Picture for 1984 Suzuki RM250
Specs for 1984 Suzuki RM250
Engine
Engine Type 2-stroke
Bore x Stroke 70 mm x 64 mm
Engine Features Single, reed valve
Engine Cooling Liquid
Ignition
Spark Plug NGK B8egv
Carburetion
Carburetor 36mm Mikuni Flatside
Transmission
Transmission 5 - speed
Chassis
Frame Type Single downtube, split cradle
Steering Rake (Castor) 27.5 degrees
Steering Trail 4.35 in
Wheelbase 58.1 in
Ground Clearance 14.6 in
Seat Height 37.0 in
Weight, dry 221 pounds
Fuel Tank Capacity 2.4 gallons
Forks
Forks 43mm Kyb
Fork Travel 11.8 in
Shock
Shock(s) Full Floater
Shock Travel 13 in
Wheels and Tires
Front Wheel 12 in
Rear Wheel 18 in
Brakes drum/drum
Ignition
Carburetion
Transmission
Chassis
Wheelbase 58.1 in
Seat Height 37.0 in
Forks
Forks 43mm Kyb
Fork Travel 11.8 in
Shock
Shock Travel 13 in
Wheels and Tires
Front Wheel 12 in
Rear Wheel 18 in
Brakes drum/drum
This page last modified: Thursday, 09-Aug-2012 22:51:38 PDT
