OEM-CYCLE
OEM-Cycle
Kawasaki KX250F, KX450F ENGINE, PARTS, AND FRAME Identification page
In an effort to help fellow bikers properly ID their bike I have provided the following information on VIN ( Vehicle Identification Number ) , Engine ID and part identification.
If you find something that is not accurate, please let us know and we will fix it.
This information is not intended for use outside of this web site or for publication.
Scroll to the right as there is a lot of data :-)
YEAR TYPE VIN FRAME USA ONLY ENGINE ID ENGINE CASES AIR BOX NO BOOT AIR BOX TO CARB BOOT DUCT CAM SHAFT EXHAUST YEAR TYPE CAM SHAFT INTAKE CARBURETOR / EFI CARBURETOR BODY CARBURETOR BOOT JOINT HOLDER EFI YEAR TYPE CARBURETOR CABLE COVER CARBURETOR CHOKE PLUNGER YEAR TYPE CARBURETOR DIAPHRAGM COVER CARBURETOR FLOAT YEAR TYPE CARBURETOR FLOAT BOWL COVER CARBURETOR FUEL LINE FITTING YEAR TYPE CARBURETOR MAIN JET COVER CARBURETOR MAIN NOZZLE YEAR TYPE CARBURETOR SHAFT CARBURETOR THROTTLE POSITION SENSOR YEAR TYPE CARBURETOR THROTTLE STOP SCREW CARBURETOR THROTTLE VALVE CARBURETOR TOP COVER CASE SAVER CHAIN GUIDE CDI YEAR TYPE CHAIN GUIDE PLASTIC CHAIN GUIDE PLATE (ALUMINUM) COIL (IGNITION) YEAR TYPE CLUTCH ARM CLUTCH BASKET CLUTCH COVER (INNER) CLUTCH COVER (OUTER) CLUTCH HUB (INNER) CLUTCH PRESSURE (OPERATING) PLATE CRANK SHAFT CRANK SHAFT (HOT RODS) YEAR TYPE CYLINDER CYLINDER HEAD COVER CYLINDER HEAD H2O SENSOR ENGINE MOUNTS FRONT EXHAUST PIPE HEADER GUARD EXHAUST SYSTEM PRO CIRCUIT TI-4 YEAR TYPE FLY WHEEL ROTOR FOOT PEGS YEAR TYPE FORKS FORK SEAL SIZES YEAR TYPE FORK UNDER HOLDER (STEERING STEM LOWER TRIPLE CLAMP) YEAR TYPE FORK UPPER CROWN HOLDER (TRIPLE TREE) FRONT AXLE FRONT BRAKE CALIPER FRONT BRAKE CALIPER MOUNT FRONT BRAKE HOSE YEAR TYPE FRONT BRAKE LEVER FRONT BRAKE MASTER CYLINDER YEAR TYPE FRONT HUB FRONT RIM YEAR TYPE GAS TANK GAS TANK IMS HEAD HEAD COVER INNER CLUTCH COVER YEAR TYPE KICK IDLER SPUR GEAR KICK LEVER KICK LEVER SHAFT KICK LEVER SHAFT SPUR GEAR MUD FLAP YEAR TYPE OIL FILTER CAP OIL PUMP HOUSING PISTON  YEAR TYPE PRIMARY CRANK GEAR RADIATOR HOSES RADIATOR LEFT RADIATOR RIGHT RADIATOR SCREEN LEFT RADIATOR SCREEN RIGHT YEAR TYPE REAR AXLE REAR AXLE CHAIN ADJUSTMENT BLOCK LEFT REAR AXLE CHAIN ADJUSTMENT BLOCK RIGHT REAR AXLE SPACERS COLLARS REAR BRAKE CALIPER REAR BRAKE CALIPER HOLDER MOUNT REAR BRAKE LEVER REAR BRAKE MASTER CYLINDER REAR BRAKE ROTOR YEAR TYPE REAR HUB YEAR TYPE REAR RIM SEAT SEAT SDG SHIFT DRUM SHIFT FORKS SHIFT FORK PINS SHIFT SHAFT YEAR TYPE SHOCK SHOCK YEAR TYPE SHOCK ARM LINKAGE UNI TRAK SHOCK ARM TIE ROD SHOCK ARM LINKAGE BEARINGS (Uni-Trak) SHOCK ARM LINKAGE BEARINGS (Uni-Trak) ALL BALLS SIDE COVERS YEAR TYPE STATOR STATOR COVER SUB FRAME SWING ARM SWING ARM PIVOT PIN YEAR TYPE THROTTLE HOUSING TIMING CHAIN YEAR TYPE TIMING CHAIN TENSIONER TRANSMISSION TRANSMISSION INPUT SHAFT TRANSMISSION OUTPUT SHAFT YEAR TYPE VALVE EXHAUST VALVE INTAKE VALVE BUCKETS TAPPET EXHAUST YEAR TYPE VALVE BUCKETS TAPPET INTAKE VOLTAGE REGULATOR WATER PUMP COVER WATER PUMP IMPELLER WATER PUMP SHAFT YEAR TYPE WIRE HARNESS ENGINE WEIGHT YEAR TYPE
2004 KX250F     FITS 04 KX250F - 14001-0032 FITS 06-08 KX250F KX450F - 11011-0055-6Z   FITS 04-05 KX250F - 49118-0022 2004 KX250F FITS 04-05 KX250F - 49118-0013 KEIHIN FLAT CR FCR J022 37MM FITS 04-05 KX250F - 15003-0022 KEIHIN FLAT CR FCR J022 - FITS 04-05 KX250F   2004 KX250F FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 14091-0209 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 16016-0009 2004 KX250F FITS 04-10 KX250F FITS 99-00 KX125, 99-07 KX250, 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 16031-1100 2004 KX250F FITS 04-10 KX250F, 06-08 KX450F FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 92005-0016 2004 KX250F FITS 88-00 KX125, 88-07 KX250, 88-04 KX500, 04-10 KX250F, 06-08 KX450F, 88-06 KDX200, 97-05 KDX220 - 16049-1051 FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450F - 49121-0001 2004 KX250F FITS 04-06 KX250F, 06 KX450F - 16041-0002 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R AUSTRALIAN - 21176-0016  2004 KX250F FITS 04-10 KX250F - 16021-0005 FITS 04-06 KX250F, 06 KX450F - 16025-0008 FITS 04-10 KX250F - 14091-0208     2004 KX250F FITS 03-05 KX125, 03-08 KX250, 04-05 KX250F 12053-1468     2004 KX250F           FITS 03-05 KX125, 04-14 KX250F - 13187-1089 FITS 04-05 KX250F - 13031-0016  FITS 04-08 KX250F - 4064 2004 KX250F FITS 04 KX250F - 11005-0005           2004 KX250F     2004 KX250F   48mm x 58mm x 8.5/10 2004 KX250F   2004 KX250F     04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 04 KX125 KX250 KX250F - 43095-0054 2004 KX250F FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 FITS 05-07 KX250, 05 KX250F, 06-07 KX100, 06-07 KX85 - 43015-0041 2004 KX250F F-0012 - BRG ID 20MM - BRG TO BRG 90MM - 36 SPOKES - ROTOR BC 4X AT 116MM - FITS 04-05 KX125 KX250 KX250F - 41034-0018 1.85 X 20 FITS 02 KX250, 03-05 KX125, 04-08 KX250F 2004 KX250F       FITS 04-08 KX250F - 14091-0058   2004 KX250F 26T - FITS 04-08 KX250F - 59051-0006   FITS 04-14 KX250F - 13066-0004 28T - FITS 04-12 KX250F - 59051-0033 FITS 04-06 KX250F, 06 YZ450F - 35019-0005 2004 KX250F       2004 KX250F             2004 KX250F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466       FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514 NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022   FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004 FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514 2004 KX250F 0003-1 / 0003-2 - 25MM AXLE DIA - BRG TO BRG 133.5MM - ROTOR OD 240MM - ROTOR BC 4 ON 133MM - SPROCKET BC 6 ON 150MM - FITS 03-05 KX125, 03-06 KX250, 04-06 KX250F, 06 KX450F - 41034-0004 2004 KX250F       FITS 04-06 KX250F - 13141-0002 FITS 04-06 RM-Z250 - K1314-00022 - K1314-00024 - K1314-00023     2004 KX250F     2004 KX250F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71117   2004 KX250F         FITS 94-05 KX125, 04-07 KX250, 04-05 KX250F 2004 KX250F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002   2004 KX250F         2004 KX250F FITS 04-14 KX250F - 12005-0002      2004 KX250F       FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-14 KX250F - 59256-1065   2004 KX250F 46.1 NO CARB, OIL, PLUG, OR KICKER 2004 KX250F
2005 KX250F JKAKXMNC35A01#### KX250NE00#### FITS 05 KX250F - 14001-0048 FITS 06-08 KX250F KX450F - 11011-0055-6Z   FITS 04-05 KX250F - 49118-0022 2005 KX250F FITS 04-05 KX250F - 49118-0013 KEIHIN FLAT CR FCR J022 37MM FITS 04-05 KX250F - 15003-0022 KEIHIN FLAT CR FCR J022 - FITS 04-05 KX250F   2005 KX250F FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 14091-0209 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 16016-0009 2005 KX250F FITS 04-10 KX250F FITS 99-00 KX125, 99-07 KX250, 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 16031-1100 2005 KX250F FITS 04-10 KX250F, 06-08 KX450F FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 92005-0016 2005 KX250F FITS 88-00 KX125, 88-07 KX250, 88-04 KX500, 04-10 KX250F, 06-08 KX450F, 88-06 KDX200, 97-05 KDX220 - 16049-1051 FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450F - 49121-0001 2005 KX250F FITS 04-06 KX250F, 06 KX450F - 16041-0002 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R AUSTRALIAN - 21176-0016  2005 KX250F FITS 04-10 KX250F - 16021-0005 FITS 04-06 KX250F, 06 KX450F - 16025-0008 FITS 04-10 KX250F - 14091-0208   KOKUSAN DENKI - 2119-0041 CU7515 - FITS 05 KX250F - 21119-0041 2005 KX250F FITS 03-05 KX125, 03-08 KX250, 04-05 KX250F 12053-1468   F6T563 - FITS 05 KX250F, 06-08 KX450F, 08-09 KLX450R - 21121-0016 2005 KX250F         FITS 05-16 KX250F - 13087-0017 FITS 03-05 KX125, 04-14 KX250F - 13187-1089 FITS 04-05 KX250F - 13031-0016  FITS 04-08 KX250F - 4064 2005 KX250F             2005 KX250F   FITS 05-07 KX250, 05-08 KX250F,07-08 KX450F, 08-13 KLX450 - LEFT 34028-0014 - RIGHT 34028-0015 2005 KX250F 1201 2-R / 1201 2-L - 48MM CHROME OD - C/L 940MM (37") UPPER 55.92MM - LOWER 59.1MM - BRAKE C/L 102MM - AXLE CLAMPS 20 & 25MM ID 48mm x 58mm x 8.5/10 2005 KX250F GOLD - FITS 05 KX250 KX250F - 44037-0031-D3 2005 KX250F     04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 05 KX125 KX250, 05-06 KX250F - 43095-0060 2005 KX250F FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2005 KX250F F-0012 - BRG ID 20MM - BRG TO BRG 90MM - 36 SPOKES - ROTOR BC 4X AT 116MM - FITS 04-05 KX125 KX250 KX250F - 41034-0018 1.85 X 20 FITS 02 KX250, 03-05 KX125, 04-08 KX250F 2005 KX250F     FITS 05 kx250f - 11008-0050 FITS 04-08 KX250F - 14091-0058   2005 KX250F 26T - FITS 04-08 KX250F - 59051-0006   FITS 04-14 KX250F - 13066-0004 28T - FITS 04-12 KX250F - 59051-0033 FITS 04-06 KX250F, 06 YZ450F - 35019-0005 2005 KX250F FITS 05-14 KX250F -      2005 KX250F             2005 KX250F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466       FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514 NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022   FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004 FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514 2005 KX250F 0003-1 / 0003-2 - 25MM AXLE DIA - BRG TO BRG 133.5MM - ROTOR OD 240MM - ROTOR BC 4 ON 133MM - SPROCKET BC 6 ON 150MM - FITS 03-05 KX125, 03-06 KX250, 04-06 KX250F, 06 KX450F - 41034-0004 2005 KX250F       FITS 04-06 KX250F - 13141-0002 FITS 04-06 RM-Z250 - K1314-00022 - K1314-00024 - K1314-00023     2005 KX250F   KYB - FITS 05 KX250F - 45014-0083-8V - CLICK HERE FOR MEASUREMENTS 2005 KX250F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71117   2005 KX250F FITS 05-06 KX250F - 21003-0027   FITS 05 KX250F - 32160-0102-458   FITS 94-05 KX125, 04-07 KX250, 04-05 KX250F 2005 KX250F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002   2005 KX250F         2005 KX250F FITS 04-14 KX250F - 12005-0002      2005 KX250F     FITS 05-14 KX250F - 16142-0020 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-14 KX250F - 59256-1065   2005 KX250F 2005 KX250F
2006 KX250F     FITS 06 KX250F - 14001-0070 FITS 06-08 KX250F KX450F - 11011-0055-6Z   FITS 06-09 KX250F - 49118-0065 2006 KX250F FITS 06-10 KX250F - 49118-0066 KEIHIN FLAT CR FCR -080 37MM  FITS 06 KX250F - 15003-0080 2006 KX250F FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 14091-0209 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 16016-0009 2006 KX250F FITS 04-10 KX250F FITS 99-00 KX125, 99-07 KX250, 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 16031-1100 2006 KX250F FITS 04-10 KX250F, 06-08 KX450F FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 92005-0016 2006 KX250F FITS 88-00 KX125, 88-07 KX250, 88-04 KX500, 04-10 KX250F, 06-08 KX450F, 88-06 KDX200, 97-05 KDX220 - 16049-1051 FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450F - 49121-0001 2006 KX250F FITS 04-06 KX250F, 06 KX450F - 16041-0002 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R AUSTRALIAN - 21176-0016  2006 KX250F FITS 04-10 KX250F - 16021-0005 FITS 04-06 KX250F, 06 KX450F - 16025-0008 FITS 04-10 KX250F - 14091-0208   2006 KX250F       2006 KX250F         FITS 05-16 KX250F - 13087-0017 FITS 03-05 KX125, 04-14 KX250F - 13187-1089 FITS 06 KX250F - 13031-0070 FITS 04-08 KX250F - 4064 2006 KX250F             2006 KX250F   FITS 05-07 KX250, 05-08 KX250F,07-08 KX450F, 08-13 KLX450 - LEFT 34028-0014 - RIGHT 34028-0015 2006 KX250F USD - CHROME OD 47MM - UPPER 52.7MM - LOWER 58.4MM 47mm x 58mm x 10 2006 KX250F   2006 KX250F   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004 04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 05 KX125 KX250, 05-06 KX250F - 43095-0060 2006 KX250F FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2006 KX250F FITS 06 KX250, KX250F, KX450F - 41034-0005 1.85 X 20 FITS 02 KX250, 03-05 KX125, 04-08 KX250F 2006 KX250F BLACK - FITS 06-08 KX250F - 51001-0110-6Z     FITS 04-08 KX250F - 14091-0058   2006 KX250F 26T - FITS 04-08 KX250F - 59051-0006   FITS 04-14 KX250F - 13066-0004 28T - FITS 04-12 KX250F - 59051-0033 FITS 04-06 KX250F, 06 YZ450F - 35019-0005 2006 KX250F FITS 05-14 KX250F -      2006 KX250F     FITS 06-08 KX250F - 39061-0054 FITS 06-08 KX250F - 39061-0055     2006 KX250F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020 RIGHT FITS 03-05 KX125, 03-07 KX250, 04-11 KX250F, 06-11 KX450F, 08-09 12 KLX450R - 33040-1189 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022   FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004   2006 KX250F 0003-1 / 0003-2 - 25MM AXLE DIA - BRG TO BRG 133.5MM - ROTOR OD 240MM - ROTOR BC 4 ON 133MM - SPROCKET BC 6 ON 150MM - FITS 03-05 KX125, 03-06 KX250, 04-06 KX250F, 06 KX450F - 41034-0004 2006 KX250F   PAN 53066-0080 - GREEN/BLACK 53066-0131-336 - FITS 06-07 KX250F KX450F M127 - FITS 06-08 KX250F, 06-08 KX450F - 97127 FITS 04-06 KX250F - 13141-0002 FITS 04-06 RM-Z250 - K1314-00022 - K1314-00024 - K1314-00023     2006 KX250F     2006 KX250F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137   2006 KX250F FITS 05-06 KX250F - 21003-0027   FITS 06 KX250F KX450F - 32160-0153   FITS 06-14 KX250F KX450F - 33032-0012 2006 KX250F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002   2006 KX250F         2006 KX250F FITS 04-14 KX250F - 12005-0002    FITS 06-14 KX250F - 12032-0006 2006 KX250F FITS 06-14 KX250F- 12032-0005   FITS 05-14 KX250F - 16142-0020 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-14 KX250F - 59256-1065   2006 KX250F 2006 KX250F
2007 KX250F JKAKXMTC87A01#### KX250TE00#### FITS 07 KX250F - 14001-0097 FITS 09 KX250F - 11011-0148 0139 - FITS 07-08 KX250F - 14073-0139 FITS 06-09 KX250F - 49118-0065 2007 KX250F FITS 06-10 KX250F - 49118-0066 KEIHIN FLAT CR FCR POIO 37MM FITS 07-08 KX250F - 15004-0010     2007 KX250F FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 14091-0209 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 16016-0009 2007 KX250F FITS 04-10 KX250F FITS 99-00 KX125, 99-07 KX250, 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 16031-1100 2007 KX250F FITS 04-10 KX250F, 06-08 KX450F FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 92005-0016 2007 KX250F FITS 88-00 KX125, 88-07 KX250, 88-04 KX500, 04-10 KX250F, 06-08 KX450F, 88-06 KDX200, 97-05 KDX220 - 16049-1051 FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450F - 49121-0001 2007 KX250F   FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R AUSTRALIAN - 21176-0016  2007 KX250F FITS 04-10 KX250F - 16021-0005   FITS 04-10 KX250F - 14091-0208   21119-0083 CU7532 - FITS 07-08 KX250F - 21119-0083 2007 KX250F       2007 KX250F         FITS 05-16 KX250F - 13087-0017 FITS 03-05 KX125, 04-14 KX250F - 13187-1089 FITS 07-08 KX250F - 13031-0074 FITS 04-08 KX250F - 4064 2007 KX250F             2007 KX250F   FITS 05-07 KX250, 05-08 KX250F,07-08 KX450F, 08-13 KLX450 - LEFT 34028-0014 - RIGHT 34028-0015 2007 KX250F USD - CHROME OD 47MM - UPPER 52.7MM - LOWER 58.4MM - FITS 07 KX250F 47mm x 58mm x 10 2007 KX250F   2007 KX250F   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004 04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 07 KX250, 07-11 KX250F KX450F - 43095-0286 2007 KX250F FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2007 KX250F FITS 07-08 KX250F KX450F, 07 KX250 1.85 X 20 FITS 02 KX250, 03-05 KX125, 04-08 KX250F 2007 KX250F BLACK - FITS 06-08 KX250F - 51001-0110-6Z     FITS 04-08 KX250F - 14091-0058   2007 KX250F 26T - FITS 04-08 KX250F - 59051-0006   FITS 04-14 KX250F - 13066-0004 28T - FITS 04-12 KX250F - 59051-0033 FITS 07-12 KX250F KX450F, 08-12 KLX450R - 35019-0050 2007 KX250F FITS 05-14 KX250F -      2007 KX250F     FITS 06-08 KX250F - 39061-0054 FITS 06-08 KX250F - 39061-0055     2007 KX250F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020 RIGHT FITS 03-05 KX125, 03-07 KX250, 04-11 KX250F, 06-11 KX450F, 08-09 12 KLX450R - 33040-1189 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022   FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004   2007 KX250F PFD - 0025 - AXLE OD 25MM - BRG TO BRG 133MM - ROTOR OD 240MM - ROTOR BOLT CIRCLE 4 ON 133MM - SPROCKET BOLT CIRCLE 6 ON 150MM FITS 07-08 KX250F KX450F - 41034-0035-10Y 2007 KX250F TAKASAGO 19 X 1.85 FITS 03-05 KX125, 07 KX250F PAN 53066-0080 - GREEN/BLACK 53066-0131-336 - FITS 06-07 KX250F KX450F M127 - FITS 06-08 KX250F, 06-08 KX450F - 97127 FITS 07 KX250F - 13141-0022 FITS 07-08 KX250F     2007 KX250F SHOWA - K181 - Spring thickness: 11.2MM OD - Spring Diameter: 86.8MM - Spring length as mounted: 267MM - Upper mount tab thickness: 22.3MM - Upper mount tab hole ID: 10MM - Lower mount Major Width: 36.5MM - Lower mount Minor width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 486MM   2007 KX250F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137   2007 KX250F     FITS 070 KX250F KX450F - 32160-0194   FITS 06-14 KX250F KX450F - 33032-0012 2007 KX250F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002   2007 KX250F   SHAFTS AND GEARS FIT 07-08 KX250F     2007 KX250F FITS 04-14 KX250F - 12005-0002    FITS 06-14 KX250F - 12032-0006 2007 KX250F FITS 06-14 KX250F- 12032-0005   FITS 05-14 KX250F - 16142-0020 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-14 KX250F - 59256-1065 FITS 07-08 KX250F – 13107-0130 2007 KX250F 2007 KX250F
2008 KX250F     FITS 08 KX250F - 14001-0123   0139 - FITS 07-08 KX250F - 14073-0139 FITS 06-09 KX250F - 49118-0065 2008 KX250F FITS 06-10 KX250F - 49118-0066 KEIHIN FLAT CR FCR POIO 37MM FITS 07-08 KX250F - 15004-0010     2008 KX250F FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 14091-0209 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 16016-0009 2008 KX250F FITS 04-10 KX250F FITS 99-00 KX125, 99-07 KX250, 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 16031-1100 2008 KX250F FITS 04-10 KX250F, 06-08 KX450F FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 92005-0016 2008 KX250F FITS 88-00 KX125, 88-07 KX250, 88-04 KX500, 04-10 KX250F, 06-08 KX450F, 88-06 KDX200, 97-05 KDX220 - 16049-1051 FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450F - 49121-0001 2008 KX250F   FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R AUSTRALIAN - 21176-0016  2008 KX250F FITS 04-10 KX250F - 16021-0005   FITS 04-10 KX250F - 14091-0208   21119-0083 CU7532 - FITS 07-08 KX250F - 21119-0083 2008 KX250F       2008 KX250F         FITS 05-16 KX250F - 13087-0017 FITS 03-05 KX125, 04-14 KX250F - 13187-1089 FITS 07-08 KX250F - 13031-0074 FITS 04-08 KX250F - 4064 2008 KX250F             2008 KX250F   FITS 05-07 KX250, 05-08 KX250F,07-08 KX450F, 08-13 KLX450 - LEFT 34028-0014 - RIGHT 34028-0015 2008 KX250F USD - CHROME OD 47MM - UPPER 52.7MM - LOWER 58.4MM 47mm x 58mm x 10 2008 KX250F   2008 KX250F   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004 04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 07 KX250, 07-11 KX250F KX450F - 43095-0286 2008 KX250F FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2008 KX250F FITS 07-08 KX250F KX450F, 07 KX250 1.85 X 20 FITS 02 KX250, 03-05 KX125, 04-08 KX250F 2008 KX250F BLACK - FITS 06-08 KX250F - 51001-0110-6Z     FITS 04-08 KX250F - 14091-0058   2008 KX250F 26T - FITS 04-08 KX250F - 59051-0006   FITS 04-14 KX250F - 13066-0004 28T - FITS 04-12 KX250F - 59051-0033 FITS 07-12 KX250F KX450F, 08-12 KLX450R - 35019-0050 2008 KX250F FITS 05-14 KX250F -      2008 KX250F     FITS 06-08 KX250F - 39061-0054 FITS 06-08 KX250F - 39061-0055     2008 KX250F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020 RIGHT FITS 03-05 KX125, 03-07 KX250, 04-11 KX250F, 06-11 KX450F, 08-09 12 KLX450R - 33040-1189 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022   FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004   2008 KX250F PFD - 0025 - AXLE OD 25MM - BRG TO BRG 133MM - ROTOR OD 240MM - ROTOR BOLT CIRCLE 4 ON 133MM - SPROCKET BOLT CIRCLE 6 ON 150MM FITS 07-08 KX250F KX450F - 41034-0035-10Y 2008 KX250F     M127 - FITS 06-08 KX250F, 06-08 KX450F - 97127 FITS 08 KX250F - 13141-0040 FITS 07-08 KX250F     2008 KX250F     2008 KX250F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137   2008 KX250F         FITS 06-14 KX250F KX450F - 33032-0012 2008 KX250F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002   2008 KX250F   SHAFTS AND GEARS FIT 07-08 KX250F     2008 KX250F FITS 04-14 KX250F - 12005-0002    FITS 06-14 KX250F - 12032-0006 2008 KX250F FITS 06-14 KX250F- 12032-0005   FITS 05-14 KX250F - 16142-0020 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-14 KX250F - 59256-1065 FITS 07-08 KX250F – 13107-0130 2008 KX250F 2008 KX250F
2009 KX250F     FITS 09 KX250F - 14001-0150     FITS 06-09 KX250F - 49118-0065 2009 KX250F FITS 06-10 KX250F - 49118-0066       2009 KX250F FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 14091-0209 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 16016-0009 2009 KX250F FITS 04-10 KX250F FITS 99-00 KX125, 99-07 KX250, 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 16031-1100 2009 KX250F FITS 04-10 KX250F, 06-08 KX450F FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 92005-0016 2009 KX250F FITS 88-00 KX125, 88-07 KX250, 88-04 KX500, 04-10 KX250F, 06-08 KX450F, 88-06 KDX200, 97-05 KDX220 - 16049-1051 FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450F - 49121-0001 2009 KX250F   FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R AUSTRALIAN - 21176-0016  2009 KX250F FITS 04-10 KX250F - 16021-0005   FITS 04-10 KX250F - 14091-0208 FITS 09-14 KX250F - 12053-0129   2009 KX250F FITS 09-14 KX250F KX450F - 12053-0125 FITS 09-11 KX250F KX450F - 13272-0384   2009 KX250F FITS 09-14 KX250F - 13102-0034   FITS 09-14 KX250F - 14032-0136 FITS 09-12 KX250F - 14032-0120 FITS 05-16 KX250F - 13087-0017 FITS 03-05 KX125, 04-14 KX250F - 13187-1089 FITS 09 KX250F - 13031-0106 FITS 09 KX250F - 4096 2009 KX250F   FITS 09-14 KX250F - 14091-1629       2009 KX250F     2009 KX250F USD - CHROME OD 47MM - UPPER 52.7MM - LOWER 58.4MM 47mm x 58mm x 10 2009 KX250F   2009 KX250F   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004     FITS 07 KX250, 07-11 KX250F KX450F - 43095-0286 2009 KX250F FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2009 KX250F 0024 - BRG ID 20MM - BRG TO BRG 83-84MM - ROTOR BC 4X 150MM - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0034   2009 KX250F FITS 09-10 KX250F - 51001-0262     FITS 09-16 KX250F - 14091-1629 26T - FITS 09-14 KX250F - 59051-0089 2009 KX250F     FITS 04-14 KX250F - 13066-0004 28T - FITS 04-12 KX250F - 59051-0033 FITS 07-12 KX250F KX450F, 08-12 KLX450R - 35019-0050 2009 KX250F FITS 05-14 KX250F -      2009 KX250F             2009 KX250F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020 RIGHT FITS 03-05 KX125, 03-07 KX250, 04-11 KX250F, 06-11 KX450F, 08-09 12 KLX450R - 33040-1189 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022   FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004   2009 KX250F PFD - 0025 - AXLE OD 25MM - BRG TO BRG 133MM - ROTOR OD 240MM - ROTOR BOLT CIRCLE 4 ON 133MM - SPROCKET BOLT CIRCLE 6 ON 150MM, MOUNT 134MM OD - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0057 2009 KX250F   BLACK - FITS 09 KX250F KX450F - 53066-0207-MA   FITS 09 KX250F - 13141-0045 FITS 09-14 KX250F - 13140-0056 13140-0057     2009 KX250F     2009 KX250F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137 FITS 09-12 KX250F - LEFT 36001-0151-25P - RIGHT 36001-0153-25P 2009 KX250F     FITS 09 KX250F, 09-10 KX450F - 32160-0329   FITS 06-14 KX250F KX450F - 33032-0012 2009 KX250F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002   2009 KX250F FITS 09-14 KX250F - 12048-0056   14T - FITS 09-14 KX250F - 13127-0064 FITS 09 -13 KX250F - 13128-0046 2009 KX250F FITS 04-14 KX250F - 12005-0002  FITS 09-14 KX250F - 12004-0033 FITS 06-14 KX250F - 12032-0006 2009 KX250F FITS 06-14 KX250F- 12032-0005   FITS 05-14 KX250F - 16142-0020 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-14 KX250F - 59256-1065 FITS 09-14 KX250F - 13107-0196 2009 KX250F 53LB NO CARB - INCLUDES OIL, PLUG, AND KICKER 2009 KX250F
2010 KX250F     FITS 10 KX250F - 14001-0164       2010 KX250F FITS 06-10 KX250F - 49118-0066       2010 KX250F FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 14091-0209 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 16016-0009 2010 KX250F FITS 04-10 KX250F FITS 99-00 KX125, 99-07 KX250, 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 16031-1100 2010 KX250F FITS 04-10 KX250F, 06-08 KX450F FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 92005-0016 2010 KX250F FITS 88-00 KX125, 88-07 KX250, 88-04 KX500, 04-10 KX250F, 06-08 KX450F, 88-06 KDX200, 97-05 KDX220 - 16049-1051 FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450F - 49121-0001 2010 KX250F   FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R AUSTRALIAN - 21176-0016  2010 KX250F FITS 04-10 KX250F - 16021-0005   FITS 04-10 KX250F - 14091-0208 FITS 09-14 KX250F - 12053-0129   2010 KX250F FITS 09-14 KX250F KX450F - 12053-0125 FITS 09-11 KX250F KX450F - 13272-0384   2010 KX250F FITS 09-14 KX250F - 13102-0034 FITS 10-14 KX250F - 13095-0121 FITS 09-14 KX250F - 14032-0136 FITS 09-12 KX250F - 14032-0120 FITS 05-16 KX250F - 13087-0017 FITS 03-05 KX125, 04-14 KX250F - 13187-1089 FITS 10 KX250F - 13031-0136 FITS 10 KX250F - 4020 2010 KX250F   FITS 09-14 KX250F - 14091-1629         2010 KX250F     2010 KX250F USD - CHROME OD 47MM - UPPER 52.7MM - LOWER 58.4MM 47mm x 58mm x 10 2010 KX250F   2010 KX250F   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004     FITS 07 KX250, 07-11 KX250F KX450F - 43095-0286 2010 KX250F   NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2010 KX250F 0024 - BRG ID 20MM - BRG TO BRG 83-84MM - ROTOR BC 4X 150MM - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0034   2010 KX250F FITS 09-10 KX250F - 51001-0262     FITS 09-16 KX250F - 14091-1629 26T - FITS 09-14 KX250F - 59051-0089 2010 KX250F   FITS 10-12 KX250F - 13064-0059 FITS 04-14 KX250F - 13066-0004 28T - FITS 04-12 KX250F - 59051-0033 FITS 07-12 KX250F KX450F, 08-12 KLX450R - 35019-0050 2010 KX250F FITS 05-14 KX250F -  FITS 10-14 KX250F - 32099-0051   2010 KX250F 20T - FITS 10-14 KX250F - 13097-0117           2010 KX250F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020 RIGHT FITS 03-05 KX125, 03-07 KX250, 04-11 KX250F, 06-11 KX450F, 08-09 12 KLX450R - 33040-1189 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022       2010 KX250F PFD - 0025 - AXLE OD 25MM - BRG TO BRG 133MM - ROTOR OD 240MM - ROTOR BOLT CIRCLE 4 ON 133MM - SPROCKET BOLT CIRCLE 6 ON 150MM, MOUNT 134MM OD - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0057 2010 KX250F       FITS 10 KX250F - 13141-0052 FITS 09-14 KX250F - 13140-0056 13140-0057     2010 KX250F     2010 KX250F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137 FITS 09-12 KX250F - LEFT 36001-0151-25P - RIGHT 36001-0153-25P 2010 KX250F         FITS 06-14 KX250F KX450F - 33032-0012 2010 KX250F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002   2010 KX250F FITS 09-14 KX250F - 12048-0056   14T - FITS 09-14 KX250F - 13127-0064 FITS 09 -13 KX250F - 13128-0046 2010 KX250F FITS 04-14 KX250F - 12005-0002  FITS 09-14 KX250F - 12004-0033 FITS 06-14 KX250F - 12032-0006 2010 KX250F FITS 06-14 KX250F- 12032-0005   FITS 05-14 KX250F - 16142-0020 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-14 KX250F - 59256-1065 FITS 09-14 KX250F - 13107-0196 2010 KX250F 50.50LB NO CARB, OIL OR PLUG 2010 KX250F
2011 KX250F             2011 KX250F FITS 11-12 KX250F - 49118-0164     FITS 11-14 KX250F - 16065-0074 2011 KX250F     2011 KX250F     2011 KX250F     2011 KX250F     2011 KX250F     2011 KX250F       FITS 09-14 KX250F - 12053-0129   2011 KX250F FITS 09-14 KX250F KX450F - 12053-0125 FITS 09-11 KX250F KX450F - 13272-0384   2011 KX250F FITS 09-14 KX250F - 13102-0034 FITS 10-14 KX250F - 13095-0121 FITS 09-14 KX250F - 14032-0136 FITS 09-12 KX250F - 14032-0120 FITS 05-16 KX250F - 13087-0017 FITS 03-05 KX125, 04-14 KX250F - 13187-1089 FITS 11 KX250F - 13031-0143 FITS 11-13 KX250F - 4021 2011 KX250F FITS 11 KX250F - 11005-0138 FITS 09-14 KX250F - 14091-1629 FITS 11-14 KX250F - 21176-0009       2011 KX250F DENSO - 037000-8700 - MO = 8.0 - FITS 11-14 KX250F - 21007-0164   2011 KX250F USD - CHROME OD 47MM - UPPER 52.7MM - LOWER 58.4MM 47mm x 58mm x 10 2011 KX250F   2011 KX250F   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004     FITS 07 KX250, 07-11 KX250F KX450F - 43095-0286 2011 KX250F     2011 KX250F 0024 - BRG ID 20MM - BRG TO BRG 83-84MM - ROTOR BC 4X 150MM - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0034   2011 KX250F     FITS 11-12 KX250F - 11008-0218 FITS 09-16 KX250F - 14091-1629 26T - FITS 09-14 KX250F - 59051-0089 2011 KX250F   FITS 10-12 KX250F - 13064-0059 FITS 04-14 KX250F - 13066-0004 28T - FITS 04-12 KX250F - 59051-0033 FITS 07-12 KX250F KX450F, 08-12 KLX450R - 35019-0050 2011 KX250F FITS 05-14 KX250F -  FITS 10-14 KX250F - 32099-0051   2011 KX250F 20T - FITS 10-14 KX250F - 13097-0117           2011 KX250F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020 RIGHT FITS 03-05 KX125, 03-07 KX250, 04-11 KX250F, 06-11 KX450F, 08-09 12 KLX450R - 33040-1189   NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022       2011 KX250F PFD - 0025 - AXLE OD 25MM - BRG TO BRG 133MM - ROTOR OD 240MM - ROTOR BOLT CIRCLE 4 ON 133MM - SPROCKET BOLT CIRCLE 6 ON 150MM, MOUNT 134MM OD - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0057 2011 KX250F       FITS 11 KX250F - 13141-0054 FITS 09-14 KX250F - 13140-0056 13140-0057   FITS 11-14 KX250F - 13161-0077 2011 KX250F     2011 KX250F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137 FITS 09-12 KX250F - LEFT 36001-0151-25P - RIGHT 36001-0153-25P 2011 KX250F         FITS 06-14 KX250F KX450F - 33032-0012 2011 KX250F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002   2011 KX250F FITS 09-14 KX250F - 12048-0056   14T - FITS 09-14 KX250F - 13127-0064 FITS 09 -13 KX250F - 13128-0046 2011 KX250F FITS 04-14 KX250F - 12005-0002  FITS 09-14 KX250F - 12004-0033 FITS 06-14 KX250F - 12032-0006 2011 KX250F FITS 06-14 KX250F- 12032-0005   FITS 05-14 KX250F - 16142-0020 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-14 KX250F - 59256-1065 FITS 09-14 KX250F - 13107-0196 2011 KX250F 2011 KX250F
2012 KX250F   KX250YE01#### FITS 12 KX250F - 14001-0583     FITS 12-14 KX250F - 49118-0715 2012 KX250F FITS 11-12 KX250F - 49118-0164     FITS 11-14 KX250F - 16065-0074 2012 KX250F     2012 KX250F     2012 KX250F     2012 KX250F     2012 KX250F     2012 KX250F       FITS 09-14 KX250F - 12053-0129   2012 KX250F FITS 09-14 KX250F KX450F - 12053-0125     2012 KX250F FITS 09-14 KX250F - 13102-0034 FITS 10-14 KX250F - 13095-0121 FITS 09-14 KX250F - 14032-0136 FITS 09-12 KX250F - 14032-0120 FITS 05-16 KX250F - 13087-0017 FITS 03-05 KX125, 04-14 KX250F - 13187-1089 FITS 12 KX250F - 13031-0714 FITS 11-13 KX250F - 4021 2012 KX250F FITS 12 KX250F - 11005-0586 FITS 09-14 KX250F - 14091-1629 FITS 11-14 KX250F - 21176-0009       2012 KX250F DENSO - 037000-8700 - MO = 8.0 - FITS 11-14 KX250F - 21007-0164   2012 KX250F USD - CHROME OD 47MM - UPPER 52.7MM - LOWER 58.4MM 47mm x 58mm x 10 2012 KX250F   2012 KX250F   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004       2012 KX250F     2012 KX250F 0024 - BRG ID 20MM - BRG TO BRG 83-84MM - ROTOR BC 4X 150MM - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0034   2012 KX250F     FITS 11-12 KX250F - 11008-0218 FITS 09-16 KX250F - 14091-1629 26T - FITS 09-14 KX250F - 59051-0089 2012 KX250F   FITS 10-12 KX250F - 13064-0059 FITS 04-14 KX250F - 13066-0004 28T - FITS 04-12 KX250F - 59051-0033 FITS 07-12 KX250F KX450F, 08-12 KLX450R - 35019-0050 2012 KX250F FITS 05-14 KX250F -  FITS 10-14 KX250F - 32099-0051   2012 KX250F 20T - FITS 10-14 KX250F - 13097-0117           2012 KX250F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020     NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022       2012 KX250F PFD - 0025 - AXLE OD 25MM - BRG TO BRG 133MM - ROTOR OD 240MM - ROTOR BOLT CIRCLE 4 ON 133MM - SPROCKET BOLT CIRCLE 6 ON 150MM, MOUNT 134MM OD - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0057 2012 KX250F       FITS 12-13 KX250F - 13141-0575 FITS 09-14 KX250F - 13140-0056 13140-0057 FITS 12-14 - 49047-0620 49047-0621 FITS 11-14 KX250F - 13161-0077 2012 KX250F     2012 KX250F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137 FITS 09-12 KX250F - LEFT 36001-0151-25P - RIGHT 36001-0153-25P 2012 KX250F         FITS 06-14 KX250F KX450F - 33032-0012 2012 KX250F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002   2012 KX250F FITS 09-14 KX250F - 12048-0056   14T - FITS 09-14 KX250F - 13127-0064 FITS 09 -13 KX250F - 13128-0046 2012 KX250F FITS 04-14 KX250F - 12005-0002  FITS 09-14 KX250F - 12004-0033 FITS 06-14 KX250F - 12032-0006 2012 KX250F FITS 06-14 KX250F- 12032-0005   FITS 05-14 KX250F - 16142-0020 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-14 KX250F - 59256-1065 FITS 09-14 KX250F - 13107-0196 2012 KX250F 2012 KX250F
2013 KX250F           FITS 12-14 KX250F - 49118-0715 2013 KX250F       FITS 11-14 KX250F - 16065-0074 2013 KX250F     2013 KX250F     2013 KX250F     2013 KX250F     2013 KX250F     2013 KX250F       FITS 09-14 KX250F - 12053-0129   2013 KX250F FITS 09-14 KX250F KX450F - 12053-0125   FITS 13-16 KX250F - 21121-0706 2013 KX250F FITS 09-14 KX250F - 13102-0034 FITS 10-14 KX250F - 13095-0121 FITS 09-14 KX250F - 14032-0136 FITS 13-16 KX250F - 14032-0567 FITS 05-16 KX250F - 13087-0017 FITS 03-05 KX125, 04-14 KX250F - 13187-1089   FITS 11-13 KX250F - 4021 2013 KX250F   FITS 09-14 KX250F - 14091-1629 FITS 11-14 KX250F - 21176-0009       2013 KX250F DENSO - 037000-8700 - MO = 8.0 - FITS 11-14 KX250F - 21007-0164   2013 KX250F   48mm x 58mm x 8.5/10 2013 KX250F   2013 KX250F           2013 KX250F     2013 KX250F     2013 KX250F       FITS 09-16 KX250F - 14091-1629 26T - FITS 09-14 KX250F - 59051-0089 2013 KX250F     FITS 04-14 KX250F - 13066-0004     2013 KX250F FITS 05-14 KX250F -  FITS 10-14 KX250F - 32099-0051   2013 KX250F 20T - FITS 10-14 KX250F - 13097-0117           2013 KX250F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020       NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022       2013 KX250F   2013 KX250F       FITS 12-13 KX250F - 13141-0575 FITS 09-14 KX250F - 13140-0056 13140-0057 FITS 12-14 - 49047-0620 49047-0621 FITS 11-14 KX250F - 13161-0077 2013 KX250F     2013 KX250F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137   2013 KX250F   FITS 13-16 KX250F - 14031-0569     FITS 06-14 KX250F KX450F - 33032-0012 2013 KX250F     2013 KX250F FITS 09-14 KX250F - 12048-0056   14T - FITS 09-14 KX250F - 13127-0064 FITS 09 -13 KX250F - 13128-0046 2013 KX250F FITS 04-14 KX250F - 12005-0002  FITS 09-14 KX250F - 12004-0033 FITS 06-14 KX250F - 12032-0006 2013 KX250F FITS 06-14 KX250F- 12032-0005 FITS 2013-2016 KX250F, 2013-2015 KX450F - 21066-0721 FITS 05-14 KX250F - 16142-0020 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-14 KX250F - 59256-1065 FITS 09-14 KX250F - 13107-0196 2013 KX250F 2013 KX250F
2014 KX250F           FITS 12-14 KX250F - 49118-0715 2014 KX250F       FITS 11-14 KX250F - 16065-0074 2014 KX250F     2014 KX250F     2014 KX250F     2014 KX250F     2014 KX250F     2014 KX250F       FITS 09-14 KX250F - 12053-0129   2014 KX250F FITS 09-14 KX250F KX450F - 12053-0125   FITS 13-16 KX250F - 21121-0706 2014 KX250F FITS 09-14 KX250F - 13102-0034 FITS 10-14 KX250F - 13095-0121 FITS 09-14 KX250F - 14032-0136 FITS 13-16 KX250F - 14032-0567 FITS 05-16 KX250F - 13087-0017 FITS 03-05 KX125, 04-14 KX250F - 13187-1089     2014 KX250F   FITS 09-14 KX250F - 14091-1629 FITS 11-14 KX250F - 21176-0009       2014 KX250F DENSO - 037000-8700 - MO = 8.0 - FITS 11-14 KX250F - 21007-0164   2014 KX250F   48mm x 58mm x 8.5/10 2014 KX250F   2014 KX250F           2014 KX250F     2014 KX250F     2014 KX250F       FITS 09-16 KX250F - 14091-1629 26T - FITS 09-14 KX250F - 59051-0089 2014 KX250F     FITS 04-14 KX250F - 13066-0004     2014 KX250F FITS 05-14 KX250F -  FITS 10-14 KX250F - 32099-0051   2014 KX250F 20T - FITS 10-14 KX250F - 13097-0117           2014 KX250F   LEFT FITS 06-14 KX250F KX450F - 33040-0020       NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022       2014 KX250F   2014 KX250F       FITS 14 KX250F - 13141-0570 FITS 09-14 KX250F - 13140-0056 13140-0057 FITS 12-14 - 49047-0620 49047-0621 FITS 11-14 KX250F - 13161-0077 2014 KX250F     2014 KX250F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016     2014 KX250F   FITS 13-16 KX250F - 14031-0569     FITS 06-14 KX250F KX450F - 33032-0012 2014 KX250F     2014 KX250F FITS 09-14 KX250F - 12048-0056   14T - FITS 09-14 KX250F - 13127-0064   2014 KX250F FITS 04-14 KX250F - 12005-0002  FITS 09-14 KX250F - 12004-0033 FITS 06-14 KX250F - 12032-0006 2014 KX250F FITS 06-14 KX250F- 12032-0005 FITS 2013-2016 KX250F, 2013-2015 KX450F - 21066-0721 FITS 05-14 KX250F - 16142-0020 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-14 KX250F - 59256-1065 FITS 09-14 KX250F - 13107-0196 2014 KX250F FITS 2014-2016 KX250F - 26031-1558 2014 KX250F
2015 KX250F             2015 KX250F         2015 KX250F     2015 KX250F     2015 KX250F     2015 KX250F     2015 KX250F     2015 KX250F           2015 KX250F     FITS 13-16 KX250F - 21121-0706 2015 KX250F       FITS 13-16 KX250F - 14032-0567 FITS 05-16 KX250F - 13087-0017       2015 KX250F             2015 KX250F     2015 KX250F     2015 KX250F   2015 KX250F           2015 KX250F     2015 KX250F     2015 KX250F       FITS 09-16 KX250F - 14091-1629   2015 KX250F           2015 KX250F       2015 KX250F             2015 KX250F           NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022       2015 KX250F   2015 KX250F               2015 KX250F     2015 KX250F           2015 KX250F   FITS 13-16 KX250F - 14031-0569       2015 KX250F     2015 KX250F         2015 KX250F       2015 KX250F   FITS 2013-2016 KX250F, 2013-2015 KX450F - 21066-0721       2015 KX250F FITS 2014-2016 KX250F - 26031-1558 2015 KX250F
2016 KX250F        FITS 13-16 KX250F - 21121-0706           FITS 13-16 KX250F - 14032-0567 FITS 05-16 KX250F - 13087-0017        FITS 09-16 KX250F - 14091-1629        FITS 13-16 KX250F - 14031-0569                                           FITS 2013-2016 KX250F, 2013-2015 KX450F - 21066-0721           FITS 2014-2016 KX250F - 26031-1558
2006 KX450F       FITS 06-08 KX250F KX450F - 11011-0055-6Z FITS 06-08 KX450F - 14073-0085   2006 KX450F         2006 KX450F FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 14091-0209 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 16016-0009 2006 KX450F   FITS 99-00 KX125, 99-07 KX250, 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 16031-1100 2006 KX450F FITS 04-10 KX250F, 06-08 KX450F FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 92005-0016 2006 KX450F FITS 88-00 KX125, 88-07 KX250, 88-04 KX500, 04-10 KX250F, 06-08 KX450F, 88-06 KDX200, 97-05 KDX220 - 16049-1051 FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450F - 49121-0001 2006 KX450F FITS 04-06 KX250F, 06 KX450F - 16041-0002 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R AUSTRALIAN - 21176-0016  2006 KX450F   FITS 04-06 KX250F, 06 KX450F - 16025-0008       2006 KX450F     F6T563 - FITS 05 KX250F, 06-08 KX450F, 08-09 KLX450R - 21121-0016 2006 KX450F   FITS 06-09 KX450F - 13095-0052     FITS 06-12 KX450F - 13087-0015 FITS 06-09 KX450F - 13187-0007 FITS 06 KX450F - 13031-0069   2006 KX450F FITS 06-07 KX450F - 11005-0049     FITS 06-07 KX450F - 32190-0232 FITS 06-08 KX450F - 49107-0077 FITS 06-08 KX450F - 4K08450-TI-GP 2006 KX450F DENSO 132000-0023 MO = 4.5 - FITS 06-08 KX450F - 21007-0080   2006 KX450F   48mm x 58mm x 8.5/10 2006 KX450F   2006 KX450F   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004 04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300   2006 KX450F FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2006 KX450F FITS 06 KX250, KX250F, KX450F - 41034-0005   2006 KX450F   FITS 06-08 KX450F - SCREW CAP - 2.8 GAL EMBOSSED KX-31 113149-N2 - 3.2 GAL EMBOSSED KX-34 113150-N2   FITS 06-07 KX450F - 14091-0436 FITS 06-08 KX450F - 14032-0062 2006 KX450F 30T - FITS 06-12 KX450F - 59051-0030   FITS 07-08 KX450F - 13066-0008 33T - FITS 06-12 KX450F - 59051-0046 FITS 04-06 KX250F, 06 YZ450F - 35019-0005 2006 KX450F FITS 06-12 KX450F - 11065-0107    STD 96MM - FITS 06-08 KX450F - 07-12 KLX450R - 13001-0073 2006 KX450F   SET FITS 06-07 KX450F 39062-0083 39062-0084 39062-0085 39062-0086 39062-0087 39062-0088 39062-0089 FITS 06-08 KX450F - 08-09 KLX450R - 39061-0052 FITS 06-08 KX450F - 39061-0053 FITS 06-08 KX450F, 07-08 KLX450R - 14037-0036-RZ FITS 06-08 KX450F, 07-08 KLX450R - 14037-0037-RZ 2006 KX450F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020 RIGHT FITS 03-05 KX125, 03-07 KX250, 04-11 KX250F, 06-11 KX450F, 08-09 12 KLX450R - 33040-1189 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022 0046 - FITS 06-11 KX450F, 06-13 KLX450R - 13236-0086 FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004   2006 KX450F 0003-1 / 0003-2 - 25MM AXLE DIA - BRG TO BRG 133.5MM - ROTOR OD 240MM - ROTOR BC 4 ON 133MM - SPROCKET BC 6 ON 150MM - FITS 03-05 KX125, 03-06 KX250, 04-06 KX250F, 06 KX450F - 41034-0004 2006 KX450F   PAN 53066-0080 - GREEN/BLACK 53066-0131-336 - FITS 06-07 KX250F KX450F M127 - FITS 06-08 KX250F, 06-08 KX450F - 97127         2006 KX450F CLICK HERE FOR MEASUREMENTS AND PICS   2006 KX450F FITS 06 KX450F - 39007-0063 FITS 06 KX450F - 39111-0027 1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137 WHITE FITS 06-08 KX450F - LEFT 36001-0084-266 - RIGHT 36001-0088-266 2006 KX450F     FITS 06 KX250F KX450F - 32160-0153 FITS 06 KX450F - 33001-0085 FITS 06-14 KX250F KX450F - 33032-0012 2006 KX450F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002 FITS 06-08 KX450F, 08-09 12 KLX450R - 92057-0035 2006 KX450F FITS 06-12 KX450F, 08-09 12 KLX450R - 12048-0021       2006 KX450F       2006 KX450F     FITS 06-12 KX450F, 08-09 12 KLX450R - 16142-0029     2006 KX450F 2006 KX450F
2007 KX450F JKAKXGDC37A01####     FITS 06-08 KX250F KX450F - 11011-0055-6Z FITS 06-08 KX450F - 14073-0085   2007 KX450F         2007 KX450F FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 14091-0209 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 16016-0009 2007 KX450F   FITS 99-00 KX125, 99-07 KX250, 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 16031-1100 2007 KX450F FITS 04-10 KX250F, 06-08 KX450F FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 92005-0016 2007 KX450F FITS 88-00 KX125, 88-07 KX250, 88-04 KX500, 04-10 KX250F, 06-08 KX450F, 88-06 KDX200, 97-05 KDX220 - 16049-1051 FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450F - 49121-0001 2007 KX450F   FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R AUSTRALIAN - 21176-0016  2007 KX450F         FITS 07-08 KX250F - 21119-0083 2007 KX450F     F6T563 - FITS 05 KX250F, 06-08 KX450F, 08-09 KLX450R - 21121-0016 2007 KX450F   FITS 06-09 KX450F - 13095-0052     FITS 06-12 KX450F - 13087-0015 FITS 06-09 KX450F - 13187-0007 FITS 07 KX450F - 13031-0076   2007 KX450F FITS 06-07 KX450F - 11005-0049     FITS 06-07 KX450F - 32190-0232 FITS 06-08 KX450F - 49107-0077 FITS 06-08 KX450F - 4K08450-TI-GP 2007 KX450F DENSO 132000-0023 MO = 4.5 - FITS 06-08 KX450F - 21007-0080 FITS 05-07 KX250, 05-08 KX250F,07-08 KX450F, 08-13 KLX450 - LEFT 34028-0014 - RIGHT 34028-0015 2007 KX450F R OR L KX06 - CHROME 48MM - C/L 955MM (37 5/8") - UPPER 53.8MM - LOWER 59.1MM - BRAKE C/L 102MM - AXLE CLAMPS 20 & 25MM 48mm x 58mm x 8.5/10 2007 KX450F GOLD - EMBOSSED 52017 7IN - FITS 07 KX450F - 44037-0033-10Y 2007 KX450F GOLD - EMBOSSED K1022 - FITS 07-08 KX450F - 44039-0035-10Y FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004 04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 07 KX250, 07-11 KX250F KX450F - 43095-0286 2007 KX450F FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2007 KX450F FITS 07-08 KX250F KX450F, 07 KX250   2007 KX450F   FITS 06-08 KX450F - SCREW CAP - 2.8 GAL EMBOSSED KX-31 113149-N2 - 3.2 GAL EMBOSSED KX-34 113150-N2 FITS 07 KX450F - 11008-0098 FITS 06-07 KX450F - 14091-0436 FITS 06-08 KX450F - 14032-0062 2007 KX450F 30T - FITS 06-12 KX450F - 59051-0030   FITS 07-08 KX450F - 13066-0008 33T - FITS 06-12 KX450F - 59051-0046 FITS 07-12 KX250F KX450F, 08-12 KLX450R - 35019-0050 2007 KX450F FITS 06-12 KX450F - 11065-0107    STD 96MM - FITS 06-08 KX450F - 07-12 KLX450R - 13001-0073 2007 KX450F   SET FITS 06-07 KX450F 39062-0083 39062-0084 39062-0085 39062-0086 39062-0087 39062-0088 39062-0089 FITS 06-08 KX450F - 08-09 KLX450R - 39061-0052 FITS 06-08 KX450F - 39061-0053 FITS 06-08 KX450F, 07-08 KLX450R - 14037-0036-RZ FITS 06-08 KX450F, 07-08 KLX450R - 14037-0037-RZ 2007 KX450F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020 RIGHT FITS 03-05 KX125, 03-07 KX250, 04-11 KX250F, 06-11 KX450F, 08-09 12 KLX450R - 33040-1189 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022 0046 - FITS 06-11 KX450F, 06-13 KLX450R - 13236-0086 FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004   2007 KX450F PFD - 0025 - AXLE OD 25MM - BRG TO BRG 133MM - ROTOR OD 240MM - ROTOR BOLT CIRCLE 4 ON 133MM - SPROCKET BOLT CIRCLE 6 ON 150MM FITS 07-08 KX250F KX450F - 41034-0035-10Y 2007 KX450F   PAN 53066-0080 - GREEN/BLACK 53066-0131-336 - FITS 06-07 KX250F KX450F M127 - FITS 06-08 KX250F, 06-08 KX450F - 97127         2007 KX450F BOOK SAYS FITS 07 KX450 - 45014-5029 - EXTERNAL MEASUREMENTS ARE THE SAME FOR THE 2006 KX450F   2007 KX450F 0073 - FITS 07-08 KX450F, 08-13 KLX450R - 39007-0073  0019 - FITS 07-08 KX450F - 39111-0033 1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137 WHITE FITS 06-08 KX450F - LEFT 36001-0084-266 - RIGHT 36001-0088-266 2007 KX450F     FITS 07 KX250F KX450F - 32160-0194 FITS 07-08 KX450F, 08-09 12 KLX450R - 33001-0108 FITS 06-14 KX250F KX450F - 33032-0012 2007 KX450F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002 FITS 06-08 KX450F, 08-09 12 KLX450R - 92057-0035 2007 KX450F FITS 06-12 KX450F, 08-09 12 KLX450R - 12048-0021       2007 KX450F       2007 KX450F     FITS 06-12 KX450F, 08-09 12 KLX450R - 16142-0029     2007 KX450F 2007 KX450F
2008 KX450F       FITS 06-08 KX250F KX450F - 11011-0055-6Z FITS 06-08 KX450F - 14073-0085   2008 KX450F         2008 KX450F FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 14091-0209 FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R - 16016-0009 2008 KX450F   FITS 99-00 KX125, 99-07 KX250, 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 16031-1100 2008 KX450F FITS 04-10 KX250F, 06-08 KX450F FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450R - 92005-0016 2008 KX450F FITS 88-00 KX125, 88-07 KX250, 88-04 KX500, 04-10 KX250F, 06-08 KX450F, 88-06 KDX200, 97-05 KDX220 - 16049-1051 FITS 04-10 KX250F, 06-08 KX450F, 08-09 KLX450F - 49121-0001 2008 KX450F   FITS 04-10 KX250F, 06-08 KX450F, 08-09 12-13 KLX450R AUSTRALIAN - 21176-0016  2008 KX450F         FITS 07-08 KX250F - 21119-0083 2008 KX450F     F6T563 - FITS 05 KX250F, 06-08 KX450F, 08-09 KLX450R - 21121-0016 2008 KX450F   FITS 06-09 KX450F - 13095-0052     FITS 06-12 KX450F - 13087-0015 FITS 06-09 KX450F - 13187-0007 FITS 08 KX450F - 13031-0096   2008 KX450F         FITS 06-08 KX450F - 49107-0077 FITS 06-08 KX450F - 4K08450-TI-GP 2008 KX450F DENSO 132000-0023 MO = 4.5 - FITS 06-08 KX450F - 21007-0080 FITS 05-07 KX250, 05-08 KX250F,07-08 KX450F, 08-13 KLX450 - LEFT 34028-0014 - RIGHT 34028-0015 2008 KX450F   48mm x 58mm x 8.5/10 2008 KX450F   2008 KX450F GOLD - EMBOSSED K1022 - FITS 07-08 KX450F - 44039-0035-10Y FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004 04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 FITS 07 KX250, 07-11 KX250F KX450F - 43095-0286 2008 KX450F FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2008 KX450F FITS 07-08 KX250F KX450F, 07 KX250   2008 KX450F   FITS 06-08 KX450F - SCREW CAP - 2.8 GAL EMBOSSED KX-31 113149-N2 - 3.2 GAL EMBOSSED KX-34 113150-N2     FITS 06-08 KX450F - 14032-0062 2008 KX450F 30T - FITS 06-12 KX450F - 59051-0030     33T - FITS 06-12 KX450F - 59051-0046 FITS 07-12 KX250F KX450F, 08-12 KLX450R - 35019-0050 2008 KX450F FITS 06-12 KX450F - 11065-0107    STD 96MM - FITS 06-08 KX450F - 07-12 KLX450R - 13001-0073 2008 KX450F     FITS 06-08 KX450F - 08-09 KLX450R - 39061-0052 FITS 06-08 KX450F - 39061-0053 FITS 06-08 KX450F, 07-08 KLX450R - 14037-0036-RZ FITS 06-08 KX450F, 07-08 KLX450R - 14037-0037-RZ 2008 KX450F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020 RIGHT FITS 03-05 KX125, 03-07 KX250, 04-11 KX250F, 06-11 KX450F, 08-09 12 KLX450R - 33040-1189 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022 0046 - FITS 06-11 KX450F, 06-13 KLX450R - 13236-0086 FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004   2008 KX450F PFD - 0025 - AXLE OD 25MM - BRG TO BRG 133MM - ROTOR OD 240MM - ROTOR BOLT CIRCLE 4 ON 133MM - SPROCKET BOLT CIRCLE 6 ON 150MM FITS 07-08 KX250F KX450F - 41034-0035-10Y 2008 KX450F     M127 - FITS 06-08 KX250F, 06-08 KX450F - 97127         2008 KX450F     2008 KX450F 0073 - FITS 07-08 KX450F, 08-13 KLX450R - 39007-0073  0019 - FITS 07-08 KX450F - 39111-0033 1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137 WHITE FITS 06-08 KX450F - LEFT 36001-0084-266 - RIGHT 36001-0088-266 2008 KX450F       FITS 07-08 KX450F, 08-09 12 KLX450R - 33001-0108 FITS 06-14 KX250F KX450F - 33032-0012 2008 KX450F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002 FITS 06-08 KX450F, 08-09 12 KLX450R - 92057-0035 2008 KX450F FITS 06-12 KX450F, 08-09 12 KLX450R - 12048-0021       2008 KX450F       2008 KX450F     FITS 06-12 KX450F, 08-09 12 KLX450R - 16142-0029     2008 KX450F 2008 KX450F
2009 KX450F       FITS 09 KX450F - 11011-0147     2009 KX450F         2009 KX450F     2009 KX450F     2009 KX450F     2009 KX450F     2009 KX450F     2009 KX450F           2009 KX450F FITS 09-14 KX250F KX450F - 12053-0125 FITS 09-11 KX250F KX450F - 13272-0384   2009 KX450F   FITS 06-09 KX450F - 13095-0052     FITS 06-12 KX450F - 13087-0015 FITS 06-09 KX450F - 13187-0007 FITS 09 KX450F - 13031-0107   2009 KX450F             2009 KX450F     2009 KX450F   48mm x 58mm x 8.5/10 2009 KX450F   2009 KX450F   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004     FITS 07 KX250, 07-11 KX250F KX450F - 43095-0286 2009 KX450F FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 00-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2009 KX450F 0024 - BRG ID 20MM - BRG TO BRG 83-84MM - ROTOR BC 4X 150MM - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0034   2009 KX450F   FITS 09-11 KX450F - SCREW CAP - 2.7 GAL 113154-N2 FITS 09-11 KX450F - 11008-0173     2009 KX450F 30T - FITS 06-12 KX450F - 59051-0030     33T - FITS 06-12 KX450F - 59051-0046 FITS 07-12 KX250F KX450F, 08-12 KLX450R - 35019-0050 2009 KX450F FITS 06-12 KX450F - 11065-0107     2009 KX450F             2009 KX450F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020 RIGHT FITS 03-05 KX125, 03-07 KX250, 04-11 KX250F, 06-11 KX450F, 08-09 12 KLX450R - 33040-1189 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022 0046 - FITS 06-11 KX450F, 06-13 KLX450R - 13236-0086 FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004   2009 KX450F PFD - 0025 - AXLE OD 25MM - BRG TO BRG 133MM - ROTOR OD 240MM - ROTOR BOLT CIRCLE 4 ON 133MM - SPROCKET BOLT CIRCLE 6 ON 150MM, MOUNT 134MM OD - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0057 2009 KX450F   BLACK - FITS 09 KX250F KX450F - 53066-0207-MA           2009 KX450F     2009 KX450F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137   2009 KX450F     FITS 09 KX250F, 09-10 KX450F - 32160-0329   FITS 06-14 KX250F KX450F - 33032-0012 2009 KX450F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002   2009 KX450F FITS 06-12 KX450F, 08-09 12 KLX450R - 12048-0021       2009 KX450F       2009 KX450F     FITS 06-12 KX450F, 08-09 12 KLX450R - 16142-0029     2009 KX450F 64lb with oil  * not confirmed * 2009 KX450F
2010 KX450F             2010 KX450F         2010 KX450F     2010 KX450F     2010 KX450F     2010 KX450F     2010 KX450F     2010 KX450F           2010 KX450F FITS 09-14 KX250F KX450F - 12053-0125 FITS 09-11 KX250F KX450F - 13272-0384   2010 KX450F         FITS 06-12 KX450F - 13087-0015   FITS 10-12 KX450F - 13031-0133   2010 KX450F             2010 KX450F     2010 KX450F   48mm x 58mm x 8.5/10 2010 KX450F   2010 KX450F   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004     FITS 07 KX250, 07-11 KX250F KX450F - 43095-0286 2010 KX450F FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346   2010 KX450F 0024 - BRG ID 20MM - BRG TO BRG 83-84MM - ROTOR BC 4X 150MM - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0034   2010 KX450F   FITS 09-11 KX450F - SCREW CAP - 2.7 GAL 113154-N2 FITS 09-11 KX450F - 11008-0173     2010 KX450F 30T - FITS 06-12 KX450F - 59051-0030     33T - FITS 06-12 KX450F - 59051-0046 FITS 07-12 KX250F KX450F, 08-12 KLX450R - 35019-0050 2010 KX450F FITS 06-12 KX450F - 11065-0107     2010 KX450F             2010 KX450F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020 RIGHT FITS 03-05 KX125, 03-07 KX250, 04-11 KX250F, 06-11 KX450F, 08-09 12 KLX450R - 33040-1189 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022 0046 - FITS 06-11 KX450F, 06-13 KLX450R - 13236-0086 FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004   2010 KX450F PFD - 0025 - AXLE OD 25MM - BRG TO BRG 133MM - ROTOR OD 240MM - ROTOR BOLT CIRCLE 4 ON 133MM - SPROCKET BOLT CIRCLE 6 ON 150MM, MOUNT 134MM OD - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0057 2010 KX450F               2010 KX450F     2010 KX450F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137   2010 KX450F     FITS 09 KX250F, 09-10 KX450F - 32160-0329   FITS 06-14 KX250F KX450F - 33032-0012 2010 KX450F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002   2010 KX450F FITS 06-12 KX450F, 08-09 12 KLX450R - 12048-0021       2010 KX450F       2010 KX450F     FITS 06-12 KX450F, 08-09 12 KLX450R - 16142-0029     2010 KX450F 68.5 dry, no carb, no kick lever * not confirmed * 2010 KX450F
2011 KX450F             2011 KX450F         2011 KX450F     2011 KX450F     2011 KX450F     2011 KX450F     2011 KX450F     2011 KX450F           2011 KX450F FITS 09-14 KX250F KX450F - 12053-0125 FITS 09-11 KX250F KX450F - 13272-0384   2011 KX450F         FITS 06-12 KX450F - 13087-0015   FITS 10-12 KX450F - 13031-0133   2011 KX450F             2011 KX450F     2011 KX450F   48mm x 58mm x 8.5/10 2011 KX450F   2011 KX450F   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004     FITS 07 KX250, 07-11 KX250F KX450F - 43095-0286 2011 KX450F FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346   2011 KX450F 0024 - BRG ID 20MM - BRG TO BRG 83-84MM - ROTOR BC 4X 150MM - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0034   2011 KX450F   FITS 09-11 KX450F - SCREW CAP - 2.7 GAL 113154-N2 FITS 09-11 KX450F - 11008-0173     2011 KX450F 30T - FITS 06-12 KX450F - 59051-0030     33T - FITS 06-12 KX450F - 59051-0046 FITS 07-12 KX250F KX450F, 08-12 KLX450R - 35019-0050 2011 KX450F FITS 06-12 KX450F - 11065-0107     2011 KX450F             2011 KX450F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020 RIGHT FITS 03-05 KX125, 03-07 KX250, 04-11 KX250F, 06-11 KX450F, 08-09 12 KLX450R - 33040-1189 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022 0046 - FITS 06-11 KX450F, 06-13 KLX450R - 13236-0086     2011 KX450F PFD - 0025 - AXLE OD 25MM - BRG TO BRG 133MM - ROTOR OD 240MM - ROTOR BOLT CIRCLE 4 ON 133MM - SPROCKET BOLT CIRCLE 6 ON 150MM, MOUNT 134MM OD - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0057 2011 KX450F               2011 KX450F     2011 KX450F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137   2011 KX450F         FITS 06-14 KX250F KX450F - 33032-0012 2011 KX450F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002   2011 KX450F FITS 06-12 KX450F, 08-09 12 KLX450R - 12048-0021       2011 KX450F       2011 KX450F     FITS 06-12 KX450F, 08-09 12 KLX450R - 16142-0029     2011 KX450F 2011 KX450F
2012 KX450F             2012 KX450F         2012 KX450F     2012 KX450F     2012 KX450F     2012 KX450F     2012 KX450F     2012 KX450F           2012 KX450F FITS 09-14 KX250F KX450F - 12053-0125     2012 KX450F         FITS 06-12 KX450F - 13087-0015   FITS 10-12 KX450F - 13031-0133   2012 KX450F             2012 KX450F     2012 KX450F   48mm x 58mm x 8.5/10 2012 KX450F   2012 KX450F   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004       2012 KX450F     2012 KX450F 0024 - BRG ID 20MM - BRG TO BRG 83-84MM - ROTOR BC 4X 150MM - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0034   2012 KX450F   FITS 12-14 KX450F - SCREW CAP - 2.7 GAL 113158-N2       2012 KX450F 30T - FITS 06-12 KX450F - 59051-0030     33T - FITS 06-12 KX450F - 59051-0046 FITS 07-12 KX250F KX450F, 08-12 KLX450R - 35019-0050 2012 KX450F FITS 06-12 KX450F - 11065-0107     2012 KX450F             2012 KX450F FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 LEFT FITS 06-14 KX250F KX450F - 33040-0020     NISSIN 0007 2 - FITS 06-12 KX250F KX450F, 08-12 KLX450R - 43080-0037  NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022       2012 KX450F PFD - 0025 - AXLE OD 25MM - BRG TO BRG 133MM - ROTOR OD 240MM - ROTOR BOLT CIRCLE 4 ON 133MM - SPROCKET BOLT CIRCLE 6 ON 150MM, MOUNT 134MM OD - 36 SPOKES - FITS 09-12 KX250F KX450F - 41034-0057 2012 KX450F               2012 KX450F     2012 KX450F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137   2012 KX450F         FITS 06-14 KX250F KX450F - 33032-0012 2012 KX450F FITS 04-12 KX250F, 06-12 KX450F, 08-12 KLR650, 08-9 12 KLX450R - 32099-0003 - 32099-0002   2012 KX450F FITS 06-12 KX450F, 08-09 12 KLX450R - 12048-0021       2012 KX450F       2012 KX450F     FITS 06-12 KX450F, 08-09 12 KLX450R - 16142-0029     2012 KX450F 2012 KX450F
2013 KX450F             2013 KX450F         2013 KX450F     2013 KX450F     2013 KX450F     2013 KX450F     2013 KX450F     2013 KX450F           2013 KX450F FITS 09-14 KX250F KX450F - 12053-0125     2013 KX450F                 2013 KX450F             2013 KX450F     2013 KX450F   48mm x 58mm x 8.5/10 2013 KX450F   2013 KX450F           2013 KX450F     2013 KX450F     2013 KX450F   FITS 12-14 KX450F - SCREW CAP - 2.7 GAL 113158-N2 FITS 2013-2014 KX250F - 11008-0750     2013 KX450F           2013 KX450F       2013 KX450F             2013 KX450F   LEFT FITS 06-14 KX250F KX450F - 33040-0020     NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022       2013 KX450F   2013 KX450F               2013 KX450F     2013 KX450F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137   2013 KX450F         FITS 06-14 KX250F KX450F - 33032-0012 2013 KX450F     2013 KX450F         2013 KX450F       2013 KX450F   FITS 2013-2016 KX250F, 2013-2015 KX450F - 21066-0721       2013 KX450F 2013 KX450F
2014 KX450F   KX250ZE013###         2014 KX450F         2014 KX450F     2014 KX450F     2014 KX450F     2014 KX450F     2014 KX450F     2014 KX450F           2014 KX450F FITS 09-14 KX250F KX450F - 12053-0125     2014 KX450F                 2014 KX450F             2014 KX450F     2014 KX450F   48mm x 58mm x 8.5/10 2014 KX450F   2014 KX450F           2014 KX450F     2014 KX450F     2014 KX450F   FITS 12-14 KX450F - SCREW CAP - 2.7 GAL 113158-N2       2014 KX450F           2014 KX450F       2014 KX450F             2014 KX450F   LEFT FITS 06-14 KX250F KX450F - 33040-0020     NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022       2014 KX450F   2014 KX450F               2014 KX450F     2014 KX450F     1 per set - 92046-1301 - 16x22x12 = HK1612 | 6 PER SET - 92046-1151 - 20x26x16 - HK2016 22-71137   2014 KX450F         FITS 06-14 KX250F KX450F - 33032-0012 2014 KX450F     2014 KX450F         2014 KX450F       2014 KX450F   FITS 2013-2016 KX250F, 2013-2015 KX450F - 21066-0721       2014 KX450F 2014 KX450F
2015 KX450F             2015 KX450F         2015 KX450F     2015 KX450F     2015 KX450F     2015 KX450F     2015 KX450F     2015 KX450F           2015 KX450F       2015 KX450F                 2015 KX450F             2015 KX450F     2015 KX450F     2015 KX450F   2015 KX450F           2015 KX450F     2015 KX450F     2015 KX450F           2015 KX450F           2015 KX450F       2015 KX450F             2015 KX450F         NISSIN 0004 - FITS 04-15 KX250F, 06-15 KX450F, 08-09 12-13 KLX450R - 14079-0022       2015 KX450F   2015 KX450F               2015 KX450F     2015 KX450F           2015 KX450F           2015 KX450F     2015 KX450F         2015 KX450F       2015 KX450F   FITS 2013-2016 KX250F, 2013-2015 KX450F - 21066-0721       2015 KX450F 2015 KX450F
YEAR TYPE VIN FRAME USA ONLY ENGINE ID ENGINE CASES AIR BOX NO BOOT AIR BOX TO CARB BOOT DUCT CAM SHAFT EXHAUST YEAR TYPE CAM SHAFT INTAKE CARBURETOR / EFI CARBURETOR BODY CARBURETOR BOOT JOINT HOLDER EFI YEAR TYPE CARBURETOR CABLE COVER CARBURETOR CHOKE PLUNGER YEAR TYPE CARBURETOR DIAPHRAGM COVER CARBURETOR FLOAT YEAR TYPE CARBURETOR FLOAT BOWL COVER CARBURETOR FUEL LINE FITTING YEAR TYPE CARBURETOR MAIN JET COVER CARBURETOR MAIN NOZZLE YEAR TYPE CARBURETOR SHAFT CARBURETOR THROTTLE POSITION SENSOR YEAR TYPE CARBURETOR THROTTLE STOP SCREW CARBURETOR THROTTLE VALVE CARBURETOR TOP COVER CASE SAVER CHAIN GUIDE CDI YEAR TYPE CHAIN GUIDE PLASTIC CHAIN GUIDE PLATE (ALUMINUM) COIL (IGNITION) YEAR TYPE CLUTCH ARM CLUTCH BASKET CLUTCH COVER (INNER) CLUTCH COVER (OUTER) CLUTCH HUB (INNER) CLUTCH PRESSURE (OPERATING) PLATE CRANK SHAFT CRANK SHAFT (HOT RODS) YEAR TYPE CYLINDER CYLINDER HEAD COVER CYLINDER HEAD H2O SENSOR ENGINE MOUNTS FRONT EXHAUST PIPE HEADER GUARD EXHAUST SYSTEM PRO CIRCUIT TI-4 YEAR TYPE FLY WHEEL ROTOR FOOT PEGS YEAR TYPE FORKS FORK SEAL SIZES YEAR TYPE FORK UNDER HOLDER (STEERING STEM LOWER TRIPLE CLAMP) YEAR TYPE FORK UPPER CROWN HOLDER (TRIPLE TREE) FRONT AXLE FRONT BRAKE CALIPER FRONT BRAKE CALIPER MOUNT FRONT BRAKE HOSE YEAR TYPE FRONT BRAKE LEVER FRONT BRAKE MASTER CYLINDER YEAR TYPE FRONT HUB FRONT RIM YEAR TYPE GAS TANK GAS TANK IMS HEAD HEAD COVER INNER CLUTCH COVER YEAR TYPE KICK IDLER SPUR GEAR KICK LEVER KICK LEVER SHAFT KICK LEVER SHAFT SPUR GEAR MUD FLAP YEAR TYPE OIL FILTER CAP OIL PUMP HOUSING PISTON  YEAR TYPE PRIMARY CRANK GEAR RADIATOR HOSES RADIATOR LEFT RADIATOR RIGHT RADIATOR SCREEN LEFT RADIATOR SCREEN RIGHT YEAR TYPE REAR AXLE REAR AXLE CHAIN ADJUSTMENT BLOCK LEFT REAR AXLE CHAIN ADJUSTMENT BLOCK RIGHT REAR AXLE SPACERS COLLARS REAR BRAKE CALIPER REAR BRAKE CALIPER HOLDER MOUNT REAR BRAKE LEVER REAR BRAKE MASTER CYLINDER REAR BRAKE ROTOR YEAR TYPE REAR HUB YEAR TYPE REAR RIM SEAT SEAT SDG SHIFT DRUM SHIFT FORKS SHIFT FORK PINS SHIFT SHAFT YEAR TYPE SHOCK SHOCK YEAR TYPE SHOCK ARM LINKAGE UNI TRAK SHOCK ARM TIE ROD SHOCK ARM LINKAGE BEARINGS (Uni-Trak) SHOCK ARM LINKAGE BEARINGS (Uni-Trak) ALL BALLS SIDE COVERS YEAR TYPE STATOR STATOR COVER SUB FRAME SWING ARM SWING ARM PIVOT PIN YEAR TYPE THROTTLE HOUSING TIMING CHAIN YEAR TYPE TIMING CHAIN TENSIONER TRANSMISSION TRANSMISSION INPUT SHAFT TRANSMISSION OUTPUT SHAFT YEAR TYPE VALVE EXHAUST VALVE INTAKE VALVE BUCKETS TAPPET EXHAUST YEAR TYPE VALVE BUCKETS TAPPET INTAKE VOLTAGE REGULATOR WATER PUMP COVER WATER PUMP IMPELLER WATER PUMP SHAFT YEAR TYPE WIRE HARNESS ENGINE WEIGHT YEAR TYPE
This page last modified: Sunday, 18-Sep-2016 19:09:56 PDT
