Picture of 1994 Suzuki RM125
Specs for 1994 Suzuki RM125
Engine
Engine Type 2-stroke
Displacement 124 cc
Bore x Stroke 54 mm x 54 mm
Engine Cooling Liquid
Carburetion
Carburetor Mikuni Tm36
Transmission
Transmission 6 - speed
Chassis
Steering Rake (Castor) 27.8 degrees
Steering Trail 4.4 in
Wheelbase 56.4 in
Ground Clearance 27.8 in
Seat Height 37.8 in
Weight, dry 200 pounds
Fuel Tank Capacity 2.0 gallons
Forks
Forks Showa Adj Comp/reb
Fork Travel 12.2 in
Shock
Shock(s) Showa Adj Comp/reb
Shock Travel 12.8 in
Wheels and Tires
Front Wheel 21 in
Rear Wheel 19 in
Brakes Disk/Disk
