Picture for 2000 Kawasaki KX125
Specs for 2000 Kawasaki KX125
Manufacturer Kawasaki
Model Year 2000
Model KX 125
ENGINE
Engine 124cc, Liquid cooled, 2-stroke, single cylinder with KIPS
Displacement 124cc
Bore x Stroke 54.0 x 54.5mm
Compression Ratio
low speed: 9.8:1
high speed: 8.2:1
Carburetion Keihin PWK Q523 AN19
Ignition Denso 21119-1547 071000-1600
DIMENSIONS
Length 83.9"
Width 32.1"
Height 47.6"
Weight 191.7 lbs.
Ground Clearance 15.4"
Wheelbase 56.5"
Fuel Capacity 2.25 gal.
Seat Height 37.2"
DRIVETRAIN
Transmission 6-Speed
Final Drive Chain
Suspension
Front: 46mm inverted telescopic fork, preload,18-way compression and rebound damping, 12.2" of travel
Rear: Uni-trak single shock, preload, 20-way compression and 18-way rebound damping, 13.0" of travel
BRAKES/WHEELS/TIRES
Brakes
Front: Hydraulic Disc
Rear: Hydraulic Disc
Tires
Front: 80/100 x 21
Rear: 100/90 x 19
