| YEAR | TYPE | ENGINE ID | ENGINE CASE LEFT | ENGINE CASE RIGHT | VIN FRAME USA ONLY | YEAR | TYPE | AIR BOX | YEAR | TYPE | AIR BOX TO CARBURETOR BOOT | CABLE FRONT BRAKE | CABLE THROTTLE | CARBURETOR | YEAR | TYPE | CARBURETOR BOOT | CDI | CHAIN GUIDE | YEAR | CHAIN PULLER BLOCKS | CLUTCH BASKET | CLUTCH COVER | CLUTCH COVER INNER | CLUTCH BOSS INNER | CLUTCH PRESSURE PLATE OUTER | COIL | CRANK SHAFT | YEAR | CYLINDER | ENGINE MOUNTS UPPER | EXHAUST VALVE | YEAR | EXHAUST VALVE COVER FRONT | EXHAUST VALVE COVER RIGHT | EXHAUST VALVE HOLDER LEFT | YEAR | EXHAUST VALVE HOLER RIGHT | EXHAUST VALVE LINKAGE (PUSH ROD ASY) | FLY WHEEL ROTOR | YEAR | FORK INFO | FORK SEAL SIZES | YEAR | FRONT AXLE | FRONT BRAKE BACKING PLATE | FRONT BRAKE CALIPER | YEAR | FRONT BRAKE MASTER CYLINDER | YEAR | FRONT BRAKE ROTOR | FRONT FENDER | YEAR | FRONT HUB | YEAR | GAS TANK | HEAD | YEAR | KICK IDLER GEAR | KICK LEVER | KICK LEVER SHAFT | KICK LEVER SHAFT GEAR | YEAR | OIL CAPACITY | RADIATOR LEFT | RADIATOR RIGHT | YEAR | RADIATOR SHROUD LEFT | RADIATOR SHROUD RIGHT | YEAR | RADIATOR SCREENS | REAR AXLE | YEAR | REAR BRAKE BACKING PLATE | REAR BRAKE LEVER | REAR FENDER | YEAR | REAR HUB | YEAR | REED VALVE | SEAT | SHOCK ARM LINKAGE | YEAR | SIDE COVER LEFT | SIDE COVER RIGHT | YEAR | SHIFT DRUM (CAM) | SHIFT FORKS | SHIFT LEVER | YEAR | SHIFT SHAFT | SHOCK | YEAR | STATOR | STATOR COVER | SUB FRAME | SWING ARM | YEAR | SWING ARM PIVOT PIN | THROTTLE | YEAR | THROTTLE CABLE | TRANSMISSION | TRIPLE TREE – UPPER | WIRE HARNESS | YEAR |
| 1974 | YZ125A | 453-000101 | FITS 74 YZ125, 74-75 MX125 MX175 401-15111-03-00 | | | 1974 | YZ125A | | 1974 | YZ125A | | | | | 1974 | YZ125A | | | | 1974 | | | | | | | | | 1974 | FITS 74 YZ125 ONLY 453-11311-00-00 | | | 1974 | | | | 1974 | | AIR COOLED NO VALVE | | 1974 | CONVENTIONAL – 30MM CHROME OD | 30MM X 40.5MM | 1974 | | | | 1974 | | 1974 | | | 1974 | | 1974 | FITS 74 YZ125, 74-75 MX125 453-11111-00-00 | | 1974 | | | | | 1974 | | | | 1974 | | | 1974 | | | 1974 | | | | 1974 | | 1974 | | | | 1974 | | | 1974 | | | | 1974 | | | 1974 | | | | | 1974 | | | 1974 | | | | | 1974 |
| 1975 | YZ125B | 453-100101 | | | | 1975 | YZ125B | | 1975 | YZ125B | | | | | 1975 | YZ125B | | | | 1975 | | | | | | | | | 1975 | | | | 1975 | | | | 1975 | | AIR COOLED NO VALVE | | 1975 | CONVENTIONAL – 30MM CHROME OD | 30MM X 40.5MM | 1975 | | | | 1975 | | 1975 | | | 1975 | | 1975 | | | 1975 | | | | | 1975 | | | | 1975 | | | 1975 | | | 1975 | | | | 1975 | | 1975 | | | | 1975 | | | 1975 | | | | 1975 | | | 1975 | | | | | 1975 | | | 1975 | | | | | 1975 |
| 1976 | YZ125C | 537-000101 | | | | 1976 | YZ125C | | 1976 | YZ125C | | | | | 1976 | YZ125C | | | | 1976 | | | | | | | | | 1976 | | | | 1976 | | | | 1976 | | AIR COOLED NO VALVE | | 1976 | CONVENTIONAL – 34MM CHROME OD | 34MM X 46MM X 10.5 | 1976 | | | | 1976 | | 1976 | | | 1976 | | 1976 | | | 1976 | | | | | 1976 | | | | 1976 | | | 1976 | | | 1976 | | | | 1976 | | 1976 | | | | 1976 | | | 1976 | | | | 1976 | | | 1976 | | | | | 1976 | | | 1976 | | | | | 1976 |
| 1976 1/2 | YZ125X | 1G8-000101 | | | | 1976 1/2 | YZ125X | | 1976 1/2 | YZ125X | | | | | 1976 1/2 | YZ125X | | | | 1976 1/2 | | | | | | | | | 1976 1/2 | | | | 1976 1/2 | | | | 1976 1/2 | | AIR COOLED NO VALVE | | 1976 1/2 | CONVENTIONAL – 34MM CHROME OD | 34MM X 46MM X 10.5 | 1976 1/2 | | | | 1976 1/2 | | 1976 1/2 | | | 1976 1/2 | | 1976 1/2 | | | 1976 1/2 | | | | | 1976 1/2 | | | | 1976 1/2 | | | 1976 1/2 | | | 1976 1/2 | | | | 1976 1/2 | | 1976 1/2 | | | | 1976 1/2 | | | 1976 1/2 | | | | 1976 1/2 | | | 1976 1/2 | | | | | 1976 1/2 | | | 1976 1/2 | | | | | 1976 1/2 |
| 1977 | YZ125D | 1W1-000101 | FITS 77-79 YZ100, 77-78 YZ125, 80-81 IT125 - 1W1-15111-02-00 | FITS 77-81 YZ100, 77-78 YZ125, 80-81 IT125 - 1W1-15121-02-00 | | 1977 | YZ125D | | 1977 | YZ125D | | | FITS 77-79 YZ125 YZ400, 77-80 YZ250, 80 YZ465 | | 1977 | YZ125D | | | | 1977 | | | | | | | | | 1977 | | | | 1977 | | | | 1977 | | AIR COOLED NO VALVE | | 1977 | CONVENTIONAL – 36MM CHROME OD | 36MM X 48MM X 10.5/11 | 1977 | | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | | 1977 | | 1977 | | | 1977 | | 1977 | | | 1977 | | | | | 1977 | | | | 1977 | | | 1977 | | | 1977 | | | | 1977 | | 1977 | | | | 1977 | | | 1977 | | | | 1977 | | | 1977 | | | | | 1977 | | | 1977 | FITS 77-79 YZ125, 77-80 YZ250, 77-79 YZ400, 80 YZ465 | | | | 1977 |
| 1978 | YZ125E | 2K6-000101 | FITS 77-79 YZ100, 77-78 YZ125, 80-81 IT125 - 1W1-15111-02-00 | FITS 77-81 YZ100, 77-78 YZ125, 80-81 IT125 - 1W1-15121-02-00 | | 1978 | YZ125E | | 1978 | YZ125E | | | FITS 77-79 YZ125 YZ400, 77-80 YZ250, 80 YZ465 | | 1978 | YZ125E | | | | 1978 | | | | | | | | | 1978 | | | | 1978 | | | | 1978 | | AIR COOLED NO VALVE | | 1978 | CONVENTIONAL – 36MM CHROME OD | 36MM X 48MM X 10.5/11 | 1978 | | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | | 1978 | | 1978 | | | 1978 | | 1978 | | | 1978 | | | | | 1978 | | | | 1978 | | | 1978 | | | 1978 | | | | 1978 | | 1978 | | | | 1978 | | | 1978 | | | | 1978 | | | 1978 | FITS 77 YZ100, 78 YZ125, 79-80 YZ80, 81 YZ100 | | | | 1978 | | | 1978 | FITS 77-79 YZ125, 77-80 YZ250, 77-79 YZ400, 80 YZ465 | | | | 1978 |
| 1979 | YZ125F | 2X3-000101 | | | | 1979 | YZ125F | | 1979 | YZ125F | | | FITS 77-79 YZ125 YZ400, 77-80 YZ250, 80 YZ465 | | 1979 | YZ125F | | | | 1979 | | | | | | | | | 1979 | | | | 1979 | | | | 1979 | | AIR COOLED NO VALVE | | 1979 | CONVENTIONAL – 36MM CHROME OD | 36MM X 48MM X 10.5/11 | 1979 | | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | | 1979 | | 1979 | | | 1979 | | 1979 | | | 1979 | | | | | 1979 | | | | 1979 | | | 1979 | | | 1979 | | | | 1979 | | 1979 | | | | 1979 | | | 1979 | | | | 1979 | | | 1979 | | | | | 1979 | | | 1979 | FITS 77-79 YZ125, 77-80 YZ250, 77-79 YZ400, 80 YZ465 | | | | 1979 |
| 1980 | YZ125G | 3R3-000101 | FITS 80 YZ125, 80-81 IT175 - 3R3-15111-02-00 | FITS 80 YZ125, 80-81 IT175 - 3R3-15121-02-00 | | 1980 | YZ125G | | 1980 | YZ125G | | | | MIKUNI | 1980 | YZ125G | FITS 80 YZ125, 80-81 IT175 – 3R3-13565-00-00 | HITACHI TYPE TIAO-37 3R3-11 | | 1980 | | | | | | | | | 1980 | | | | 1980 | | | | 1980 | | AIR COOLED NO VALVE | | 1980 | CONVENTIONAL – 36MM CHROME OD | 36MM X 48MM X 10.5/11 | 1980 | | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | | 1980 | | 1980 | | | 1980 | | 1980 | | | 1980 | | | | | 1980 | | | | 1980 | | | 1980 | | | 1980 | | | | 1980 | | 1980 | | | | 1980 | | | 1980 | | | | 1980 | | | 1980 | | | | | 1980 | | | 1980 | | | | | 1980 |
| 1981 | YZ125H | 4V2-000101 | FITS 81 YZ125 ONLY - 4V2-15111-00-00 | FITS 81 YZ125, 82-83 IT175 YZ100 - 4V2-15121-00-00 | | 1981 | YZ125H | | 1981 | YZ125H | | | | MIKUNI | 1981 | YZ125H | | | | 1981 | | | | | | | | | 1981 | | | | 1981 | | | | 1981 | | N/A | | 1981 | CONVENTIONAL – CHROME OD 38MM - C/L 37" | 38MM X 50MM X 8 | 1981 | | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | | 1981 | | 1981 | | | 1981 | | 1981 | | | 1981 | | | | | 1981 | | | | 1981 | | | 1981 | | | 1981 | | | | 1981 | | 1981 | | | | 1981 | | | 1981 | | | | 1981 | | | 1981 | | | | | 1981 | | | 1981 | | | | | 1981 |
| 1982 | YZ125J | 5X4-000101 | FITS 82 YZ125 ONLY - 5X4-15111-00-00 | FITS 82 YZ125 ONLY - 5X4-15121-00-00 | | 1982 | YZ125J | | 1982 | YZ125J | | | | | 1982 | YZ125J | | | | 1982 | | | | | | | | | 1982 | | | | 1982 | | | | 1982 | FITS 82-87 YZ125, 86-98 YZ250, 91-97 WR250 | FITS 82-85 YZ125 24X-11990-00-00 | | 1982 | CONVENTIONAL – 38MM CHROME OD | 38MM X 50MM X 8 | 1982 | FITS 80-85 YZ250, 80-81 YZ465, 82-85 YZ125 & YZ490 | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | | 1982 | | 1982 | | | 1982 | 23X00 15MM AXLE DIA - BRG TO BRG 94MM - FITS 82-84 YZ250 & 125, 82 IT465, 82 TT250, 82 IT175, 83-84 TT600, 83 YZ490 | 1982 | | | 1982 | | | | | 1982 | | | | 1982 | | | 1982 | | | 1982 | | | | 1982 | | 1982 | | | | 1982 | | | 1982 | | | | 1982 | | | 1982 | | | | | 1982 | | | 1982 | | | | | 1982 |
| 1983 | YZ125K | 24X-000101 | 24X-15111-00-00 FITS 83-85 YZ125 | 24X-15121-00-00 FITS 83-84 YZ125 | | 1983 | YZ125K | FITS 83-85 YZ125 | 1983 | YZ125K | | FITS 82-84 YZ490, 83-84 YZ125, 83 YZ250 5X6-26341-00-00 | | | 1983 | YZ125K | | | | 1983 | | | | | | | | | 1983 | FITS 83-84 YZ125 | | | 1983 | | | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1983 | FITS 82-87 YZ125, 86-98 YZ250, 91-97 WR250 | FITS 82-85 YZ125 24X-11990-00-00 | | 1983 | CONVENTIONAL – 38MM CHROME OD | 38MM X 50MM X 8 | 1983 | FITS 80-85 YZ250, 80-81 YZ465, 82-85 YZ125 & YZ490 | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | | 1983 | | 1983 | | | 1983 | 23X00 15MM AXLE DIA - BRG TO BRG 94MM - FITS 82-84 YZ250 & 125, 82 IT465, 82 TT250, 82 IT175, 83-84 TT600, 83 YZ490 | 1983 | | 24X – FITS 83-84 YZ125 – 24X-11111-00-00 | 1983 | | | | | 1983 | | | | 1983 | | | 1983 | | | 1983 | | | | 1983 | 24X00 - BLACK - DRUM BRAKE - 17MM AXLE - OUTSIDE OF BEARINGS 134MM - 130MM DRUM - SPROCKET 6 ON A 175MM BC - FITS 83-85 YZ125 | 1983 | | | | 1983 | | | 1983 | | | | 1983 | | | 1983 | | | | | 1983 | | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1983 | | | | | 1983 |
| 1984 | YZ125L | 39W-000101 | 24X-15111-00-00 FITS 83-85 YZ125 | 24X-15121-00-00 FITS 83-84 YZ125 | | 1984 | YZ125L | FITS 83-85 YZ125 | 1984 | YZ125L | | FITS 82-84 YZ490, 83-84 YZ125, 83 YZ250 5X6-26341-00-00 | | MIKUNI 37W | 1984 | YZ125L | | HITACHI TYPE TIAO-49 39W-10 | | 1984 | | | | | | | CM61-29 CDIA | | 1984 | FITS 83-84 YZ125 | | | 1984 | | | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1984 | FITS 82-87 YZ125, 86-98 YZ250, 91-97 WR250 | FITS 82-85 YZ125 24X-11990-00-00 | | 1984 | CONVENTIONAL – 43MM CHROME OD | 43MM X 54MM X 11 | 1984 | FITS 80-85 YZ250, 80-81 YZ465, 82-85 YZ125 & YZ490 | FITS 76-81 YZ250, 76-79 YZ400, 77-84 YZ125 | | 1984 | | 1984 | | | 1984 | 23X00 15MM AXLE DIA - BRG TO BRG 94MM - FITS 82-84 YZ250 & 125, 82 IT465, 82 TT250, 82 IT175, 83-84 TT600, 83 YZ490 | 1984 | | FITS 83-84 YZ125 – 24X-11111-00-00 | 1984 | | | | | 1984 | | | | 1984 | | | 1984 | | | 1984 | | | | 1984 | 24X00 - BLACK - DRUM BRAKE - 17MM AXLE - OUTSIDE OF BEARINGS 134MM - 130MM DRUM - SPROCKET 6 ON A 175MM BC - FITS 83-85 YZ125 | 1984 | | | | 1984 | | | 1984 | | | | 1984 | | | 1984 | | | | | 1984 | | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1984 | | | | | 1984 |
| 1985 | YZ125N | 55Y-000101 | 24X-15111-00-00 FITS 83-85 YZ125 | | | 1985 | YZ125N | FITS 83-85 YZ125 | 1985 | YZ125N | | | | MIKUNI | 1985 | YZ125N | | HITACHI TYPE TIAOI-51 55Y-10 | | 1985 | | | | | | | CM61-29 CDIA | | 1985 | | | FITS 1985 YZ125 ONLY | 1985 | | | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1985 | FITS 82-87 YZ125, 86-98 YZ250, 91-97 WR250 | FITS 82-85 YZ125 24X-11990-00-00 | M100-39 55Y | 1985 | CONVENTIONAL - Y111-R SA-1 Y111-L SA-1 - CHROME OD 43MM - C/L 36 3/4" - BRAKE MOUNT C/L 85MM - AXLE 20MM & 15MM | 43MM X 54MM X 11 | 1985 | FITS 80-85 YZ250, 80-81 YZ465, 82-85 YZ125 & YZ490 | | FITS 85-88 YZ125 YZ250, 85-90 YZ490 | 1985 | | 1985 | 240MM OD - ID 117.5MM - BOLTS 4 ON BC ON 130MM - FITS 85 YZ125, 250, 490 | FITS 85-90 YZ125 490, 85-88 YZ250, 80-81 IT250 IT175 IT250, 80 IT400, 81 IT465 - 5X6-21511-11-00 - 55MM C/L WIDTH, 65MM C/L LENGTH | 1985 | 56A00 15MM AXLE DIA - BRG TO BRG 94MM - ROTOR BOLTS 4 ON BC ON 130MM - FITS 1985 YZ250 & 125 | 1985 | | 55Y FITS 85 YZ125 ONLY 55Y-11111-00-00 | 1985 | | | | | 1985 | | | | 1985 | | | 1985 | | | 1985 | | | | 1985 | 24X00 - BLACK - DRUM BRAKE - 17MM AXLE - OUTSIDE OF BEARINGS 134MM - 130MM DRUM - SPROCKET 6 ON A 175MM BC - FITS 83-85 YZ125 | 1985 | | | | 1985 | | | 1985 | | | | 1985 | | | 1985 | | | | | 1985 | | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1985 | | | | | 1985 |
| 1986 | YZ125S | 1LX-00 FITS 86-87 | FITS 86-87 YZ125 – 99999-01806-00 SET NUMBER | FITS 86-87 YZ125 - 1LX-15121-02-00 | | 1986 | YZ125S | | 1986 | YZ125S | | | | | 1986 | YZ125S | | | | 1986 | | | | | | | | | 1986 | | | | 1986 | | | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1986 | FITS 82-87 YZ125, 86-98 YZ250, 91-97 WR250 | FITS 86-87 YZ125 1LX-11990-00-00 | | 1986 | CONVENTIONAL – 43MM CHROME OD | 43MM X 55MM X 9.5/10.5/11 | 1986 | FITS 86-91 YZ125 YZ250, 86-90 YZ490, ANY MANY OTHERS | | FITS 85-88 YZ125 YZ250, 85-90 YZ490 | 1986 | | 1986 | | FITS 85-90 YZ125 490, 85-88 YZ250, 80-81 IT250 IT175 IT250, 80 IT400, 81 IT465 - 5X6-21511-11-00 - 55MM C/L WIDTH, 65MM C/L LENGTH | 1986 | | 1986 | FITS 86-88 YZ125 – 1LX-24110-00-00 | FITS 86-89 YZ125 | 1986 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1986 | | FITS 86-88 YZ125, 86-87 YZ250 | FITS 86-92 YZ125, 92 WR200 | 1986 | | | 1986 | BLACK – FITS 83-89 YZ250, 86-89 YZ125, 89 YZ250WR - 24Y-2172A-01-00 | | 1986 | | | FITS 86-90 YZ125 YZ250 YZ490 - 1LX-21611-00-00 | 1986 | | 1986 | | 5X6 – FITS 86-88 YZ125, YZ250, YZ490 1LX-24770-10-00 | FITS 86-90 YZ490, 86 YZ125, 87 YZ250 | 1986 | LEFT 1LX-21711-01-98 - FITS 86-88 YZ125, 86-87 YZ250, 86-90 YZ490 | RIGHT - 99999-01787-00 - FITS 86-87 YZ125 YZ250 YZ490 | 1986 | | | FITS 86-95 YZ125 | 1986 | FITS 86-90 YZ125 | | 1986 | | | | | 1986 | | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1986 | | | | | 1986 |
| 1987 | YZ125T | 2HG-00 FITS 86-87 | FITS 86-87 YZ125 – 99999-01806-00 SET NUMBER | FITS 86-87 YZ125 - 1LX-15121-02-00 | | 1987 | YZ125T | FITS 87-88 YZ125, 86-87 YZ250, 87-90 YZ490 | 1987 | YZ125T | FITS 87-88 YZ125 | | | | 1987 | YZ125T | | | | 1987 | | | | | | | | | 1987 | | | | 1987 | | | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1987 | FITS 82-87 YZ125, 86-98 YZ250, 91-97 WR250 | FITS 86-87 YZ125 1LX-11990-00-00 | FP8167 2HG | 1987 | KAYABA - CONVENTIONAL - Y1LX-R - Y1LX-L - CHROME OD 43MM - C/L 36 3/4" - BRAKE MOUNT C/L 85MM - AXLE 20MM & 15MM | 43MM X 55MM X 9.5/10.5/11 | 1987 | FITS 86-91 YZ125 YZ250, 86-90 YZ490, ANY MANY OTHERS | | FITS 85-88 YZ125 YZ250, 85-90 YZ490 | 1987 | | 1987 | | FITS 85-90 YZ125 490, 85-88 YZ250, 80-81 IT250 IT175 IT250, 80 IT400, 81 IT465 - 5X6-21511-11-00 - 55MM C/L WIDTH, 65MM C/L LENGTH | 1987 | 2HH00 - BLACK - 15MM AXLE DIA - BRG TO BRG 86.7MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - 36 SPOKES - FITS 87-89 YZ125, YZ250 & 87-90 YZ490 | 1987 | FITS 86-88 YZ125 – 1LX-24110-00-00 | 1LX FITS 86-89 YZ125 | 1987 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1987 | | FITS 86-88 YZ125, 86-87 YZ250 | FITS 86-92 YZ125, 92 WR200 | 1987 | FITS 87-88 YZ125 2HG-21731-00-00 | FITS 87-88 YZ125 2HG-21741-00-00 | 1987 | BLACK – FITS 83-89 YZ250, 86-89 YZ125, 89 YZ250WR - 24Y-2172A-01-00 | | 1987 | FITS 83-87 YZ250, 87 YZ125, 83 YZ490 | | FITS 86-90 YZ125 YZ250 YZ490 - 1LX-21611-00-00 | 1987 | | 1987 | | 5X6 – FITS 86-88 YZ125, YZ250, YZ490 1LX-24770-10-00 | | 1987 | LEFT 1LX-21711-01-98 - FITS 86-88 YZ125, 86-87 YZ250, 86-90 YZ490 | RIGHT - 99999-01787-00 - FITS 86-87 YZ125 YZ250 YZ490 | 1987 | | | FITS 86-95 YZ125 | 1987 | FITS 86-90 YZ125 | | 1987 | | | | FITS 87-88 YZ125 | 1987 | | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1987 | | | | | 1987 |
| 1988 | YZ125U | 2VN-00 | FITS 88-91 YZ125 – 1LX-15111-12-00 | FITS 88-90 YZ125 – 1LX-15121-11-00 | | 1988 | YZ125U | FITS 87-88 YZ125, 86-87 YZ250, 87-90 YZ490 | 1988 | YZ125U | FITS 87-88 YZ125 | | | MIKUNI TM 35MM | 1988 | YZ125U | FITS 88 YZ125 ONLY – 2VN-13565-00-00 – C/L TO C/L HORIZONTAL 71MM, VERTICAL 57.5MM | KOKUSAN DENKI 2VN CU16 | | 1988 | | FITS 88 YZ125 ONLY | | | | | | | 1988 | | | ONLY FITS 1988 | 1988 | | | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1988 | | FITS 88 YZ125 ONLY 2VN-11990-00-00 | 2VN FP5147 | 1988 | CONVENTIONAL – 43MM CHROME OD | 43MM X 55MM X 9.5/10.5/11 | 1988 | FITS 86-91 YZ125 YZ250, 86-90 YZ490, ANY MANY OTHERS | | FITS 85-88 YZ125 YZ250, 85-90 YZ490 | 1988 | | 1988 | OD 230MM - ID 86MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - FITS 85-86 TT600, TT350 - 86 IT200 - 88 YZ125, YZ250 - 88-90 YZ490 | FITS 85-90 YZ125 490, 85-88 YZ250, 80-81 IT250 IT175 IT250, 80 IT400, 81 IT465 - 5X6-21511-11-00 - 55MM C/L WIDTH, 65MM C/L LENGTH | 1988 | 2HH00 - BLACK - 15MM AXLE DIA - BRG TO BRG 86.7MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - 36 SPOKES - FITS 87-89 YZ125, YZ250 & 87-90 YZ490 | 1988 | FITS 86-88 YZ125 – 1LX-24110-00-00 | FITS 86-89 YZ125 | 1988 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1988 | | FITS 86-88 YZ125, 86-87 YZ250 | FITS 86-92 YZ125, 92 WR200 | 1988 | FITS 87-88 YZ125 2HG-21731-00-00 | FITS 87-88 YZ125 2HG-21741-00-00 | 1988 | BLACK – FITS 83-89 YZ250, 86-89 YZ125, 89 YZ250WR - 24Y-2172A-01-00 | | 1988 | | 2VN-27200-01-00 FITS 88 YZ125 ONLY | FITS 86-90 YZ125 YZ250 YZ490 - 1LX-21611-00-00 | 1988 | 2VN00 BLACK - 20MM AXLE DIA - OUTSIDE OF BRGS 131MM - ROTOR DIA 220MM - ROTOR 6 BOLTS ON A 133MM BOLT CIRCLE - SPROCKET 6 ON 175MM BC - 36 SPOKES - FITS 88-89 YZ125 & 250 | 1988 | FITS 88-92 YZ125 – 2VN-13610-00-00 – C/L TO C/L HORIZONTAL 71MM, VERTICAL 57.5MM | 5X6 – FITS 86-88 YZ125, YZ250, YZ490 1LX-24770-10-00 | | 1988 | LEFT 1LX-21711-01-98 - FITS 86-88 YZ125, 86-87 YZ250, 86-90 YZ490 | | 1988 | | | FITS 86-95 YZ125 | 1988 | FITS 86-90 YZ125 | | 1988 | | | | FITS 87-88 YZ125 | 1988 | | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1988 | | SHAFTS AND GEARS FIT 88 YZ125 ONLY | | | 1988 |
| 1989 | YZ125W | 3JD-00 | FITS 88-91 YZ125 – 1LX-15111-12-00 | FITS 88-90 YZ125 – 1LX-15121-11-00 | JYA3JDW02KA00XXXX | 1989 | YZ125W | | 1989 | YZ125W | | | FITS 89-93 YZ125 YZ250, 91 WR250 | MIKUNI TM | 1989 | YZ125W | 3JD | | | 1989 | | FITS 89-90 YZ125 | | 3JD00 T-1 FITS 89-93 | | | CM61-29 CDIA | FITS 1989 ONLY | 1989 | FITS 1989 ONLY | | ONLY FITS 1989 | 1989 | | | 39W – FIT'S 83-89 YZ125, 86-88 YZ250 - 39W-W1132-00-00 | 1989 | | FITS 89 YZ125 ONLY 3JD-11990-00-00 | 3JD FP5211 81 | 1989 | USD - 3S-L 3S-R - CHROME OD IS 41MM - RED UPPERS - C/L 37" - UPPER 49.9MM - LOWER 55.6MM - C/L OF CALIPER 78MM - AXLE 15MM & 20MM | 41MM X 53MM X 8/9.5/10.5 | 1989 | FITS 86-91 YZ125 YZ250, 86-90 YZ490, ANY MANY OTHERS | | FITS 89 YZ125 YZ250 YZ250WR, 92-93 WR500 | 1989 | | 1989 | OD 230MM - ID 86MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - FITS 89 YZ 125, 250, 250WR, 92-93 WR500 | FITS 85-90 YZ125 490, 85-88 YZ250, 80-81 IT250 IT175 IT250, 80 IT400, 81 IT465 - 5X6-21511-11-00 - 55MM C/L WIDTH, 65MM C/L LENGTH | 1989 | 2HH00 - BLACK - 15MM AXLE DIA - BRG TO BRG 86.7MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - 36 SPOKES - FITS 87-89 YZ125, YZ250 & 87-90 YZ490 | 1989 | FITS 89-92 YZ125 | FITS 86-89 YZ125 | 1989 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1989 | 650 CM3 | | FITS 86-92 YZ125, 92 WR200 | 1989 | | | 1989 | BLACK – FITS 83-89 YZ250, 86-89 YZ125, 89 YZ250WR - 24Y-2172A-01-00 | FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F | 1989 | | | FITS 86-90 YZ125 YZ250 YZ490 - 1LX-21611-00-00 | 1989 | 2VN00 BLACK - 20MM AXLE DIA - OUTSIDE OF BRGS 131MM - ROTOR DIA 220MM - ROTOR 6 BOLTS ON A 133MM BOLT CIRCLE - SPROCKET 6 ON 175MM BC - 36 SPOKES - FITS 88-89 YZ125 & 250 | 1989 | | | 3JD-2 89-90 YZ125, 90 YZ250 & YZ250WR | 1989 | FITS 88-90 YZ250 89-90 YZ125 | | 1989 | | 3JD – 2VN | FITS 86-95 YZ125 | 1989 | FITS 86-90 YZ125 | | 1989 | 9F | | | | 1989 | | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1989 | | | UPPER APPROX. 49.8MM - LOWER APPROX. 55.4MM - C/L 185MM | | 1989 |
| 1990 | YZ125A1 | 3SR-00 | FITS 88-91 YZ125 – 1LX-15111-12-00 | FITS 88-90 YZ125 – 1LX-15121-11-00 | | 1990 | YZ125A1 | FITS 90 YZ125 YZ250 YZ250WR | 1990 | YZ125A1 | | | FITS 89-93 YZ125 YZ250, 91 WR250 | MIKUNI TM | 1990 | YZ125A1 | | | | 1990 | | FITS 89-90 YZ125 | | FITS 89-93 | | | | | 1990 | | | | 1990 | | | FITS 89-94 96-98 YZ250, 90-91 YZ125, 91-97 WR250 | 1990 | | FITS 90-93 YZ125 3SR-11990-00-00 | F3T81671 8Y01 FITS 90-91 | 1990 | USD - 3S-L 3S-R - CHROME OD IS 41MM - RED UPPERS - C/L 37" - UPPER 49.9MM - LOWER 55.6MM - C/L OF CALIPER 78MM - AXLE 15MM & 20MM | 41MM X 53MM X 8/9.5/10.5 | 1990 | FITS 86-91 YZ125 YZ250, 86-90 YZ490, ANY MANY OTHERS | | | 1990 | | 1990 | ROTOR OD 245MM, ID 86MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - FITS 90-91 YZ125 & YZ250, 91 WR250 | FITS 85-90 YZ125 490, 85-88 YZ250, 80-81 IT250 IT175 IT250, 80 IT400, 81 IT465 - 5X6-21511-11-00 - 55MM C/L WIDTH, 65MM C/L LENGTH | 1990 | 2HH00- GRAY - 15MM AXLE DIA - BRG TO BRG 86-87MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - FITS 90-91 YZ125 & YZ250, 91 WR250, 92-93 WR500 | 1990 | FITS 89-92 YZ125 | FITS 86-89 YZ125 | 1990 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1990 | | | FITS 86-92 YZ125, 92 WR200 | 1990 | | | 1990 | | FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F | 1990 | | | FITS 86-90 YZ125 YZ250 YZ490 - 1LX-21611-00-00 | 1990 | 2VN00 SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR DIA 220MM (8 5/8") ROTOR BOLT CIRCLE 6 BOLTS ON A 133MM DIA - SPROCKET BOLT CIRCLE 6 BOLTS ON A 175MM DIA - FITS 90-98 YZ125 & YZ250, 91-97 WR250, 98 WR400F | 1990 | | | 3JD-2 89-90 YZ125, 90 YZ250 & YZ250WR | 1990 | FITS 88-90 YZ250 89-90 YZ125 | | 1990 | | | FITS 86-95 YZ125 | 1990 | FITS 86-90 YZ125 | SPRING THICKNESS: 11.2MM OD - SPRING DIAMETER: 87.5MM - SPRING LENGTH AS MOUNTED: 254MM - UPPER MOUNT TAB THICKNESS: 25.8MM - UPPER MOUNT TAB HOLE ID: 10MM - LOWER MOUNT WIDTH: 19.6MM - LOWER MOUNT HOLE ID: 10MM - EYE TO EYE: 490MM | 1990 | FITS 90-91 | | | | 1990 | | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1990 | | | UPPER APPROX. 49.8MM - LOWER APPROX. 55.4MM - C/L 185MM | | 1990 |
| 1991 | YZ125B1 | 3XJ-00 | FITS 88-91 YZ125 – 1LX-15111-12-00 | FITS 91-92 YZ125 – 1LX-15121-12-00 | JYA3XJW06MA40XXXX | 1991 | YZ125B1 | FITS 91-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 | 1991 | YZ125B1 | | | FITS 89-93 YZ125 YZ250, 91 WR250 | MIKUNI TM | 1991 | YZ125B1 | | | | 1991 | | FITS 91-92 YZ125 | | FITS 89-93 | | | | | 1991 | FITS 91 YZ125 ONLY | | | 1991 | | | FITS 89-94 96-98 YZ250, 90-91 YZ125, 91-97 WR250 | 1991 | | FITS 90-93 YZ125 3SR-11990-00-00 | F3T81671 1080 FITS 90-91 | 1991 | USD - 3S-L 3S-R - CHROME OD 43MM - C/L 37 1/2" - UPPER 51.9MM - LOWER 56.6MM - C/L OF CALIPER MOUNT 78MM - AXLE 15MM & 20MM | 43MM X 55MM X 9.5/10.5/11 | 1991 | FITS 86-91 YZ125 YZ250, 86-90 YZ490, ANY MANY OTHERS | | | 1991 | | 1991 | ROTOR OD 245MM, ID 86MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - FITS 90-91 YZ125 & YZ250, 91 WR250 | | 1991 | 2HH00- GRAY - 15MM AXLE DIA - BRG TO BRG 86-87MM - 6 BOLTS UNEQUAL SPACING ON A 102MM BOLT CIRCLE - FITS 90-91 YZ125 & YZ250, 91 WR250, 92-93 WR500 | 1991 | FITS 89-92 YZ125 | 3XJ | 1991 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1991 | | | FITS 86-92 YZ125, 92 WR200 | 1991 | | | 1991 | | FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F | 1991 | | | FITS 91 YZ125 YZ250 WR250, 92 WR500 - 3XJ-21611-01-00 | 1991 | 2VN00 SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR DIA 220MM (8 5/8") ROTOR BOLT CIRCLE 6 BOLTS ON A 133MM DIA - SPROCKET BOLT CIRCLE 6 BOLTS ON A 175MM DIA - FITS 90-98 YZ125 & YZ250, 91-97 WR250, 98 WR400F | 1991 | | | | 1991 | | | 1991 | | | FITS 86-95 YZ125 | 1991 | FITS 91-93 YZ125 | | 1991 | FITS 90-91 | | | | 1991 | | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1991 | | | UPPER 51.9MM - LOWER 56.6MM - C/L 185MM | | 1991 |
| 1992 | YZ125D1 | 4DB-00 | FITS 92 YZ125 ONLY – 4DB-15111-00-00 | FITS 91-92 YZ125 – 1LX-15121-12-00 | | 1992 | YZ125D1 | FITS 91-92 YZ125 YZ250, 91-93 WR250, 92-93 WR500 | 1992 | YZ125D1 | | | FITS 89-93 YZ125 YZ250, 91 WR250 | MIKUNI TM | 1992 | YZ125D1 | | | | 1992 | | FITS 91-92 YZ125 | | FITS 89-93 | | | | | 1992 | 4DB 124CM3 Y-2 | | | 1992 | | | | 1992 | | FITS 90-93 YZ125 3SR-11990-00-00 | F4T800 1X01 | 1992 | USD - CHROME OD 43MM - C/L 37 1/4" | 43MM X 55MM X 9.5/10.5/11 | 1992 | FITS 92-97 WR250, 92-95 YZ125 YZ250 | | | 1992 | | 1992 | ROTOR OD 245MM ID 118.5MM - ROTOR 6 ON A 134MM BOLT CIRCLE - FITS 92-96 YZ125, YZ250, WR250 | FITS 92-95 YZ125, 92-96 YZ250 WR250 - 4DA-21511-00-00 | 1992 | 145-FR - AXLE OD 17MM - BRG TO BRG 69-70MM - ROTOR BC 6 ON 133MM - FITS 92-95 YZ125 & YZ250, 92-97 WR250 | 1992 | FITS 89-92 YZ125 | 4DB FITS 92 YZ125 ONLY 4DB-11111-00-00 | 1992 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 86-92 YZ125 4DB-15620-01-00 | FITS 86-92 1LX-15660-00-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1992 | | | FITS 86-92 YZ125, 92 WR200 | 1992 | | | 1992 | | FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F | 1992 | | | FITS 92 YZ125 YZ250, 92-93 WR250, 93 WR500 - 3XJ-21611-02-00 | 1992 | 2VN00 SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR DIA 220MM (8 5/8") ROTOR BOLT CIRCLE 6 BOLTS ON A 133MM DIA - SPROCKET BOLT CIRCLE 6 BOLTS ON A 175MM DIA - FITS 90-98 YZ125 & YZ250, 91-97 WR250, 98 WR400F | 1992 | | | | 1992 | | | 1992 | | | FITS 86-95 YZ125 | 1992 | FITS 91-93 YZ125 | | 1992 | FITS 92 YZ125 ONLY | | | | 1992 | | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1992 | | | | | 1992 |
| 1993 | YZ125E1 | 4EX-00 | FITS 93 YZ125 ONLY – 4EX-15111-00-00 | FITS 93 YZ125 ONLY – 4EX-15121-00-00 | | 1993 | YZ125E1 | FITS 93-94 YZ125 YZ250 | 1993 | YZ125E1 | | | FITS 89-93 YZ125 YZ250, 91 WR250 | | 1993 | YZ125E1 | | | | 1993 | | FITS 93 YZ125 ONLY | | FITS 89-93 | FITS 93-2011 YZ125 | | | | 1993 | | | | 1993 | | | | 1993 | | FITS 90-93 YZ125 3SR-11990-00-00 | | 1993 | USD – CHROME OD 43MM – LEFT 4EX-23102-L0-00, RIGHT 4EX-23103-L0-00 | 43MM X 55MM X 9.5/10.5/11 | 1993 | FITS 92-97 WR250, 92-95 YZ125 YZ250 | | FITS 93-97 YZ125 YZ250, 94-97 WR250 | 1993 | | 1993 | ROTOR OD 245MM ID 118.5MM - ROTOR 6 ON A 134MM BOLT CIRCLE - FITS 92-96 YZ125, YZ250, WR250 | FITS 92-95 YZ125, 92-96 YZ250 WR250 - 4DA-21511-00-00 | 1993 | 145-FR - AXLE OD 17MM - BRG TO BRG 69-70MM - ROTOR BC 6 ON 133MM - FITS 92-95 YZ125 & YZ250, 92-97 WR250 | 1993 | | 4EX FITS 93 YZ125 ONLY 4EX-11111-00-00 | 1993 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 93 YZ125 4DB-15620-02-00 | FITS 93 YZ125 1LX-15660-01-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1993 | | | | 1993 | FITS 93-95 YZ125 YZ250, 94-95 WR250 - 4EW-21731-00-00 | FITS 93-95 YZ125 YZ250, 94-95 WR250 - 4EW-21741-00-00 | 1993 | | FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F | 1993 | | | | 1993 | 2VN00 SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR DIA 220MM (8 5/8") ROTOR BOLT CIRCLE 6 BOLTS ON A 133MM DIA - SPROCKET BOLT CIRCLE 6 BOLTS ON A 175MM DIA - FITS 90-98 YZ125 & YZ250, 91-97 WR250, 98 WR400F | 1993 | | FITS 93 YZ125 YZ250, 4EW-24770-10-00 | FITS 93-95 YZ125 YZ250, 94-97 WR250 | 1993 | | | 1993 | | | FITS 86-95 YZ125 | 1993 | FITS 91-93 YZ125 | | 1993 | | | | | 1993 | | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1993 | | | | | 1993 |
| 1994 | YZ125F1 | 4JY-00 | FITS 94-95 YZ125 – 4JY-15111-00-00 | FITS 94-95 YZ125 – 4JY-15121-00-00 | | 1994 | YZ125F1 | FITS 93-94 YZ125 YZ250 | 1994 | YZ125F1 | | | | | 1994 | YZ125F1 | | FITS 94-95 YZ125 | | 1994 | FITS 94-95 YZ125, YZ250 | FITS 94-04 YZ125, 96 YZ250 | | | FITS 93-2011 YZ125 | | | | 1994 | FITS 94-95 YZ125 | | FITS 94 YZ125 ONLY LEFT 4JY-1131A-00-00, RIGHT 4JY-1132A-00-00 | 1994 | | FITS 94-04 YZ125 | | 1994 | | FITS 94-95 YZ125 4JY-11990-00-00 | F5T306 FITS 94-95 | 1994 | KYB - USD - CHROME OD 43MM - C/L 36 3/4" - UPPER 51.9MM - LOWER 56.6MM - C/L OF BRAKE MOUNT 78MM - AXLE 17MM & 22MM | 43MM X 55MM X 9.5/10.5/11 | 1994 | FITS 92-97 WR250, 92-95 YZ125 YZ250 | | FITS 93-97 YZ125 YZ250, 94-97 WR250 | 1994 | | 1994 | ROTOR OD 245MM ID 118.5MM - ROTOR 6 ON A 134MM BOLT CIRCLE - FITS 92-96 YZ125, YZ250, WR250 | FITS 92-95 YZ125, 92-96 YZ250 WR250 - 4DA-21511-00-00 | 1994 | 145-FR - AXLE OD 17MM - BRG TO BRG 69-70MM - ROTOR BC 6 ON 133MM - FITS 92-95 YZ125 & YZ250, 92-97 WR250 | 1994 | | 4JY Y-2 FITS 94-95, 98-00 | 1994 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 94-96 YZ125 1LX-15660-02-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1994 | | | | 1994 | FITS 93-95 YZ125 YZ250, 94-95 WR250 - 4EW-21731-00-00 | FITS 93-95 YZ125 YZ250, 94-95 WR250 - 4EW-21741-00-00 | 1994 | | FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F | 1994 | | | | 1994 | 2VN00 SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR DIA 220MM (8 5/8") ROTOR BOLT CIRCLE 6 BOLTS ON A 133MM DIA - SPROCKET BOLT CIRCLE 6 BOLTS ON A 175MM DIA - FITS 90-98 YZ125 & YZ250, 91-97 WR250, 98 WR400F | 1994 | | FITS 94 YZ125, 250 4JX-24770-00-00 | FITS 93-95 YZ125 YZ250, 94-97 WR250 | 1994 | | | 1994 | | | FITS 86-95 YZ125 | 1994 | FITS 94-95 YZ125 | | 1994 | | | | | 1994 | | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1994 | | | 4JX - FITS 94-95 YZ125, 94 YZ250, 94-97 WR250 - 4JX-23435-00-00 | | 1994 |
| YEAR | TYPE | ENGINE ID | ENGINE CASE LEFT | ENGINE CASE RIGHT | VIN FRAME USA ONLY | YEAR | TYPE | AIR BOX | YEAR | TYPE | AIR BOX TO CARBURETOR BOOT | CABLE FRONT BRAKE | CABLE THROTTLE | CARBURETOR | YEAR | TYPE | CARBURETOR BOOT | CDI | CHAIN GUIDE | YEAR | CHAIN PULLER BLOCKS | CLUTCH BASKET | CLUTCH COVER | CLUTCH COVER INNER | CLUTCH BOSS INNER | CLUTCH PRESSURE PLATE OUTER | COIL | CRANK SHAFT | YEAR | CYLINDER | ENGINE MOUNTS UPPER | EXHAUST VALVE | YEAR | EXHAUST VALVE COVER FRONT | EXHAUST VALVE COVER RIGHT | EXHAUST VALVE HOLDER LEFT | YEAR | EXHAUST VALVE HOLER RIGHT | EXHAUST VALVE LINKAGE (PUSH ROD ASY) | FLY WHEEL ROTOR | YEAR | FORK INFO | | YEAR | FRONT AXLE | FRONT BRAKE BACKING PLATE | FRONT BRAKE CALIPER | YEAR | FRONT BRAKE MASTER CYLINDER | YEAR | FRONT BRAKE ROTOR | FRONT FENDER | YEAR | FRONT HUB | YEAR | GAS TANK | HEAD | YEAR | KICK IDLER GEAR | KICK LEVER | KICK LEVER SHAFT | KICK LEVER SHAFT GEAR | YEAR | OIL CAPACITY | RADIATOR LEFT | RADIATOR RIGHT | YEAR | RADIATOR SHROUD LEFT | RADIATOR SHROUD RIGHT | YEAR | RADIATOR SCREENS | REAR AXLE | YEAR | REAR BRAKE BACKING PLATE | REAR BRAKE LEVER | REAR FENDER | YEAR | REAR HUB | YEAR | REED VALVE | SEAT | SHOCK ARM LINKAGE | YEAR | SIDE COVER LEFT | SIDE COVER RIGHT | YEAR | SHIFT DRUM (CAM) | SHIFT FORKS | SHIFT LEVER | YEAR | SHIFT SHAFT | SHOCK | YEAR | STATOR | STATOR COVER | SUB FRAME | SWING ARM | YEAR | SWING ARM PIVOT PIN | THROTTLE | YEAR | THROTTLE CABLE | TRANSMISSION | TRIPLE TREE – UPPER | WIRE HARNESS | YEAR |
| 1995 | YZ125G1 | 4PE-00 | FITS 94-95 YZ125 – 4JY-15111-00-00 | FITS 94-95 YZ125 – 4JY-15121-00-00 | | 1995 | YZ125G1 | FITS 95 YZ125 YZ250 | 1995 | YZ125G1 | | | | MIKUNI TM | 1995 | YZ125G1 | FITS 95-98 YZ125 - 71.5MM W X 58MM H | FITS 94-95 YZ125 | | 1995 | FITS 94-95 YZ125, YZ250 | FITS 94-04 YZ125, 96 YZ250 | | | FITS 93-2011 YZ125 | | | | 1995 | FITS 94-95 YZ125 | | | 1995 | | FITS 94-04 YZ125 | | 1995 | | FITS 94-95 YZ125 4JY-11990-00-00 | F4T306 FITS 94-95 | 1995 | KYB - USD - CHROME OD 43MM - C/L 36 7/8" - UPPER 51.9MM LOWER 57.4MM - C/L OF BRAKE MOUNT 78MM - AXLE 17MM & 22MM | 43MM X 55MM X 9.5/10.5/11 | 1995 | FITS 92-97 WR250, 92-95 YZ125 YZ250 | | FITS 93-97 YZ125 YZ250, 94-97 WR250 | 1995 | | 1995 | ROTOR OD 245MM ID 118.5MM - ROTOR 6 ON A 134MM BOLT CIRCLE - FITS 92-96 YZ125, YZ250, WR250 | FITS 92-95 YZ125, 92-96 YZ250 WR250 - 4DA-21511-00-00 | 1995 | 145-FR - AXLE OD 17MM - BRG TO BRG 69-70MM - ROTOR BC 6 ON 133MM - FITS 92-95 YZ125 & YZ250, 92-97 WR250 | 1995 | | FITS 94-95, 98-00 | 1995 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 94-96 YZ125 1LX-15660-02-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1995 | | | | 1995 | FITS 93-95 YZ125 YZ250, 94-95 WR250 - 4EW-21731-00-00 | FITS 93-95 YZ125 YZ250, 94-95 WR250 - 4EW-21741-00-00 | 1995 | | FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F | 1995 | | | | 1995 | 2VN00 SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR DIA 220MM (8 5/8") ROTOR BOLT CIRCLE 6 BOLTS ON A 133MM DIA - SPROCKET BOLT CIRCLE 6 BOLTS ON A 175MM DIA - FITS 90-98 YZ125 & YZ250, 91-97 WR250, 98 WR400F | 1995 | | | FITS 93-95 YZ125 YZ250, 94-97 WR250 | 1995 | FITS 95 YZ125 YZ250, 95-97 WR250 - 4EW-21711-01-00 | FITS 95 YZ125 YZ250, 95-97 WR250 - 4EW-21721-01-00 | 1995 | | | FITS 86-95 YZ125 | 1995 | FITS 94-95 YZ125 | | 1995 | | | | | 1995 | | FITS 83-95 YZ125 & YZ250, 83-90 YZ490, 92-93 WR500 | 1995 | | | 4JX - FITS 94-95 YZ125, 94 YZ250, 94-97 WR250 - 4JX-23435-00-00 | | 1995 |
| 1996 | YZ125H1 | 4SS-00 E101E-00XXXX | | FITS 96 YZ125 & YZ250 | | 1996 | YZ125H1 | FITS 96-01 YZ125 YZ250 | 1996 | YZ125H1 | FITS 96-98 YZ125, 96-97 YZ250 | | | MIKUNI TMX FITS 96 YZ125 ONLY | 1996 | YZ125H1 | FITS 95-98 YZ125 - 71.5MM W X 58MM H | FITS 96 YZ125 ONLY | | 1996 | | FITS 94-04 YZ125, 96 YZ250 | | | FITS 93-2011 YZ125 | | | FITS 96-97 ONLY | 1996 | FITS 96-97 YZ125 | | FITS 96-98 YZ125 | 1996 | FITS 96-2011 YZ125 | FITS 94-04 YZ125 | | 1996 | | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | F4SS 00 7X7 FITS 96-01 YZ125, 02-09 YZ85 | 1996 | Y4SS-L Y4SS-R - USD - CHROME OD 46MM - C/L 36 3/4" - UPPER 53.9MM - LOWER 58.9MM - C/L OF BRAKE MOUNT 78MM - AXLE 20MM & 25MM | 46MM X 58MM X 10.5 | 1996 | FITS 96-98 YZ125 & YZ250 | | FITS 93-97 YZ125 YZ250, 94-97 WR250 | 1996 | FITS 96-00 YZ125 YZ250, 97 WR250, 97-99 YZ80, 98-00 WR400F, 98-99 YZ400, 00 YZ426 | 1996 | ROTOR OD 245MM ID 118.5MM - ROTOR 6 ON A 134MM BOLT CIRCLE - FITS 92-96 YZ125, YZ250, WR250 | | 1996 | 14,0 45-FR-Y 20MM AXLE DIA - BRG TO BRG 68MM - FITS 96-01 YZ125, 97-01 YZ250, 98-99 YZ400F, 00-01 YZ426F | 1996 | | 4JY FITS 96-97 YZ125 | 1996 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 94-96 YZ125 1LX-15660-02-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1996 | | FITS 96-01 YZ125 | FITS 96-01 YZ125 | 1996 | | | 1996 | | FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F | 1996 | | | FITS 96-97 YZ125 YZ250 - 4SS-21611-00-00 | 1996 | 2VN00 SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR DIA 220MM (8 5/8") ROTOR BOLT CIRCLE 6 BOLTS ON A 133MM DIA - SPROCKET BOLT CIRCLE 6 BOLTS ON A 175MM DIA - FITS 90-98 YZ125 & YZ250, 91-97 WR250, 98 WR400F | 1996 | | | | 1996 | FITS 96-01 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-01 YZ125 YZ250 - 4SS-21721-00-00 | 1996 | | FITS 96-01 YZ125 | FITS 96-03 YZ125, 88-98 YZ250, 83-86 TT600 | 1996 | | | 1996 | 4SR 00 T-1 FITS 96-04 YZ125 | | | | 1996 | | | 1996 | | | | | 1996 |
| 1997 | YZ125J1 | 4XM-00 | FITS 97 YZ125 ONLY – 4XM-15111-00-00 | FITS 97 YZ125 ONLY – 4XM-15121-00-00 | JYA4XMW07VA00XXXX | 1997 | YZ125J1 | FITS 96-01 YZ125 YZ250 | 1997 | YZ125J1 | FITS 96-98 YZ125, 96-97 YZ250 | | | MIKUNI TMX | 1997 | YZ125J1 | FITS 95-98 YZ125 - 71.5MM W X 58MM H | FITS 97-99 YZ125 | FITS 97-02 YZ125, YZ250, 98-00 WR400F, 98-99 YZ400F, 00-02 YZ426F, 01-02 WR426F | 1997 | | FITS 94-04 YZ125, 96 YZ250 | | | FITS 93-2011 YZ125 | | | FITS 96-97 ONLY | 1997 | FITS 96-97 YZ125 | FITS 97-01 YZ125 | FITS 96-98 YZ125 | 1997 | FITS 96-2011 YZ125 | FITS 94-04 YZ125 | | 1997 | | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | F4SS 00 FITS 96-01 YZ125, 02-09 YZ85 | 1997 | USD - CHROME OD 46MM - C/L 37" | 46MM X 58MM X 10.5 | 1997 | FITS 96-98 YZ125 & YZ250 | | FITS 93-97 YZ125 YZ250, 94-97 WR250 | 1997 | FITS 96-00 YZ125 YZ250, 97 WR250, 97-99 YZ80, 98-00 WR400F, 98-99 YZ400, 00 YZ426 | 1997 | ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 97-00 YZ125 & YZ250, 97 WR250, 98-00 WR400, 98-99 YZ400F, 00 YZ426F | FITS 97 YZ125 YZ250 WR250 - 4DA-21511-10-00 | 1997 | 14,0 45-FR-Y 20MM AXLE DIA - BRG TO BRG 68MM - FITS 96-01 YZ125, 97-01 YZ250, 98-99 YZ400F, 00-01 YZ426F | 1997 | | 4JY FITS 96-97 YZ125 | 1997 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1997 | | FITS 96-01 YZ125 | FITS 96-01 YZ125 | 1997 | | | 1997 | | FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F | 1997 | | FITS 97-07 YZ125 YZ250, 98-00 WR400F, 01-04 WR250F, 01-02 YZ426F | FITS 96-97 YZ125 YZ250 - 4SS-21611-00-00 | 1997 | 2VN00 SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR DIA 220MM (8 5/8") ROTOR BOLT CIRCLE 6 BOLTS ON A 133MM DIA - SPROCKET BOLT CIRCLE 6 BOLTS ON A 175MM DIA - FITS 90-98 YZ125 & YZ250, 91-97 WR250, 98 WR400F | 1997 | - 71.5MM W X 58MM H | | | 1997 | FITS 96-01 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-01 YZ125 YZ250 - 4SS-21721-00-00 | 1997 | | FITS 96-01 YZ125 | FITS 96-03 YZ125, 88-98 YZ250, 83-86 TT600 | 1997 | | | 1997 | 4SS-00 67P T-1 4SR 00 FITS 96-04 YZ125 | | FITS 97 YZ125 & YZ250 | | 1997 | | | 1997 | | | | | 1997 |
| 1998 | YZ125K1 | 5DH-00 E101E-0000XX | FITS 98 YZ125 ONLY – 5DH-15111-00-00 | FITS 98 YZ125 ONLY – 5DH-15121-00-00 | JYACE01CWA000XXXX | 1998 | YZ125K1 | FITS 96-01 YZ125 YZ250 | 1998 | YZ125K1 | FITS 96-98 YZ125, 96-97 YZ250 | | | MIKUNI TMX | 1998 | YZ125K1 | FITS 95-98 YZ125 - 71.5MM W X 58MM H | FITS 97-99 YZ125 | FITS 97-02 YZ125, YZ250, 98-00 WR400F, 98-99 YZ400F, 00-02 YZ426F, 01-02 WR426F | 1998 | | FITS 94-04 YZ125, 96 YZ250 | 4JY00 FITS 98-04 YZ125 | | FITS 93-2011 YZ125 | | | | 1998 | | FITS 97-01 YZ125 | FITS 96-98 YZ125 | 1998 | FITS 96-2011 YZ125 | FITS 94-04 YZ125 | | 1998 | | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | F4SS 00 FITS 96-01 YZ125, 02-09 YZ85 | 1998 | USD - CHROME OD 46MM - C/L 37" | 46MM X 58MM X 10.5 | 1998 | FITS 96-98 YZ125 & YZ250 | | FITS 98-00 YZ125, YZ250, WR400F, 98-99 YZ400F, YZ426F | 1998 | FITS 96-00 YZ125 YZ250, 97 WR250, 97-99 YZ80, 98-00 WR400F, 98-99 YZ400, 00 YZ426 | 1998 | ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 97-00 YZ125 & YZ250, 97 WR250, 98-00 WR400, 98-99 YZ400F, 00 YZ426F | FITS 98-99 YZ125 YZ250 YZ400F - 4DA-21511-20-00 | 1998 | 14,0 45-FR-Y 20MM AXLE DIA - BRG TO BRG 68MM - FITS 96-01 YZ125, 97-01 YZ250, 98-99 YZ400F, 00-01 YZ426F | 1998 | | FITS 94-95, 98-00 | 1998 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1998 | | FITS 96-01 YZ125 | FITS 96-01 YZ125 | 1998 | FITS 98-01 YZ250 YZ125 | | 1998 | | FITS 89-98 YZ125 YZ250, 91 WR250, 98 WR400F YZ400F | 1998 | | FITS 97-07 YZ125 YZ250, 98-00 WR400F, 01-04 WR250F, 01-02 YZ426F | FITS 98-01 YZ125 YZ125, 98-02 YZ250, 98-99 YZ400F, 00-02 YZ426F | 1998 | 2VN00 SILVER - 20MM AXLE DIA - BRG TO BRG 131MM - ROTOR DIA 220MM (8 5/8") ROTOR BOLT CIRCLE 6 BOLTS ON A 133MM DIA - SPROCKET BOLT CIRCLE 6 BOLTS ON A 175MM DIA - FITS 90-98 YZ125 & YZ250, 91-97 WR250, 98 WR400F | 1998 | | | | 1998 | FITS 96-01 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-01 YZ125 YZ250 - 4SS-21721-00-00 | 1998 | | FITS 96-01 YZ125 | FITS 96-03 YZ125, 88-98 YZ250, 83-86 TT600 | 1998 | | | 1998 | FITS 96-04 YZ125 | | | | 1998 | FITS 98-01 YZ125 YZ250, 01 YZ250F WR250F WR426F, 98-99 YZ400F, 00-01 YZ426F, 98-00 WR400F 5DH-22141-00-00 | | 1998 | | | | FITS 98-01 YZ125 | 1998 |
| 1999 | YZ125L1 | 5ET-00 E105E-01XXXX | FITS 99-00 YZ125 – 5ET-15111-00-00 | FITS 99-00 YZ125 – 5ET-15121-00-00 | JYACE03C2XA00XXXX | 1999 | YZ125L1 | FITS 96-01 YZ125 YZ250 | 1999 | YZ125L1 | | | | MIKUNI 36MM | 1999 | YZ125L1 | 5ET - 2 3/4" X 2 3/8" | FITS 97-99 YZ125 | FITS 97-02 YZ125, YZ250, 98-00 WR400F, 98-99 YZ400F, 00-02 YZ426F, 01-02 WR426F | 1999 | | 4EX FITS 94-04 YZ125, 96 YZ250 | 4JY00 FITS 98-04 YZ125 | TUSHIMA 4JY 10 | FITS 93-2011 YZ125 | | | | 1999 | 5ET – FITS 99 YZ125 ONLY - 5ET-11311-00-00 | FITS 97-01 YZ125 | FITS 1999 YZ125 ONLY | 1999 | FITS 96-2011 YZ125 | FITS 94-04 YZ125 | | 1999 | | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | F4SS 00 8ZB - 75MM OD - 61.4MM ID FITS 96-01 YZ125, 02-09 YZ85 | 1999 | Y5DH-L Y5DH-R – USD - CHROME OD 46MM - 36 7/8" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE MOUNT HOLES 102MM – AXLE CLAMPS 20 & 25MM | 46MM X 58MM X 10.5 | 1999 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | | FITS 98-00 YZ125, YZ250, WR400F, 98-99 YZ400F, YZ426F | 1999 | FITS 96-00 YZ125 YZ250, 97 WR250, 97-99 YZ80, 98-00 WR400F, 98-99 YZ400, 00 YZ426 | 1999 | ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 97-00 YZ125 & YZ250, 97 WR250, 98-00 WR400, 98-99 YZ400F, 00 YZ426F | FITS 98-99 YZ125 YZ250 YZ400F - 4DA-21511-20-00 | 1999 | 14,0 45-FR-Y 20MM AXLE DIA - BRG TO BRG 68MM - FITS 96-01 YZ125, 97-01 YZ250, 98-99 YZ400F, 00-01 YZ426F | 1999 | | FITS 94-95, 98-00 | 1999 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 KX125 1LX-15641-00-00 | 1999 | | FITS 96-01 YZ125 | FITS 96-01 YZ125 | 1999 | FITS 98-01 YZ250 YZ125 | | 1999 | | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 1999 | | FITS 97-07 YZ125 YZ250, 98-00 WR400F, 01-04 WR250F, 01-02 YZ426F | FITS 98-01 YZ125 YZ125, 98-02 YZ250, 98-99 YZ400F, 00-02 YZ426F | 1999 | 5ET00 - 22MM AXLE DIA - BRG TO BRG 120MM - ROTOR DIA 9 5/8" - ROTOR 6 BOLTS ON A BOLT CIRCLE DIA 5 1/4" - FITS 99-09 YZ125, YZ250, 99-00 YZ400F, 01-02 YZ426F, 03-08 YZ450F, 99-00 WR400, 01-02 WR426, 03-09 WR450 | 1999 | | | | 1999 | FITS 96-01 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-01 YZ125 YZ250 - 4SS-21721-00-00 | 1999 | | R 4SS 6 - L 4SS 5 - 2VN 2 FITS 96-01 YZ125 | FITS 96-03 YZ125, 88-98 YZ250, 83-86 TT600 | 1999 | | | 1999 | 4SS-00 8ZF T-1 4SR 01 FITS 96-04 YZ125 | PA6 GF45 | | | 1999 | FITS 98-01 YZ125 YZ250, 01 YZ250F WR250F WR426F, 98-99 YZ400F, 00-01 YZ426F, 98-00 WR400F 5DH-22141-00-00 | | 1999 | | | | FITS 98-01 YZ125 | 1999 |
| 2000 | YZ125M1 | 5HD-00 E109E-00XXXX | FITS 99-00 YZ125 – 5ET-15111-00-00 | FITS 99-00 YZ125 – 5ET-15121-00-00 | JYACE05C8YA00XXXX | 2000 | YZ125M1 | FITS 96-01 YZ125 YZ250 | 2000 | YZ125M1 | | | | MIKUNI 5HD FITS 00 YZ125 ONLY | 2000 | YZ125M1 | | FITS 2000 YZ125 ONLY | FITS 97-02 YZ125, YZ250, 98-00 WR400F, 98-99 YZ400F, 00-02 YZ426F, 01-02 WR426F | 2000 | | FITS 94-04 YZ125, 96 YZ250 | 4JY00 FITS 98-04 YZ125 | 4JY | FITS 93-2011 YZ125 | FITS 00-211 YZ125 | | | 2000 | FITS 00 YZ125 ONLY | FITS 97-01 YZ125 | | 2000 | FITS 96-2011 YZ125 | FITS 94-04 YZ125 | | 2000 | | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | F4SS 00 098 FITS 96-01 YZ125, 02-09 YZ85 | 2000 | Y5DH-L Y5DH-R – USD - CHROME OD 46MM - 36 7/8" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE MOUNT HOLES 102MM – AXLE CLAMPS 20 & 25MM | 46MM X 58MM X 10.5 | 2000 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | | FITS 98-00 YZ125, YZ250, WR400F, 98-99 YZ400F, YZ426F | 2000 | FITS 96-00 YZ125 YZ250, 97 WR250, 97-99 YZ80, 98-00 WR400F, 98-99 YZ400, 00 YZ426 | 2000 | ROTOR OD 245MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 97-00 YZ125 & YZ250, 97 WR250, 98-00 WR400, 98-99 YZ400F, 00 YZ426F | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2000 | 14,0 45-FR-Y 20MM AXLE DIA - BRG TO BRG 68MM - FITS 96-01 YZ125, 97-01 YZ250, 98-99 YZ400F, 00-01 YZ426F | 2000 | | FITS 94-95, 98-00 | 2000 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 KX125 1LX-15641-00-00 | 2000 | | FITS 96-01 YZ125 | FITS 96-01 YZ125 | 2000 | FITS 98-01 YZ250 YZ125 | | 2000 | | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2000 | | FITS 97-07 YZ125 YZ250, 98-00 WR400F, 01-04 WR250F, 01-02 YZ426F | FITS 98-01 YZ125 YZ125, 98-02 YZ250, 98-99 YZ400F, 00-02 YZ426F | 2000 | 5ET00 - 22MM AXLE DIA - BRG TO BRG 120MM - ROTOR DIA 9 5/8" - ROTOR 6 BOLTS ON A BOLT CIRCLE DIA 5 1/4" - FITS 99-09 YZ125, YZ250, 99-00 YZ400F, 01-02 YZ426F, 03-08 YZ450F, 99-00 WR400, 01-02 WR426, 03-09 WR450 | 2000 | | | | 2000 | FITS 96-01 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-01 YZ125 YZ250 - 4SS-21721-00-00 | 2000 | | FITS 96-01 YZ125 | FITS 96-03 YZ125, 88-98 YZ250, 83-86 TT600 | 2000 | | | 2000 | 4SS-00 976 FITS 96-04 YZ125 | PA6 GF45 | | | 2000 | FITS 98-01 YZ125 YZ250, 01 YZ250F WR250F WR426F, 98-99 YZ400F, 00-01 YZ426F, 98-00 WR400F 5DH-22141-00-00 | | 2000 | | | 5HD – FITS 00 YZ125 YZ250 YZ426 - 5HC-23435-10-00 | FITS 98-01 YZ125 | 2000 |
| 2001 | YZ125N1 | 5MV-00 E111E-01XXXX | FITS 01 YZ125 ONLY – 5MV-15111-00-00 | FITS 01 YZ125 ONLY – 5MV-15121-00-00 | | 2001 | YZ125N1 | FITS 96-01 YZ125 YZ250 | 2001 | YZ125N1 | | | | MIKUNI | 2001 | YZ125N1 | | | FITS 97-02 YZ125, YZ250, 98-00 WR400F, 98-99 YZ400F, 00-02 YZ426F, 01-02 WR426F | 2001 | | FITS 94-04 YZ125, 96 YZ250 | 4JY00 FITS 98-04 YZ125 | | FITS 93-2011 YZ125 | FITS 00-211 YZ125 | | | 2001 | 5MV FITS 01 YZ125 ONLY | FITS 97-01 YZ125 | | 2001 | FITS 96-2011 YZ125 | FITS 94-04 YZ125 | | 2001 | | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | F4SS 00 098 FITS 96-01 YZ125, 02-09 YZ85 | 2001 | Y5DH-L Y5DH-R – USD - CHROME OD 46MM - 36 7/8" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE MOUNT HOLES 102MM – AXLE CLAMPS 20 & 25MM | 46MM X 58MM X 10.5 | 2001 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | | | 2001 | | 2001 | ROTOR OD 250MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 01-06 WR250F, 01-02 WR426F, 01-07 YZ125 & YZ250, 03-06 WR450F & YZ450F | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2001 | 14,0 45-FR-Y 20MM AXLE DIA - BRG TO BRG 68MM - FITS 96-01 YZ125, 97-01 YZ250, 98-99 YZ400F, 00-01 YZ426F | 2001 | | 5MV | 2001 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 KX125 1LX-15641-00-00 | 2001 | | FITS 96-01 YZ125 | FITS 96-01 YZ125 | 2001 | FITS 98-01 YZ250 YZ125 | | 2001 | | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2001 | | FITS 97-07 YZ125 YZ250, 98-00 WR400F, 01-04 WR250F, 01-02 YZ426F | FITS 98-01 YZ125 YZ125, 98-02 YZ250, 98-99 YZ400F, 00-02 YZ426F | 2001 | 5ET00 - 22MM AXLE DIA - BRG TO BRG 120MM - ROTOR DIA 9 5/8" - ROTOR 6 BOLTS ON A BOLT CIRCLE DIA 5 1/4" - FITS 99-09 YZ125, YZ250, 99-00 YZ400F, 01-02 YZ426F, 03-08 YZ450F, 99-00 WR400, 01-02 WR426, 03-09 WR450 | 2001 | | 4SS-00 | | 2001 | FITS 96-01 YZ125 YZ250 - 4SS-21711-00-00 | FITS 96-01 YZ125 YZ250 - 4SS-21721-00-00 | 2001 | | FITS 96-01 YZ125 | FITS 96-03 YZ125, 88-98 YZ250, 83-86 TT600 | 2001 | | | 2001 | 4SR 01 T-1 FITS 96-04 YZ125 | PA6 GF45 | | | 2001 | FITS 98-01 YZ125 YZ250, 01 YZ250F WR250F WR426F, 98-99 YZ400F, 00-01 YZ426F, 98-00 WR400F 5DH-22141-00-00 | | 2001 | | | 5HD – FITS 01 YZ125 YZ250 YZ426 - 5HC-23435-11-00 | FITS 98-01 YZ125 | 2001 |
| 2002 | YZ125P1 | 5NY-00 E112E-00XXXX | FITS 02 YZ125 ONLY – 5NY-15111-00-00 | FITS 02 YZ125 ONLY – 5NY-15121-00-00 | JYACE09C52A00XXXX | 2002 | YZ125P1 | FITS 02-10 YZ125, 02-09 YZ250 | 2002 | YZ125P1 | | | | MIKUNI | 2002 | YZ125P1 | | 5NY00 | FITS 97-02 YZ125, YZ250, 98-00 WR400F, 98-99 YZ400F, 00-02 YZ426F, 01-02 WR426F | 2002 | | FITS 94-04 YZ125, 96 YZ250 | 4JY00 FITS 98-04 YZ125 | | FITS 93-2011 YZ125 | FITS 00-211 YZ125 | | | 2002 | FITS 02 YZ125 ONLY | | | 2002 | FITS 96-2011 YZ125 | FITS 94-04 YZ125 | | 2002 | | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | F5CU 11 17L | 2002 | Y5DH-L Y5DH-R – USD - CHROME OD 46MM - 36 7/8" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE MOUNT HOLES 102MM – AXLE CLAMPS 20 & 25MM | 46MM X 58MM X 10.5 | 2002 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | | | 2002 | | 2002 | ROTOR OD 250MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 01-06 WR250F, 01-02 WR426F, 01-07 YZ125 & YZ250, 03-06 WR450F & YZ450F | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2002 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-09 - YZ426F 02 - YZ450F 03-09 | 2002 | | 5MV | 2002 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 KX125 1LX-15641-00-00 | 2002 | | FITS 02-04 YZ125 | FITS 02-04 YZ125 | 2002 | FITS 02-03 YZ125 YZ250 – 5NY-21730-00-00 | FITS 02-03 YZ125 YZ250 – 5NY-21740-00-00 | 2002 | FITS 02-11 YZ125, 02-09 YZ250 | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2002 | | FITS 97-07 YZ125 YZ250, 98-00 WR400F, 01-04 WR250F, 01-02 YZ426F | FITS 02-05 YZ125 YZ250 | 2002 | 5ET00 - 22MM AXLE DIA - BRG TO BRG 120MM - ROTOR DIA 9 5/8" - ROTOR 6 BOLTS ON A BOLT CIRCLE DIA 5 1/4" - FITS 99-09 YZ125, YZ250, 99-00 YZ400F, 01-02 YZ426F, 03-08 YZ450F, 99-00 WR400, 01-02 WR426, 03-09 WR450 | 2002 | | 5NY-00 FITS 02-03 YZ125 & YZ250 | | 2002 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2002 | FITS 02-03 YZ85, 02-04 YZ125 5NY-18541-00-00 | FITS 02-03 YZ85, 02-04 YZ125 5NY-18511-00-00 5NY-18512-00-00 5NY-18513-00-00 | FITS 96-03 YZ125, 88-98 YZ250, 83-86 TT600 | 2002 | | | 2002 | 4SS 01 T-1 4SR 01 FITS 96-04 YZ125 | PA6 GF45 | | | 2002 | | | 2002 | | | 5NL – FITS 01-03 YZ250F, 02-03 YZ125 YZ250, 02 YZ426F - 5NL-23435-00-00 | | 2002 |
| 2003 | YZ125R1 | 5UN-00 E113E-0058XX | | FITS 03-04 YZ125 | JYACE10C63A00XXXX | 2003 | YZ125R1 | FITS 02-10 YZ125, 02-09 YZ250 | 2003 | YZ125R1 | FITS 02-09 YZ250, 03-04 YZ125 | | | MIKUNI 5UN1 00 W274 | 2003 | YZ125R1 | | 5NY, 5NY-10 299 FITS 03-04YZ125 | | 2003 | | T-1 5NY00 FITS 94-04 YZ125, 96 YZ250 | 4JY00 FITS 98-04 YZ125 | | FITS 93-2011 YZ125 | FITS 00-211 YZ125 | | | 2003 | FITS 03 YZ125 ONLY | | FITS 03-04 YZ125 LEFT 5HD-1131D-20-00, RIGHT 5HD-1132D-20-00 | 2003 | FITS 96-2011 YZ125 | FITS 94-04 YZ125 | | 2003 | | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | F5CU 11 285 | 2003 | Y5DH-L Y5DH-R – USD - CHROME OD 46MM - 36 7/8" C/L - UPPER 53.9MM LOWER 58.4MM - BRAKE MOUNT HOLES 102MM – AXLE CLAMPS 20 & 25MM | 46MM X 58MM X 10.5 | 2003 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | | FITS 03-04 WR250F WR450F YZ125 YZ250 | 2003 | | 2003 | ROTOR OD 250MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 01-06 WR250F, 01-02 WR426F, 01-07 YZ125 & YZ250, 03-06 WR450F & YZ450F | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2003 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-09 - YZ426F 02 - YZ450F 03-09 | 2003 | | 5UN, FITS 03-04 YZ125 | 2003 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 KX125 1LX-15641-00-00 | 2003 | | FITS 02-04 YZ125 | FITS 02-04 YZ125 | 2003 | FITS 02-03 YZ125 YZ250 – 5NY-21730-00-00 | FITS 02-03 YZ125 YZ250 – 5NY-21740-00-00 | 2003 | FITS 02-11 YZ125, 02-09 YZ250 | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2003 | | FITS 97-07 YZ125 YZ250, 98-00 WR400F, 01-04 WR250F, 01-02 YZ426F | FITS 02-05 YZ125 YZ250 | 2003 | 5ET00 - 22MM AXLE DIA - BRG TO BRG 120MM - ROTOR DIA 9 5/8" - ROTOR 6 BOLTS ON A BOLT CIRCLE DIA 5 1/4" - FITS 99-09 YZ125, YZ250, 99-00 YZ400F, 01-02 YZ426F, 03-08 YZ450F, 99-00 WR400, 01-02 WR426, 03-09 WR450 | 2003 | | 5NY-00 FITS 02-03 YZ125 & YZ250 | | 2003 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2003 | FITS 02-03 YZ85, 02-04 YZ125 5NY-18541-00-00 | FITS 02-03 YZ85, 02-04 YZ125 5NY-18511-00-00 5NY-18512-00-00 5NY-18513-00-00 | FITS 96-03 YZ125, 88-98 YZ250, 83-86 TT600 | 2003 | | | 2003 | 4SS 01 T-1 4SR 01 FITS 96-04 YZ125 | PA6 GF45 | | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F 5UN-22110-00-00 | 2003 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F 5NY-22141-01-00 | | 2003 | | GEARS AND SHAFTS FIT 03-04 YZ125 | 5NL – FITS 01-03 YZ250F, 02-03 YZ125 YZ250, 02 YZ426F - 5NL-23435-00-00 | | 2003 |
| 2004 | YZ125 | | | FITS 03-04 YZ125 | JYACE13C74A00XXXX | 2004 | YZ125 | FITS 02-10 YZ125, 02-09 YZ250 | 2004 | YZ125 | FITS 02-09 YZ250, 03-04 YZ125 | | | | 2004 | YZ125 | | FITS 03-04YZ125 | | 2004 | | FITS 94-04 YZ125, 96 YZ250 | 4JY00 FITS 98-04 YZ125 | | FITS 93-2011 YZ125 | FITS 00-211 YZ125 | | | 2004 | FITS 04 YZ125 ONLY | | FITS 03-04 YZ125 LEFT 5HD-1131D-20-00, RIGHT 5HD-1132D-20-00 | 2004 | FITS 96-2011 YZ125 | FITS 94-04 YZ125 | | 2004 | | FITS 96-04 YZ125, 96-98 YZ80 4SS-11990-00-00 | | 2004 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | 2004 | FITS 99-04 YZ125 YZ250, 98-00 YZ400F WR400F, 00-02 YZ426F, 01-04 WR250F, 03-04 YZ450F WR450F – 5BE-25181-00-00 | | FITS 03-04 WR250F WR450F YZ125 YZ250 | 2004 | | 2004 | ROTOR OD 250MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 01-06 WR250F, 01-02 WR426F, 01-07 YZ125 & YZ250, 03-06 WR450F & YZ450F | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2004 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-09 - YZ426F 02 - YZ450F 03-09 | 2004 | | FITS 03-04 YZ125 | 2004 | FITS 86-04 YZ125 1LX-15651-00-00 | FITS 94-04 YZ125 4DB-15620-03-00 | FITS 97-04 YZ125 1LX-15660-03-00 | FITS 86-04 KX125 1LX-15641-00-00 | 2004 | | FITS 02-04 YZ125 | FITS 02-04 YZ125 | 2004 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2004 | FITS 02-11 YZ125, 02-09 YZ250 | 22MM FITS 99-04 YZ125 YZ250, 01-04 YZ250F WR250F, 99 YZ400F, 00-02 YZ426F, 03-04 YZ450F WR450F, 99-00 WR400F, 01-02 WR426F - 5ET-25381-00-00 | 2004 | | FITS 97-07 YZ125 YZ250, 98-00 WR400F, 01-04 WR250F, 01-02 YZ426F | FITS 02-05 YZ125 YZ250 | 2004 | 5ET00 - 22MM AXLE DIA - BRG TO BRG 120MM - ROTOR DIA 9 5/8" - ROTOR 6 BOLTS ON A BOLT CIRCLE DIA 5 1/4" - FITS 99-09 YZ125, YZ250, 99-00 YZ400F, 01-02 YZ426F, 03-08 YZ450F, 99-00 WR400, 01-02 WR426, 03-09 WR450 | 2004 | | | | 2004 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2004 | FITS 02-03 YZ85, 02-04 YZ125 5NY-18541-00-00 | FITS 02-03 YZ85, 02-04 YZ125 5NY-18511-00-00 5NY-18512-00-00 5NY-18513-00-00 | | 2004 | | | 2004 | FITS 96-04 YZ125 | | | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F 5UN-22110-00-00 | 2004 | FITS 03-04 YZ125 YZ250 YZ250F YZ450F WR250F WR450F 5NY-22141-01-00 | | 2004 | | GEARS AND SHAFTS FIT 03-04 YZ125 | | | 2004 |
| 2005 | YZ125 | | | FITS 05-09 YZ125 | | 2005 | YZ125 | FITS 02-10 YZ125, 02-09 YZ250 | 2005 | YZ125 | | | | | 2005 | YZ125 | | | | 2005 | | | | | FITS 93-2011 YZ125 | FITS 00-211 YZ125 | | | 2005 | | | | 2005 | FITS 96-2011 YZ125 | | | 2005 | | FITS 05 YZ125 ONLY 1C3-11990-00-00 | | 2005 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | 2005 | | | | 2005 | | 2005 | ROTOR OD 250MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 01-06 WR250F, 01-02 WR426F, 01-07 YZ125 & YZ250, 03-06 WR450F & YZ450F | FITS 00-05 YZ125 YZ250, 01-05 YZ250F WR250F, 00-02 YZ426F, 03-05 YZ450F, 00 WR400F, 01-02 WR426F, 03-05 WR450F - 5HD-21511-00-00 | 2005 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-09 - YZ426F 02 - YZ450F 03-09 | 2005 | | | 2005 | | | | | 2005 | | | | 2005 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2005 | FITS 02-11 YZ125, 02-09 YZ250 | | 2005 | | FITS 97-07 YZ125 YZ250, 98-00 WR400F, 01-04 WR250F, 01-02 YZ426F | FITS 02-05 YZ125 YZ250 | 2005 | 5ET00 - 22MM AXLE DIA - BRG TO BRG 120MM - ROTOR DIA 9 5/8" - ROTOR 6 BOLTS ON A BOLT CIRCLE DIA 5 1/4" - FITS 99-09 YZ125, YZ250, 99-00 YZ400F, 01-02 YZ426F, 03-08 YZ450F, 99-00 WR400, 01-02 WR426, 03-09 WR450 | 2005 | | | | 2005 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2005 | | | | 2005 | | | 2005 | | | | | 2005 | | | 2005 | | | | | 2005 |
| 2006 | YZ125 | | | FITS 05-09 YZ125 | | 2006 | YZ125 | FITS 02-10 YZ125, 02-09 YZ250 | 2006 | YZ125 | | | | | 2006 | YZ125 | | | | 2006 | | | | | FITS 93-2011 YZ125 | FITS 00-211 YZ125 | | | 2006 | | | | 2006 | FITS 96-2011 YZ125 | | | 2006 | | FITS 06-11 YZ125 1C3-11990-10-00 | | 2006 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | 2006 | | | | 2006 | | 2006 | ROTOR OD 250MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 01-06 WR250F, 01-02 WR426F, 01-07 YZ125 & YZ250, 03-06 WR450F & YZ450F | FITS 06 YZ125 YZ250 YZ250F YZ450F WR250F WR450F - 1C3-21511-50-00 | 2006 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-09 - YZ426F 02 - YZ450F 03-09 | 2006 | | | 2006 | | | | | 2006 | | | | 2006 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2006 | FITS 02-11 YZ125, 02-09 YZ250 | | 2006 | | FITS 97-07 YZ125 YZ250, 98-00 WR400F, 01-04 WR250F, 01-02 YZ426F | | 2006 | 5ET00 - 22MM AXLE DIA - BRG TO BRG 120MM - ROTOR DIA 9 5/8" - ROTOR 6 BOLTS ON A BOLT CIRCLE DIA 5 1/4" - FITS 99-09 YZ125, YZ250, 99-00 YZ400F, 01-02 YZ426F, 03-08 YZ450F, 99-00 WR400, 01-02 WR426, 03-09 WR450 | 2006 | | | | 2006 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2006 | | | | 2006 | | | 2006 | | | FITS 05-09 YZ250, 06-11 YZ125 | | 2006 | | | 2006 | | | | | 2006 |
| 2007 | YZ125 | | | FITS 05-09 YZ125 | | 2007 | YZ125 | FITS 02-10 YZ125, 02-09 YZ250 | 2007 | YZ125 | | | | | 2007 | YZ125 | | | | 2007 | | | | | FITS 93-2011 YZ125 | FITS 00-211 YZ125 | | | 2007 | | | | 2007 | FITS 96-2011 YZ125 | | | 2007 | | FITS 06-11 YZ125 1C3-11990-10-00 | | 2007 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | 2007 | | | | 2007 | | 2007 | ROTOR OD 250MM ID 118MM - ROTOR BOLT CIRCLE 6 ON 134MM - FITS 01-06 WR250F, 01-02 WR426F, 01-07 YZ125 & YZ250, 03-06 WR450F & YZ450F | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2007 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-09 - YZ426F 02 - YZ450F 03-09 | 2007 | | | 2007 | | | | | 2007 | | | | 2007 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2007 | FITS 02-11 YZ125, 02-09 YZ250 | | 2007 | | FITS 97-07 YZ125 YZ250, 98-00 WR400F, 01-04 WR250F, 01-02 YZ426F | | 2007 | 5ET00 - 22MM AXLE DIA - BRG TO BRG 120MM - ROTOR DIA 9 5/8" - ROTOR 6 BOLTS ON A BOLT CIRCLE DIA 5 1/4" - FITS 99-09 YZ125, YZ250, 99-00 YZ400F, 01-02 YZ426F, 03-08 YZ450F, 99-00 WR400, 01-02 WR426, 03-09 WR450 | 2007 | | | | 2007 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2007 | | | | 2007 | | | 2007 | | | FITS 05-09 YZ250, 06-11 YZ125 | | 2007 | | | 2007 | | | | | 2007 |
| 2008 | YZ125 | | | FITS 05-09 YZ125 | | 2008 | YZ125 | FITS 02-10 YZ125, 02-09 YZ250 | 2008 | YZ125 | | | | | 2008 | YZ125 | | | | 2008 | | | | | FITS 93-2011 YZ125 | FITS 00-211 YZ125 | | | 2008 | | | | 2008 | FITS 96-2011 YZ125 | | | 2008 | | FITS 06-11 YZ125 1C3-11990-10-00 | | 2008 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | 2008 | | | | 2008 | | 2008 | | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2008 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-09 - YZ426F 02 - YZ450F 03-09 | 2008 | | | 2008 | | | | | 2008 | | | | 2008 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2008 | FITS 02-11 YZ125, 02-09 YZ250 | | 2008 | | | | 2008 | 5ET00 - 22MM AXLE DIA - BRG TO BRG 120MM - ROTOR DIA 9 5/8" - ROTOR 6 BOLTS ON A BOLT CIRCLE DIA 5 1/4" - FITS 99-09 YZ125, YZ250, 99-00 YZ400F, 01-02 YZ426F, 03-08 YZ450F, 99-00 WR400, 01-02 WR426, 03-09 WR450 | 2008 | | | | 2008 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2008 | | | | 2008 | | | 2008 | | | FITS 05-09 YZ250, 06-11 YZ125 | | 2008 | | | 2008 | | | | | 2008 |
| 2009 | YZ125 | | | FITS 05-09 YZ125 | | 2009 | YZ125 | FITS 02-10 YZ125, 02-09 YZ250 | 2009 | YZ125 | | | | | 2009 | YZ125 | | | | 2009 | | | | | FITS 93-2011 YZ125 | FITS 00-211 YZ125 | | | 2009 | | | | 2009 | FITS 96-2011 YZ125 | | | 2009 | | FITS 06-11 YZ125 1C3-11990-10-00 | | 2009 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | 2009 | | | | 2009 | | 2009 | | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2009 | 194 - 20MM AXLE DIA - BRG TO BRG 79MM FITS YZ125, 250, 250F 02-09 - YZ426F 02 - YZ450F 03-09 | 2009 | | | 2009 | | | | | 2009 | | | | 2009 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2009 | FITS 02-11 YZ125, 02-09 YZ250 | | 2009 | | | | 2009 | | 2009 | | | | 2009 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2009 | | | | 2009 | | | 2009 | | | FITS 05-09 YZ250, 06-11 YZ125 | | 2009 | | | 2009 | | | | | 2009 |
| 2010 | YZ125 | | | | | 2010 | YZ125 | FITS 02-10 YZ125, 02-09 YZ250 | 2010 | YZ125 | | | | | 2010 | YZ125 | | | | 2010 | | | | | FITS 93-2011 YZ125 | FITS 00-211 YZ125 | | | 2010 | | | | 2010 | FITS 96-2011 YZ125 | | | 2010 | | FITS 06-11 YZ125 1C3-11990-10-00 | | 2010 | USD – 48MM CHROME OD | 48MM X 58MM X 8.5/10 | 2010 | | | | 2010 | | 2010 | | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2010 | | 2010 | | | 2010 | | | | | 2010 | | | | 2010 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2010 | FITS 02-11 YZ125, 02-09 YZ250 | | 2010 | | | | 2010 | | 2010 | | | | 2010 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | FITS 02-10 YZ125 YZ250 - 5NY-21721-00-00 | 2010 | | | | 2010 | | | 2010 | | | FITS 05-09 YZ250, 06-11 YZ125 | | 2010 | | | 2010 | | | | | 2010 |
| 2011 | YZ125 | | | | | 2011 | YZ125 | | 2011 | YZ125 | | | | | 2011 | YZ125 | | | | 2011 | | | | | FITS 93-2011 YZ125 | FITS 00-211 YZ125 | | | 2011 | | | | 2011 | FITS 96-2011 YZ125 | | | 2011 | | FITS 06-11 YZ125 1C3-11990-10-00 | | 2011 | | 48MM X 58MM X 8.5/10 | 2011 | | | | 2011 | | 2011 | | FITS 07-11 YZ125 YZ250, 07-10 YZ250F 07-09 YZ450F, 07-09 11 WR250F WR450F - 1C3-21511-51-00 | 2011 | | 2011 | | | 2011 | | | | | 2011 | | | | 2011 | FITS 04-11 YZ125 YZ250 – 5XE-21730-00-00 | FITS 04-11 YZ125 YZ250 – 5XE-21740-00-00 | 2011 | FITS 02-11 YZ125, 02-09 YZ250 | | 2011 | | | | 2011 | | 2011 | | | | 2011 | FITS 02-11 YZ125 YZ250 – 5NY-21711-00-00 | | 2011 | | | | 2011 | | | 2011 | | | FITS 05-09 YZ250, 06-11 YZ125 | | 2011 | | | 2011 | | | | | 2011 |
