Picture for 1988 Kawasaki KX125
Specs for 1988 Kawasaki KX125
Engine
Engine Type 2-stroke
Displacement 124 cc
Bore x Stroke 56 mm x 50.6 mm
Engine Features case reed, power valve
Cylinder Lining Electrofusion
Compression Ratio 8.39:1
Engine Cooling Liquid
Ignition
Spark Plug NGK B10eg
Carburetion
Carburetor Keihin PWK35
Main Jet 148
Pilot Jet 52
Jet Needle R1368J/3
Cutaway 6
Fuel Level 15-17 mm
Transmission
Transmission 6 - speed
Transmission Oil SAE 10w30 (factory recommended)
Transmission Oil Capacity 650 cc
First Gear 2.142 : 1
Second Gear 1.714 : 1
Third Gear 1.4 : 1
Fourth Gear 1.181 : 1
Fifth Gear 1.041 : 1
Sixth Gear 0.92 : 1
Overall Drive Ratio 12.611
Final Drive 12/47
Chassis
Frame Type single backbone
Steering Rake (Castor) 27 degrees
Steering Trail 4.8 in
Wheelbase 57.7 in
Ground Clearance 15 in
Seat Height 37.4 in
Weight, dry 190 pounds
Fuel Tank Capacity 2.3 gallons
Forks
Forks 43mm KYB cartridge
Fork Travel 11.8 in
Fork Compression 16 positions
Fork Preload Internal
Fork Oil Capacity 539 cc
Fork Oil Level 128 mm
Shock
Shock(s) KYB
Shock Travel 13 in
Shock Rebound 16 positions
Shock Compression 16 positions
Shock Preload External
Wheels and Tires
Front Wheel 21 in
Rear Wheel 18 in
Brakes Disk/Disk
This page last modified: Thursday, 09-Aug-2012 22:51:39 PDT
