250F WR250F WR426F, 99-00 WR400F - 5ET-2217A-00-00 | 5DH####XX - FITS 00-01 YZ125 YZ250 YZ426F, 00 WR400F, 01 WR426F YZ250F - 5DH-2217F-01-00 | 2001 | 4SS-00 FITS 96-04 YZ125 - white/red white/blued 248-372 black/red green/white 720-1080, green/blue black 44-66 - 4SS-85560-02-00 | PA6 GF45 - FITS 94-03 YZ125 - 4JY-15411-00-00 | FITS 00-01 YZ125 YZ250 - 5HC-21190-00-P0 | FITS 01 YZ125 YZ250 YZ250F YZ426F WR250F WR450F - 5MV-22110-00-00 | 2001 | FITS 98-01 YZ125 YZ250, 01 YZ250F WR250F WR426F, 98-99 YZ400F, 00-01 YZ426F, 98-00 WR400F 5DH-22141-00-00 | 2001 | FITS 97-02 YZ125 - 4XM-17411-00-00 | 2001 | FITS 97-02 YZ125 - 4XM-17121-00-00 | FITS 97-02 YZ125 - 4EX-17131-01-00 | 2001 | FITS 93-02 YZ125 - 4EX-17151-00-00 | FITS 97-02 YZ125 - 4XM-17161-00-00 | 2001 | FITS 92-02 YZ125 - 4XM-17221-00-00 | FITS 90-02 YZ125 - 3SR-17231-00-00 | FITS 93-02 YZ125 - 4EX-17241-00-00 | 2001 | 2001 | FITS 01-02 YZ125 - 5DH-23340-M0-00 | FITS 01 YZ125 YZ250 YZ426F - 5HC-23435-11-00 | 2001 | FITS 02-03 YZ85, 99-04 YZ125 - 5DH-12459-01-00 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 98-01 YZ125 | 2001 | |||||||||||||||||||||||||||||||||||||||||
2002 | YZ125P1 | 5NY-00 E112E-00XXXX | FITS 02 YZ125 – 5NY-15111-00-00 | FITS 02 YZ125 – 5NY-15121-00-00 | JYACE09C52A00XXXX | 2002 | YZ125P1 | FITS 02 YZ125 YZ250 - 5NY-14401-00-00 | 2002 | YZ125P1 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | 5NX00 - FITS 02 YZ125 - 5NY-14453-00-00 | 2002 | 2002 | MIKUNI | 2002 | YZ125P1 | 5MV10 - FITS 02 YZ85 YZ125 - 5MV-13565-10-00 | 2002 | 5NY00 FITS 02-03 YZ125 - 5NY-85540-00-00 | FITS 97-02 YZ125, YZ250, 98-00 WR400F, 98-99 YZ400F, 00-02 YZ426F, 01-02 WR426F | 2002 | FITS 02-04 YZ250 YZ125 YZ250F WR250F, 02 WR426F YZ426F, 03-04 YZ450F WR450F - 5NY-25388-00-00 5NY-25389-00-00 | FITS 01-02 YZ250 YZ250 YZ250F YZ426F WR250F WR426F - 5MV-22151-00-00 | FITS 02-04 YZ125 - 5NY-16150-00-00 | FITS 02-04 YZ125 - 5NY-15490-00-00 | FITS 98-04 YZ125 - 4JY-15431-14-00 | 2002 | FITS 02-03 YZ85, 02-11 YZ125 - 5NY-16371-00-00 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | FITS 96-03 YZ125 - 4SS-82310-00-00 | FITS 01-04 YZ125 - 5MV-11400-00-00 | 2002 | 4036 - CRANK - FITS 01-04 YZ125 | 5NY - FITS 02 YZ125 YZ85 - 5NY-11311-00-00 | 2002 | FITS 02-04 YZ125 - 5NY-21425-00-00 | 24012 | FITS 02-03 YZ125 - 5NY-14610-00-00 | 2002 | stamped 1112-024041 - P/N 24041 - FITS 00-04 YZ125 | 2002 | FITS 01-02 YZ125 - LEFT 5HD-1131D-10-00 RIGHT 5HD-1132D-10-00 | 2002 | FITS 96-04 YZ125 - 4SS-1131M-00-00 | FITS 98-04 YZ125 - 4JY-11991-01-00 | 2002 | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | 2002 | F5CU 11 - FITS 02-03 YZ125 - 5CU-85550-11-00 | FITS 99-03 YZ125 YZ250, 99 YZ400F, 00-02 YZ426F, 03 YZ450F, 01-06 WR250F, 99-00 WR400F, 01-02 WR426F, 03-06 WR450F - 5ET-27411-00-00 5ET-27421-00-00 | 2002 | KYB - Y5DH-L Y5DH-R – USD - CHROME OD 46MM - 36 7/8" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE MOUNT HOLES 102MM – AXLE CLAMPS 20 & 25MM | 46MM X 58MM X 10.5 | FITS YZ125 YZ250 YZ250F YZ426F WR250F WR426F - 5NY-23111-L0-00 | FITS 96-04 YZ125-YZ250 YZ250F-YZ450 | 2002 | FITS 96-03 YZ125 YZ250, 01-03 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 4SS-2314G-L0-00 5DH-2314F-L0-00 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 YZ250F WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | HYDRAULIC | FITS 01-02 YZ125 - 5MV-2580T-00-00 - TYPICALLY SOLD WITH THE CALIPER MOUNT | 2002 | FITS 01-02 YZ125 - 5MV-2580T-00-00 - TYPICALLY SOLD WITH THE CALIPER | FITS 02 YZ125 YZ250 YZ250F YZ426F WR250F WR426F - 5NY-W2587-01-00 | 2002 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2002 | FITS 00-05 YZ125 YZ250 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS 02-15 YZ125 YZ250, 02-13 YZ250F, 02 YZ426F - 03-13 YZ450F - 5NY-25111-00-00 | 2002 | FITS 99-04 YZ125 YZ250, 01-04 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 98-00 WR400F, 01-02 WR426F - 5BE-25181-00-00 | FITS 02-03 YZ125 YZ250 - 5NY-24110-00-00 - CLARKE MFG FITS 02-15 YZ125 YZ250 | FITS 99-05 YZ250 – 5CU-11990-00-00 | FITS 02-11 YZ125 YZ250, 02-03 YZ85 | 5MV - FITS 01-02 YZ125 - 5MV-11111-00-00 | 2002 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 2002 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 2002 | FITS 00-04 YZ125, 01-04 YZ250F - 5HD-23485-10-00 | 00-05 YZ125 YZ250 YZ250F | FITS 91-92 94-03 YZ125 - 3XJ-16111-00-00 | FITS 02-04 YZ125 | FITS 02-04 YZ125 - 5NY-12461-00-00 | 2002 | FITS 02-03 YZ125 YZ250 – 5NY-21730-00-00 | FITS 02-03 YZ125 YZ250 – 5NY-21740-00-00 | 2002 | FITS 02-12 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | FITS 02-03 YZ125 YZ250 YZ250F - 5NL-2172A-10-00 | FITS 02-03 YZ125 YZ250 YZ250F - 5NL-2172A-10-00 | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2002 | FITS YZ125 YZ250 YZ250F YZ426F WR250F WR426F - 5NY-2580W-00-00 - SOLD WITH THE CALIPER | 2002 | FITS 95-02 YZ125 YZ250, 01-02 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 95-97 WR250, 98-00 WR400F, 01-02 WR250F WR426F - 4GY-27491-00-00 | 2002 | FITS YZ125 YZ250 YZ250F YZ426F WR250F WR426F - 5NY-2580W-00-00 - SOLD WITH THE CALIPER | FITS 97-04 YZ125 YZ250, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F, 01-04 YZ250F WR250F - 4XM-27200-00-00 | FITS 90-02 YZ125 YZ250 - 3SP-2583V-00-00 | FITS 02-05 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | 2002 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2002 | 5NY-00 FITS 02-03 YZ125 & YZ250 - 5NY-24770-00-00 | FITS 93-03 YZ125 -4EX-18531-00-00 4EX-18535-00-00 | 2002 | FITS 02-04 YZ125 YZ250 WR250F, 02 YZ426F, 03-04 YZ450F WR450F - 5NY-2217A-00-00 | FITS 02-03 YZ125 YZ250 YZ250F, 02 YZ426F WR426F, 03 YZ450F WR450F - 5NY-2217F-00-00 | 2002 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2002 | FITS 02-05 YZ125 YZ250 | FITS 02-05 YZ125 YZ250 | FITS 02-03 YZ85, 02-04 YZ125 5NY-18541-00-00 | FITS 02-03 YZ85, 02-04 YZ125 5NY-18511-00-00 5NY-18512-00-00 5NY-18513-00-00 | FITS 96-03 YZ125, 96-98 YZ250, 96-97 WR250 - 4SS-18110-00-00 | 2002 | FITS 02-03 YZ125 - 4SS-18101-10-00 | 2002 | FITS 02-04 YZ125 YZ250 YZ250F WR250F, 02 YZ426F WR426F, 03-04 YZ450F WR450F - 5NY-2217A-00-00 | 5NY 0112EK - FITS 02-03 YZ125 YZ250 YZ250F, 02 YZ426F WR426F, 03 YZ450F WR450F - 5NY-2217F-00-00 | 2002 | 4SS-00 FITS 96-04 YZ125 - white/red white/blued 248-372 black/red green/white 720-1080, green/blue black 44-66 - 4SS-85560-02-00 | PA6 GF45 - FITS 94-03 YZ125 - 4JY-15411-00-00 | FITS 02-04 YZ125 YZ250 - 5XE-21190-00-00 | 5NY 1 KM-3 - FITS 02 YZ125 YZ250 YZ250F YZ426F WR250F WR426F - 5NY-22110-00-00 | 2002 | FITS 02 YZ125 YZ250 YZ250F YZ426F WR250F WR426F - 5NY-22141-00-00 | 2002 | FITS 02 YZ125 - 5NY-17411-00-00 | 2002 | FITS 97-02 YZ125 - 4XM-17121-00-00 | FITS 97-02 YZ125 - 4EX-17131-01-00 | 19T - FITS 02-04 YZ125 - 5NY-17141-00-00 | 2002 | FITS 93-02 YZ125 - 4EX-17151-00-00 | FITS 97-02 YZ125 - 4XM-17161-00-00 | FITS 02-04 YZ125 - 5NY-17421-00-00 | 2002 | FITS 92-02 YZ125 - 4XM-17221-00-00 | 29T - FITS 02-04 YZ125 - 5NY-17231-00-00 | 24T - FITS 02-04 YZ125 - 5NY-17241-00-00 | 2002 | 25T - FITS 02-04 YZ125 - 5NY-17251-00-00 | 2002 | FITS 01-02 YZ125 - 5DH-23340-M0-00 | FITS 02-03 YZ125 YZ250, 01-03 YZ250F, 02 YZ426F - 5NL-23435-00-00 | 2002 | FITS 02-03 YZ125 - 4JY-12422-01-00 | FITS 02-03 YZ85, 99-04 YZ125 - 5DH-12459-01-00 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 02-04 YZ125 - 5NY-82509-00-00 | 2002 | |||||||||||||||||||||||||||||||
2003 | YZ125R1 | 5UN-00 E113E-00XXXX | FITS 03-04 YZ125 | JYACE10C63A00XXXX | 2003 | YZ125R1 | FITS 03-11 YZ125 YZ250 - 5NY-14401-01-00 | 2003 | YZ125R1 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | FITS 02-11 YZ250, 03-04 YZ125 - 5NX-14453-00-00 | 2003 | 2003 | MIKUNI 5UN1 00 W274 | 2003 | YZ125R1 | FITS 03-04 YZ125 - 5UN-13565-00-00 | 2003 | 5NY00 FITS 02-03 YZ125 - 5NY-85540-00-00 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F, 03-06 WR450F - 5UN-22128-00-00 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F, 03-06 WR450F - 5UN-22199-00-00 | 2003 | FITS 02-04 YZ250 YZ125 YZ250F WR250F, 02 WR426F YZ426F, 03-04 YZ450F WR450F - 5NY-25388-00-00 5NY-25389-00-00 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 5UN-22151-00-00 | FITS 02-04 YZ125 - 5NY-16150-00-00 | FITS 02-04 YZ125 - 5NY-15490-00-00 | FITS 98-04 YZ125 - 4JY-15431-14-00 | 2003 | FITS 02-03 YZ85, 02-11 YZ125 - 5NY-16371-00-00 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | FITS 96-03 YZ125 - 4SS-82310-00-00 | FITS 01-04 YZ125 - 5MV-11400-00-00 | 2003 | 4036 - CRANK - FITS 01-04 YZ125 | 5UN - FITS 03 YZ125 YZ85 - 5UN-11311-00-00 | 2003 | FITS 02-04 YZ125 - 5NY-21425-00-00 | 24012 | FITS 02-03 YZ125 - 5NY-14610-00-00 | 2003 | stamped 1112-024041 - P/N 24041 - FITS 00-04 YZ125 | FITS 03 YZ125 - PY03125P | 2003 | FITS 03-04 YZ125 LEFT 5HD-1131D-20-00, RIGHT 5HD-1132D-20-00 | 2003 | FITS 96-04 YZ125 - 4SS-1131M-00-00 | FITS 98-04 YZ125 - 4JY-11991-01-00 | 2003 | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | 2003 | F5CU 11 - FITS 02-03 YZ125 - 5CU-85550-11-00 | FITS 99-03 YZ125 YZ250, 99 YZ400F, 00-02 YZ426F, 03 YZ450F, 01-06 WR250F, 99-00 WR400F, 01-02 WR426F, 03-06 WR450F - 5ET-27411-00-00 5ET-27421-00-00 | 2003 | KYB - Y5DH-L Y5DH-R – USD - CHROME OD 46MM - 36 7/8" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE MOUNT HOLES 102MM – AXLE CLAMPS 20 & 25MM | 46MM X 58MM X 10.5 | FITS 96-04 YZ125-YZ250 YZ250F-YZ450 | 2003 | FITS 96-03 YZ125 YZ250, 01-03 YZ250F WR250F, 98-99 YZ400F, 00-02 YZ426F, 03 YZ450F WR450F - 98-00 WR400F, 01-02 WR426F, 4SS-2314G-L0-00 5DH-2314F-L0-00 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 YZ250F WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | HYDRAULIC | NISSIN - 2V3 - FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 5UN-2580T-00-00 | 2003 | NISSIN 3 A 1 1 - FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - TYPICALLY SOLD WITH THE CALIPER | FITS 03 YZ125 YZ250 YZ250F YZ450F WR250F WR450F YZ85 - 5UN-W2587-00-00 | 2003 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2003 | FITS 00-05 YZ125 YZ250 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS 02-15 YZ125 YZ250, 02-13 YZ250F, 02 YZ426F - 03-13 YZ450F - 5NY-25111-00-00 | 2003 | FITS 99-04 YZ125 YZ250, 01-04 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 98-00 WR400F, 01-02 WR426F - 5BE-25181-00-00 | FITS 02-03 YZ125 YZ250 - 5NY-24110-00-00 - CLARKE MFG FITS 02-15 YZ125 YZ250 | FITS 99-05 YZ250 – 5CU-11990-00-00 | FITS 02-11 YZ125 YZ250, 02-03 YZ85 | 5UN, FITS 03-04 YZ125 | 2003 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 2003 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 2003 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | FITS 00-04 YZ125, 01-04 YZ250F - 5HD-23485-10-00 | 00-05 YZ125 YZ250 YZ250F | FITS 91-92 94-03 YZ125 - 3XJ-16111-00-00 | FITS 02-04 YZ125 | FITS 02-04 YZ125 - 5NY-12461-00-00 | 2003 | FITS 02-03 YZ125 YZ250 – 5NY-21730-00-00 | FITS 02-03 YZ125 YZ250 – 5NY-21740-00-00 | 2003 | FITS 02-12 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | FITS 02-03 YZ125 YZ250 YZ250F - 5NL-2172A-10-00 | FITS 02-03 YZ125 YZ250 YZ250F - 5NL-2172A-10-00 | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2003 | FITS 03-05 YZ125 YZ250 YZ250F YZ450F, 03 WR250F WR450F - 5UN-25383-00-00 | SOLD WITH MOUNT - FITS 03-04 YZ125, 04 WR250F WR45F, YZ450F - 5UN-2580W-10-00 | 2003 | 2003 | SOLD WITH MOUNT - FITS 03-04 YZ125, 04 WR250F WR45F, YZ450F - 5UN-2580W-10-00 | FITS 97-04 YZ125 YZ250, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F, 01-04 YZ250F WR250F - 4XM-27200-00-00 | FITS 03-04 YZ125 YZ250, 03-05 YZ250F YZ450F, 03-06 WR250F WR450F - 5UN-2583V-00-00 | FITS 02-05 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | 2003 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2003 | 5NY-00 FITS 02-03 YZ125 & YZ250 - 5NY-24770-00-00 | FITS 93-03 YZ125 -4EX-18531-00-00 4EX-18535-00-00 | 2003 | FITS 02-04 YZ125 YZ250 WR250F, 02 YZ426F, 03-04 YZ450F WR450F - 5NY-2217A-00-00 | FITS 02-03 YZ125 YZ250 YZ250F, 02 YZ426F WR426F, 03 YZ450F WR450F - 5NY-2217F-00-00 | 2003 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2003 | FITS 02-05 YZ125 YZ250 | FITS 02-05 YZ125 YZ250 | FITS 02-03 YZ85, 02-04 YZ125 5NY-18541-00-00 | FITS 02-03 YZ85, 02-04 YZ125 5NY-18511-00-00 5NY-18512-00-00 5NY-18513-00-00 | FITS 96-03 YZ125, 96-98 YZ250, 96-97 WR250 - 4SS-18110-00-00 | 2003 | FITS 02-03 YZ125 - 4SS-18101-10-00 | 2003 | FITS 02-04 YZ125 YZ250 YZ250F WR250F, 02 YZ426F WR426F, 03-04 YZ450F WR450F - 5NY-2217A-00-00 | 5NY 0112EK - FITS 02-03 YZ125 YZ250 YZ250F, 02 YZ426F WR426F, 03 YZ450F WR450F - 5NY-2217F-00-00 | 2003 | 4SS-00 FITS 96-04 YZ125 - white/red white/blued 248-372 black/red green/white 720-1080, green/blue black 44-66 - 4SS-85560-02-00 | PA6 GF45 - FITS 94-03 YZ125 - 4JY-15411-00-00 | FITS 02-04 YZ125 YZ250 - 5XE-21190-00-00 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F 5UN-22110-00-00 | 2003 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F 5NY-22141-01-00 | 2003 | GEARS AND SHAFTS FIT 03-04 YZ125 | 13T - FITS 03-04 YZ125 - 5UN-17411-00-00 | 2003 | 15T - FITS 03-04 YZ125 - 5UN-17121-00-00 | 19T - FITS 03-04 YZ125 - 5NY-17131-00-00 | 19T - FITS 02-04 YZ125 - 5NY-17141-00-00 | 2003 | 23T - FITS 03-04 YZ125 - 5NY-17151-00-00 | FITS 02-04 YZ125 - 5NY-17421-00-00 | 30T - FITS 03-04 YZ125 - 5UN-17211-00-00 | 2003 | 28T - FITS 03-04 YZ125 - 5UN-17221-00-00 | 29T - FITS 02-04 YZ125 - 5NY-17231-00-00 | 24T - FITS 02-04 YZ125 - 5NY-17241-00-00 | 2003 | 25T - FITS 02-04 YZ125 - 5NY-17251-00-00 | 2003 | FITS 02-03 YZ125 YZ250, 01-03 YZ250F, 02 YZ426F - 5NL-23435-00-00 | 2003 | FITS 02-03 YZ125 - 4JY-12422-01-00 | FITS 02-03 YZ85, 99-04 YZ125 - 5DH-12459-01-00 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 02-04 YZ125 - 5NY-82509-00-00 | 2003 | ||||||||||||||||||||||||||||||
2004 | YZ125 | EII6E0 | FITS 03-04 YZ125 | JYACE13C74A00XXXX | 2004 | YZ125 | FITS 03-11 YZ125 YZ250 - 5NY-14401-01-00 | 2004 | YZ125 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | FITS 02-11 YZ250, 03-04 YZ125 - 5NX-14453-00-00 | 2004 | 2004 | 2004 | YZ125 | FITS 03-04 YZ125 - 5UN-13565-00-00 | 2004 | FITS 04YZ125 - 5NY-85540-11-00 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F, 03-06 WR450F - 5UN-22128-00-00 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F, 03-06 WR450F - 5UN-22199-00-00 | 2004 | FITS 02-04 YZ250 YZ125 YZ250F WR250F, 02 WR426F YZ426F, 03-04 YZ450F WR450F - 5NY-25388-00-00 5NY-25389-00-00 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 5UN-22151-00-00 | FITS 02-04 YZ125 - 5NY-16150-00-00 | FITS 02-04 YZ125 - 5NY-15490-00-00 | FITS 98-04 YZ125 - 4JY-15431-14-00 | 2004 | FITS 02-03 YZ85, 02-11 YZ125 - 5NY-16371-00-00 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 98-04 YZ125, 02-03 YZ85, 01-07 YZ250F, 01-11 WR250F, 08-11 XT250 - 5DH-16321-00-00 - 3XJ-16321-00-00 | FITS 01-04 YZ125 - 5MV-11400-00-00 | 2004 | 4036 - CRANK - FITS 01-04 YZ125 | 5XE - FITS 04 YZ125 - 5XE-11311-00-00 | 2004 | FITS 02-04 YZ125 - 5NY-21425-00-00 | 24012 | 2004 | stamped 1112-024041 - P/N 24041 - FITS 00-04 YZ125 | FITS 04 YZ125 - PY04125P | 2004 | FITS 03-04 YZ125 LEFT 5HD-1131D-20-00, RIGHT 5HD-1132D-20-00 | 2004 | FITS 96-04 YZ125 - 4SS-1131M-00-00 | FITS 98-04 YZ125 - 4JY-11991-01-00 | 2004 | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | 2004 | 2004 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | FITS 96-04 YZ125-YZ250 YZ250F-YZ450 | 2004 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 YZ250F WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | HYDRAULIC | NISSIN - 2V3 - FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 5UN-2580T-00-00 | 2004 | NISSIN 3 A 1 1 - FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - TYPICALLY SOLD WITH THE CALIPER | FITS 04-06 YZ125 YZ250, 04-11 YZ85, 04-05 YZ250F YZ450F WR250F WR450F - 5XE-W2587-00-00 | 2004 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2004 | FITS 00-05 YZ125 YZ250 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS 02-15 YZ125 YZ250, 02-13 YZ250F, 02 YZ426F - 03-13 YZ450F - 5NY-25111-00-00 | 2004 | FITS 99-04 YZ125 YZ250, 01-04 YZ250F, 98-99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 98-00 WR400F, 01-02 WR426F - 5BE-25181-00-00 | FITS 04 YZ125 YZ250 - 5XE-24110-00-00 - CLARKE MFG FITS 02-15 YZ125 YZ250 | FITS 99-05 YZ250 – 5CU-11990-00-00 | FITS 02-11 YZ125 YZ250, 02-03 YZ85 | 5UN, FITS 03-04 YZ125 | 2004 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 YZ125 1LX-15641-00-00 | 2004 | FITS 77-83 YZ100, 77-04 YZ125 YZ250, 80-97 YZ80, 77-79 YZ400, 80-81 YZ465, 82-90 YZ490, 80-82 IT465, 83-84 IT490 - 23X-83976-00-00 | 2004 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | FITS 00-04 YZ125, 01-04 YZ250F - 5HD-23485-10-00 | 00-05 YZ125 YZ250 YZ250F | FITS 02-04 YZ125 | FITS 02-04 YZ125 - 5NY-12461-00-00 | 2004 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2004 | FITS 02-12 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | FITS 04-05 YZ125 YZ250 YZ250F, 05-06 WR250F - 5NL-2172A-11-00 | FITS 04-05 YZ125 YZ250 YZ250F, 05-06 WR250F - 5NL-2172A-11-00 | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2004 | FITS 03-05 YZ125 YZ250 YZ250F YZ450F, 03 WR250F WR450F - 5UN-25383-00-00 | SOLD WITH MOUNT - FITS 03-04 YZ125, 04 WR250F WR45F, YZ450F - 5UN-2580W-10-00 | 2004 | 2004 | SOLD WITH MOUNT - FITS 03-04 YZ125, 04 WR250F WR45F, YZ450F - 5UN-2580W-10-00 | FITS 97-04 YZ125 YZ250, 98-99 YZ400F, 98-00 WR400F, 00-02 YZ426F, 01-02 WR426F, 01-04 YZ250F WR250F - 4XM-27200-00-00 | FITS 03-04 YZ125 YZ250, 03-05 YZ250F YZ450F, 03-06 WR250F WR450F - 5UN-2583V-00-00 | FITS 02-05 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | 2004 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2004 | 2004 | FITS 02-04 YZ125 YZ250 WR250F, 02 YZ426F, 03-04 YZ450F WR450F - 5NY-2217A-00-00 | 2004 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2004 | FITS 02-05 YZ125 YZ250 | FITS 02-05 YZ125 YZ250 | FITS 02-03 YZ85, 02-04 YZ125 5NY-18541-00-00 | FITS 02-03 YZ85, 02-04 YZ125 5NY-18511-00-00 5NY-18512-00-00 5NY-18513-00-00 | 2004 | 2004 | FITS 02-04 YZ125 YZ250 YZ250F WR250F, 02 YZ426F WR426F, 03-04 YZ450F WR450F - 5NY-2217A-00-00 | 2004 | 4SS-00 FITS 96-04 YZ125 - white/red white/blued 248-372 black/red green/white 720-1080, green/blue black 44-66 - 4SS-85560-02-00 | FITS 02-04 YZ125 YZ250 - 5XE-21190-00-00 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F 5UN-22110-00-00 | 2004 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F 5NY-22141-01-00 | 2004 | GEARS AND SHAFTS FIT 03-04 YZ125 | 13T - FITS 03-04 YZ125 - 5UN-17411-00-00 | 2004 | 15T - FITS 03-04 YZ125 - 5UN-17121-00-00 | 19T - FITS 03-04 YZ125 - 5NY-17131-00-00 | 19T - FITS 02-04 YZ125 - 5NY-17141-00-00 | 2004 | 23T - FITS 03-04 YZ125 - 5NY-17151-00-00 | FITS 02-04 YZ125 - 5NY-17421-00-00 | 30T - FITS 03-04 YZ125 - 5UN-17211-00-00 | 2004 | 28T - FITS 03-04 YZ125 - 5UN-17221-00-00 | 29T - FITS 02-04 YZ125 - 5NY-17231-00-00 | 24T - FITS 02-04 YZ125 - 5NY-17241-00-00 | 2004 | 25T - FITS 02-04 YZ125 - 5NY-17251-00-00 | 2004 | 2004 | FITS 02-03 YZ85, 99-04 YZ125 - 5DH-12459-01-00 | FITS 98 YZ80, 02-03 YZ85, 98-04 YZ125, 01-11 YZ250F, 01-09 11 WR250F - 5DH-12451-00-00 | FITS 02-04 YZ125 - 5NY-82509-00-00 | 2004 | ||||||||||||||||||||||||||||||||||||||||||||||
2005 | YZ125 | FITS 05-09 YZ125 | 2005 | YZ125 | FITS 03-11 YZ125 YZ250 - 5NY-14401-01-00 | 2005 | YZ125 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | 2005 | 2005 | 2005 | YZ125 | 2005 | FITS 05-07 YZ125 YZ250, 05-06 YZ250F YZ450F - 1C3-22128-00-00 | 2005 | 2005 | FITS 02-03 YZ85, 02-11 YZ125 - 5NY-16371-00-00 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 05-06 YZ125 - 1C3-11400-00-00 | 2005 | 4054 - CRANK - FITS 05-12 YZ125 | 1C3 - FITS 05 YZ125 - 1C3-11311-00-00 | 2005 | 24012 | 2005 | 24049 | FITS 05-13 YZ125 - PY05125P | 2005 | 2005 | FITS 05-11 YZ125 - 1C3-11992-00-00 | 2005 | FITS 05 YZ125 1C3-11990-00-00 | 2005 | FITS 05-06 YZ125 - 1C3-85550-00-00 | 2005 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | FITS 05-07 YZ125-YZ250 YZ250F-YZ450 | 2005 | FITS 05-06 YZ250F, 05-07 YZ125 YZ250 YZ450F, 05-13 WR250F, 05-15 WR450F - 1C3-25181-10-00 | HYDRAULIC | FITS 05-07 YZ125 YZ250 YZ250F YZ450F, 05-11 WR250F WR450F - 1C3-2580T-00-00 | 2005 | FITS 04-06 YZ125 YZ250, 04-11 YZ85, 04-05 YZ250F YZ450F WR250F WR450F - 5XE-W2587-00-00 | 2005 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2005 | FITS 00-05 YZ125 YZ250 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS 02-15 YZ125 YZ250, 02-13 YZ250F, 02 YZ426F - 03-13 YZ450F - 5NY-25111-00-00 | 2005 | FITS 05 YZ125 YZ250 - 1C3-24110-00-00 - CLARKE MFG FITS 02-15 YZ125 YZ250 | FITS 99-05 YZ250 – 5CU-11990-00-00 | FITS 02-11 YZ125 YZ250, 02-03 YZ85 | 2005 | FITS 05-06 YZ125 - 4DB-15620-04-00 | 2005 | 2005 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | 00-05 YZ125 YZ250 YZ250F | 2005 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2005 | FITS 02-12 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | FITS 04-05 YZ125 YZ250 YZ250F, 05-06 WR250F - 5NL-2172A-11-00 | FITS 04-05 YZ125 YZ250 YZ250F, 05-06 WR250F - 5NL-2172A-11-00 | FITS 05 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 1C3-25381-00-00 | 2005 | FITS 03-05 YZ125 YZ250 YZ250F YZ450F, 03 WR250F WR450F - 5UN-25383-00-00 | 2005 | 2005 | fits 05-08 yz125 yz250, 06-08 yz250f yz450f, 07-08 wr250f wr450f - 1C3-2583V-00-00 | FITS 02-05 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | 2005 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2005 | 2005 | 2005 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2005 | FITS 02-05 YZ125 YZ250 | FITS 02-05 YZ125 YZ250 | 2005 | 2005 | FITS 05-11 YZ125 YZ250, 05 YZ250F YZ450F, 05-06 WR250F WR450F - 1C3-2217A-00-00 | 2005 | FITS 05 YZ125 - 1C3-85560-00-00 | FITS 05 YZ125 YZ250 YZ250F YZ450F WR250R WR450F - 1C3-22110-00-00 | 2005 | 2005 | 2005 | 2005 | 2005 | 2005 | 2005 | 5XE20 - FITS 05 YZ125 YZ250 YZ250F YZ450F - 5XE-23435-20-00 - 190MM C/L TO C/L OF FORK TUBES | 2005 | 2005 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2006 | YZ125 | FITS 05-09 YZ125 | 2006 | YZ125 | FITS 03-11 YZ125 YZ250 - 5NY-14401-01-00 | 2006 | YZ125 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | 2006 | 2006 | 2006 | YZ125 | 2006 | FITS 05-07 YZ125 YZ250, 05-06 YZ250F YZ450F - 1C3-22128-00-00 | FITS 06-07 YZ125 YZ250, 06 YZ250F YZ450F -1C3-22199-10-00 | 2006 | 2006 | FITS 02-03 YZ85, 02-11 YZ125 - 5NY-16371-00-00 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 05-06 YZ125 - 1C3-11400-00-00 | 2006 | 4054 - CRANK - FITS 05-12 YZ125 | 1C3 - FITS 06 YZ125 - 1C3-11311-01-00 | 2006 | 24012 | 2006 | FITS 05-13 YZ125 - PY05125P | 2006 | 2006 | FITS 05-11 YZ125 - 1C3-11992-00-00 | 2006 | FITS 06-11 YZ125 1C3-11990-10-00 | 2006 | FITS 05-06 YZ125 - 1C3-85550-00-00 | 2006 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | FITS 06 YZ125 YZ250 YZ250F YZ450F - 1C3-23170-N0-00 | FITS 05-07 YZ125-YZ250 YZ250F-YZ450 | 2006 | FITS 06 YZ125 YZ250 YZ250F YZ450F - 1C3-23136-M0-00 | FITS 05-06 YZ250F, 05-07 YZ125 YZ250 YZ450F, 05-13 WR250F, 05-15 WR450F - 1C3-25181-10-00 | HYDRAULIC | FITS 05-07 YZ125 YZ250 YZ250F YZ450F, 05-11 WR250F WR450F - 1C3-2580T-00-00 | 2006 | FITS 04-06 YZ125 YZ250, 04-11 YZ85, 04-05 YZ250F YZ450F WR250F WR450F - 5XE-W2587-00-00 | 2006 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | FITS 06 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 1C3-21511-50-00 | 2006 | FITS 06-12 YZ125 YZ250 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS 02-15 YZ125 YZ250, 02-13 YZ250F, 02 YZ426F - 03-13 YZ450F - 5NY-25111-00-00 | 2006 | FITS 06 YZ125 YZ250 - 1C3-24110-50-00 - CLARKE MFG FITS 02-15 YZ125 YZ250 | FITS 02-11 YZ125 YZ250, 02-03 YZ85 | 2006 | FITS 05-06 YZ125 - 4DB-15620-04-00 | 2006 | 2006 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | FITS 06-11 YZ125 YZ250 YZ250F | 2006 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2006 | FITS 02-12 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | FITS 06-11 YZ125 YZ250 - 5NL-2172A-20-00 | FITS 06-11 YZ125 YZ250 - 5NL-2172A-20-00 | FITS 06 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 1C3-25381-10-00 | 2006 | 2006 | 2006 | fits 05-08 yz125 yz250, 06-08 yz250f yz450f, 07-08 wr250f wr450f - 1C3-2583V-00-00 | FITS 02-12 YZ125 YZ250 | 2006 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2006 | 2006 | 2006 | (K=50N/MM) FITS 06-13 YZ125, 06-12 YZ250, 06-09 YZ250F YZ450F - 1C3-22212-30-00 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2006 | FITS 06-12 YZ125 YZ250 | FITS 06-12 YZ125 YZ250 | 2006 | 2006 | FITS 05-11 YZ125 YZ250, 05 YZ250F YZ450F, 05-06 WR250F WR450F - 1C3-2217A-00-00 | 2006 | FITS 06-11 YZ125 - 1C3-85560-10-00 | FITS 05-09 YZ250, 06-11 YZ125 | FITS 06-07 YZ125 YZ250, 06 YZ250F YZ450F WR250F WR450F - 1C3-22110-50-00 | 2006 | 2006 | 2006 | 2006 | 2006 | 2006 | 2006 | FITS 06 YZ250F, 06-14 YZ125 - 1C3-23340-M0-00 | FITS 06 YZ250F YZ450F, 06-14 YZ125 YZ250 - 1C3-23435-50-00 | 2006 | 2006 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2007 | YZ125 | FITS 05-09 YZ125 | 2007 | YZ125 | FITS 03-11 YZ125 YZ250 - 5NY-14401-01-00 | 2007 | YZ125 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | 2007 | 2007 | 2007 | YZ125 | 2007 | FITS 05-07 YZ125 YZ250, 05-06 YZ250F YZ450F - 1C3-22128-00-00 | FITS 06-07 YZ125 YZ250, 06 YZ250F YZ450F -1C3-22199-10-00 | 2007 | 2007 | FITS 02-03 YZ85, 02-11 YZ125 - 5NY-16371-00-00 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 07-11 YZ125 - 1C3-11400-20-00 | 2007 | 4054 - CRANK - FITS 05-12 YZ125 | 1C3 - FITS 07-11 YZ125 - 1C3-11311-10-00 | 2007 | 24012 | 2007 | FITS 05-13 YZ125 - PY05125P | 2007 | 2007 | FITS 05-11 YZ125 - 1C3-11992-00-00 | 2007 | FITS 06-11 YZ125 1C3-11990-10-00 | 2007 | 2007 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | FITS 05-07 YZ125-YZ250 YZ250F-YZ450 | 2007 | FITS 05-06 YZ250F, 05-07 YZ125 YZ250 YZ450F, 05-13 WR250F, 05-15 WR450F - 1C3-25181-10-00 | HYDRAULIC | FITS 05-07 YZ125 YZ250 YZ250F YZ450F, 05-11 WR250F WR450F - 1C3-2580T-00-00 | 2007 | FITS 07 YZ125 YZ250, 06 YZ250F, 06-07 YZ450F, 06-11 WR250F WR450F - 5XE-W2587-10-00 | 2007 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2007 | FITS 06-12 YZ125 YZ250 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS 02-15 YZ125 YZ250, 02-13 YZ250F, 02 YZ426F - 03-13 YZ450F - 5NY-25111-00-00 | 2007 | FITS 07-11 YZ125 YZ250 - 1C3-24110-90-00 - CLARKE MFG FITS 02-15 YZ125 YZ250 | FITS 02-11 YZ125 YZ250, 02-03 YZ85 | 2007 | FITS 07-11 YZ125 - 4DB-15620-10-00 | 2007 | 2007 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | FITS 06-11 YZ125 YZ250 YZ250F | 2007 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2007 | FITS 02-12 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | FITS 06-11 YZ125 YZ250 - 5NL-2172A-20-00 | FITS 06-11 YZ125 YZ250 - 5NL-2172A-20-00 | FITS 07-11 YZ125 YZ250 YZ250F, 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-25381-90-00 AXLE | 2007 | 2007 | 2007 | fits 05-08 yz125 yz250, 06-08 yz250f yz450f, 07-08 wr250f wr450f - 1C3-2583V-00-00 | FITS 02-12 YZ125 YZ250 | 2007 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2007 | 2007 | 2007 | (K=50N/MM) FITS 06-13 YZ125, 06-12 YZ250, 06-09 YZ250F YZ450F - 1C3-22212-30-00 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2007 | FITS 06-12 YZ125 YZ250 | FITS 06-12 YZ125 YZ250 | 2007 | 2007 | FITS 05-11 YZ125 YZ250, 05 YZ250F YZ450F, 05-06 WR250F WR450F - 1C3-2217A-00-00 | 2007 | FITS 06-11 YZ125 - 1C3-85560-10-00 | FITS 05-09 YZ250, 06-11 YZ125 | FITS 06-07 YZ125 YZ250, 06 YZ250F YZ450F WR250F WR450F - 1C3-22110-50-00 | 2007 | 2007 | 2007 | 2007 | 2007 | 2007 | 2007 | FITS 06 YZ250F YZ450F, 06-14 YZ125 YZ250 - 1C3-23435-50-00 | 2007 | 2007 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2008 | YZ125 | FITS 05-09 YZ125 | 2008 | YZ125 | FITS 03-11 YZ125 YZ250 - 5NY-14401-01-00 | 2008 | YZ125 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | 2008 | 2008 | 2008 | YZ125 | 2008 | 2008 | 2008 | FITS 02-03 YZ85, 02-11 YZ125 - 5NY-16371-00-00 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 07-11 YZ125 - 1C3-11400-20-00 | 2008 | 4054 - CRANK - FITS 05-12 YZ125 | 1C3 - FITS 07-11 YZ125 - 1C3-11311-10-00 | 2008 | 24012 | 2008 | FITS 05-13 YZ125 - PY05125P | 2008 | 2008 | FITS 05-11 YZ125 - 1C3-11992-00-00 | 2008 | FITS 06-11 YZ125 1C3-11990-10-00 | 2008 | 2008 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | FITS 08-10 YZ125-YZ250 | 2008 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-25181-G0-00 | HYDRAULIC | FITS 07-11 YZ250F, 08-11 YZ125 YZ250 YZ450F - 5XC-2580T-G0-00 | 2008 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-W2587-00-00 | 2008 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2008 | FITS 06-12 YZ125 YZ250 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS 02-15 YZ125 YZ250, 02-13 YZ250F, 02 YZ426F - 03-13 YZ450F - 5NY-25111-00-00 | 2008 | FITS 07-11 YZ125 YZ250 - 1C3-24110-90-00 - CLARKE MFG FITS 02-15 YZ125 YZ250 | FITS 02-11 YZ125 YZ250, 02-03 YZ85 | 2008 | FITS 07-11 YZ125 - 4DB-15620-10-00 | 2008 | 2008 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | FITS 06-11 YZ125 YZ250 YZ250F | 2008 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2008 | FITS 02-12 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | FITS 06-11 YZ125 YZ250 - 5NL-2172A-20-00 | FITS 06-11 YZ125 YZ250 - 5NL-2172A-20-00 | FITS 07-11 YZ125 YZ250 YZ250F, 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-25381-90-00 AXLE | 2008 | 2008 | 2008 | fits 05-08 yz125 yz250, 06-08 yz250f yz450f, 07-08 wr250f wr450f - 1C3-2583V-00-00 | FITS 02-12 YZ125 YZ250 | 2008 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2008 | 2008 | 2008 | (K=50N/MM) FITS 06-13 YZ125, 06-12 YZ250, 06-09 YZ250F YZ450F - 1C3-22212-30-00 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2008 | FITS 06-12 YZ125 YZ250 | FITS 06-12 YZ125 YZ250 | 2008 | 2008 | FITS 05-11 YZ125 YZ250, 05 YZ250F YZ450F, 05-06 WR250F WR450F - 1C3-2217A-00-00 | 2008 | FITS 06-11 YZ125 - 1C3-85560-10-00 | FITS 05-09 YZ250, 06-11 YZ125 | FITS 08-11 YZ125 YZ250, 09, 11 WR250F WR450F - 1C3-22110-90-00 | 2008 | 2008 | 2008 | 2008 | 2008 | 2008 | 2008 | FITS 06 YZ250F YZ450F, 06-14 YZ125 YZ250 - 1C3-23435-50-00 | 2008 | 2008 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2009 | YZ125 | FITS 05-09 YZ125 | 2009 | YZ125 | FITS 03-11 YZ125 YZ250 - 5NY-14401-01-00 | 2009 | YZ125 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | 2009 | 2009 | 2009 | YZ125 | 2009 | 2009 | 2009 | FITS 02-03 YZ85, 02-11 YZ125 - 5NY-16371-00-00 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 07-11 YZ125 - 1C3-11400-20-00 | 2009 | 4054 - CRANK - FITS 05-12 YZ125 | 1C3 - FITS 07-11 YZ125 - 1C3-11311-10-00 | 2009 | 24012 | 2009 | FITS 05-13 YZ125 - PY05125P | 2009 | 2009 | FITS 05-11 YZ125 - 1C3-11992-00-00 | 2009 | FITS 06-11 YZ125 1C3-11990-10-00 | 2009 | 2009 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | FITS 08-10 YZ125-YZ250 | 2009 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-25181-G0-00 | HYDRAULIC | FITS 07-11 YZ250F, 08-11 YZ125 YZ250 YZ450F - 5XC-2580T-G0-00 | 2009 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-W2587-00-00 | 2009 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2009 | FITS 06-12 YZ125 YZ250 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS 02-15 YZ125 YZ250, 02-13 YZ250F, 02 YZ426F - 03-13 YZ450F - 5NY-25111-00-00 | 2009 | FITS 07-11 YZ125 YZ250 - 1C3-24110-90-00 - CLARKE MFG FITS 02-15 YZ125 YZ250 | FITS 02-11 YZ125 YZ250, 02-03 YZ85 | 2009 | FITS 07-11 YZ125 - 4DB-15620-10-00 | 2009 | 2009 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | FITS 06-11 YZ125 YZ250 YZ250F | 2009 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2009 | FITS 02-12 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | FITS 06-11 YZ125 YZ250 - 5NL-2172A-20-00 | FITS 06-11 YZ125 YZ250 - 5NL-2172A-20-00 | FITS 07-11 YZ125 YZ250 YZ250F, 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-25381-90-00 AXLE | 2009 | 2009 | 2009 | FITS 02-12 YZ125 YZ250 | 2009 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2009 | 2009 | 2009 | (K=50N/MM) FITS 06-13 YZ125, 06-12 YZ250, 06-09 YZ250F YZ450F - 1C3-22212-30-00 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2009 | FITS 06-12 YZ125 YZ250 | FITS 06-12 YZ125 YZ250 | 2009 | 2009 | FITS 05-11 YZ125 YZ250, 05 YZ250F YZ450F, 05-06 WR250F WR450F - 1C3-2217A-00-00 | 2009 | FITS 06-11 YZ125 - 1C3-85560-10-00 | FITS 05-09 YZ250, 06-11 YZ125 | FITS 08-11 YZ125 YZ250, 09, 11 WR250F WR450F - 1C3-22110-90-00 | 2009 | 2009 | 2009 | 2009 | 2009 | 2009 | 2009 | FITS 06 YZ250F YZ450F, 06-14 YZ125 YZ250 - 1C3-23435-50-00 | 2009 | 2009 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2010 | YZ125 | 2010 | YZ125 | FITS 03-11 YZ125 YZ250 - 5NY-14401-01-00 | 2010 | YZ125 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | 2010 | 2010 | 2010 | YZ125 | 2010 | 2010 | 2010 | FITS 02-03 YZ85, 02-11 YZ125 - 5NY-16371-00-00 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 07-11 YZ125 - 1C3-11400-20-00 | 2010 | 4054 - CRANK - FITS 05-12 YZ125 | 1C3 - FITS 07-11 YZ125 - 1C3-11311-10-00 | 2010 | 24012 | 2010 | FITS 05-13 YZ125 - PY05125P | 2010 | 2010 | FITS 05-11 YZ125 - 1C3-11992-00-00 | 2010 | FITS 06-11 YZ125 1C3-11990-10-00 | 2010 | 2010 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | FITS 08-10 YZ125-YZ250 | 2010 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-25181-G0-00 | HYDRAULIC | FITS 07-11 YZ250F, 08-11 YZ125 YZ250 YZ450F - 5XC-2580T-G0-00 | 2010 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-W2587-00-00 | 2010 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2010 | FITS 06-12 YZ125 YZ250 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS 02-15 YZ125 YZ250, 02-13 YZ250F, 02 YZ426F - 03-13 YZ450F - 5NY-25111-00-00 | 2010 | FITS 07-11 YZ125 YZ250 - 1C3-24110-90-00 - CLARKE MFG FITS 02-15 YZ125 YZ250 | FITS 02-11 YZ125 YZ250, 02-03 YZ85 | 2010 | FITS 07-11 YZ125 - 4DB-15620-10-00 | 2010 | 2010 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | FITS 06-11 YZ125 YZ250 YZ250F | 2010 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2010 | FITS 02-12 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | FITS 06-11 YZ125 YZ250 - 5NL-2172A-20-00 | FITS 06-11 YZ125 YZ250 - 5NL-2172A-20-00 | 2010 | 2010 | 2010 | FITS 02-12 YZ125 YZ250 | 2010 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2010 | 2010 | 2010 | (K=50N/MM) FITS 06-13 YZ125, 06-12 YZ250, 06-09 YZ250F YZ450F - 1C3-22212-30-00 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2010 | FITS 06-12 YZ125 YZ250 | FITS 06-12 YZ125 YZ250 | 2010 | 2010 | FITS 05-11 YZ125 YZ250, 05 YZ250F YZ450F, 05-06 WR250F WR450F - 1C3-2217A-00-00 | 2010 | FITS 06-11 YZ125 - 1C3-85560-10-00 | FITS 05-09 YZ250, 06-11 YZ125 | FITS 08-11 YZ125 YZ250, 09, 11 WR250F WR450F - 1C3-22110-90-00 | 2010 | 2010 | 2010 | 2010 | 2010 | 2010 | 2010 | FITS 06 YZ250F YZ450F, 06-14 YZ125 YZ250 - 1C3-23435-50-00 | 2010 | 2010 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2011 | YZ125 | 2011 | YZ125 | FITS 03-11 YZ125 YZ250 - 5NY-14401-01-00 | 2011 | YZ125 | FITS 97-11 YZ125 YZ250 - 3JD-14458-01-00 | 2011 | 2011 | 2011 | YZ125 | 2011 | 2011 | 2011 | FITS 02-03 YZ85, 02-11 YZ125 - 5NY-16371-00-00 | FITS 02-03 YZ85, 00-11 YZ125, 01-11 YZ250F, 01-11 WR250F - 5HD-16351-00-00 | FITS 07-11 YZ125 - 1C3-11400-20-00 | 2011 | 4054 - CRANK - FITS 05-12 YZ125 | 1C3 - FITS 07-11 YZ125 - 1C3-11311-10-00 | 2011 | 24012 | 2011 | FITS 05-13 YZ125 - PY05125P | 2011 | 2011 | FITS 05-11 YZ125 - 1C3-11992-00-00 | 2011 | FITS 06-11 YZ125 1C3-11990-10-00 | 2011 | 2011 | 48MM X 58MM X 8.5/10 | 2011 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-25181-G0-00 | HYDRAULIC | FITS 07-11 YZ250F, 08-11 YZ125 YZ250 YZ450F - 5XC-2580T-G0-00 | 2011 | FITS 08-11 YZ125 YZ250 YZ450F, 07-11 YZ250F - 5XC-W2587-00-00 | 2011 | 250MM OD - 118.1MM ID - 6X ON 134MM BC - FLOATING STYLE - FITS 02-11 YZ125 YZ250 YZ250F, 03-11 YZ450F - 5XC-2581T-G0-00 - 2.92MM NEW THICKNESS | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2011 | FITS 06-12 YZ125 YZ250 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS 02-15 YZ125 YZ250, 02-13 YZ250F, 02 YZ426F - 03-13 YZ450F - 5NY-25111-00-00 | 2011 | FITS 07-11 YZ125 YZ250 - 1C3-24110-90-00 - CLARKE MFG FITS 02-15 YZ125 YZ250 | FITS 02-11 YZ125 YZ250, 02-03 YZ85 | 2011 | FITS 07-11 YZ125 - 4DB-15620-10-00 | 2011 | 2011 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | FITS 06-11 YZ125 YZ250 YZ250F | 2011 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2011 | FITS 02-12 YZ125 YZ250 | FITS 02-12 YZ125 YZ250 | FITS 06-11 YZ125 YZ250 - 5NL-2172A-20-00 | FITS 06-11 YZ125 YZ250 - 5NL-2172A-20-00 | FITS 07-11 YZ125 YZ250 YZ250F, 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-25381-90-00 AXLE | 2011 | 2011 | 2011 | FITS 02-12 YZ125 YZ250 | 2011 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2011 | 2011 | 2011 | (K=50N/MM) FITS 06-13 YZ125, 06-12 YZ250, 06-09 YZ250F YZ450F - 1C3-22212-30-00 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | 2011 | FITS 06-12 YZ125 YZ250 | FITS 06-12 YZ125 YZ250 | 2011 | 2011 | FITS 05-11 YZ125 YZ250, 05 YZ250F YZ450F, 05-06 WR250F WR450F - 1C3-2217A-00-00 | 2011 | FITS 06-11 YZ125 - 1C3-85560-10-00 | FITS 05-09 YZ250, 06-11 YZ125 | FITS 08-11 YZ125 YZ250, 09, 11 WR250F WR450F - 1C3-22110-90-00 | 2011 | 2011 | 2011 | 2011 | 2011 | 2011 | 2011 | FITS 06 YZ250F YZ450F, 06-14 YZ125 YZ250 - 1C3-23435-50-00 | 2011 | 2011 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
24012 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS 02-15 YZ125 YZ250, 02-13 YZ250F, 02 YZ426F - 03-13 YZ450F - 5NY-25111-00-00 | - CLARKE MFG FITS 02-15 YZ125 YZ250 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2012 | (K=50N/MM) FITS 06-13 YZ125, 06-12 YZ250, 06-09 YZ250F YZ450F - 1C3-22212-30-00 | FITS 06 YZ250F YZ450F, 06-14 YZ125 YZ250 - 1C3-23435-50-00 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
24012 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS 02-15 YZ125 YZ250, 02-13 YZ250F, 02 YZ426F - 03-13 YZ450F - 5NY-25111-00-00 | - CLARKE MFG FITS 02-15 YZ125 YZ250 | FITS 03-13 YZ250F WR250F WR450F, 03-09 YZ450F, 04-13 YZ125 YZ250 - 5TA-21642-00-00 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | 2013 | (K=50N/MM) FITS 06-13 YZ125, 06-12 YZ250, 06-09 YZ250F YZ450F - 1C3-22212-30-00 | FITS 06 YZ250F YZ450F, 06-14 YZ125 YZ250 - 1C3-23435-50-00 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
24012 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS 02-15 YZ125 YZ250, 02-13 YZ250F, 02 YZ426F - 03-13 YZ450F - 5NY-25111-00-00 | - CLARKE MFG FITS 02-15 YZ125 YZ250 | 5ET00 - 22MM AXLE OD - BRG TO BRG 120MM - ROTOR OD 245MM, 6X BC DIA 133MM - FITS 99-13 YZ125 YZ250, 99 YZ400, 00-02 YZ426F, 01-13 YZ250F WR250F 03-12 YZ450F, 99-00 WR400F, 01-02 WR426F, 03-13 WR450F – 5ET-25311-00-00 | FITS 06 YZ250F YZ450F, 06-14 YZ125 YZ250 - 1C3-23435-50-00 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
YEAR | TYPE | ENGINE ID | ENGINE CASE LEFT | ENGINE CASE RIGHT | VIN FRAME USA | YEAR | TYPE | AIR BOX | YEAR | TYPE | AIR BOX CAGE | AIR BOX TO CARBURETOR BOOT | CABLE CLUTCH | YEAR | CABLE FRONT BRAKE | CABLE THROTTLE | YEAR | CARBURETOR | YEAR | TYPE | CARBURETOR BOOT | YEAR | CDI | CHAIN GUIDE | CHAIN GUIDE PLASTIC INSERT (CHAIN SUPPORT) | YEAR | CHAIN PULLER BLOCKS | CHAIN SLIDER | CLUTCH BASKET | CLUTCH COVER | CLUTCH COVER INNER | YEAR | CLUTCH BOSS INNER | CLUTCH PRESSURE PLATE OUTER | CLUTCH PLATES FRICTION | CLUTCH PLATES METAL | COIL | CRANK SHAFT | YEAR | CRANK SHAFT (HOT RODS) | CYLINDER | YEAR | ENGINE MOUNTS UPPER | ENGINE MOUNTS LOWER | EXHAUST ARRESTOR (FMF TURBINE 2) | EXHAUST PIPE | YEAR | EXHAUST PIPE FMF RACING FATTY | EXHAUST PIPE PRO CIRCUIT PLATINUM | YEAR | EXHAUST VALVE | YEAR | EXHAUST VALVE COVER FRONT | EXHAUST VALVE COVER RIGHT | EXHAUST VALVE HOLDER LEFT | YEAR | EXHAUST VALVE HOLER RIGHT | EXHAUST VALVE LINKAGE (PUSH ROD ASY) | YEAR | FLY WHEEL ROTOR | FOOT PEGS | YEAR | FORK INFO | FORK SEAL SIZES | FORK CAP | FORK INTERNAL DAMPENER CYLINDER | FORK GUARDS | FORK GUARDS ACERBIS | YEAR | FORK GUARD MOUNTS | FORK OUTER TUBE ALUMINUM | FRONT AXLE | FRONT BRAKE BACKING PLATE | FRONT BRAKE CALIPER | YEAR | FRONT BRAKE CALIPER MOUNT | FRONT BRAKE HOSE | FRONT BRAKE MASTER CYLINDER | YEAR | FRONT BRAKE ROTOR | FRONT FENDER | YEAR | FRONT FENDER ACERBIS | FRONT HUB | YEAR | FRONT RIM | GAS CAP | GAS TANK | GOVERNOR PUSH ROD | GOVERNOR SHAFT AND GEAR | HEAD | YEAR | KICK IDLER GEAR | KICK LEVER | KICK LEVER SHAFT | KICK LEVER SHAFT GEAR | YEAR | KILL SWITCH | YEAR | MUD FLAP | NUMBER PLATE | NUMBER PLATE ACERBIS | OIL CAPACITY | PRIMARY CRANK GEAR | RADIATOR LEFT | RADIATOR RIGHT | YEAR | RADIATOR HOSE SETS | RADIATOR SHROUD LEFT | RADIATOR SHROUD RIGHT | YEAR | RADIATOR SHROUD LEFT ACERBIS | RADIATOR SHROUD RIGHT ACERBIS | RADIATOR SCREEN LEFT | RADIATOR SCREEN RIGHT | REAR AXLE | YEAR | REAR AXLE SPACERS COLLARS | REAR BRAKE BACKING PLATE | REAR BRAKE CALIPER | YEAR | REAR BRAKE CALIPER GUARD | YEAR | REAR BRAKE CALIPER MOUNT | REAR BRAKE CALIPER MOUNT | REAR BRAKE LEVER | REAR BRAKE LEVER BOLT | REAR BRAKE MASTER CYLINDER | REAR BRAKE TENSION BAR | REAR FENDER | REAR FENDER ACERBIS | YEAR | REAR HUB | YEAR | REED VALVE | SEAT | SHIFT FORK ALIGNMENT GUIDES RODS SHAFTS | YEAR | SHOCK | SHOCK ARM (RELAY ARM) | SHOCK ARM LINKAGE (CONNECTING ROD ) | YEAR | SHOCK SPRING | SIDE COVER LEFT | SIDE COVER RIGHT | YEAR | SIDE COVER LEFT ACERBIS | SIDE COVER RIGHT ACERBIS | SHIFT DRUM (CAM) | SHIFT FORKS | SHIFT LEVER | YEAR | SHIFT SHAFT | SHOCK | YEAR | SHOCK ARM | SHOCK ARM LINKAGE | YEAR | STATOR | STATOR COVER | SUB FRAME | SWING ARM | YEAR | SWING ARM PIVOT PIN | THROTTLE | YEAR | THROTTLE CABLE | TRANSMISSION | TRANSMISSION MAIN SHAFT | YEAR | TRANSMISSION MAIN SHAFT 2ND GEAR | TRANSMISSION MAIN SHAFT 3RD GEAR | TRANSMISSION MAIN SHAFT 4TH GEAR | YEAR | TRANSMISSION MAIN SHAFT 5TH GEAR | TRANSMISSION MAIN SHAFT 6TH GEAR | TRANSMISSION COUNTER (DRIVE) SHAFT | TRANSMISSION DRIVE SHAFT 1ST GEAR | YEAR | TRANSMISSION DRIVE SHAFT 2ND GEAR | TRANSMISSION DRIVE SHAFT 3RD GEAR | TRANSMISSION DRIVE SHAFT 4TH GEAR | YEAR | TRANSMISSION DRIVE SHAFT 5TH GEAR | TRANSMISSION DRIVE SHAFT 5TH GEAR | YEAR | TRIPLE TREE – LOWER | TRIPLE TREE - UPPER (CROWN) | YEAR | WATER PUMP COVER | WATER PUMP SHAFT | WATER PUMP IMPELLER | WIRE HARNESS | YEAR |
