OEM-CYCLE
OEM-CYCLE HOME
About Us
Contact Us
Site Map
Used Dirt Bike Parts
ATK Used Parts
Bultaco Used Parts
Honda Used Parts
Husaberg Used Parts
Husqvarna Used Parts
Kawasaki Used Parts
KTM Used Parts
Maico Used Parts
Suzuki Used Parts
Yamaha Used Parts
Misc Used Parts
Bike Identification
What year is my dirt bike
WORLD WIDE PICS CR125
WORLD WIDE PICS CR500
World Wide Pics Of KX500
WORLD WIDE PICS KX450F
WORLD WIDE PICS KX250
WORLD WIDE PICS RM250
WORLD WIDE PICS YZ250
Building our new shop
KX500 JETTING GUIDE
CRANK BEARING REMOVAL
SPLITTING YOUR CASES
BIKES IN DISASSEMBLY
Employees wasting time
Misc Parts
2006 Tundra rear brake re
Picture for 1988 Kawasaki KX125
Specs for 1988 Kawasaki KX125
Engine
Engine Type 2-stroke
Displacement 124 cc
Bore x Stroke 56 mm x 50.6 mm
Engine Features case reed, power valve
Cylinder Lining Electrofusion
Compression Ratio 8.39:1
Engine Cooling Liquid
Ignition
Spark Plug NGK B10eg
Carburetion
Carburetor Keihin PWK35
Main Jet 148
Pilot Jet 52
Jet Needle R1368J/3
Cutaway 6
Fuel Level 15-17 mm
Transmission
Transmission 6 - speed
Transmission Oil SAE 10w30 (factory recommended)
Transmission Oil Capacity 650 cc
First Gear 2.142 : 1
Second Gear 1.714 : 1
Third Gear 1.4 : 1
Fourth Gear 1.181 : 1
Fifth Gear 1.041 : 1
Sixth Gear 0.92 : 1
Overall Drive Ratio 12.611
Final Drive 12/47
Chassis
Frame Type single backbone
Steering Rake (Castor) 27 degrees
Steering Trail 4.8 in
Wheelbase 57.7 in
Ground Clearance 15 in
Seat Height 37.4 in
Weight, dry 190 pounds
Fuel Tank Capacity 2.3 gallons
Forks
Forks 43mm KYB cartridge
Fork Travel 11.8 in
Fork Compression 16 positions
Fork Preload Internal
Fork Oil Capacity 539 cc
Fork Oil Level 128 mm
Shock
Shock(s) KYB
Shock Travel 13 in
Shock Rebound 16 positions
Shock Compression 16 positions
Shock Preload External
Wheels and Tires
Front Wheel 21 in
Rear Wheel 18 in
Brakes Disk/Disk
