Pictures for 2001 Kawasaki KDX200
2001 Kawasaki KDX200 Specs
Engine: 2-stroke single w/KIPS
Displacement: 198cc
Bore x Stroke: 66.0 x 58.0mm
Cooling: Liquid
Carburetion: Keihin PWK35
Induction: 6-petal reed valve
Compression ratio: 7.9:1 (high speed) - 9.4:1 (low speed)
Ignition: Electronic CDI
Transmission: 6-speed
Frame: High-tensile steel perimeter design
Rake/trail: 26.50/4.3 in.
Suspension type, front: 43mm conventional cartridge fork
Suspension adjustments, front: front 20-way compression damping adjustment
Suspension type, rear: UNI-TRAKĀ® single-shock system
Suspension adjustments, rear: adjustable preload, 20-way compression and
18-way rebound damping adjustment
Wheel travel, front: 11.4 in.
Wheel travel: 11.8 in.
Tire, front: 80/100 x 21
Tire, rear: 100/100 x 18
Brakes, front/rear: Hydraulic disc/Disc
Overall length: 83.5 in.
Overall width: 35.0 in.
Overall height: 48.4 in.
Ground Clearance: 13.4 in.
Seat height: 36.2 in.
Dry weight: 222.6 lbs.
Fuel capacity: 2.9 gal.
Wheelbase: 56.5 in.
Displacement: 198cc
Cooling: Liquid
Wheelbase: 56.5 in.
This page last modified: Thursday, 09-Aug-2012 22:51:39 PDT
