OEM-CYCLE
OEM-Cycle
KX250 ENGINE, PARTS, AND FRAME Identification page
In an effort to help fellow bikers properly ID their bike I have provided the following information on VIN ( Vehicle Identification Number ) , Engine ID and part identification.
If you find something that is not accurate, please let us know and we will fix it.
This information is not intended for use outside of this web site or for publication.
Remember, scroll to the right as there is a lot of data :-)
If you need used parts for your KX250 Click on this link
YEAR TYPE ENGINE ID ENGINE CASES VIN FRAME USA  VIN FRAME EUROPE AIR BOX CAGE ELEMENT HOLDER AIR BOX NO BOOT YEAR AIR BOX TO CARBURETOR BOOT CABLE CLUTCH CABLE FRONT BRAKE CABLE THROTTLE YEAR CARBURETOR YEAR CARBURETOR BOOT CARBURETOR FLOAT VALVE CARBURETOR JETTING STOCK YEAR CDI CHAIN ADJUSTMENT BLOCKS CHAIN GUIDE YEAR CHAIN SLIDE CLUTCH ARM CLUTCH BASKET YEAR CLUTCH BASKET HINSON CLUTCH COVER CLUTCH COVER INNER CLUTCH FRICTION PLATES YEAR CLUTCH HUB (INNER) CLUTCH PERCH CLUTCH PRESSURE PLATE YEAR CLUTCH PUSH ROD COIL YEAR COMPRESSION COUNTER SPROCKET GUARD  CRANK SHAFT CRANK SHAFT CONNECTING ROD CRANK CONNECTING ROD STROKE CRANK SHAFT HOT RODS CRANK SHAFT CONNECTING ROD HOT RODS YEAR CYLINDER YEAR CYLINDER WATER NECK ELBOW ENGINE MOUNTS FRONT YEAR ENGINE MOUNTS UPPER EXHAUST PIPE STOCK EXHAUST MUFFLER STOCK YEAR EXHAUST PIPE FMF GNARLY EXHAUST PIPE FMF FATTY EXHAUST PIPE FACTORY FATTY EXHAUST PIPE PRO CIRCUIT PLATINUM YEAR EXHAUST VALVE CENTER EXHAUST VALVE LEFT EXHAUST VALVE RIGHT EXHAUST VALVE COVER FRONT EXHAUST VALVE COVER RIGHT EXHAUST VALVE COVER LEFT (RESONATOR) FLY WHEEL / ROTOR FOOT PEGS FOOT PEG SPRINGS YEAR FORK INFO FORK SEAL SIZE YEAR FORK CYLINDER INTERNAL FORK OIL FORK PIPE INNER CHROME LEFT FORK PIPE INNER CHROME RIGHT FORK PIPE OUTER UPPER FORK SPRING GUIDE PLASTIC FORK SPRING SEAT TOP CAP YEAR FORK GUARDS FORK GUARD SLIDER MOUNTS FORK UNDER HOLDER (STEERING STEM LOWER TRIPLE CLAMP) FORK UNDER HOLDER BEARING (STEERING STEM) YEAR FORK UNDER HOLDER BEARING MEASUREMENTS (STEERING STEM) FORK UPPER HOLDER (TOP CLAMP) YEAR FORK UPPER HOLDER BEARING(TOP CLAMP) YEAR FORK UPPER HOLDER BEARING MEASUREMENTS(TOP CLAMP) YEAR FORK VALVE ADJUSTER BOTTOM FRONT AXLE FRONT AXLE COLLARS SPACERS & CAPS FRONT AXLE HOLDER YEAR FRONT BRAKE CALIPER FRONT BRAKE CALIPER MOUNT YEAR FRONT BRAKE HOSE FRONT BRAKE LEVER FRONT BRAKE MASTER CYLINDER YEAR FRONT BRAKE ROTOR FRONT FENDER YEAR FRONT HUB GAS TANK YEAR GAS TANK CAP GOVERNOR GOVERNOR SPUR GEAR HEAD HEAD WATER ELBOW NECK IMPELLER & SHAFT KICK IDLER GEAR YEAR KICK LEVER KICK LEVER BOSS KICK LEVER SHAFT KICK LEVER SHAFT ASY KILL ENGINE STOP SWITCH MUD FLAP NUMBER PLATE YEAR OIL CAPACITY OIL DRAIN PLUG PISTON STD BORE AND STROKE PRIMARY CRANK GEAR YEAR RADIATOR LEFT RADIATOR RIGHT RADIATOR SHROUD LEFT RADIATOR SHROUD RIGHT YEAR RADIATOR SCREENS REAR AXLE YEAR REAR BRAKE BACKING PLATE REAR BRAKE CALIPER REAR BRAKE CALIPER GUARD REAR BRAKE CALIPER MOUNT YEAR REAR BRAKE HOSE REAR BRAKE LEVER REAR BRAKE MASTER CYLINDER REAR BRAKE MASTER CYLINDER GUARD YEAR REAR BRAKE ROTOR REAR FENDER YEAR REAR HUB YEAR REAR WHEEL SPACERS (WHEEL COLLARS) REED VALVE ASY REED VALVE V-FORCE 3 YEAR SEAT SEAT SDG SHIFT DRUM YEAR SHIFT FORKS SHIFT FORK ROD GUIDE SHAFTS YEAR SHIFT LEVER SHIFT SHAFT YEAR SHOCK SHOCK BRACKETS SHOCK ARM UNI TRAK SHOCK ARM LINKAGE (ARMS OR RODS) YEAR SHOCK SPRING SIDE COVERS SIDE COVER RIGHT YEAR SPROCKET COLLAR STATOR STATOR COVER SUB FRAME YEAR SWING ARM SWING ARM PIVOT PIN THROTTLE TRANSMISSION GEARING TRANSMISSION INPUT SHAFT YEAR TRANSMISSION INPUT 2ND GEAR TRANSMISSION INPUT 3RD GEAR TRANSMISSION OUTPUT SHAFT TRANSMISSION OUTPUT SHAFT 1ST GEAR TRANSMISSION OUTPUT SHAFT 2ND GEAR VOLTAGE REGULATOR WATER PUMP COVER WATER PUMP NECK ELBOW YEAR WATER PUMP IMPELLER WATER PUMP SHAFT WIRE HARNESS YEAR ENGINE WEIGHT YEAR
1974 KX250 K2E 900001 - K2E 903675 FITS 74-79 KX250 K2 900001 - K2 903597     FITS 74-76 78-79 KX125 KX250 11011-1008 1974 FITS 74-76, 78-79 KX250 - 14073-1005 FITS 74-79 KX125 KX250 - 54011-1006 FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 FITS 74-76 78-79 KX250, 79-80 KDX400, 80 KDX250 - 54012-1045 1974   1974 FITS 74-76 78-79 KX250, 79-80 KDX400, 81 KDX420, 82 KDX450 - 16065-1005     1974 FITS 74-76 78-79 KX125 KX250 - 21119-018   FITS 74-76 78-79 KX125 KX250 1974 FITS 74-76 78-79 KX125 KX250 12053-1017 FITS 74-76 78-79 KX250 13168-1042 FITS 74-76 78-79 KX250 13095-043 1974 no info BLACK – FITS 74-76 78-79 KX250 14032-1009-21 ONE PIECE FITS 74-76 78-79 13088-036 1974 FITS 74-79, 79-80 KX250 , KDX400, 81 KDX420, 82 KDX450 - 13086-016   FITS 74-76 78-79 KX250 13087-039 1974   FITS 74 76 78-81 KX125 KX250, 75 KX400, 80-81 KX420 1974     FITS 74-79 KX250 - 13031-1020 FITS 74-81 KX250, 80-84 KDX250 - 13044-5007 69.5MM BORE X ? STROKE N/A N/A 1974 AIR COOLED FITS 74-76 78-79 KX250 11005-149-21 1974     1974   FITS 74-76 77-79 KX250 – 49070-1015   1974 N/A N/A N/A   1974             MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420 - 21007-1013 - 21007-026     1974 CONVENTIONAL – 35MM CHROME OD 35MM X 48MM X 10.5/11 1974               1974   CONVENTIONAL   FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1974     1974 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1974   1974   15MM OD, THREADS M14 X 1.5 – FITS 74-76 78-81 KX250, 80-81 KX420 – 41068-1006     1974     1974       1974     1974 15MM AXLE DIA - BRG TO BRG  76-77MM - DRUM MAX DIA 140.75MM - FITS 74, 76, 78-81 KX250 - 75 KX400 - 80-81 KX420   1974               1974               1974       OUTER 22T - FITS 74-76 78-79 KX250 - 13121-029 1974 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1974 AIR COOLED   1974 DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42006-059       1974         1974   BLACK - FITS 74 76-79 KX250, 75 KX400 - 35022-132-10 1974 17MM AXLE DIA - BRG TO BRG133-134MM - DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42005-045-21 1974       1974       1974     1974     1974         1974       1974   FITS 74-79 KX250, 80-81 KX420 - 21003-1010 FITS 74-79 KX250 14031-075-21 PART OF MAIN FRAME 1974 FITS 74-79 KX125 KX250 - 33001-1030     FITS 74-76 KX250 78-79 KX250 FITS 74-76 KX250 78-79 KX250 - 13127-1013 1974     FITS 74-76 KX250 78-79 KX250 - 13128-1003       AIR COOLED   1974       1974   1974
1975 KX250 K2E903676 - K2E907900 FITS 74-79 KX250 K2 903598 - K2 908000     FITS 74-76 78-79 KX125 KX250 11011-1008 1975 FITS 74-76, 78-79 KX250 - 14073-1005 FITS 74-79 KX125 KX250 - 54011-1006 FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 FITS 74-76 78-79 KX250, 79-80 KDX400, 80 KDX250 - 54012-1045 1975   1975 FITS 74-76 78-79 KX250, 79-80 KDX400, 81 KDX420, 82 KDX450 - 16065-1005     1975 FITS 74-76 78-79 KX125 KX250 - 21119-018   FITS 74-76 78-79 KX125 KX250 1975 FITS 74-76 78-79 KX125 KX250 12053-1017 FITS 74-76 78-79 KX250 13168-1042 FITS 74-76 78-79 KX250 13095-043 1975 no info BLACK – FITS 74-76 78-79 KX250 14032-1009-21 ONE PIECE FITS 74-76 78-79 13088-036 1975 FITS 74-79, 79-80 KX250 , KDX400, 81 KDX420, 82 KDX450 - 13086-016   FITS 74-76 78-79 KX250 13087-039 1975     1975     FITS 74-79 KX250 - 13031-1020 FITS 74-81 KX250, 80-84 KDX250 - 13044-5007 70MM BORE X 64.9MM STROKE N/A N/A 1975 AIR COOLED FITS 74-76 78-79 KX250 11005-149-21 1975     1975   FITS 74-76 77-79 KX250 – 49070-1015   1975 N/A N/A N/A   1975             MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420 - 21007-1013 - 21007-026     1975 CONVENTIONAL – 35MM CHROME OD 35MM X 48MM X 10.5/11 1975               1975   CONVENTIONAL   FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1975     1975 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1975   1975   15MM OD, THREADS M14 X 1.5 – FITS 74-76 78-81 KX250, 80-81 KX420 – 41068-1006     1975     1975       1975     1975     1975       FITS 74 76 78-81 KX250, 80-82 KDX250       1975               1975       OUTER 22T - FITS 74-76 78-79 KX250 - 13121-029 1975 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1975 AIR COOLED   1975 DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42006-059       1975         1975     1975 17MM AXLE DIA - BRG TO BRG133-134MM - DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42005-045-21 1975       1975       1975     1975     1975         1975       1975   FITS 74-79 KX250, 80-81 KX420 - 21003-1010 FITS 74-79 KX250 14031-075-21 PART OF MAIN FRAME 1975 FITS 74-79 KX125 KX250 - 33001-1030     FITS 74-76 KX250 78-79 KX250 FITS 74-76 KX250 78-79 KX250 - 13127-1013 1975     FITS 74-76 KX250 78-79 KX250 - 13128-1003       AIR COOLED   1975       1975   1975
1976 KX250 K2E907901 FITS 74-79 KX250 K2 908001     FITS 74-76 78-79 KX125 KX250 11011-1008 1976 FITS 74-76, 78-79 KX250 - 14073-1005 FITS 74-79 KX125 KX250 - 54011-1006 FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 FITS 74-76 78-79 KX250, 79-80 KDX400, 80 KDX250 - 54012-1045 1976   1976 FITS 74-76 78-79 KX250, 79-80 KDX400, 81 KDX420, 82 KDX450 - 16065-1005     1976 FITS 74-76 78-79 KX125 KX250 - 21119-018   FITS 74-76 78-79 KX125 KX250 1976 FITS 74-76 78-79 KX125 KX250 12053-1017 FITS 74-76 78-79 KX250 13168-1042 FITS 74-76 78-79 KX250 13095-043 1976 no info BLACK – FITS 74-76 78-79 KX250 14032-1009-21 ONE PIECE FITS 74-76 78-79 13088-036 1976 FITS 74-79, 79-80 KX250 , KDX400, 81 KDX420, 82 KDX450 - 13086-016   FITS 74-76 78-79 KX250 13087-039 1976   FITS 74 76 78-81 KX125 KX250, 75 KX400, 80-81 KX420 1976     FITS 74-79 KX250 - 13031-1020 FITS 74-81 KX250, 80-84 KDX250 - 13044-5007 70MM BORE X 64.9MM STROKE N/A N/A 1976 AIR COOLED FITS 74-76 78-79 KX250 11005-149-21 1976     1976   FITS 74-76 77-79 KX250 – 49070-1015   1976 N/A N/A N/A   1976             MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420 - 21007-1013 - 21007-026     1976 CONVENTIONAL – 36MM CHROME OD 36MM X 48MM X 10.5/11 1976               1976   CONVENTIONAL   FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1976     1976 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1976   1976   15MM OD, THREADS M14 X 1.5 – FITS 74-76 78-81 KX250, 80-81 KX420 – 41068-1006     1976     1976       1976     1976 15MM AXLE DIA - BRG TO BRG  76-77MM - DRUM MAX DIA 140.75MM - FITS 74, 76, 78-81 KX250 - 75 KX400 - 80-81 KX420   1976               1976               1976       OUTER 22T - FITS 74-76 78-79 KX250 - 13121-029 1976 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1976 AIR COOLED   1976 DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42006-059       1976         1976   BLACK - FITS 74 76-79 KX250, 75 KX400 - 35022-132-10 1976 17MM AXLE DIA - BRG TO BRG133-134MM - DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42005-045-21 1976       1976       1976     1976     1976         1976       1976   FITS 74-79 KX250, 80-81 KX420 - 21003-1010 FITS 74-79 KX250 14031-075-21 PART OF MAIN FRAME 1976 FITS 74-79 KX125 KX250 - 33001-1030     FITS 74-76 KX250 78-79 KX250 FITS 74-76 KX250 78-79 KX250 - 13127-1013 1976     FITS 74-76 KX250 78-79 KX250 - 13128-1003       AIR COOLED   1976       1976   1976
1976 1/2 KX250 KX250AE0018 FITS 74-79 KX250       FITS 74-76 78-79 KX125 KX250 11011-1008 1976 1/2 FITS 74-76, 78-79 KX250 - 14073-1005 FITS 74-79 KX125 KX250 - 54011-1006 FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 FITS 74-76 78-79 KX250, 79-80 KDX400, 80 KDX250 - 54012-1045 1976 1/2   1976 1/2 FITS 74-76 78-79 KX250, 79-80 KDX400, 81 KDX420, 82 KDX450 - 16065-1005     1976 1/2 FITS 74-76 78-79 KX125 KX250 - 21119-018   FITS 74-76 78-79 KX125 KX250 1976 1/2 FITS 74-76 78-79 KX125 KX250 12053-1017 FITS 74-76 78-79 KX250 13168-1042 FITS 74-76 78-79 KX250 13095-043 1976 1/2 no info BLACK – FITS 74-76 78-79 KX250 14032-1009-21 ONE PIECE FITS 74-76 78-79 13088-036 1976 1/2 FITS 74-79, 79-80 KX250 , KDX400, 81 KDX420, 82 KDX450 - 13086-016   FITS 74-76 78-79 KX250 13087-039 1976 1/2     1976 1/2     FITS 74-79 KX250 - 13031-1020 FITS 74-81 KX250, 80-84 KDX250 - 13044-5007 70MM BORE X 64.9MM STROKE N/A N/A 1976 1/2 AIR COOLED FITS 74-76 78-79 KX250 11005-149-21 1976 1/2     1976 1/2   FITS 74-76 77-79 KX250 – 49070-1015   1976 1/2 N/A N/A N/A   1976 1/2             MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420 - 21007-1013 - 21007-026     1976 1/2 CONVENTIONAL – 36MM CHROME OD 36MM X 48MM X 10.5/11 1976 1/2               1976 1/2   CONVENTIONAL   FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1976 1/2     1976 1/2 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1976 1/2   1976 1/2   15MM OD, THREADS M14 X 1.5 – FITS 74-76 78-81 KX250, 80-81 KX420 – 41068-1006     1976 1/2     1976 1/2       1976 1/2     1976 1/2     1976 1/2       FITS 74 76 78-81 KX250, 80-82 KDX250       1976 1/2               1976 1/2       OUTER 22T - FITS 74-76 78-79 KX250 - 13121-029 1976 1/2 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1976 1/2 AIR COOLED   1976 1/2         1976 1/2         1976 1/2   BLACK - FITS 74 76-79 KX250, 75 KX400 - 35022-132-10 1976 1/2   1976 1/2       1976 1/2       1976 1/2     1976 1/2     1976 1/2         1976 1/2       1976 1/2   FITS 74-79 KX250, 80-81 KX420 - 21003-1010 FITS 74-79 KX250 14031-075-21 PART OF MAIN FRAME 1976 1/2 FITS 74-79 KX125 KX250 - 33001-1030     FITS 74-76 KX250 78-79 KX250 FITS 74-76 KX250 78-79 KX250 - 13127-1013 1976 1/2     FITS 74-76 KX250 78-79 KX250 - 13128-1003       AIR COOLED   1976 1/2       1976 1/2   1976 1/2
1977 KX250 KX250AE0018 FITS 74-79 KX250         1977         1977   1977       1977       1977       1977 no info       1977       1977     1977           N/A N/A 1977   1977     1977       1977 N/A N/A N/A   1977             MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420 - 21007-1013 - 21007-026     1977     1977               1977         1977     1977   1977   1977         1977     1977       1977     1977 15MM AXLE DIA - BRG TO BRG  76-77MM - DRUM MAX DIA 140.75MM - FITS 74, 76, 78-81 KX250 - 75 KX400 - 80-81 KX420   1977               1977               1977         1977 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1977     1977         1977         1977   BLACK - FITS 74 76-79 KX250, 75 KX400 - 35022-132-10 1977   1977       1977       1977     1977     1977         1977       1977   FITS 74-79 KX250, 80-81 KX420 - 21003-1010 FITS 74-79 KX250 14031-075-21 PART OF MAIN FRAME 1977 FITS 74-79 KX125 KX250 - 33001-1030         1977                 1977       1977   1977
1978 KX250 KX250AE 000001 FITS 74-79 KX250 KX250A 000001     FITS 74-76 78-79 KX125 KX250 11011-1008 1978 FITS 74-76, 78-79 KX250 - 14073-1005 FITS 74-79 KX125 KX250 - 54011-1006 FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 FITS 74-76 78-79 KX250, 79-80 KDX400, 80 KDX250 - 54012-1045 1978   1978 FITS 74-76 78-79 KX250, 79-80 KDX400, 81 KDX420, 82 KDX450 - 16065-1005     1978 FITS 74-76 78-79 KX125 KX250 - 21119-018   FITS 74-76 78-79 KX125 KX250 1978 FITS 74-76 78-79 KX125 KX250 12053-1017 FITS 74-76 78-79 KX250 13168-1042 FITS 74-76 78-79 KX250 13095-043 1978 no info BLACK – FITS 74-76 78-79 KX250 14032-1009-21 ONE PIECE FITS 74-76 78-79 13088-036 1978 FITS 74-79, 79-80 KX250 , KDX400, 81 KDX420, 82 KDX450 - 13086-016   FITS 74-76 78-79 KX250 13087-039 1978   FITS 74 76 78-81 KX125 KX250, 75 KX400, 80-81 KX420 1978     FITS 74-79 KX250 - 13031-1020 FITS 74-81 KX250, 80-84 KDX250 - 13044-5007 70MM BORE X 64.9MM STROKE N/A N/A 1978 AIR COOLED FITS 74-76 78-79 KX250 11005-149-21 BORE 71MM STROKE 64.9MM 1978     1978   FITS 74-76 77-79 KX250 – 49070-1015   1978 N/A N/A N/A   1978             MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420 - 21007-1013 - 21007-026     1978 CONVENTIONAL – 36MM CHROME OD 36MM X 48MM X 10.5/11 1978               1978   CONVENTIONAL   FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1978     1978 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1978   1978   15MM OD, THREADS M14 X 1.5 – FITS 74-76 78-81 KX250, 80-81 KX420 – 41068-1006     1978     1978       1978     1978 15MM AXLE DIA - BRG TO BRG  76-77MM - DRUM MAX DIA 140.75MM - FITS 74, 76, 78-81 KX250 - 75 KX400 - 80-81 KX420   1978       FITS 74 76 78-81 KX250, 80-82 KDX250       1978               1978     70MM BORE X 64.9 STROKE OUTER 22T - FITS 74-76 78-79 KX250 - 13121-029 1978 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1978 AIR COOLED   1978 DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42006-059       1978         1978   BLACK - FITS 74 76-79 KX250, 75 KX400 - 35022-132-10 1978 17MM AXLE DIA - BRG TO BRG133-134MM - DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42005-045-21 1978       1978       1978     1978     1978         1978       1978   FITS 74-79 KX250, 80-81 KX420 - 21003-1010 FITS 74-79 KX250 14031-075-21 PART OF MAIN FRAME 1978 FITS 74-79 KX125 KX250 - 33001-1030     FITS 74-76 KX250 78-79 KX250 FITS 74-76 KX250 78-79 KX250 - 13127-1013 1978     FITS 74-76 KX250 78-79 KX250 - 13128-1003       AIR COOLED   1978       1978   1978
1979 KX250 KX250AE001801 FITS 74-79 KX250 KX250A-001801     FITS 74-76 78-79 KX125 KX250 11011-1008 1979 FITS 74-76, 78-79 KX250 - 14073-1005 FITS 74-79 KX125 KX250 - 54011-1006 FITS 74-81 KX125, 74-76 78-79 KX250 - 54005-1016 FITS 74-76 78-79 KX250, 79-80 KDX400, 80 KDX250 - 54012-1045 1979   1979 FITS 74-76 78-79 KX250, 79-80 KDX400, 81 KDX420, 82 KDX450 - 16065-1005     1979 FITS 74-76 78-79 KX125 KX250 - 21119-018   FITS 74-76 78-79 KX125 KX250 1979 FITS 74-76 78-79 KX125 KX250 12053-1017 FITS 74-76 78-79 KX250 13168-1042 FITS 74-76 78-79 KX250 13095-043 1979 no info BLACK – FITS 74-76 78-79 KX250 14032-1009-21 ONE PIECE FITS 74-76 78-79 13088-036 1979 FITS 74-79, 79-80 KX250 , KDX400, 81 KDX420, 82 KDX450 - 13086-016   FITS 74-76 78-79 KX250 13087-039 1979   FITS 74 76 78-81 KX125 KX250, 75 KX400, 80-81 KX420 1979     FITS 74-79 KX250 - 13031-1020 FITS 74-81 KX250, 80-84 KDX250 - 13044-5007 70MM BORE X 64.9MM STROKE N/A N/A 1979 AIR COOLED FITS 74-76 78-79 KX250 11005-149-21 BORE 71MM STROKE 64.9MM 1979     1979   FITS 74-76 77-79 KX250 – 49070-1015   1979 N/A N/A N/A   1979             MR2393 FITS 74-79 KX125 KX250, 75 KX400, 80-81 KX420 - 21007-1013 - 21007-026     1979 CONVENTIONAL – CHROME OD 38MM 38MM X 50MM X 10.5 1979               1979   CONVENTIONAL   FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1979     1979 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1979   1979   15MM OD, THREADS M14 X 1.5 – FITS 74-76 78-81 KX250, 80-81 KX420 – 41068-1006     1979     1979       1979     1979 15MM AXLE DIA - BRG TO BRG  76-77MM - DRUM MAX DIA 140.75MM - FITS 74, 76, 78-81 KX250 - 75 KX400 - 80-81 KX420   1979       FITS 74 76 78-81 KX250, 80-82 KDX250       1979               1979     70MM BORE X 64.9 STROKE OUTER 22T - FITS 74-76 78-79 KX250 - 13121-029 1979 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1979 AIR COOLED   1979 DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42006-059       1979         1979   BLACK - FITS 74 76-79 KX250, 75 KX400 - 35022-132-10 1979 17MM AXLE DIA - BRG TO BRG133-134MM - DRUM 150.75MM MAX DIA - FITS 74-76 78-79 KX250, 75-76 KX400 - 42005-045-21 1979       1979       1979     1979     1979         1979       1979   FITS 74-79 KX250, 80-81 KX420 - 21003-1010 FITS 74-79 KX250 14031-075-21 PART OF MAIN FRAME 1979 FITS 74-79 KX125 KX250 - 33001-1030     FITS 74-76 KX250 78-79 KX250 FITS 74-76 KX250 78-79 KX250 - 13127-1013 1979     FITS 74-76 KX250 78-79 KX250 - 13128-1003       AIR COOLED   1979       1979   1979
1980 KX250 KX250AE0056 FITS 80-81 KX250, 80-82 KDX250 KX250A-50XXXX     FITS 80-81 KX125 KX250 KDX420, 80-82 KDX175 11011-1047 1980 FITS 80-81 KX250 - 14073-1035       1980 MIKUNI 1980 FITS 80-82 KDX250, 80-81 KX250, 16065-1029     1980 FITS 80-81 KX250 - 21119-1018   FITS 80-81 KX125 KX250 KX420, 80-82 KDX175 1980 FITS 80-81 KX125 KX250 KX420 12053-1046 FITS 80-82 KX250, 80-84 KDX250 13102-1006 FITS 80-82 KX250 KDX250 13095-1026 1980 no info BLACK - FITS 80-82 KX250, 81-82 KDX250 14032-1028 ONE PIECE   1980 FITS 80-84 KX250 KDX250, 83-84 KX500 - 13087-044   FITS 80-82 KX250 KDX250 - 13187-1009 1980   FITS 74 76 78-81 KX125 KX250, 75 KX400, 80-81 KX420 1980     FITS 80-81 KX250 - 13031-1038 FITS 74-81 KX250, 80-84 KDX250 - 13044-5007 70MM BORE X 64.9MM STROKE N/A N/A 1980 1081 AIR COOLED FITS 80-81 KX250 11005-1081 BORE 71MM STROKE 64.9MM 1980     1980   FITS 80-81 KX250 – 49070-1025   1980 N/A N/A N/A   1980             MR2379 FITS 80-81 KX250 - 21007-1028     1980 CONVENTIONAL – CHROME OD 38MM – C/L 36 5/16” - 15MM AXLE CLAMP – M14 X 1.5 – OAL 42.5” - FITS 80-81 KX250 KX420 – 44001-1118 38MM X 50MM X 10.5 1980               1980   CONVENTIONAL   FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1980     1980 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1980   1980   15MM OD, THREADS M14 X 1.5 – FITS 74-76 78-81 KX250, 80-81 KX420 – 41068-1006     1980     1980       1980     1980 15MM AXLE DIA - BRG TO BRG  76-77MM - DRUM MAX DIA 140.75MM - FITS 74, 76, 78-81 KX250 - 75 KX400 - 80-81 KX420 GREEN – FITS 80-81 KX250 KX420 – 51001-1030-7F 1980       FITS 74 76 78-81 KX250, 80-82 KDX250     FITS 80-86 KX250, 80-84 KDX250 - 59051-1022 1980 FITS 75 KX400, 79-82 KDX450, 80-81 KX250 KX420, 83-84 KX500   FITS 80-82 KX250 KDX250 KDX175 - 13066-1014 FITS 80-82 KDX250 KX250       1980     70MM BORE X 64.9 STROKE OUTER 20T, FITS 80-82 KX250, 80-84 KDX250 - 13097-1028 1980 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1980 AIR COOLED   1980 FITS 80-81 KX250 KX420, 80 KDX250, 79-80 KDX400 - 41035-4001       1980         1980   GREEN - FITS 80-81 KX125 KX250 KX420 - 35022-1043-6W 1980 17MM AXLE DIA - BRG TO BRG133-134MM - DRUM 150.75MM MAX DIA - FITS 80-81 KX250 KX420, 80-82 KDX250, 81-82 KDX450 - 41034-1019 1980       1980       1980   SET FITS 80-89 KX250, 84-87 KXT250 49047-1009 - 49047-1011 1980     1980         1980       1980     FITS 80-81 KX250 14031-1042 PART OF MAIN FRAME 1980 FITS 80-81 KX250 KX420 - 33001-1043     FITS 80-82 KX250 FITS 80-81 KX250 – 13127-1022 1980     FITS 80-82 KX250, 80 KDX250 - 13128-1025 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     AIR COOLED   1980       1980   1980
1981 KX250 KX250AE0082 FITS 80-81 KX250, 80-82 KDX250       FITS 80-81 KX125 KX250 KDX420, 80-82 KDX175 11011-1047 1981 FITS 80-81 KX250 - 14073-1035       1981   1981 FITS 80-82 KDX250, 80-81 KX250, 16065-1029     1981 FITS 80-81 KX250 - 21119-1018   FITS 80-81 KX125 KX250 KX420, 80-82 KDX175 1981 FITS 80-81 KX125 KX250 KX420 12053-1046 FITS 80-82 KX250, 80-84 KDX250 13102-1006 FITS 80-82 KX250 KDX250 13095-1026 1981 no info BLACK - FITS 80-82 KX250, 81-82 KDX250 14032-1028 ONE PIECE   1981 FITS 80-84 KX250 KDX250, 83-84 KX500 - 13087-044   FITS 80-82 KX250 KDX250 - 13187-1009 1981   FITS 74 76 78-81 KX125 KX250, 75 KX400, 80-81 KX420 1981     FITS 80-81 KX250 - 13031-1038 FITS 74-81 KX250, 80-84 KDX250 - 13044-5007 70MM BORE X 64.9MM STROKE N/A N/A 1981 1081 AIR COOLED FITS 80-81 KX250 11005-1081 BORE 71MM STROKE 64.9MM 1981     1981   FITS 80-81 KX250 – 49070-1025   1981 N/A N/A N/A   1981             MR2379 FITS 80-81 KX250 - 21007-1028     1981 CONVENTIONAL – CHROME OD 38MM – C/L 36 5/16” - 15MM AXLE CLAMP – M14 X 1.5 – OAL 42.5” - FITS 80-81 KX250 KX420 – 44001-1118 38MM X 50MM X 10.5 1981               1981   CONVENTIONAL   FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1981     1981 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1981   1981   15MM OD, THREADS M14 X 1.5 – FITS 74-76 78-81 KX250, 80-81 KX420 – 41068-1006     1981     1981       1981     1981 15MM AXLE DIA - BRG TO BRG  76-77MM - DRUM MAX DIA 140.75MM - FITS 74, 76, 78-81 KX250 - 75 KX400 - 80-81 KX420 GREEN – FITS 80-81 KX250 KX420 – 51001-1030-7F 1981       FITS 74 76 78-81 KX250, 80-82 KDX250     FITS 80-86 KX250, 80-84 KDX250 - 59051-1022 1981 FITS 75 KX400, 79-82 KDX450, 80-81 KX250 KX420, 83-84 KX500   FITS 80-82 KX250 KDX250 KDX175 - 13066-1014 FITS 80-82 KDX250 KX250       1981     70MM BORE X 64.9 STROKE OUTER 20T, FITS 80-82 KX250, 80-84 KDX250 - 13097-1028 1981 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1981 AIR COOLED   1981 FITS 80-81 KX250 KX420, 80 KDX250, 79-80 KDX400 - 41035-4001       1981     FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200   1981   GREEN - FITS 80-81 KX125 KX250 KX420 - 35022-1043-6W 1981 17MM AXLE DIA - BRG TO BRG133-134MM - DRUM 150.75MM MAX DIA - FITS 80-81 KX250 KX420, 80-82 KDX250, 81-82 KDX450 - 41034-1019 1981       1981       1981   SET FITS 80-89 KX250, 84-87 KXT250 49047-1009 - 49047-1011 1981     1981         1981       1981     FITS 80-81 KX250 14031-1042 PART OF MAIN FRAME 1981 FITS 80-81 KX250 KX420 - 33001-1043     FITS 80-82 KX250 FITS 80-81 KX250 – 13127-1022 1981     FITS 80-82 KX250, 80 KDX250 - 13128-1025 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     AIR COOLED   1981       1981   1981
1982 KX250 KX250AE010801-012846 FITS 82 KX250, 81-82 KDX250       FITS 82 KX250, 81-82 KDX250 11010-5063 1982 FITS 82 KX250, 81-82 KDX250 - 14073-1069 fits 81-82 KDX250, 82 KX250 - 54011-1103 HYDRAULIC FITS 81-84 KDX250, 82 KDX450 KX250 - 54012-1118 1982   1982 FITS 84-85 KXT250, 81-84 KDX250, 82-84 KX250, 16065-1048     1982 FITS 82 KX250 - 21119-1044   FITS 82-83 KX125, 82 KX250, 81-82 KDX250 1982 FITS 82-83 KX125, 82 KX250, 81-82 KDX250 12053-1062 FITS 80-82 KX250, 80-84 KDX250 13102-1006 FITS 80-82 KX250 KDX250 13095-1026 1982 no info BLACK - FITS 80-82 KX250, 81-82 KDX250 14032-1028 ONE PIECE   1982 FITS 80-84 KX250 KDX250, 83-84 KX500 - 13087-044   FITS 80-82 KX250 KDX250 - 13187-1009 1982   FITS 81-82 KDX250, 82-83 KX125, 82-84 KX250 1982     FITS 82 KX250, 81-84 KDX250 - 13031-1049  FITS 74-81 KX250, 80-84 KDX250 - 13044-5007 70MM BORE X 64.9MM STROKE N/A N/A 1982 1150 AIR COOLED FITS 82 KX250  11005-1150 BORE 71MM STROKE 64.9MM 1982     1982   FITS 82 KX250  – 18002-1199   1982 N/A N/A N/A   1982             F3T80671 - FITS 82 KX250 - 21007-1049     1982 CONVENTIONAL – 41MM CHROME OD 41MM X 53MM X 10.5 1982               1982   CONVENTIONAL   FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1982     1982 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1982   1982   FITS 82-83 KX125, 82-84 KX250, 83-84 KX500     1982 FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200   1982   FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 1982 OD 250MM - ID 129.5MM - BC 8 ON 146MM - FITS 82-84 KX125 & KX250, 83-84 KX500   1982 PAT 585875 - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR 8 ON A 145MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 36 SPOKES   1982             FITS 80-86 KX250, 80-84 KDX250 - 59051-1022 1982     FITS 80-82 KX250 KDX250 KDX175 - 13066-1014 FITS 80-82 KDX250 KX250       1982 900CC   70MM BORE X 64.9 STROKE OUTER 20T, FITS 80-82 KX250, 80-84 KDX250 - 13097-1028 1982 AIR COOLED AIR COOLED AIR COOLED AIR COOLED 1982 AIR COOLED   1982 41035-1107 FOR 130MM DRUM – IT SHOULD FIT 82-83 KX125, 82-84 KX250, 83-84 KX500       1982     FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200   1982   GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 35022-1204-AE 1982 R-1108 - PAT 585873 - 17MM AXLE DIA - BRG TO BRG 131-132MM - DRUM 130MM ID - SPROCKET 6 ON A 150MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 1982       1982       1982   SET FITS 80-89 KX250, 84-87 KXT250 49047-1009 - 49047-1011 1982     1982         1982   GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 -  36001-1146-6W GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 -  36001-1147-6W 1982     FITS 82 KX250, 81-84 KDX250 14031-1088 PART OF MAIN FRAME 1982 FITS 82 KX250  33001-1125 FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042   FITS 80-82 KX250 FITS 82 KX250  – 13127-1047 1982     FITS 80-82 KX250, 80 KDX250 - 13128-1025 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     AIR COOLED   1982       1982   1982
1983 KX250 KH1 KX250CE000001-002800 FITS 83-84 KX250, 84-85 KXT250 - 14001-5152       FITS 83-84 KX250 11011-1115 1983 FITS 83-84 KX250 - 14073-1092 FITS 84-85 KXT, 83-85 KX250, 83-84 KX500 - 54011-1112 HYDRAULIC FITS 83-84 KX250 - 54012-1207 1983   1983 FITS 84-85 KXT250, 81-84 KDX250, 82-84 KX250, 16065-1048     1983 FITS 83-84 KX250 - 21119-1103   FITS 82-83 KX125, 83-85 KX250 & KX500, 83 KDX200 & KDX250 1983 FITS 84-86 KX125, 83-86 KX250 KX500 KDX200, 86-87 KXT250 FITS 83-85 KX250, 83-84 KX500, 84-85 KXT250 13102-1077 FITS 83-84 KX250 KDX250 13095-1050 1983 no info FITS 83-84 KX250, 84-85 KXT250 14032-1094 ONE PIECE FITS 83-86 KX250, 84-87 KXT - 13088-1065 1983 FITS 80-84 KX250 KDX250, 83-84 KX500 - 13087-044   FITS 83-84 KDX250, 83-86 KX250 KX500, 84-87 KXT - 13187-1011 1983   CM61-29 FITS 82-85 KX125, 83-85 KX250, 85-86 KDX200 1983   FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 FITS 83-85 KX250, 84-85 KXT250 - 13031-1189 FITS 83-85 KX250, 84-85 KXT250 - 13044-5042 70MM BORE X 64.9MM STROKE N/A N/A 1983 1347 FITS 83-84 KX250 11005-1347 BORE 70MM STROKE 64.9MM 1983 FITS 83-85 KX250, 85-87 KX500, 84-85 KXT250 - 52014-1004   1983   FITS 83-84 KX250 – 18002-1433   1983 N/A N/A N/A   1983             F3T80872 FITS 83-84 KX250 - 21007-1060 FITS 83-84 KX250 & KX500 - 34028-1050 - 34028-1051 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1983 CONVENTIONAL – 43MM CHROME OD 43MM X 55MM X 9.5/10.5/11 1983   SAE 10, 624-632 mL or 21.1-21.4 oz per side           1983   CONVENTIONAL FITS 83-84 KX250, KX500, 84 KX125 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1983   FITS 83-84 KX250, KX500 1983 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1983   1983   FITS 82-83 KX125, 82-84 KX250, 83-84 KX500     1983 FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 FITS 82-86 KX125, 83-86 KX250 KX250 - PART OF CALIPER ASY 43041-1084 1983   FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 1983 OD 250MM - ID 129.5MM - BC 8 ON 146MM - FITS 82-84 KX125 & KX250, 83-84 KX500   1983 PAT 585875 - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR 8 ON A 145MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 36 SPOKES   1983       FITS 83-84 KX250,84-85 KXT250 - 11001-1110     FITS 80-86 KX250, 80-84 KDX250 - 59051-1022 1983 FITS 83-86 KX250 - 13064-1105    FITS 83-86 KX250 - 13066-1052         1983 700CC   70MM BORE X 64.9 STROKE INNER 21S,  OUTER 20T - FITS 83-87 KX250 13097-1070 1983 FITS 83-84 KX250 39061-1051 FITS 83-84 KX250 39061-1052     1983 BLACK  14037-1077-6C FITS 85-86 KX500, 83-86 KX250, 86-87 KXT250   1983 41035-1107 FOR 130MM DRUM – IT SHOULD FIT 82-83 KX125, 82-84 KX250, 83-84 KX500       1983   FITS 83-84 KX250 KX500 43001-1159 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200   1983   GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 35022-1204-AE 1983 R-1108 - PAT 585873 - 17MM AXLE DIA - BRG TO BRG 131-132MM - DRUM 130MM ID - SPROCKET 6 ON A 150MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 1983       1983     FITS 83-84 KX250 - 13239-1077 1983 FITS 83-89 KX250, 84-86 KXT250, 91-94 KDX250 - 13140-1071 - 13140-1072 - 13140-1073 SET FITS 80-89 KX250, 84-87 KXT250 49047-1009 - 49047-1011 1983 FITS 83-86 KX250, KX500 - 13242-1166 FITS 83-84 KX250 - 13161-1042 1983 FITS 83-84 KX250 - 45014-1258   FITS 83-84 KX250 KX500 -39007-1052   1983   GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 -  36001-1146-6W GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 -  36001-1147-6W 1983     FITS 83-86 KX250, 84-86 KXT250 14031-1104 PART OF MAIN FRAME 1983 FITS 83-84 KX250 KX500 - 33001-1205 FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042   FITS 83-85 KX250 FITS 83-86 KX250, 84-87 KXT250 - 13128-1047 1983     FITS 83-86 KX250, 84-87 KXT250 - 13128-1047 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 83-84 KX250, 84-85 KXT250 - 16142-1008   1983   FITS 82-84 KX125, 83-85 87 KX250, 84-85 KXT250 - 13234-1009   1983   1983
1984 KX250 KH1 KX250CE002801-12388 FITS 83-84 KX250, 84-85 KXT250 - 14001-5152 JKAKXMC18EA00XXXX     FITS 83-84 KX250 11011-1115 1984 FITS 83-84 KX250 - 14073-1092 FITS 84-85 KXT, 83-85 KX250, 83-84 KX500 - 54011-1112 HYDRAULIC FITS 83-84 KX250 - 54012-1207 1984 MIKUNI 1984 FITS 84-85 KXT250, 81-84 KDX250, 82-84 KX250, 16065-1048     1984 FITS 83-84 KX250 - 21119-1103   FITS 82-83 KX125, 83-85 KX250 & KX500, 83 KDX200 & KDX250 1984 FITS 84-86 KX125, 83-86 KX250 KX500 KDX200, 86-87 KXT250 FITS 83-85 KX250, 83-84 KX500, 84-85 KXT250 13102-1077 FITS 83-84 KX250 KDX250 13095-1050 1984 no info FITS 83-84 KX250, 84-85 KXT250 14032-1094 ONE PIECE FITS 83-86 KX250, 84-87 KXT - 13088-1065 1984 FITS 80-84 KX250 KDX250, 83-84 KX500 - 13087-044   FITS 83-84 KDX250, 83-86 KX250 KX500, 84-87 KXT - 13187-1011 1984   CM61-29 FITS 82-85 KX125, 83-85 KX250, 85-86 KDX200 1984   FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 FITS 83-85 KX250, 84-85 KXT250 - 13031-1189 FITS 83-85 KX250, 84-85 KXT250 - 13044-5042 70MM BORE X 64.9MM STROKE N/A N/A 1984 1347 FITS 83-84 KX250 11005-1347 BORE 70MM STROKE 64.9MM 1984 FITS 83-85 KX250, 85-87 KX500, 84-85 KXT250 - 52014-1004   1984   FITS 83-84 KX250 – 18002-1433   1984 N/A N/A N/A   1984             F3T80872 FITS 83-84 KX250 - 21007-1060 FITS 83-84 KX250 & KX500 - 34028-1050 - 34028-1051 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1984 CONVENTIONAL - CHROME OD 43MM C/L 36.5" 43MM X 55MM X 9.5/10.5/11 1984               1984   CONVENTIONAL FITS 83-84 KX250, KX500, 84 KX125 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1984   FITS 83-84 KX250, KX500 1984 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1984   1984   FITS 82-83 KX125, 82-84 KX250, 83-84 KX500     1984 FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 FITS 82-86 KX125, 83-86 KX250 KX250 - PART OF CALIPER ASY 43041-1084 1984   FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 1984 OD 250MM - ID 129.5MM - BC 8 ON 146MM - FITS 82-84 KX125 & KX250, 83-84 KX500   1984 PAT 585875 - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR 8 ON A 145MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 36 SPOKES   1984       FITS 83-84 KX250,84-85 KXT250 - 11001-1110     FITS 80-86 KX250, 80-84 KDX250 - 59051-1022 1984 FITS 83-86 KX250 - 13064-1105    FITS 83-86 KX250 - 13066-1052         1984 700CC   70MM BORE X 64.9 STROKE INNER 21S,  OUTER 20T - FITS 83-87 KX250 13097-1070 1984 FITS 83-84 KX250 39061-1051 FITS 83-84 KX250 39061-1052     1984 BLACK  14037-1077-6C FITS 85-86 KX500, 83-86 KX250, 86-87 KXT250   1984 41035-1107 FOR 130MM DRUM – IT SHOULD FIT 82-83 KX125, 82-84 KX250, 83-84 KX500       1984   FITS 83-84 KX250 KX500 43001-1159 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200   1984   GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 - 35022-1204-AE 1984 R-1108 - PAT 585873 - 17MM AXLE DIA - BRG TO BRG 131-132MM - DRUM 130MM ID - SPROCKET 6 ON A 150MM BC - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 1984       1984     FITS 83-84 KX250 - 13239-1077 1984 FITS 83-89 KX250, 84-86 KXT250, 91-94 KDX250 - 13140-1071 - 13140-1072 - 13140-1073 SET FITS 80-89 KX250, 84-87 KXT250 49047-1009 - 49047-1011 1984 FITS 83-86 KX250, KX500 - 13242-1166 FITS 83-84 KX250 - 13161-1042 1984 FITS 83-84 KX250 - 45014-1258   FITS 83-84 KX250 KX500 -39007-1052   1984   GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 -  36001-1146-6W GREEN - FITS 82-83 KX125, 82-84 KX250, 83-84 KX500 -  36001-1147-6W 1984     FITS 83-86 KX250, 84-86 KXT250 14031-1104 PART OF MAIN FRAME 1984 FITS 83-84 KX250 KX500 - 33001-1205 FITS 82-86 KX125, 82-84 KX250, 83-84 KX500, 81-84 KDX250, 83-85 KDX200, 84-85 KXT250 - 33032-1042   FITS 83-85 KX250 FITS 83-86 KX250, 84-87 KXT250 - 13128-1047 1984     FITS 83-86 KX250, 84-87 KXT250 - 13128-1047 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 83-84 KX250, 84-85 KXT250 - 16142-1008   1984   FITS 82-84 KX125, 83-85 87 KX250, 84-85 KXT250 - 13234-1009   1984   1984
1985 KX250 KX250DE000001-004200 FITS 85  JKAKXM---FA0-----   FITS 84-85 KX125, 85-86 KX250 KX500, 86-88 KDX200 - 13091-1267 FITS 85 KX250 KX500 11011-1180 1985 FITS 85-86 KX250 - 14073-1195 FITS 84-85 KXT, 83-85 KX250, 83-84 KX500 - 54011-1112 HYDRAULIC FITS 85 KX250, 83-85 KX500 - 54012-1211 1985 MIKUNI 1985 FITS 86-87 KXT250, 85-86 KX250, 16065-1124 FITS 85-86 KX250 KX500 - 16030-1060   1985 FITS 85 KX250  – 21119-1148   FITS 82-83 KX125, 83-85 KX250 & KX500, 83 KDX200 & KDX250 1985 FITS 84-86 KX125, 83-86 KX250 KX500 KDX200, 86-87 KXT250 FITS 83-85 KX250, 83-84 KX500, 84-85 KXT250 13102-1077 FITS 85-86 KX250 - 13095-1139 1985 no info FITS 85 KX250  14032-1183 ONE PIECE FITS 83-86 KX250, 84-87 KXT - 13088-1065 1985 FITS 85 KX250 KX500 - 13087-1061    FITS 83-84 KDX250, 83-86 KX250 KX500, 84-87 KXT - 13187-1011 1985   CM61-29 FITS 82-85 KX125, 83-85 KX250, 85-86 KDX200 1985   FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 FITS 83-85 KX250, 84-85 KXT250 - 13031-1189 FITS 83-85 KX250, 84-85 KXT250 - 13044-5042 70MM BORE X 64.9MM STROKE N/A N/A 1985 1415 FITS 85 KX250  11005-1415 BORE 71MM STROKE 64.9MM 1985 FITS 83-85 KX250, 85-87 KX500, 84-85 KXT250 - 52014-1004   1985   FITS 85 KX250  – 18002-1552   1985 N/A N/A N/A   1985             FITS 85 KX250  - 21007-1129 FITS 85 KX125 KX250 KX500 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1985 CONVENTIONAL – 43MM CHROME OD 43MM X 55MM X 9.5/10.5/11 1985   10W20, 550-558 mL or 18.6-18.9oz per side           1985   CONVENTIONAL FITS 85 KX125, KX250, KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1985   FITS 85 KX250, KX500 1985 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1985   1985   FITS 85-88 KX125 KX250 KX500 - 41068-1241     1985 FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 FITS 82-86 KX125, 83-86 KX250 KX250 - PART OF CALIPER ASY 43041-1084 1985   FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 1985 OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92   1985 F-1123 - BLACK - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR OD 250MM - 8 ON A 146MM BC - FITS 85-87 KX125 KX250 KX500 - 41034-1115   1985             FITS 80-86 KX250, 80-84 KDX250 - 59051-1022 1985 FITS 83-86 KX250 - 13064-1105    FITS 83-86 KX250 - 13066-1052         1985 800CC   70MM BORE X 64.9 STROKE INNER 21S,  OUTER 20T - FITS 83-87 KX250 13097-1070 1985 FITS 85-86 KX250 39061-1064 FITS 85-86 KX250 39061-1065 GREEN – FITS 85 KX250 KX500 - 49089-5004-6W GREEN - FITS 85 KX250 KX500 - 49089-5005-6W 1985 BLACK  14037-1077-6C FITS 85-86 KX500, 83-86 KX250, 86-87 KXT250 FITS 85-87 KX125 KX250 KX500 - 41068-1180 1985 HYDRAULIC BRAKE       1985   FITS 84-85 KX125, 85 KX250 KX500 43001-1173 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200   1985   GREEN – FITS 84-85 KX125, 85 KX250 KX500 - 35022-1203-6W 1985 BLACK - 20MM AXLE DIA - BRG TO BRG 131-132MM - DRUM - FITS 85 KX250 & KX500 1985       1985 FITS 85 KX125, 250 & 500   FITS 85-89 KX250 - 13141-1069 1985 FITS 83-89 KX250, 84-86 KXT250, 91-94 KDX250 - 13140-1071 - 13140-1072 - 13140-1073 SET FITS 80-89 KX250, 84-87 KXT250 49047-1009 - 49047-1011 1985 FITS 83-86 KX250, KX500 - 13242-1166   1985     FITS 85 KX250 KX500 - 39007-5006   1985   GREEN - FITS 84-85 KX125, 85 KX250 KX500 - 36001-1279-AE GREEN - FITS 84-85 KX125, 85 KX250 KX500 - 36001-1280-AE 1985   FITS 85 KX250  FITS 83-86 KX250, 84-86 KXT250 14031-1104 PART OF MAIN FRAME 1985 FITS 85 KX125 KX250 33001-1230 FITS 85 KX125, 85-86 KX250 KX500   FITS 83-85 KX250 FITS 85-86 KX250, 86-87 KXT250 - 13127-1120 1985     FITS 83-86 KX250, 84-87 KXT250 - 13128-1047 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 85 KX250    1985   FITS 82-84 KX125, 83-85 87 KX250, 84-85 KXT250 - 13234-1009   1985   1985
1986 KX250 KX250DE004201- ON FITS 86  JKAKXMD13GA0-----   FITS 84-85 KX125, 85-86 KX250 KX500, 86-88 KDX200 - 13091-1267 FITS 86 KX250 KX500 11011-1220 1986 FITS 85-86 KX250 - 14073-1195 FITS 86 KX250 KX500 - 54011-1233 HYDRAULIC FITS 86 KX250 KX500 - 54012-1309 1986   1986 FITS 86-87 KXT250, 85-86 KX250, 16065-1124 FITS 85-86 KX250 KX500 - 16030-1060   1986 FITS 86 KX250  – 21119-1192   FITS 86-87 KX125 & KX250 & KX500 1986 FITS 84-86 KX125, 83-86 KX250 KX500 KDX200, 86-87 KXT250 FITS 86 KX500, KX250, 86-87 TECATE FITS 85-86 KX250 - 13095-1139 1986 no info FITS 86 KX250, 86-87 KXT250 14032-1208 ONE PIECE FITS 83-86 KX250, 84-87 KXT - 13088-1065 1986 FITS 86 KX250, 86-87 KXT250 - 13087-1081   FITS 83-84 KDX250, 83-86 KX250 KX500, 84-87 KXT - 13187-1011 1986   FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms 1986   FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 FITS 86 KX250 - 13031-1223 FITS 86-93 KX250, 91-94 KDX250 - 13044-5056 70MM BORE X 64.9MM STROKE N/A N/A 1986 1471 FITS 86 KX250, 86-87 TECATE 11005-1471 BORE 71MM STROKE 64.9MM 1986     1986   FITS 86 KX250  – 18002-1628   1986 N/A N/A N/A   1986   FITS 86 KX250 - 12005-1069 FITS 86 KX250 - 12005-1070       F3T80874 FITS 86-88 - 21007-1141 FITS 86-87 KDX200 KX125 KX250 KX500 - 34028-1173 - 34028-1174 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1986 CONVENTIONAL – 43MM CHROME OD 43MM X 55MM X 9.5/10.5/11 1986               1986   CONVENTIONAL FITS 86 KX125, KX250, KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1986   FITS 86 KX125 KX250 KX500 44039-1142 1986 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1986   1986   FITS 85-88 KX125 KX250 KX500 - 41068-1241     1986 FITS 82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 FITS 82-86 KX125, 83-86 KX250 KX250 - PART OF CALIPER ASY 43041-1084 1986   FITS 82-86 KX125 KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200, 46092-1108 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200 1986 OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92   1986 F-1123 - BLACK - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR OD 250MM - 8 ON A 146MM BC - FITS 85-87 KX125 KX250 KX500 - 41034-1115   1986             FITS 80-86 KX250, 80-84 KDX250 - 59051-1022 1986 FITS 83-86 KX250 - 13064-1105    FITS 83-86 KX250 - 13066-1052       FITS 86-89 KX125 KX250 KX500 - 58029-5018-6W GREEN 1986 800CC   70MM BORE X 64.9 STROKE INNER 21S,  OUTER 20T - FITS 83-87 KX250 13097-1070 1986 FITS 85-86 KX250 39061-1064 FITS 85-86 KX250 39061-1065 GREEN - FITS 86 KX250 KX500 - 49089-5009-6W GREEN - FITS 86 KX250 KX500 - 49089-5010-6W 1986 BLACK  14037-1077-6C FITS 85-86 KX500, 83-86 KX250, 86-87 KXT250 FITS 85-87 KX125 KX250 KX500 - 41068-1180 1986 HYDRAULIC BRAKE FITS 86 KX125, KX250, KX500     1986 FITS 86-87 KX125 KX250 KX500 - 43059-1364  FITS 86 KX250 KX500 43001-1195 FITS 82-86 KX125 & KX250, 83-86 KX500, 84-87 KX80, 86-88 KDX200   1986 FITS 86 KX250 & KX500 GREEN – FITS 86-87 KX125 KX250 KX500 - 35022-1217-6W  1986 R-1158 – BLACK - 20MM – BRG TO BRG 144-145MM – ROTOR OD 220MM – ROTOR BC 8 ON 126MM – SPROCKET 6 ON 150MM BC – 36 SPOKES – FITS 86-87 KX125 KX250 KX500 - 41034-1139 1986 LEFT FITS 86-88 KX125 KX250 KX125 - 92027-1942 FITS 86 KX250    1986 FITS 86 KX125, KX250 & KX500 - 53001-1436   FITS 85-89 KX250 - 13141-1069 1986 FITS 83-89 KX250, 84-86 KXT250, 91-94 KDX250 - 13140-1071 - 13140-1072 - 13140-1073 SET FITS 80-89 KX250, 84-87 KXT250 49047-1009 - 49047-1011 1986 FITS 83-86 KX250, KX500 - 13242-1166   1986     FITS 86 KX250 KX500 - 39007-1081   1986       1986 FITS 86-90 KX250, 86-87 KXT250 - 92027-1963 FITS 86 KX250  FITS 83-86 KX250, 84-86 KXT250 14031-1104 PART OF MAIN FRAME 1986 FITS 86 KX250 & KX500 - 33001-1246 FITS 85 KX125, 85-86 KX250 KX500   FITS 86-87 KX250 FITS 85-86 KX250, 86-87 KXT250 - 13127-1120 1986     FITS 83-86 KX250, 84-87 KXT250 - 13128-1047 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 86-87 KX250, KXT250 - 16142-1067   1986   FITS 86 KX250, 86-87 KXT250 - 13234-1062   1986   1986
1987 KX250 KX250EE000001-004800 FITS 87  JKAKXM---HA0-----   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 87 KX125 KX250 KX500 11011-1241 1987 FITS 87 KX250 - 14073-1287 FITS 87 KX250 KX500 - 54011-1252 HYDRAULIC FITS 87 KX250 KX500 - 54012-1324 1987 MIKUNI - FITS 87 KX250 - 15001-1311 1987 FITS 87 KX250  16065-1150   92064-044 JET-PILOT NO 45 - 92063-050 JET-MAIN NO 350A - 16017-1234 JET-NEEDLE,R-2 1987 FITS 87 KX250  – 21119-1220   FITS 86-87 KX125 & KX250 & KX500 1987 FITS 87 KX125 KX250 KX500, 87-88 KDX200, 87-88 KXF250 FITS 87 KX250 & KX500 FITS 87 KX250  1987 no info FITS 87 KX250 14032-1229 ONE PIECE FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  1987 FITS 87 KX250 KX500 - 13087-1085   FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1987   FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms 1987   FITS 82-87 KX125, 83-87 KX250 KX500 KDX200, 84-87 KXT250 - 14026-1119 FITS 87 KX250 - 13031-1232 CLICK HERE FOR PICS FITS 86-93 KX250, 91-94 KDX250 - 13044-5056 67.4MM BORE X 70MM STROKE N/A N/A 1987 1509 FITS 87 KX250  11005-1509 BORE 66.40 STROKE 70MM 1987     1987   FITS 87 KX250  – 18002-1716   1987 N/A N/A N/A   1987   FITS 87 KX250 - 12005-1081 FITS 87 KX250 - 12005-1092       F3T80874 FITS 86-88 - 21007-1141 FITS 86-87 KDX200 KX125 KX250 KX500 - 34028-1173 - 34028-1174 83-87 KX250 KX500, 84-87 KX125, 84-94 KDX200 1987 CONVENTIONAL - CHROME OD 43MM C/L 36.75" 43MM X 55MM X 9.5/10.5/11 1987               1987   CONVENTIONAL FITS 87 KX250, KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1987   FITS 87 KX250 KX500 44039-1147 1987 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1987   1987   FITS 85-88 KX125 KX250 KX500 - 41068-1241     1987 FITS 87 KX125 KX250 KX500 CALIPER HOLDER FITS 87-88 KX500, 88 KX125 KX250 - 43044-1069  1987 FITS 87 KX125 KX250 KX500 - 43059-1385 FITS 87 KX125 KX250 KX500 46092-1141 FITS 87 KX125 KX250 KX500 1987 OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92   1987 F-1123 - BLACK - 17MM AXLE DIA - BRG TO BRG 102MM - ROTOR OD 250MM - 8 ON A 146MM BC - FITS 85-87 KX125 KX250 KX500 - 41034-1115   1987 FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089           26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 1987 FITS 87 KX250 - 13064-1131 FITS 87 KX250 - 13061-1211 FITS 87 KX250 - 13066-1064 FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200     FITS 86-89 KX125 KX250 KX500 - 58029-5018-6W GREEN 1987 800CC   67.4MM BORE X 70MM STROKE INNER 21S,  OUTER 20T - FITS 83-87 KX250 13097-1070 1987 FITS 87-88 KX250 39061-1100 FITS 87-88 KX250 39061-1101     1987 BLACK 14037-1087 FITS 87 KX250, KX500 FITS 85-87 KX125 KX250 KX500 - 41068-1180 1987 HYDRAULIC BRAKE FITS 87-88 KX125, KX250, KX500 - 43041-1244   FITS 87-88 KX125 KX250 KX500 - 43044-1068 1987 FITS 86-87 KX125 KX250 KX500 - 43059-1364  FITS 87 KX250 KX500 43001-1217  FITS 87 KX125 & KX250 & KX500   1987 OD: 8 11/16" - ID: 4 5/16" - 8 BOLT HOLES ON A 4 15/16" BOLT CIRCLE GREEN – FITS 86-87 KX125 KX250 KX500 - 35022-1217-6W  1987 R-1158 – BLACK - 20MM – BRG TO BRG 144-145MM – ROTOR OD 220MM – ROTOR BC 8 ON 126MM – SPROCKET 6 ON 150MM BC – 36 SPOKES – FITS 86-87 KX125 KX250 KX500 - 41034-1139 1987   FITS 87 KX250  FITS 87-04 KX250 1987 FITS 87 KX125 KX250 KX500   FITS 85-89 KX250 - 13141-1069 1987 FITS 83-89 KX250, 84-86 KXT250, 91-94 KDX250 - 13140-1071 - 13140-1072 - 13140-1073 SET FITS 80-89 KX250, 84-87 KXT250 49047-1009 - 49047-1011 1987 FITS 87 KX250 & KX500 FITS 87-93 KX250 - 13161-1145 1987     FITS 87 KX125 KX250 KX500 - 39007-1115 FITS 87 KX250 KX500 - 46102-1200 1987   FITS 87 KX125 KX250 KX125 - LEFT 36002-5310-6W  FITS 87 KX125 KX250 KX125 – RIGHT 36001-1345-AC 1987 FITS 86-90 KX250, 86-87 KXT250 - 92027-1963   FITS 87 KX250 14031-1201 FITS 87 KX125 KX250 KX500 - 32002-1911 1987 FITS 87 KX250 KX500 - 33001-1276     FITS 86-87 KX250 FITS 87 KX250  – 13127-1142 1987     FITS 87 KX250   – 13128-1141 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 86-87 KX250, KXT250 - 16142-1067   1987   FITS 82-84 KX125, 83-85 87 KX250, 84-85 KXT250 - 13234-1009   1987   1987
1988 KX250 KX250EE004801-010700 SET FITS 88 KX250 - 14001-5246 JKAKXM---JA0-----   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 88 KX250  11011-1272 1988 1330 - FITS 88 KX250 - 14073-1330 FITS 88-89 KX250 KX500 - 54011-1264 HYDRAULIC FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 1988 KEIHIN PWK V398 - FITS 88 KX250 - 15001-1398 1988 FITS 88-93 KX250, 91-94 KDX250 - 16065-1168   92064-1130 JET-PILOT,#52 - 92063-1373 JET-MAIN,#172 - 16009-1408 NEEDLE-JET,R1368J 1988 FITS 88 KX250  – 21119-1246 FITS 88-89 KX125 KX250 KX500 - 33040-1085 FITS 88-89 KX125 KX250 KX500 1988 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 FITS 88 KX250 & KX500 - 13102-1094 88-89 KX250, 91-94 KDX250 - 13095-1171 1988 no info FITS 88-89 KX250 14032-1244 FITS 88-89 KX250 14032-1243 FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  1988 FITS 88-91 KX250, 88 KX500 - 13087-1098   FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1988   FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms 1988     FITS 88 KX250 - 13031-1262  FITS 86-93 KX250, 91-94 KDX250 - 13044-5056 67.4MM BORE X 70MM STROKE N/A N/A 1988 1542 FITS 88 KX250  11005-1542 BORE 66.40 STROKE 70MM 1988   FITS 88-89 KX250 - 32029-1507 1988 FITS 88 KX125 KX250 - 32029-1570 FITS 88 KX250  – 18002-1801   1988 N/A 20034 N/A   1988 FITS 88 KX250     FITS 88-92 KX250, 89-04 KX500 - 14024-1588     F3T80874 FITS 86-88 - 21007-1141 FITS 88-89 KX125 KX250 KX500 - 34028-1233 - 34028-1234 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1988   43MM X 55MM X 9.5/10.5/11 1988               1988   CONVENTIONAL FITS 88 KX250, KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1988   FITS 88 KX250 KX500 44039-1176 1988 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1988   1988   FITS 85-88 KX125 KX250 KX500 - 41068-1241     1988 FITS 88 KX125 KX250 KX500 FITS 87-88 KX500, 88 KX125 KX250 43044-1069 1988   FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 FITS 88 KX125 KX250 KX500 - 43015-1367 1988 OD: 9 13/16" - ID 5 3/32" - 8 HOLES ON A 5 3/4" BOLT CIRCLE FITS 85-88 KX125, 250, 500, KDX200 86-92 GREEN - FITS 88 KX250 KX500, 86-88 KDX200 - 35004-1176-6W   1988 F-1123 - GRAY - 17MM AXLE DIA - BRG TO BRG 102MM - FITS 88 KX 125, 250, 500 - 41034-1170 GREEN - FITS 88 KX250, 88-91 KX500 - 51001-1281-6W  1988 FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089     1268 - FITS 88 KX250 - 11001-1268      26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 1988 FITS 88-89 KX250 - 13064-1135   FITS 88-93 KX250, 91-94 KDX250 - 13066-1068 FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200     FITS 86-89 KX125 KX250 KX500 - 58029-5018-6W GREEN 1988 800CC   67.4MM BORE X 70MM STROKE INNER 21S, OUTER 20T - FITS 88-92 KX250 - 13097-1208 1988 FITS 87-88 KX250 39061-1100 FITS 87-88 KX250 39061-1101     1988 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 FITS 88 KX125 KX250 KX500 - 41068-1249 CLICK HERE FOR MEASUREMENTS 1988 HYDRAULIC BRAKE FITS 87-88 KX125, KX250, KX500 - 43041-1244   FITS 87-88 KX125 KX250 KX500 - 43044-1068 1988   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368   1988 OD: 8 11/16" - ID: 4 5/16" - 8 BOLT HOLES ON A 4 15/16" BOLT CIRCLE GREEN – FITS 88 KX250 KX500 - 35022-1234-6W 1988 R-1158 – GRAY - 20MM – BRG TO BRG 144-145MM – ROTOR OD 220MM – ROTOR BC 8 ON 126MM – SPROCKET 6 ON 150MM BC – 36 SPOKES – FITS 88 KX 125, 250, 500 - 41034-1171 1988     FITS 87-04 KX250 1988 PAN STAMP 1531 - FITS 88 KX125 KX250 KX500 - 53001-1532   FITS 85-89 KX250 - 13141-1069 1988 FITS 83-89 KX250, 84-86 KXT250, 91-94 KDX250 - 13140-1071 - 13140-1072 - 13140-1073 SET FITS 80-89 KX250, 84-87 KXT250 49047-1009 - 49047-1011 1988 FITS 88-93 KX125, KX250 & KX500 - 13156-1240 FITS 87-93 KX250 - 13161-1145 1988     FITS 88 KX125 KX250 KX500 - 39007-1145   1988   GREEN – FITS 88 KX125 KX250 KX500 - 36002-5451-6W GREEN - FITS 88 KX250 KX500 – 36001-1376-AC 1988 FITS 86-90 KX250, 86-87 KXT250 - 92027-1963 FITS 88 KX250 - 21003-1186 FITS 88-89 KX250 14031-1218 FITS 88 KX125 KX250 KX500 - 32002-1965 1988 FITS 88 KX125 KX250 KX500 - 33001-1306-X3 FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137   FITS 88-89 KX250 15T - FITS 88-89 KX250 – 13127-1162 / OPTION 13T - 13127-1172 1988 17T - FITS 88-93 KX250 - 13129-1911   FITS 88-89 KX250, 91-94 KDX250 - 13128-1151 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160 27T - FITS 88-89 KX250 - 13129-1912   FITS 88-91 KX250, 91-94 KDX250 - 16142-1085 FITS 88-89 KX125 KX250 - 52014-1063 1988   FITS 88-90 KX250 - 13234-1079   1988   1988
1989 KX250 KX250EE010701- ON FITS 89  JKAKXMG14KA00XXXX   FITS 87- 89 KX125 KX250, 87-04 KX500, 89-06 KDX200,  97-05 KDX220, 91-94 KDX250, 93-96 KLX650, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S - 13091-1454 FITS 89 KX125 KX250, 90-04 KX500 11011-1304 1989 FITS 89 KX250 - 14073-1373 FITS 88-89 KX250 KX500 - 54011-1264 HYDRAULIC FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 1989 KEIHIN PWK V464 - FITS 89 KX250 - 15001-1464 1989 FITS 88-93 KX250, 91-94 KDX250 - 16065-1168   92064-1145 JET-PILOT,#55 - 92063-1373 JET-MAIN, #172 - 16009-1408 NEEDLE-JET,R1368J 1989 FITS 89 KX250  – 21119-1254 FITS 88-89 KX125 KX250 KX500 - 33040-1085 FITS 88-89 KX125 KX250 KX500 1989 FITS 88-89 KX125 KX250, 88-04 KX500, 89-93 KDX200, 91-94 KDX250 12053-1240 BOOK SAYS IT FITS 89 KX250 & KX500 - 13102-1101 - IT WILL FIT 88-04 KX500 88-89 KX250, 91-94 KDX250 - 13095-1171 1989 no info FITS 88-89 KX250 14032-1244 FITS 88-89 KX250 14032-1243 FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  1989 FITS 88-91 KX250, 88 KX500 - 13087-1098   FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1989   FITS 86-89 KZ125 KX250, 89-94 KDX200 - 21121-1170 - .8-1.2 ohms 1989     FITS 89 KX250 - 13031-1292 FITS 86-93 KX250, 91-94 KDX250 - 13044-5056 67.4MM BORE X 70MM STROKE N/A N/A 1989 1566 FITS 89 KX250  11005-1566 BORE 66.40 STROKE 70MM 1989   FITS 89 KX250 - 32029-1651 1989 FITS 89 KX125 KX250 - 32029-1649 FITS 89 KX250  – 18002-1866   1989 N/A 20034 N/A PK89250P - FITS 89 KX250 1989 FITS 89 KX250     FITS 88-92 KX250, 89-04 KX500 - 14024-1588     F3T81471 8X01 FITS 1989 KX250  - 21007-1180 FITS 88-89 KX125 KX250 KX500 - 34028-1233 - 34028-1234 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1989 CONVENTIONAL - KX 89 L / KX 89 R - CHROME OD 46MM - C/L 36.75" - BRAKE MOUNT 78MM - AXLE CLAMP ID'S 22MM 46MM X 58MM X 10.5 1989               1989   CONVENTIONAL FITS 89 KX125, KX250, KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1989   FITS 89 KX125 KX250 KX500 44039-1192 1989 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1989   1989   FITS 89 KX125 KX250 KX500 FITS 89-93 KX500, 89-92 KX125 KX250, 93-96 KLX650C KLX650R, 94-96 KLX250R, 97-07 KLX300R, 00-10 KL250 - 44063-1056 1989 FITS 89 KX125 KX250 KX500 - 43041-1294 FITS 89 KX125 KX250 KX500 - 14079-1071 1989   FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 FITS 89-90 KX125 KX250 KX500 KX80 - 43015-1395 1989 ROTOR OD 250MM - ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 89-91 KX125 KX250, 89-93 KX500, 93-94 KDX200   1989 F-1212 - GRAY - 17MM AXLE DIA - BRG TO BRG 92MM - ROTOR BC 4 ON 116MM - FITS 89 KX125 KX250 KX500 FITS 89 KX250 1989 FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089     1293 - FITS 89 KX250 - 11001-1293     26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 1989 FITS 88-89 KX250 - 13064-1135   FITS 88-93 KX250, 91-94 KDX250 - 13066-1068 FITS 86-89 KX125, 87-89 KX250, 87-04 KX500, 89-94 KDX200     FITS 86-89 KX125 KX250 KX500 - 58029-5018-6W GREEN 1989 800CC   67.4MM BORE X 70MM STROKE INNER 21S, OUTER 20T - FITS 88-92 KX250 - 13097-1208 1989 FITS 89 KX250, 89-94 KDX200 39061-1127 FITS 89 KX250 39061-1128     1989 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 FITS 89 KX125 KX250 KX500 - 41068-1277 1989 HYDRAULIC BRAKE FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448   FITS 89 KX125 KX250 KX500 - 43044-1082 1989   FITS 88-89 KX125 KX250, 88-04 KX500 - 43001-1239 FITS 88-89 KX125 KX250, 88-04 KX500 - 43015-1368   1989 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 GREEN - FITS 89-04 KX500, 88-89 KX125, 89 KX250 - 35022-1241-6W 1989 R-1213 – GRAY – 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM – 36 SPOKES – FITS 89 KDX200, KX125, KX250, KX500 - 2 BRG - 41034-1184 1989 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R FITS 89-92 KX250 - 12021-1082 FITS 87-04 KX250 1989 PAN STAMP 1531 - FITS 89 KX125 KX250 KX500 - 53001-1577-MD   FITS 85-89 KX250 - 13141-1069 1989 FITS 83-89 KX250, 84-86 KXT250, 91-94 KDX250 - 13140-1071 - 13140-1072 - 13140-1073 SET FITS 80-89 KX250, 84-87 KXT250 49047-1009 - 49047-1011 1989 FITS 88-93 KX125, KX250 & KX500 - 13156-1240 FITS 87-93 KX250 - 13161-1145 1989 fits 89 kx250 - 45014-1437   FITS 89 KX125 KX250 KX500 - 39007-1170 FITS 89 KX125 KX250, 89-04 KX500 - 46102-1253 1989   GREEN - FITS 89-95 KX500, 89 KX125 KX250, 89-94 KDX200 - 36010-5023-6W GREEN – FITS 89 KX125 KX250 KX500 - 36010-5135-6W 1989 FITS 86-90 KX250, 86-87 KXT250 - 92027-1963 FITS 1989 KX250 - 21003-1195 FITS 88-89 KX250 14031-1218 FITS 89-90 KX500, 89 KX125 KX250 - 32160-1031 1989 FITS 89 KX125 KX250 KX500 – 33001-1324-CE FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137   FITS 88-89 KX250 15T - FITS 88-89 KX250 – 13127-1162 / OPTION 13T - 13127-1172 1989 17T - FITS 88-93 KX250 - 13129-1911   FITS 88-89 KX250, 91-94 KDX250 - 13128-1151 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160 27T - FITS 88-89 KX250 - 13129-1912   FITS 88-91 KX250, 91-94 KDX250 - 16142-1085 FITS 88-89 KX125 KX250 - 52014-1063 1989   FITS 88-90 KX250 - 13234-1079   1989   1989
1990 KX250 KX250HE000001- ON SET FITS 90 KX250 - 14001-5275 JKAKXMH17LA00XXXX   FITS 90 KX125 KX250 - 13091-1663 FITS 90-91 KX125 KX250 11011-1336 1990 FITS 90-91 KX250 - 14073-1428 FITS 90 KX250, 90-04 KX500 - 54011-1304 HYDRAULIC FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 1990 KEIHIN PWK V561 - FITS 90 KX250 - 15001-1561 1990 FITS 88-93 KX250, 91-94 KDX250 - 16065-1168   JET-PILOT NO INFO - 92063-1368 JET-MAIN,#160 - 16009-1590 NEEDLE-JET,N85C 1990 FITS 90 KX250  – 21119-1282 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1990 FITS 90 KX125 KX250 12053-1269 FITS 90 KX250, 90-04 KX500 13102-1107 FITS 90-91 KX250 13095-1206 1990 no info FITS 90-91 KX250, 91-94 KDX250 14032-1283 FITS 90 KX250  14032-1282 FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  1990 FITS 88-91 KX250, 88 KX500 - 13087-1098   FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1990   F6T537 FITS 90-91 KX125 & KX250, 94 KX125 & KX250 - 21121-1181 - 21121-1234 1990     FITS 90 KX250, 91-94 KDX250 - 13031-1302 FITS 86-93 KX250, 91-94 KDX250 - 13044-5056 67.4MM BORE X 70MM STROKE N/A N/A 1990 1601 FITS 90 KX250  11005-1601 BORE 66.40 STROKE 70MM 1990     1990 FITS 90-91 KX125 KX250 - 32029-1714 FITS 90 KX250  – 18002-1931   1990 N/A 20040 N/A   1990 FITS 90-92 KX250 & 91-94 KDX250 - 12005-1142 FITS 90-92 KX250, 91-94 KDX250 - 12005-1140 FITS 90-92 KX250, 91-94 KDX250 - 12005-1141 FITS 88-92 KX250, 89-04 KX500 - 14024-1588     F3T81472 FITS 90-91 KX250 - 21007-1199 FITS 90 KX125 KX250, 90-91 KX500 - 34028-1318 - 34028-1319 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1990 X125 R, X125 L - USD - CHROME OD 41MM - C/L 37.375" -  48.7MM UPPER - 55.6MM LOWER - BRAKE MOUNTS C/L 60MM - AXLE CLAMP 22MM ID 41MM X 53MM X 8/9.5/10.5 1990               1990 FITS 90-93 KX125 KX250 KX500 - 55020-1384 FITS 90-93 KX125 KX250 KX500 - 13070-1204 FITS 90 KX125, KX250, KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1990   FITS 90 KX250 KX500 44039-1190 1990 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1990   1990   FITS 90-92 KX125 KX250, 90-93 KX500 41068-1310 FITS 89-93 KX500, 89-92 KX125 KX250, 93-96 KLX650C KLX650R, 94-96 KLX250R, 97-07 KLX300R, 00-10 KL250 - 44063-1056 1990 FITS 90 KX125 KX250 KX500 - 43041-1285 FITS 90-91 KX125 KX250 KX500, 91 KDX250 - 14079-1072 1990 FITS 90-93 KX125 KX250 KX500 - 43059-1577 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 FITS 89-90 KX125 KX250 KX500 KX80 - 43015-1395 1990 ROTOR OD 250MM - ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 89-91 KX125 KX250, 89-93 KX500, 93-94 KDX200   1990 F-1212 - GRAY - 17MM AXLE DIA - BRG TO BRG 92MM - FITS 90-92 KX125 AND 250 - 1990-1993 KX500 - 41034-1204 GREEN - FITS 90-91 KX125 KX250  51001-1320-6W 51001-1340-6W 1990 FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089     1315 - FITS 90 KX250 - 11001-1315     26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 1990 FITS 90 KX250 - 13064-1149   FITS 88-93 KX250, 91-94 KDX250 - 13066-1068 FITS 90-91 KX250     FITS 90 KX125 KX250 KX500 58029-5027-6W GREEN 1990 800CC   67.4MM BORE X 70MM STROKE INNER 21S, OUTER 20T - FITS 88-92 KX250 - 13097-1208 1990 FITS 90 KX125, 90-91 KX250 39061-1147 FITS 90-91 KX250 39061-1146     1990 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 1990 HYDRAULIC BRAKE FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448   FITS 90-93 KX125 KX250, 90-91 KX500 - 43044-1092 1990 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 90-91 KX125 KX250 - 43001-1277     1990 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 GREEN - FITS 90-91 KX125 KX250 - 35022-1256-6W 1990 R-1213 OR R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG 1990 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM FITS 89-92 KX250 - 12021-1082 FITS 87-04 KX250 1990 FITS 90 KX125 KX250 - 53001-1592-MZ   FITS 90-91 KX250 - 13141-1162 1990 SET FITS 90-91 KX250 - 13140-1185 - 13140-1186 - 13140-1187 SET FITS 90-95 KX250, 91-94 KDX250 - 49047-1063 49047-1080 - 9.98MM OD 1990 FITS 88-93 KX125, KX250 & KX500 - 13156-1240 FITS 87-93 KX250 - 13161-1145 1990 FITS 90 KX250 - 45014-1452 FITS 90-91 KX125 KX250 - LEFT 32037-1522 - RIGHT 32037-1523 STAMPED 39007-1213A - FITS 90 KX125 KX250 - 39007-1188 FITS 90 KX125 KX250 -  OLD 46102-1282 NEW 46102-1289  1990   GREEN - FITS 90-91 KX125 KX250 - 36010-5289-6W GREEN - FITS 90-91 KX125 KX250 -  36010-5290-6W 1990 FITS 86-90 KX250, 86-87 KXT250 - 92027-1963 FITS 1990 KX250 - 21003-1205 FITS 90-93 kx250 - 14031-1244 FITS 90 KX125 KX250 - 32160-1096 1990 FITS 90 KX125 KX250 – 33001-1346-CE FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137   FITS 90-91 KX250 15T - FITS 90 KX250  – 13127-1195 1990 17T - FITS 88-93 KX250 - 13129-1911   FITS 90-96 KX250 – 13128-1173 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 88-91 KX250, 91-94 KDX250 - 16142-1085   1990   FITS 88-90 KX250 - 13234-1079   1990   1990
1991 KX250 KX250HE000001- ON FITS 91 KX250 - 14001-5285 JKAKXM---MA0-----   FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 90-91 KX125 KX250 11011-1336 1991 FITS 90-91 KX250 - 14073-1428 FITS 91-92 KX250 - 54011-1315 HYDRAULIC FITS 88-91 KX250, 88-04 KX500, 88 KDX200 - 54012-1341 1991 KEHIN PWK V674 - FITS 91 KX250 – 15001-1674 1991 FITS 88-93 KX250, 91-94 KDX250 - 16065-1168   JET-PILOT NO INFO - 92063-1368 JET-MAIN,#160 - 16009-1590 NEEDLE-JET,N85C 1991 FITS 91 KX250  – 21119-1306 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1991 FITS 91-93 KX125 KX250 12053-1278 FITS 91-94 KX250 KDX250 13102-1110 FITS 90-91 KX250 13095-1206 1991 no info FITS 90-91 KX250, 91-94 KDX250 14032-1283 FITS 91 KX250 14032-1293 FITS 87-91 KX250 KX500, 91-94 KDX250 - 13088-1069  1991 FITS 88-91 KX250, 88 KX500 - 13087-1098 FITS 91 KX125 KX250 KX500 - 13091-1680 FITS 87-91 kx250, 87-04 kx500, 91-94 kdx250, 87-88 KXF250 - 13187-1060 1991   F6T537 FITS 90-91 KX125 & KX250, 94 KX125 & KX250 - 21121-1181 - 21121-1234 1991     FITS 91 KX250 - 13031-1315 FITS 86-93 KX250, 91-94 KDX250 - 13044-5056 66.4MM BORE X 72MM STROKE N/A N/A 1991 1643 FITS 91 KX250  11005-1643 BORE 66.40 STROKE 70MM 1991     1991 FITS 90-91 KX125 KX250 - 32029-1714 FITS 91 KX250  – 18090-1068   1991 N/A 20041 N/A   1991 FITS 90-92 KX250 & 91-94 KDX250 - 12005-1142 FITS 90-92 KX250, 91-94 KDX250 - 12005-1140 FITS 90-92 KX250, 91-94 KDX250 - 12005-1141 FITS 88-92 KX250, 89-04 KX500 - 14024-1588     F3T81472 FITS 90-91 KX250 - 21007-1199 FITS 91 KX125 KX250 KDX25, 92 KX500 - 34028-1332 - 34028-1333 FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1991 USD - X125-R X125-L - 43MM CHROME OD - C/L 37.25" - BLUE - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 60.5MM AXLE CLAMP 22MM ID 43MM X 55MM X 9.5/10.5/11 1991               1991 FITS 90-93 KX125 KX250 KX500 - 55020-1384 FITS 90-93 KX125 KX250 KX500 - 13070-1204 FITS 91 KX125, KX250, 91-93 KX500 FITS 74-76 78-91 KX250, 80-81 KX420, 83-04 KX500, 83-94 KDX200, 81-84 KDX250, 84-87 KXT250 - 92116-1008 1991   FITS 91 KX250, 91-93 KX500 44039-1212 1991 FITS 84-87 KXT250, 74-76 78-91 KX125 KX250, 83-04 KX500, 75-76 KX400, 80-81 KX420, 78-84 KL250, 80-84 91-94 KDX250, 83-06 KDX200, 97-05 KDX200, 79-80 94-96 06-10 KLX250, 93-96 KLX650R & C - 92047-017 1991   1991   FITS 90-92 KX125 KX250, 90-93 KX500 41068-1310 FITS 89-93 KX500, 89-92 KX125 KX250, 93-96 KLX650C KLX650R, 94-96 KLX250R, 97-07 KLX300R, 00-10 KL250 - 44063-1056 1991 FITS 91 KX125 KX250. 91-92 KX500, 91-94 KDX250, 93-94 KDX200 - 43041-1427 FITS 90-91 KX125 KX250 KX500, 91 KDX250 - 14079-1072 1991 FITS 90-93 KX125 KX250 KX500 - 43059-1577 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 FITS 91-92 KX125 KX250, 91 KX500 - 43015-1443 1991 ROTOR OD 250MM - ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 89-91 KX125 KX250, 89-93 KX500, 93-94 KDX200   1991 F-1212 - GRAY - 17MM AXLE DIA - BRG TO BRG 92MM - FITS 90-92 KX125 AND 250 - 1990-1993 KX500 - 41034-1204 GREEN - FITS 90-91 KX125 KX250  51001-1320-6W 51001-1340-6W 1991 FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089     1338 - FITS 91 KX250 - 11001-1338     26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 1991 FITS 91 KX250 - 13064-1155   FITS 88-93 KX250, 91-94 KDX250 - 13066-1068 FITS 90-91 KX250     FITS 91 KX125 KX250 KX500 58029-5028-6W GREEN 1991 800CC   67.4MM BORE X 70MM STROKE INNER 21S, OUTER 20T - FITS 88-92 KX250 - 13097-1208 1991 FITS 90 KX125, 90-91 KX250 39061-1147 FITS 90-91 KX250 39061-1146     1991 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 1991 HYDRAULIC BRAKE FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448   FITS 90-93 KX125 KX250, 90-91 KX500 - 43044-1092 1991 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 90-91 KX125 KX250 - 43001-1277 FITS 91 KX125 KX250 43015-1440   1991 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 GREEN - FITS 90-91 KX125 KX250 - 35022-1256-6W 1991 R-1213 OR R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG 1991 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM FITS 89-92 KX250 - 12021-1082 FITS 87-04 KX250 1991 FITS 90 KX125 KX250 - 53001-1592-MZ   FITS 90-91 KX250 - 13141-1162 1991 SET FITS 90-91 KX250 - 13140-1185 - 13140-1186 - 13140-1187 SET FITS 90-95 KX250, 91-94 KDX250 - 49047-1063 49047-1080 - 9.98MM OD 1991 FITS 88-93 KX125, KX250 & KX500 - 13156-1240 FITS 87-93 KX250 - 13161-1145 1991   FITS 90-91 KX125 KX250 - LEFT 32037-1522 - RIGHT 32037-1523 STAMPED 39007-1213A - FITS 91-92 KX125 KX250 - 39007-1197 STAMPED 93 - FITS 91-96 KX125 KX250 - 46102-1293  1991   GREEN - FITS 90-91 KX125 KX250 - 36010-5289-6W GREEN - FITS 90-91 KX125 KX250 -  36010-5290-6W 1991   FITS 1991 KX250  FITS 90-93 kx250 - 14031-1244 FITS 91 KX125 KX250 - 32160-1151 1991 FITS 91 KX125 KX250 – 33001-1370-CE FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S - 33032-1137   FITS 90-91 KX250 15T - FITS 91-93 KX250 - 13127-1201 1991 17T - FITS 88-93 KX250 - 13129-1911   FITS 90-96 KX250 – 13128-1173 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 88-91 KX250, 91-94 KDX250 - 16142-1085   1991       1991   1991
1992 KX250 KX250JE00XXXX FITS 92 KX250 - 14001-5302 - KAWI MAN SAYS 92-96 WILL FIT, 97-04 USE A LARGER SHIFT FORK PIN & 1 LESS CASE BOLT & NARROWER SHIFT DRUM JKAKXM---MA0-----   FITS 92-93 KX15 KX250 - 13091-1785 FITS 92-93 KX125 & KX250 1992 FITS 92 KX250 - 14073-1508 FITS 91-92 KX250 - 54011-1315 HYDRAULIC FITS 92-97 KX125 KX250 - 54012-1432 1992 KEIHIN PWK V755 - FITS 92 KX250 - 15001-1755 1992 FITS 88-93 KX250, 91-94 KDX250 - 16065-1168   92064-1146 JET-PILOT,#58 - 92063-1369 JET-MAIN,#162 - 16009-1696 NEEDLE-JET,NOLB 1992 FITS 92 KX250  – 21119-1343 FITS 90-92 KX125 KX250, 90-04 KX500 - 33040-1106 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1992 FITS 91-93 KX125 KX250 12053-1278 FITS 91-94 KX250 KDX250 13102-1110 FITS 92-93 KX250 13095-1240 1992 HO58 FITS 92-05 KX250 FITS 92-94 KX250 – 14032-1313 FITS 92 KX250 14032-1312 FITS 92-07 KX250 1992 FITS 92-93 KX250 - 13087-1139   FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 1992   F6T537 FITS 92-93 KX250 1992 780-1220 kPa OR 114-176 PSI FITS 92-04 KX250, 89-04 KX500, 91-94 KDX250 - 14026-1174 - PLASTIC FITS 92 KX250 - 13031-1328 FITS 86-93 KX250, 91-94 KDX250 - 13044-5056 66.4MM BORE X 72MM STROKE FITS 92-04 KX250 4017 N/A 1992 1671 FITS 92 KX250  11005-1671 BORE 66.40 STROKE 72MM 1992     1992 FITS 92-93 KX125 KX250 - 32029-1791 FITS 92 KX250  – 18090-1152   1992 N/A 20042 N/A   1992 FITS 90-92 KX250 & 91-94 KDX250 - 12005-1142 FITS 90-92 KX250, 91-94 KDX250 - 12005-1140 FITS 90-92 KX250, 91-94 KDX250 - 12005-1141 FITS 88-92 KX250, 89-04 KX500 - 14024-1588     FITS 92-97 KX250 - 21007-1234 - F4T803 71 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1992 USD - CHROME OD 43MM - C/L 37.25" - BLUE - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 60.5MM 43MM X 55MM X 9.5/10.5/11 1992               1992 FITS 90-93 KX125 KX250 KX500 - 55020-1384 FITS 90-93 KX125 KX250 KX500 - 13070-1204 FITS 92-94 KX125 KX250 - 44037-1298 FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 1992 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM FITS 92-95 KX250 - 44039-1225 1992 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 1992 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  1992   FITS 90-92 KX125 KX250, 90-93 KX500 41068-1310 FITS 89-93 KX500, 89-92 KX125 KX250, 93-96 KLX650C KLX650R, 94-96 KLX250R, 97-07 KLX300R, 00-10 KL250 - 44063-1056 1992 FITS 92-93 KX125 KX250, 93 KX500 - 43041-1462 FITS 92-93 KX125 KX250 KX500, 92-94 KDX250 - 14079-1088 1992 FITS 90-93 KX125 KX250 KX500 - 43059-1577 FITS 88-92 KX125 KX250, 88-93 KX500 KX80, 89-94 KDX200, 91-94 KD250 FITS 91-92 KX125 KX250, 91 KX500 - 43015-1443 1992 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07   1992 F-1212 - GRAY - 17MM AXLE DIA - BRG TO BRG 92MM - FITS 90-92 KX125 AND 250 - 1990-1993 KX500 - 41034-1204 FITS 92-93 KX125 KX250 51001-1360 1992 FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089   27T - FITS 92-04 KX250 - 59051-1248 1368 - FITS 92 KX250 - 11001-1368    FITS 92-04 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 1992 FITS 92 KX250 - 13064-1159   FITS 88-93 KX250, 91-94 KDX250 - 13066-1068 FITS 92-93 KX250     FITS 92-95 KX125 KX250 KX500 58029-1074-6F WHITE 1992     66.4MM BORE X 72MM STROKE INNER 21S, OUTER 20T - FITS 88-92 KX250 - 13097-1208 1992 FITS 91-93 KX125, 92-93 KX 250 39061-1173 FITS 92-93 KX125 KX250 39061-1175     1992 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 FITS 90-04 KX500, 90-92 KX125 KX250 - 41068-1299 1992 HYDRAULIC BRAKE FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448   FITS 90-93 KX125 KX250, 90-91 KX500 - 43044-1092 1992 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 92-93 KX125 KX250 - 43001-1303 FITS 92-94 KDX250, 92-93 KX125 KX250, 93-95 KLX650R - 43015-1469   1992 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200   1992 R-1213 OR R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG 1992 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM FITS 89-92 KX250 - 12021-1082 FITS 87-04 KX250 1992 FITS 92-93 KX125 KX250 - 53001-1697-LK   FITS 92-96 KX250 - 13141-1174 1992 SET FITS 92-93 KX250 - 13140-1203 13140-1204 13140-1205 SET FITS 90-95 KX250, 91-94 KDX250 - 49047-1063 49047-1080 - 9.98MM OD 1992 FITS 88-93 KX125, KX250 & KX500 - 13156-1240 FITS 87-93 KX250 - 13161-1145 1992 FITS 92 KX250 - 45014-1514-W1 - CLICK HERE FOR MEASUREMENTS   STAMPED 39007-1213A - FITS 91-92 KX125 KX250 - 39007-1197 STAMPED 93 - FITS 91-96 KX125 KX250 - 46102-1293  1992       1992   F245 3X15 FITS 92-93 KX250, WHITE/RED TO WHITE/GREEN 396-594, RED TO BLACK/RED 288-432, WHITE TO RED 14-21 FITS 90-93 kx250 - 14031-1244 FITS 92-93 KX125 KX250 - 32160-1219-CC 1992 FITS 92 KX125 KX250 – 33001-1393-CE FITS 92-93 KX125 KX250, 93-96 KLX650R - 33032-1167   FITS KX250 92-93 15T - FITS 91-93 KX250 - 13127-1201 1992 17T - FITS 88-93 KX250 - 13129-1911   FITS 90-96 KX250 – 13128-1173 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 92-99 KX250 - 16142-1117   1992 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 92-00 KX250 - 13234-1096   1992   1992
1993 KX250 KX250JE00XXXX FITS 93 KX250 - 14001-5367 - KAWI MAN SAYS 92-96 WILL FIT, 97-04 USE A LARGER SHIFT FORK PIN & 1 LESS CASE BOLT & NARROWER SHIFT DRUM JKAKXM---PA0-----   FITS 92-93 KX15 KX250 - 13091-1785 FITS 92-93 KX125 & KX250 1993 FITS 93 KX250 - 14073-1570 FITS 93-95 KX250 - 54011-1327 HYDRAULIC FITS 92-97 KX125 KX250 - 54012-1432 1993 KEIHIN PWK V789 - Main Jet #162 - Slow Jet #58 - FITS 93 KX250 - 15001-1789 1993 FITS 88-93 KX250, 91-94 KDX250 - 16065-1168   92064-1144 JET-PILOT,#50 - 92063-1369 JET-MAIN,#162 - 16009-1758 NEEDLE-JET,NOZF 1993 FITS 93 KX250  – 21119-1362   FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1993 FITS 91-93 KX125 KX250 12053-1278 FITS 91-94 KX250 KDX250 13102-1110 FITS 92-93 KX250 13095-1240 1993 HO58 FITS 92-05 KX250 FITS 92-94 KX250 – 14032-1313 1179 1312 FITS 93-96 KX250 – 14032-1327 FITS 92-07 KX250 1993 FITS 92-93 KX250 - 13087-1139   FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 1993   F6T537 FITS 92-93 KX250 1993 780-1220 kPa OR 114-176 PSI FITS 92-04 KX250, 89-04 KX500, 91-94 KDX250 - 14026-1174 - PLASTIC FITS 93 KX250 - 13031-1347 FITS 86-93 KX250, 91-94 KDX250 - 13044-5056 66.4MM BORE X 72MM STROKE FITS 92-04 KX250 4017 N/A 1993 1686 FITS 93 KX250  11005-1686 BORE 66.40 STROKE 72MM 1993     1993 FITS 92-93 KX125 KX250 - 32029-1791 FITS 93 KX250  – 18120-1054   1993 N/A 20042 N/A 1993 FITS 93-94 KX250 - 12023-1066 - 12005-1185 - 13168-1499 - 12005-1184 FITS 93-94 KX250 - 12005-1182  FITS 93-94 KX250 - 12005-1183 FITS 93-00 KX250 - 14090-1219 FITS 93-04 KX250 - 14090-1249 FITS 93-03 KX250 - 14090-1226 FITS 92-97 KX250 - 21007-1234 - F4T803 71 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1993 USD - CHROME OD 43MM - C/L 37.25" - BLUE - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 60.5MM 43MM X 55MM X 9.5/10.5/11 1993               1993 FITS 90-93 KX125 KX250 KX500 - 55020-1384 FITS 90-93 KX125 KX250 KX500 - 13070-1204 FITS 92-94 KX125 KX250 - 44037-1298 FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 1993 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM FITS 92-95 KX250 - 44039-1225 1993 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 1993 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  1993   FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342 FITS 93-98 KX125 KX250, 94-04 KX500 - 92143-1581 - 11012-1581   1993 FITS 92-93 KX125 KX250, 93 KX500 - 43041-1462 FITS 92-93 KX125 KX250 KX500, 92-94 KDX250 - 14079-1088 1993 FITS 90-93 KX125 KX250 KX500 - 43059-1577   FITS 93 KX125 KX250 - 43015-1544 1993 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07   1993 F-1249 - AXLE OD 20MM - 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125, KX250 & 94-04 KX500 FITS 92-93 KX125 KX250 51001-1360 1993 FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089   27T - FITS 92-04 KX250 - 59051-1248 1384 - FITS 93 kx250 - 11001-1384 FITS 93-04 KX250, 91-94 KDX250 - 52014-1077 FITS 92-04 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 1993 FITS 93 KX250 - 13064-1161   FITS 88-93 KX250, 91-94 KDX250 - 13066-1068 FITS 92-93 KX250     FITS 92-95 KX125 KX250 KX500 58029-1074-6F WHITE 1993 .70 LITER   66.4MM BORE X 72MM STROKE INNER 21S, OUTER 20T - FITS 93-98 KX250, 91-94 KDX250 13097-1308 1993 FITS 91-93 KX125, 92-93 KX 250 39061-1173 FITS 92-93 KX125 KX250 39061-1175     1993 GREEN 14037-1099-6W  FITS 88-95 KX500, 88-93 KX250, 90-93 KX125, 89-95 KDX200, 91-94 KDX250, 94-95 KLX250 FITS 93-02 KX125 KX250 - 41068-1343 1993 HYDRAULIC BRAKE FITS 89-93 KX125 KX250 KX500, 91-94 KDX250, 95-03 KDX200, 97-03 KDX220 - 43041-1448   FITS 90-93 KX125 KX250, 90-91 KX500 - 43044-1092 1993 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 92-93 KX125 KX250 - 43001-1303 FITS 92-94 KDX250, 92-93 KX125 KX250, 93-95 KLX650R - 43015-1469   1993 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200   1993 R-1213 OR R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG 1993 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM FITS 93 KX250 FITS 87-04 KX250 1993 FITS 92-93 KX125 KX250 - 53001-1697-LK   FITS 92-96 KX250 - 13141-1174 1993 SET FITS 92-93 KX250 - 13140-1203 13140-1204 13140-1205 SET FITS 90-95 KX250, 91-94 KDX250 - 49047-1063 49047-1080 - 9.98MM OD 1993 FITS 88-93 KX125, KX250 & KX500 - 13156-1240 FITS 87-93 KX250 - 13161-1145 1993     STAMPED 39007-1213 - FITS 93 KX125 & KX250 - 39007-1213 STAMPED 93 - FITS 91-96 KX125 KX250 - 46102-1293  1993       1993   FITS 92-93 KX250, WHITE/RED TO WHITE/GREEN 396-594, RED TO BLACK/RED 288-432, WHITE TO RED 14-21 FITS 90-93 kx250 - 14031-1244 FITS 92-93 KX125 KX250 - 32160-1219-CC 1993 FITS 93 KX125 KX250 – 33001-1406-CE FITS 92-93 KX125 KX250, 93-96 KLX650R - 33032-1167   FITS KX250 92-93 15T - FITS 91-93 KX250 - 13127-1201 1993 17T - FITS 88-93 KX250 - 13129-1911   FITS 90-96 KX250 – 13128-1173 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 92-99 KX250 - 16142-1117   1993 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 92-00 KX250 - 13234-1096   1993   1993
1994 KX250 KX250KE00XXXX FITS 94 KX250 - 14001-5335 - KAWI MAN SAYS 92-96 WILL FIT, 97-04 USE A LARGER SHIFT FORK PIN & 1 LESS CASE BOLT & NARROWER SHIFT DRUM JKAKXMK10RA00XXXX   FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 94 KX125 KX250 11011-1418-RG 1994 FITS 94-95 KX250 - 14073-1582 FITS 93-95 KX250 - 54011-1327 HYDRAULIC FITS 92-97 KX125 KX250 - 54012-1432 1994 KEIHIN PWK V886 - FITS 94 KX250 - 15001-1886 1994 FITS 94-95 KX250 - 16065-1292   92064-1142 JET-PILOT,#45 - 92063-1370 JET-MAIN,#165 - 16009-1762 NEEDLE-JET,NIEE 1994 1ST W/G, W/R, B/R, W, R, 2ND B, B/W, B/Y FITS 94 KX250  - 21119-1393 FITS 94-96 KX125 KX250 - 33040-1136 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1994 FITS 94-96 KX125 KX250 12053-1336 FITS 91-94 KX250 KDX250 13102-1110 FITS 94-96 KX250 13095-1278 1994 HO58 FITS 92-05 KX250 FITS 92-94 KX250 – 14032-1313 1179 1312 FITS 93-96 KX250 – 14032-1327 FITS 92-07 KX250 1994 FITS 94-96 KX250 - 13087-1153   FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 1994   F6T537 FITS 90-91 KX125 & KX250, 94 KX125 & KX250 - 21121-1181 - 21121-1234 1994 780-1220 kPa OR 114-176 PSI FITS 92-04 KX250, 89-04 KX500, 91-94 KDX250 - 14026-1174 - PLASTIC FITS 94 KX250 - 13031-1365 FITS 94-96 KX250 - 13032-1076 66.4MM BORE X 72MM STROKE FITS 92-04 KX250 4017 N/A 1994 1722 FITS 94 KX250  11005-1722 BORE 66.40 STROKE 72MM 1994     1994 FITS 94-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 94 KX250 – 18120-1055   1994 N/A 20045 N/A PK94250P * FITS 94 KX250 1994 FITS 93-94 KX250 - 12023-1066 - 12005-1185 - 13168-1499 - 12005-1184 FITS 93-94 KX250 - 12005-1182  FITS 93-94 KX250 - 12005-1183 FITS 93-00 KX250 - 14090-1219 FITS 93-04 KX250 - 14090-1249 FITS 93-03 KX250 - 14090-1226 FITS 92-97 KX250 - 21007-1234 - F4T803 71 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1994 USD - CHROME OD 43MM C/L 37.25" - GOLD UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM 43MM X 55MM X 9.5/10.5/11 1994               1994 FITS 94-95 KX125 KX250 KX500 - 55020-1492-RZ FITS 94-95 KX125 KX250 KX500 - LH 13070-1277 - RH 13070-1278 FITS 92-94 KX125 KX250 - 44037-1298 FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 1994 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM FITS 92-95 KX250 - 44039-1225 1994 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 1994 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  1994   FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342 FITS 93-98 KX125 KX250, 94-04 KX500 - 92143-1581 - 11012-1581   1994 FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220R, 97-03 KLX300R - 43041-1576 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 1994 FITS 94 KX125 KX250 KX500 - 43059-1760 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 94-95 KX125 KX250 KX500 KX80 - 43015-1556 1994 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W 1994 F-1249 - AXLE OD 20MM - 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125, KX250 & 94-04 KX500 FITS 94 KX125 KX250 - 51001-1388-6Z 1994 FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089   27T - FITS 92-04 KX250 - 59051-1248 1398 FITS 94 KX250 - 11001-1398 FITS 93-04 KX250, 91-94 KDX250 - 52014-1077 FITS 92-04 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 1994 FITS 94-01 KX250 - 13064-1186   FITS 94-95 KX250 - 13066-1090 FITS 94-95 KX250   FITS 94-02 KX125 KX250 FITS 92-95 KX125 KX250 KX500 58029-1074-6F WHITE 1994 .85 LITER = .9 QUARTS   66.4MM BORE X 72MM STROKE INNER 21S, OUTER 20T - FITS 93-98 KX250, 91-94 KDX250 13097-1308 1994 FITS 94-96 KX125 KX250 39061-1197 FITS 94-96 KX125 KX250 39061-1198     1994 GREEN - FITS 94-95 KX125, KX250 - 14037-1179-6W FITS 93-02 KX125 KX250 - 41068-1343 1994 HYDRAULIC BRAKE FITS 94 KX125 KX250, 94-95 KX500 - 43041-1532 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F FITS 92-95 KX500, 94 KX125 KX250 - 43044-1111 1994 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561   FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  FITS 94-98 KX125 KX250, 95-06 KDX200, 97-05 KDX220 - 55020-1487 1994 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 GREEN - FITS 94-98 KX125 KX250 - 35023-1362-6W 1994 R-1213 OR R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG 1994 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM   FITS 87-04 KX250 1994 FITS 94-98 KX125 & KX250 BUT THEY HAVE DIFFERENT SEAT COVERS   FITS 92-96 KX250 - 13141-1174 1994 SET FITS 94-95 KX250 - 13140-1204 13140-1205 13140-1225 SET FITS 90-95 KX250, 91-94 KDX250 - 49047-1063 49047-1080 - 9.98MM OD 1994 FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 FITS 94-96 KX250 - 13161-1200 1994 FITS 94 KX250 - 45014-1560-45 - CLICK HERE FOR MEASUREMENTS   FITS 94 & 96 KX125 KX250 39007-1228 STAMPED 93 - FITS 91-96 KX125 KX250 - 46102-1293  1994       1994   F245 FITS 94 KX250, WHITE/RED TO WHITE/GREEN 396-594, RED TO BLACK/RED 288-432, WHITE TO RED 14-21 FITS 94-04 KX250 14031-1283 FITS 94 KX125 KX250 - 32160-1308-CC 1994 FITS 94 KX125 KX250 – 33001-1442-TX FITS 94-97 KX125 KX250 - 33032-1172 FITS 92-05 KX125, 92-07 KX250 - ASY FITS 94-96 15T - FITS 94-98 KX250 13127-1227 1994     FITS 90-96 KX250 – 13128-1173 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 92-99 KX250 - 16142-1117 1082 - FITS 94-04 KX250 - 52014-1082 1994 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 92-00 KX250 - 13234-1096   1994   1994
1995 KX250 KX250KE00XXXX FITS 95 KX250 - 14001-5336 - KAWI MAN SAYS 92-96 WILL FIT, 97-04 USE A LARGER SHIFT FORK PIN & 1 LESS CASE BOLT & NARROWER SHIFT DRUM JKAKXMK16SA00XXXX   FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 95 KX125 KX250 11011-1446-RG 1995 FITS 94-95 KX250 - 14073-1582 FITS 93-95 KX250 - 54011-1327 HYDRAULIC FITS 92-97 KX125 KX250 - 54012-1432 1995 KEIHIN PWK G096 - FITS 95 KX250 - 15003-1096 1995 FITS 94-95 KX250 - 16065-1292   92064-1142 JET-PILOT,#45 - 92063-1368 JET-MAIN,#160 - 16009-1757 NEEDLE-JET,NOZE 1995 FITS 95 KX250  – 21119-1431 FITS 94-96 KX125 KX250 - 33040-1136 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1995 FITS 94-96 KX125 KX250 12053-1336 FITS 95-96 KX250 13102-1126 FITS 94-96 KX250 13095-1278 1995 HO58 FITS 92-05 KX250 FITS 95-98 KX250 – 14032-1391 1179 1312 FITS 93-96 KX250 – 14032-1327 FITS 92-07 KX250 1995 FITS 94-96 KX250 - 13087-1153 13091-1728 92170-1226 FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 1995   FITS 95-98 KX250 - 21121-1248 1995 780-1220 kPa OR 114-176 PSI FITS 92-04 KX250, 89-04 KX500, 91-94 KDX250 - 14026-1174 - PLASTIC FITS 95-96 KX250 - 13031-1390 FITS 94-96 KX250 - 13032-1076 66.4MM BORE X 72MM STROKE FITS 92-04 KX250 4017 N/A 1995 1751 FITS 95 KX250  11005-1751 BORE 66.40 STROKE 72MM 1995     1995 FITS 94-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 95 KX250  – 18120-1064   1995 20058 N/A N/A PK95250P - FITS 95-97 KX250 1995 FITS 95-96 KIX250 - 12005-1203 FITS 95-97 KX250 - 12005-1242 FITS 95-97 KX250 - 12005-1243 FITS 93-00 KX250 - 14090-1219 FITS 93-04 KX250 - 14090-1249 FITS 93-03 KX250 - 14090-1226 FITS 92-97 KX250 - 21007-1234 - F4T803 71 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1995 USD - CHROME OD 43MM - C/L 37.25" - GOLD UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE ID 25MM 43MM X 55MM X 9.5/10.5/11 1995               1995 FITS 94-95 KX125 KX250 KX500 - 55020-1492-RZ FITS 94-95 KX125 KX250 KX500 - LH 13070-1277 - RH 13070-1278 FITS 95 KX125 KX250 - 44037-1329 FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 1995 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM FITS 92-95 KX250 - 44039-1225 1995 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 1995 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  1995   FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342 FITS 93-98 KX125 KX250, 94-04 KX500 - 92143-1581 - 11012-1581   1995 FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220R, 97-03 KLX300R - 43041-1576 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 1995 FITS 95 KX125 KX250 KX500 - 43059-1881 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 94-95 KX125 KX250 KX500 KX80 - 43015-1556 1995 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W 1995 F-1249 - AXLE OD 20MM - 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125, KX250 & 94-04 KX500 FITS 95 KX125 KX250 – 51001-1468-6Z 1995 FITS 87-95 KX125 KX250 KX500, 88-95 KX80, 89-95 KDX200, 91-94 KDX250, 93-95 KLX650, 94 KLX250 - 51049-1089   27T - FITS 92-04 KX250 - 59051-1248 1425 FITS 95-02 KX250 - 11001-1425 FITS 93-04 KX250, 91-94 KDX250 - 52014-1077 FITS 92-04 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 1995 FITS 94-01 KX250 - 13064-1186   FITS 94-95 KX250 - 13066-1090 FITS 94-95 KX250 FITS 95-02 KX125 KX250, 96-04 KX500, 95-06 KDX200, 97-05 KDX220, 27010-1350 FITS 94-02 KX125 KX250 FITS 92-95 KX125 KX250 KX500 58029-1074-6F WHITE 1995     66.4MM BORE X 72MM STROKE INNER 21S, OUTER 20T - FITS 93-98 KX250, 91-94 KDX250 13097-1308 1995 FITS 94-96 KX125 KX250 39061-1197 FITS 94-96 KX125 KX250 39061-1198 FITS 95 KX125 KX250 - 49089-5232-6W FITS 95 KX125 KX250 - 49089-5233-6W 1995 GREEN - FITS 94-95 KX125, KX250 - 14037-1179-6W FITS 93-02 KX125 KX250 - 41068-1343 1995 HYDRAULIC BRAKE FITS 95-96 KX125 KX250, 96-03 KX500, 96 KLX650R, 97-03 KLX300R - 43041-1577 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F FITS 95-96 KX125 KX250, 96-04 KX500, 96 KLX650R, 97-07 KLX300R - 14079-1105  1995 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 95-96 KX125 KX250 - 43001-1360 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  FITS 94-98 KX125 KX250, 95-06 KDX200, 97-05 KDX220 - 55020-1487 1995 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 GREEN - FITS 94-98 KX125 KX250 - 35023-1362-6W 1995 R-1213 OR R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG 1995 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM FITS 95-96 KX250 - 12022-1075 FITS 87-04 KX250 1995 FITS 94-98 KX125 & KX250 BUT THEY HAVE DIFFERENT SEAT COVERS   FITS 92-96 KX250 - 13141-1174 1995 SET FITS 94-95 KX250 - 13140-1204 13140-1205 13140-1225 SET FITS 90-95 KX250, 91-94 KDX250 - 49047-1063 49047-1080 - 9.98MM OD 1995 FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 FITS 94-96 KX250 - 13161-1200 1995 KYB  - SPRING THICKNESS: 11.5MM OD - SPRING OD: 88MM - BODY OD 55.6MM - SPRING LENGTH AS MOUNTED: 265MM - UPPER MOUNT TAB WIDTH: 22MM - UPPER MOUNT TAB HOLE ID: 10MM - LOWER MOUNT OUTSIDE WIDTH: 41.7MM - LOWER MOUNT INSIDE WIDTH 22.7MM - LOWER MOUNT HOLE ID: 10MM - EYE TO EYE: 457MM - 45014-1594-45   1231 - FITS 95 KX125 & KX250 - 39007-1231 STAMPED 93 - FITS 91-96 KX125 KX250 - 46102-1293  1995   WHITE FITS 95-98 KX125 KX250 - 36001-1538-6F WHITE FITS 95-98 KX125 KX250 - 36001-1539-6F 1995   F4T80373 FITS 95-97 KX250 - 21003-1293 - WHITE/RED TO WHITE/GREEN 396-594, RED TO BLACK/RED 288-432, WHITE TO RED 14-21 FITS 94-04 KX250 14031-1283 FITS 95-97 KX125 KX250 32160-1397-CC 1995 FITS 95 KX125 KX250 – 33001-1464-TX FITS 94-97 KX125 KX250 - 33032-1172 FITS 92-05 KX125, 92-07 KX250 - ASY FITS 94-96 15T - FITS 94-98 KX250 13127-1227 1995     FITS 90-96 KX250 – 13128-1173 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 92-99 KX250 - 16142-1117 1082 - FITS 94-04 KX250 - 52014-1082 1995 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 92-00 KX250 - 13234-1096   1995 55LB WITH SPARK PLUG, KICK LEVER, REED, AND BOOT, NO CARB. NO OIL, SHIFT LEVER 1995
1996 KX250 KX250KE00XXXX FITS 96 KX250 - 14001-1207 - KAWI MAN SAYS 92-96 WILL FIT, 97-04 USE A LARGER SHIFT FORK PIN & 1 LESS CASE BOLT & NARROWER SHIFT DRUM JKAKXM---TA0-----   FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 96-97 KX125 KX250 11011-1472-RG 1996 1649 - FITS 96-98 KX250 - 14073-1649 FITS 96 KX250 - 54011-1357 HYDRAULIC FITS 92-97 KX125 KX250 - 54012-1432 1996 KEIHIN PWK G202 - FITS 96 KX250 - 15003-1202 1996 FITS 96 KX250 - 16065-1315   92064-1142 JET-PILOT,#45 - 92063-1368 JET-MAIN,#160 - 16009-1761 NEEDLE-JET,NIED 1996 FITS 96 KX250  – 21119-1452 FITS 94-96 KX125 KX250 - 33040-1136 FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 1996 FITS 94-96 KX125 KX250 12053-1336 FITS 95-96 KX250 13102-1126 FITS 94-96 KX250 13095-1278 1996 HO58 FITS 92-05 KX250 FITS 95-98 KX250 – 14032-1391 1179 1312 FITS 93-96 KX250 – 14032-1327 FITS 92-07 KX250 1996 FITS 94-96 KX250 - 13087-1153   FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 1996   FITS 95-98 KX250 - 21121-1248 1996 780-1220 kPa OR 114-176 PSI FITS 92-04 KX250, 89-04 KX500, 91-94 KDX250 - 14026-1174 - PLASTIC FITS 95-96 KX250 - 13031-1390 FITS 94-96 KX250 - 13032-1076 66.4MM BORE X 72MM STROKE FITS 92-04 KX250 4017 N/A 1996 1793 FITS 96 KX250  11005-1793 BORE 66.40 STROKE 72MM 1996     1996 FITS 94-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 96 KX250  – 18120-1067 FITS 96 KX250 - 18100-1068 1996 20058 N/A N/A PK95250P - FITS 95-97 KX250 1996 FITS 95-96 KIX250 - 12005-1203 FITS 95-97 KX250 - 12005-1242 FITS 95-97 KX250 - 12005-1243 FITS 93-00 KX250 - 14090-1219 FITS 93-04 KX250 - 14090-1249 FITS 93-03 KX250 - 14090-1226 FITS 92-97 KX250 - 21007-1234 - F4T803 71 FITS 92-96 KX125 KX250, 93-04 KX500, 92-94 KDX250, 95-05 KDX200, 97-05 KDX220 - 34028-1332-CE 34028-1365-CE FITS 88-04 KX500, 88-96 KX125 KX250, 91 93-94 KDX250, 95-05 KDX200, 97-05 KDX220 1996 USD – KYB – KX94 L KX94 R – CHROME OD 46MM – C/L 37 1/8” - UPPER 53.9MM – LOWER 58.9MM – BRAKE MOUNT C/L 102MM – AXLE CLAMP 20MM & 25MM 46MM X 58MM X 10.5 1996     FITS 96-97 KX125 KX250, 97-04 KX500 - 44013-1413 FITS 96-97 KX125 KX250, 97-04 KX500 - 44013-1414 FITS 96-97 KX125 KX250, 97-02 KX500 - 44008-1037-14 FITS 96-98 KX125, 96-97 KX250 - 44028-1096 FITS 96-98 KX125 KX250, 97-04 KX500 - 44029-1159 1996     FITS 96-97 kx125 kx250 - 44037-1338 FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 1996 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM FITS 96-98 KX250 44039-1262 1996 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 1996 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  1996   FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342 FITS 93-98 KX125 KX250, 94-04 KX500 - 92143-1581 - 11012-1581   1996 FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 97-03 KDX220R, 97-03 KLX300R - 43041-1576 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 1996 FITS 96 KX125 KX250, 96-04 KX500 - 43059-1913 FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 FITS 96 KX125 KX250 KX500 - 43015-1574 1996 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W 1996 F-1249 - AXLE OD 20MM - 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125, KX250 & 94-04 KX500 FITS 96-98 KX125 KX250 - 51001-1489-6Z 1996     27T - FITS 92-04 KX250 - 59051-1248 1425 FITS 95-02 KX250 - 11001-1425 FITS 93-04 KX250, 91-94 KDX250 - 52014-1077 FITS 92-04 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 1996 FITS 94-01 KX250 - 13064-1186   FITS 96-98 KX250 - 13066-1091 FITS 96-97 KX250 FITS 95-02 KX125 KX250, 96-04 KX500, 95-06 KDX200, 97-05 KDX220, 27010-1350 FITS 94-02 KX125 KX250 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 1996   FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 66.4MM BORE X 72MM STROKE INNER 21S, OUTER 20T - FITS 93-98 KX250, 91-94 KDX250 13097-1308 1996 FITS 94-96 KX125 KX250 39061-1197 FITS 94-96 KX125 KX250 39061-1198 FITS 96 KX125 KX250   1996   FITS 93-02 KX125 KX250 - 41068-1343 1996 HYDRAULIC BRAKE FITS 95-96 KX125 KX250, 96-03 KX500, 96 KLX650R, 97-03 KLX300R - 43041-1577 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F FITS 95-96 KX125 KX250, 96-04 KX500, 96 KLX650R, 97-07 KLX300R - 14079-1105  1996 FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 FITS 95-96 KX125 KX250 - 43001-1360 FITS 94-96 KX125 KX250, 93-96 KLX650, 96 KLX650R, 95-03 KDX200, 97-03 KDX220 - 43015-1515  FITS 94-98 KX125 KX250, 95-06 KDX200, 97-05 KDX220 - 55020-1487 1996 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 GREEN - FITS 94-98 KX125 KX250 - 35023-1362-6W 1996 R-1213 OR R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM – ROTOR BC 6X ON 116MM – 36 SPOKES - FITS 90-94 KDX200, 90-96 KX125 KX250 KX500 - 2 BRG 1996 FITS 90-96 KX125 KX250 KX500 - 92143-1356 - ID 20.26MM, MAJ OD 36.06MM, MINOR OD 25MM, LENGTH 19.63MM FITS 95-96 KX250 - 12022-1075 FITS 87-04 KX250 1996 FITS 94-98 KX125 & KX250 BUT THEY HAVE DIFFERENT SEAT COVERS   FITS 92-96 KX250 - 13141-1174 1996 SET FITS 96-01 KX250 13140-1248 13140-1249 13140-1250 SET FITS 96-00 KX250 - 49047-1092 - 49047-1093 - 11.89MM OD 1996 FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 FITS 94-96 KX250 - 13161-1200 1996 KYB  - SPRING THICKNESS: 11.7MM OD - SPRING OD: 87MM - BODY OD 55.5MM - SPRING LENGTH AS MOUNTED: 262MM - UPPER MOUNT TAB WIDTH: 22MM - UPPER MOUNT TAB HOLE ID: 10MM - LOWER MOUNT OUTSIDE WIDTH: 41.2MM - LOWER MOUNT INSIDE WIDTH 22.4MM - LOWER MOUNT HOLE ID: 10MM - EYE TO EYE: 457MM    FITS 94 & 96 KX125 KX250 39007-1228 STAMPED 93 - FITS 91-96 KX125 KX250 - 46102-1293  1996   WHITE FITS 95-98 KX125 KX250 - 36001-1538-6F WHITE FITS 95-98 KX125 KX250 - 36001-1539-6F 1996   F4T80373 FITS 95-97 KX250 - 21003-1293 - WHITE/RED TO WHITE/GREEN 396-594, RED TO BLACK/RED 288-432, WHITE TO RED 14-21 FITS 94-04 KX250 14031-1283 FITS 95-97 KX125 KX250 32160-1397-CC 1996 FITS 96 KX125 KX250 – 33001-1487-TX FITS 94-97 KX125 KX250 - 33032-1172 FITS 92-05 KX125, 92-07 KX250 - ASY FITS 94-96 15T - FITS 94-98 KX250 13127-1227 1996     FITS 90-96 KX250 – 13128-1173 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 92-99 KX250 - 16142-1117 1082 - FITS 94-04 KX250 - 52014-1082 1996 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 92-00 KX250 - 13234-1096   1996   1996
1997 KX250 KX250KE0XXXXX FITS 97-99 KX250 - 14001-1241 - KAWI MAN SAYS 97-01 ALL INTERCHANGE JKAKXMK18VA02XXXX   FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 96-97 KX125 KX250 11011-1472-RG 1997 1649 - FITS 96-98 KX250 - 14073-1649 FITS 97-98 KX250 - 54011-1365 HYDRAULIC FITS 92-97 KX125 KX250 - 54012-1432 1997 KEIHIN PWK G279 - FITS 97 KX250 - 15003-1279 1997 FITS 97-98 KX250 - 16065-1334   92064-1142 JET-PILOT,#45 - 92063-1370 JET-MAIN,#165 - 16009-1916 NEEDLE-JET,N3WF 1997 FITS 97 KX250  – 21119-1492 FITS 97-02 KX125 KX250 - 33040-1156 FITS 97-02 KX125 KX250 1997 FITS 97-98 KX125 KX250 12053-1375 FITS 97-98 KX250 13102-1137 FITS 97-98 KX250 13095-1343 1997 HO58 FITS 92-05 KX250 FITS 95-98 KX250 – 14032-1391 1179 – FITS 97-99 KX250 - 14032-1443 - MISSING ONE CASE BOLT FITS 92-07 KX250 1997 1139 - FITS 97-07 KX250 – 13087-1168   FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 1997 FITS 97-98 KX250 - 13116-1156 FITS 95-98 KX250 - 21121-1248 1997 780-1220 kPa OR 114-176 PSI FITS 92-04 KX250, 89-04 KX500, 91-94 KDX250 - 14026-1174 - PLASTIC FITS 97 KX250 - 13031-1415 FITS 97 KX250 - 13032-1224 66.4MM BORE X 72MM STROKE FITS 92-04 KX250 4017 N/A 1997 1835 FITS 97 KX250  11005-1835 BORE 66.40 STROKE 72MM 1997     1997 FITS 94-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-98 KX250 – 18120-1070   1997 20059 20054 N/A PK95250P - FITS 95-97 KX250 1997 FITS 97 KX250 FITS 95-97 KX250 - 12005-1242 FITS 95-97 KX250 - 12005-1243 FITS 93-00 KX250 - 14090-1219 FITS 93-04 KX250 - 14090-1249 FITS 93-03 KX250 - 14090-1226 FITS 92-97 KX250 - 21007-1234 - F4T803 71 FITS 97-01 KX125 & KX250 34028-1475-CE 34028-1476-CE FITS 97-00 KX125 KX250 - 92144-1951 1997 USD - CHROME OD 46MM C/L 37.25" – UPPER 53.9MM – LOWER 58.9MM  - BRAKE MOUNT C/L 102MM – AXLE CLAMP 20MM & 25MM 46MM X 58MM X 10.5 1997 FITS 97 KX125 KX250 - 44023-1112   FITS 96-97 KX125 KX250, 97-04 KX500 - 44013-1413 FITS 96-97 KX125 KX250, 97-04 KX500 - 44013-1414 FITS 96-97 KX125 KX250, 97-02 KX500 - 44008-1037-14 FITS 96-98 KX125, 96-97 KX250 - 44028-1096 FITS 96-98 KX125 KX250, 97-04 KX500 - 44029-1159 1997 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 FITS 96-97 kx125 kx250 - 44037-1338 FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 1997 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM FITS 96-98 KX250 44039-1262 1997 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 1997 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  1997 FITS 97 KX125 KX250 - 49116-1147 FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342 FITS 93-98 KX125 KX250, 94-04 KX500 - 92143-1581 - 11012-1581   1997 FITS 97-98 KX125 KX250 - 43041-1605 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 1997 FITS 97-98 KX125 KX250 - 43059-1950 FITS 97-00 KX100, 97-99 KX125 KX250, 97-03 KX500, 97-00 KX80 46092-1191 304 - FITS 97-99 KX125 KX250 - 43015-1582 1997 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W 1997 F-1249 - AXLE OD 20MM - 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125, KX250 & 94-04 KX500 FITS 96-98 KX125 KX250 - 51001-1489-6Z 1997     27T - FITS 92-04 KX250 - 59051-1248 1425 FITS 95-02 KX250 - 11001-1425 FITS 93-04 KX250, 91-94 KDX250 - 52014-1077 FITS 92-04 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 1997 FITS 94-01 KX250 - 13064-1186   FITS 96-98 KX250 - 13066-1091 FITS 96-97 KX250 FITS 95-02 KX125 KX250, 96-04 KX500, 95-06 KDX200, 97-05 KDX220, 27010-1350 FITS 94-02 KX125 KX250 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 1997   FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 66.4MM BORE X 72MM STROKE INNER 21S, OUTER 20T - FITS 93-98 KX250, 91-94 KDX250 13097-1308 1997 FITS 97 KX125 KX250 39061-1229 FITS 97 KX125 KX250 39061-1230     1997 FITS 97-05 KX125, 97-04 KX250 - 14037-1310-RZ FITS 93-02 KX125 KX250 - 41068-1343 1997 HYDRAULIC BRAKE FITS 97-98 KX125 KX250 - 43041-1606 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F 1118 - FITS 97-02 KX125 KX250 - 14079-1111 1997   FITS 97-98 KX125 & KX250 - 43001-1382 FITS 97-01 KX125 KX250, 43015-1597 FITS 94-98 KX125 KX250, 95-06 KDX200, 97-05 KDX220 - 55020-1487 1997 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 GREEN - FITS 94-98 KX125 KX250 - 35023-1362-6W 1997 R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - 97-98 KX125 & 250, 97-04 KX500 - 3 BRG - 41034-1270 1997 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM   FITS 87-04 KX250 1997 FITS 94-98 KX125 & KX250 BUT THEY HAVE DIFFERENT SEAT COVERS   FITS 97-02 KX250 - 13141-1200 - SM OD 13.91 - LG OD 24.96 - OAL 74.42 1997 SET FITS 96-01 KX250 13140-1248 13140-1249 13140-1250 SET FITS 96-00 KX250 - 49047-1092 - 49047-1093 - 11.89MM OD 1997 FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 FITS 97-99 KX250 - 13161-1252 1997     FITS 97 KX125 KX250 - 39007-1243 FITS 97-01 KX125 KX250 - 46102-1404 - EYE TO EYE 123.5MM, 15MM ID - STAMPED 04 1997 K=4.9 - 11.45MM WHITE FITS 95-98 KX125 KX250 - 36001-1538-6F WHITE FITS 95-98 KX125 KX250 - 36001-1539-6F 1997   F4T80373 FITS 95-97 KX250 - 21003-1293 - WHITE/RED TO WHITE/GREEN 396-594, RED TO BLACK/RED 288-432, WHITE TO RED 14-21 FITS 94-04 KX250 14031-1283 FITS 95-97 KX125 KX250 32160-1397-CC 1997 FITS 97-98 KX250 - 33001-1512-TX FITS 94-97 KX125 KX250 - 33032-1172 FITS 92-05 KX125, 92-07 KX250 - ASY FITS 97-98 15T - FITS 94-98 KX250 13127-1227 1997     FITS 97-98 KX250 – 13128-1215 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 92-99 KX250 - 16142-1117 1082 - FITS 94-04 KX250 - 52014-1082 1997 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 92-00 KX250 - 13234-1096   1997   1997
1998 KX250 KX250KE0XXXXX FITS 97-99 KX250 - 14001-1241 - KAWI MAN SAYS 97-01 ALL INTERCHANGE JKAKXMKC5WA03XXXX   FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 98 KX125 KX250 11011-1534-RG 1998 1649 - FITS 96-98 KX250 - 14073-1649 FITS 97-98 KX250 - 54011-1365 HYDRAULIC FITS 98 KX125 KX250 - 54012-1561 1998 KEIHIN PWK G342 - FITS 98 KX250 - 38MM ID 1998 FITS 97-98 KX250 - 16065-1334   92064-1142 JET-PILOT,#45 - 92063-1367 JET-MAIN,#158 - 16009-1759 NEEDLE-JET, N0ZG - 16159-1054 JET-POWER,#55 1998 DENSO 071000-1260/1261 21119-1507/1522 FITS 97-02 KX125 KX250 - 33040-1156 FITS 97-02 KX125 KX250 1998 FITS 97-98 KX125 KX250 12053-1375 FITS 97-98 KX250 13102-1137 FITS 97-98 KX250 13095-1343 1998 HO58 FITS 92-05 KX250 FITS 95-98 KX250 – 14032-1391 1179 – FITS 97-99 KX250 - 14032-1443 - MISSING ONE CASE BOLT FITS 92-07 KX250 1998 1139 - FITS 97-07 KX250 – 13087-1168   FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 1998 FITS 97-98 KX250 - 13116-1156 FITS 95-98 KX250 - 21121-1248 1998 780-1220 kPa OR 114-176 PSI FITS 92-04 KX250, 89-04 KX500, 91-94 KDX250 - 14026-1174 - PLASTIC FITS 98-99 KX250 - 13031-1434 FITS 98-99 KX250 - 13032-1236  66.4MM BORE X 72MM STROKE FITS 92-04 KX250 4017 N/A 1998 1851 FITS 98-99 KX250 11005-1851 BORE 66.40 STROKE 72MM 1998     1998 FITS 94-98 KX250, 95-06 KDX200, 97-05 KDX2250 - 32029-1944 FITS 97-98 KX250 – 18120-1070   1998 20059 20054 N/A   1998 FITS 98 KX250 - 49116-1159 FITS 98 KX250 - 12005-1252 FITS 98 KX250 - 12005-1253 FITS 93-00 KX250 - 14090-1219 FITS 93-04 KX250 - 14090-1249 FITS 93-03 KX250 - 14090-1226 DENSO 032000-9070 - FITS 98 KX250 - 21007-1328 FITS 97-01 KX125 & KX250 34028-1475-CE 34028-1476-CE FITS 97-00 KX125 KX250 - 92144-1951 1998 USD - KYB - CHROME OD 46MM - C/L 37.25" - UPPER 53.9MM - LOWER 58.4MM - BRAKE MOUNT C/L 102MM - AXLE CLAMP 20MM & 25MM 46MM X 58MM X 10.5 1998             FITS 96-98 KX125 KX250, 97-04 KX500 - 44029-1159 1998 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 FITS 98-00 KX125 KX250 44037-1371 FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 1998 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM FITS 96-98 KX250 44039-1262 1998 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 1998 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  1998   FITS 93-98 KX125 & KX250, 94-04 KX500 – 41068-1342 FITS 93-98 KX125 KX250, 94-04 KX500 - 92143-1581 - 11012-1581   1998 FITS 97-98 KX125 KX250 - 43041-1605 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 1998 FITS 97-98 KX125 KX250 - 43059-1950 FITS 97-00 KX100, 97-99 KX125 KX250, 97-03 KX500, 97-00 KX80 46092-1191 304 - FITS 97-99 KX125 KX250 - 43015-1582 1998 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W 1998 F-1249 - AXLE OD 20MM - 89.5MM - ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-98 KX125, KX250 & 94-04 KX500 FITS 96-98 KX125 KX250 - 51001-1489-6Z 1998   FITS 98-99 KX250 - 59051-1277 - 49111-1060 - 13070-1206 - 49114-1074 - 39129-1018 -  27T - FITS 92-04 KX250 - 59051-1248 1425 FITS 95-02 KX250 - 11001-1425 FITS 93-04 KX250, 91-94 KDX250 - 52014-1077 FITS 92-04 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 1998 FITS 94-01 KX250 - 13064-1186   FITS 96-98 KX250 - 13066-1091 Verified, it will fit 98-01 FITS 95-02 KX125 KX250, 96-04 KX500, 95-06 KDX200, 97-05 KDX220, 27010-1350 FITS 94-02 KX125 KX250 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 1998 .85 LITER = .9 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 66.4MM BORE X 72MM STROKE INNER 21S, OUTER 20T - FITS 93-98 KX250, 91-94 KDX250 13097-1308 1998 FITS 98 KX125 KX250 39061-1257 FITS 98 KX125 KX250 39061-1258     1998 FITS 97-05 KX125, 97-04 KX250 - 14037-1310-RZ FITS 93-02 KX125 KX250 - 41068-1343 1998 HYDRAULIC BRAKE FITS 97-98 KX125 KX250 - 43041-1606 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F 1118 - FITS 97-02 KX125 KX250 - 14079-1111 1998   FITS 97-98 KX125 & KX250 - 43001-1382 FITS 97-01 KX125 KX250, 43015-1597 FITS 94-98 KX125 KX250, 95-06 KDX200, 97-05 KDX220 - 55020-1487 1998 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 GREEN - FITS 94-98 KX125 KX250 - 35023-1362-6W 1998 R-1237 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - 97-98 KX125 & 250, 97-04 KX500 - 3 BRG - 41034-1270 1998 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM FITS 98 KX250 - 12021-1112 FITS 87-04 KX250 1998 FITS 94-98 KX125 & KX250 BUT THEY HAVE DIFFERENT SEAT COVERS   FITS 97-02 KX250 - 13141-1200 - SM OD 13.91 - LG OD 24.96 - OAL 74.42 1998 SET FITS 96-01 KX250 13140-1248 13140-1249 13140-1250 SET FITS 96-00 KX250 - 49047-1092 - 49047-1093 - 11.89MM OD 1998 FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 FITS 97-99 KX250 - 13161-1252 1998 KYB  - SPRING THICKNESS: 11.7MM OD - SPRING OD: 87MM - BODY OD 53.75MM - SPRING LENGTH AS MOUNTED: 260MM - UPPER MOUNT TAB WIDTH: 22MM - UPPER MOUNT TAB HOLE ID: 10MM - LOWER MOUNT OUTSIDE WIDTH: 41.6MM - LOWER MOUNT INSIDE WIDTH 22.6MM - LOWER MOUNT HOLE ID: 10MM - EYE TO EYE: 457MM    FITS 98 KX125 & KX250 - 39007-1255 FITS 97-01 KX125 KX250 - 46102-1404 - EYE TO EYE 123.5MM, 15MM ID - STAMPED 04 1998   WHITE FITS 95-98 KX125 KX250 - 36001-1538-6F WHITE FITS 95-98 KX125 KX250 - 36001-1539-6F 1998   21003-1322A FITS 98 KX250, WHITE/YELLOW TO GREEN/WHITE 180-380, RED TO WHITE 7-15 FITS 94-04 KX250 14031-1283 FITS 98 KX125 KX250 - 32160-1512-CC 1998 FITS 97-98 KX250 - 33001-1512-TX FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 FITS 92-05 KX125, 92-07 KX250 - ASY FITS 97-98 15T - FITS 94-98 KX250 13127-1227 1998     FITS 97-98 KX250 – 13128-1215 32T - FITS 80-98 KX250, 84-87 KXT250 - 13129-1160     FITS 92-99 KX250 - 16142-1117 1082 - FITS 94-04 KX250 - 52014-1082 1998 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 92-00 KX250 - 13234-1096   1998   1998
1999 KX250 KX250LE00XXXX FITS 97-99 KX250 - 14001-1241 - KAWI MAN SAYS 97-01 ALL INTERCHANGE JKAKXMLC8XA00XXXX kx250lla01100 FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 99-02 KX125 KX250 11011-1557-6D 1999 1743 - FITS 99-02 KX250 - 14073-1743 FITS 99-04 KX250 - 54011-1389 HYDRAULIC FITS 99-03 KX125 KX250 - 54012-1598 1999 KEIHIN PWK G490 - FITS 99 KX250 - 38MM ID 1999 FITS 99-02 KX250 - 16065-1358   92064-1142 JET-PILOT,#45 - 92063-1367 JET-MAIN,#158 - 16187-1074 NEEDLE-JET,N3YK - 16159-1054 JET-POWER,#55 1999 DENSO 071000-1440 21119-1525 FITS 99 KX250 - Timing 11* BTDC @ 7000 RPM FITS 97-02 KX125 KX250 - 33040-1156 FITS 97-02 KX125 KX250 1999 FITS 99-03 KX125 KX250 12053-1422 FITS 99-00 KX250 13102-1146 FITS 99-01 KX250 13095-1368 1999 HO58 FITS 92-05 KX250 FITS 99-02 KX250 – 14032-1483 1179 – FITS 97-99 KX250 - 14032-1443 - MISSING ONE CASE BOLT FITS 92-07 KX250 1999 1139 - FITS 97-07 KX250 – 13087-1168   FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 1999   FITS 99-02 KX250 - 21121-1281 1999 780-1220 kPa OR 114-176 PSI FITS 92-04 KX250, 89-04 KX500, 91-94 KDX250 - 14026-1174 - PLASTIC FITS 98-99 KX250 - 13031-1434 FITS 98-99 KX250 - 13032-1236  66.4MM BORE X 72MM STROKE FITS 92-04 KX250 4017 N/A 1999 1851 FITS 98-99 KX250 11005-1851 BORE 66.40 STROKE 72MM 1999     1999 FITS 99-02 KX250 - 32190-1165 FITS 99-00 KX250 – 18120-1087 FITS 99-00 KX250 - 18100-1078 1999 20059 20054 N/A PK99250P - FITS 99 KX250 1999 FITS 99 KX250 - 49116-1173 FITS 99-04 KX250 - 12005-1284 FITS 99-04 KX250 - 12005-1285  FITS 93-00 KX250 - 14090-1219 FITS 93-04 KX250 - 14090-1249 FITS 93-03 KX250 - 14090-1226 DENSO 032000-9330 - FITS 99 KX250 - 21007-1350 - 4.9KG FITS 97-01 KX125 & KX250 34028-1475-CE 34028-1476-CE FITS 97-00 KX125 KX250 - 92144-1951 1999 USD - KYB - K312-L K312-R - CHROME OD 46MM - C/L 37.375" - UPPER 54.9MM - LOWER 58.4MM - BRAKE MOUNT C/L 102MM - AXLE 20MM & 25MM 46MM X 58MM X 10.5 1999               1999 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 FITS 98-00 KX125 KX250 44037-1371 FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 1999 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM FITS 99-00 KX250 44039-1293 - 190MM FROM C/L TO C/L OF FORK TUBES 1999 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 1999 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  1999   FITS 99-03 KX125 & 250 – 41068-1406     1999 FITS 99 KX125 KX250 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 1999 FITS 99-00 KX125 KX250 - 43095-1132 FITS 97-00 KX100, 97-99 KX125 KX250, 97-03 KX500, 97-00 KX80 46092-1191 304 - FITS 97-99 KX125 KX250 - 43015-1582 1999 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W 1999 F-1249 - 20MM AXLE DIA - BRG TO BRG 90MM - ROTOR 4 BOLTS ON A 115MM BC- FITS 99-02 KX125 & 250 - 41034-1300 BLACK - 51001-1547 - FITS 99-02 KX125 KX250 - 51001-1547-6Z 1999 FITS 99-04 KX250, 99-05 KX125, 00-07 KX65, 01-05 KX85, 02-05 KLX110 - 51048-1124  FITS 98-99 KX250 - 59051-1277 - 49111-1060 - 13070-1206 - 49114-1074 - 39129-1018 -  27T - FITS 92-04 KX250 - 59051-1248 1425 FITS 95-02 KX250 - 11001-1425 FITS 93-04 KX250, 91-94 KDX250 - 52014-1077 FITS 92-04 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 1999 FITS 94-01 KX250 - 13064-1186   FITS 99-01 KX250 - 13066-1099 Verified, it will fit 98-01 FITS 95-02 KX125 KX250, 96-04 KX500, 95-06 KDX200, 97-05 KDX220, 27010-1350 FITS 94-02 KX125 KX250 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 1999   FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 66.4MM BORE X 72MM STROKE INNER 21S, OUTER 20T - FITS 99-01 KX250 - 13097-1402 1999 FITS 99-02 KX125 KX250 39061-1262 FITS 99-02 KX125 KX250 39061-1263 FITS 99-02 KX125 KX250, LH 49089-1140-6W FITS 99-02 KX125 KX250, RH 49089-1141-6W 1999 FITS 97-05 KX125, 97-04 KX250 - 14037-1310-RZ FITS 93-02 KX125 KX250 - 41068-1343 1999 HYDRAULIC BRAKE 86E - FITS 99 KX125 KX250 - 43041-1687 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F 1118 - FITS 97-02 KX125 KX250 - 14079-1111 1999 FITS 99-01 KX250 43095-1134 FITS 99 KX125 KX250 - 43077-1085 FITS 97-01 KX125 KX250, 43015-1597   1999 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 GREEN - FITS 99 KX125 KX250 - 35023-1505-6W 1999 R-1287 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - FITS 99-02 KX125, 250 - 3 BRG 1999 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM   FITS 87-04 KX250 1999 FITS 99 KX125 KX250 - LOW 53001-1879-MH - HIGH 53001-1880-MH FITS 99-02 KX125 KX250 FITS 97-02 KX250 - 13141-1200 - SM OD 13.91 - LG OD 24.96 - OAL 74.42 1999 SET FITS 96-01 KX250 13140-1248 13140-1249 13140-1250 SET FITS 96-00 KX250 - 49047-1092 - 49047-1093 - 11.89MM OD 1999 FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 FITS 97-99 KX250 - 13161-1252 1999   1277 - FITS 99-01 KX125 & KX250 - 39007-1277 FITS 97-01 KX125 KX250 - 46102-1404 - EYE TO EYE 123.5MM, 15MM ID - STAMPED 04 1999   WHITE - FITS 99-01 KX125 KX250, LH 36001-1627-6F WHITE - FITS 99-01 KX125 KX250,  RH 36001-1628-6F 1999   FITS 99-00 KX250 21003-1340 FITS 94-04 KX250 14031-1283 FITS 99 KX125 KX250 - 32160-1547-CC 1999 FITS 99 KX250 - 33001-1557-TX FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 FITS 92-05 KX125, 92-07 KX250 - ASY 1999 15T - FITS 99-02 KX250 - 13127-1267 1999     FITS 99-02 KX250 – 13128-1232     SH542-12 FITS 99 KX125 KX250 - 21066-1116 FITS 92-99 KX250 - 16142-1117 1082 - FITS 94-04 KX250 - 52014-1082 1999 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 92-00 KX250 - 13234-1096 FITS 99 KX125 KX250 - 26030-1655 1999   1999
2000 KX250 KX250LE01XXXX FITS 00-01 KX250  - 14001-1282 - KAWI MAN SAYS 97-01 ALL INTERCHANGE JKAKXMLC6YA01XXXX JKAKX250LLA FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 99-02 KX125 KX250 11011-1557-6D 2000 1743 - FITS 99-02 KX250 - 14073-1743 FITS 99-04 KX250 - 54011-1389 HYDRAULIC FITS 99-03 KX125 KX250 - 54012-1598 2000 KEIHIN PWK G524 38MM FITS 00 KX250  15003-1524 2000 FITS 99-02 KX250 - 16065-1358   92064-1130 JET-PILOT,#52 - 92063-1368 JET-MAIN,#160 - 16009-1915 NEEDLE-JET,N3WE - 16159-1058 JET-POWER,#48 2000 DENSO 071000-1610 21119-1548 FITS 2000 KX250  21119-1548 - Timing 13* BTDC @ 7000 RPM FITS 97-02 KX125 KX250 - 33040-1156 FITS 97-02 KX125 KX250 2000 FITS 99-03 KX125 KX250 12053-1422 FITS 99-04 KX250 13102-1154 FITS 99-01 KX250 13095-1368 2000 HO58 FITS 92-05 KX250 FITS 99-02 KX250 – 14032-1483 1542 – FITS 00-01 KX250 – 14032-1502 FITS 92-07 KX250 2000 1139 - FITS 97-07 KX250 – 13087-1168   FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 2000   FITS 99-02 KX250 - 21121-1281 2000 780-1220 kPa OR 114-176 PSI FITS 92-04 KX250, 89-04 KX500, 91-94 KDX250 - 14026-1174 - PLASTIC FITS 2000 KX250  13031-1476 FITS 00-01 KX250 - 13032-1263 66.4MM BORE X 72MM STROKE FITS 92-04 KX250 4017 N/A 2000 1911 FITS 00 KX250  11005-1911 BORE 66.40 STROKE 72MM 2000     2000 FITS 99-02 KX250 - 32190-1165 FITS 99-00 KX250 – 18120-1087 FITS 99-00 KX250 - 18100-1078 2000 20059 20054 N/A PK00250P - FITS 00 KX250 2000 FITS 00 KX250  FITS 99-04 KX250 - 12005-1284 FITS 99-04 KX250 - 12005-1285  FITS 93-00 KX250 - 14090-1219 FITS 93-04 KX250 - 14090-1249 FITS 93-03 KX250 - 14090-1226 DENSO 032000-9500 FITS 00 KX250 - 21007-1372 FITS 97-01 KX125 & KX250 34028-1475-CE 34028-1476-CE FITS 97-00 KX125 KX250 - 92144-1951 2000 USD - KYB - K312-L K312-R - CHROME OD 46MM - C/L 37.375" - UPPER 54.9MM - LOWER 58.4MM - BRAKE MOUNT C/L 102MM - AXLE 20MM & 25MM 46MM X 58MM X 10.5 2000   SAE 5W20, OIL LEVEL 88MM OR 3.46 IN.           2000 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 FITS 98-00 KX125 KX250 44037-1371 FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 2000 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM FITS 99-00 KX250 44039-1293 - 190MM FROM C/L TO C/L OF FORK TUBES 2000 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 2000 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  2000   FITS 99-03 KX125 & 250 – 41068-1406     2000 NISSIN ML3 3- FITS 00 KX125 KX250 - 43041-1721 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 2000 FITS 99-00 KX125 KX250 - 43095-1132 FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 00 KX125 KX250 KX65 - 43015-1654 2000 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W 2000 F-1249 - 20MM AXLE DIA - BRG TO BRG 90MM - ROTOR 4 BOLTS ON A 115MM BC- FITS 99-02 KX125 & 250 - 41034-1300 BLACK - 51001-1547 - FITS 99-02 KX125 KX250 - 51001-1547-6Z 2000 FITS 99-04 KX250, 99-05 KX125, 00-07 KX65, 01-05 KX85, 02-05 KLX110 - 51048-1124  FITS 00-01 KX250 - 59051-1381 - 49111-1062 - 13070-1343 - 49114-1074 27T - FITS 92-04 KX250 - 59051-1248 1425 FITS 95-02 KX250 - 11001-1425 FITS 93-04 KX250, 91-94 KDX250 - 52014-1077 FITS 92-04 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 2000 FITS 94-01 KX250 - 13064-1186   FITS 99-01 KX250 - 13066-1099 Verified, it will fit 98-01 FITS 95-02 KX125 KX250, 96-04 KX500, 95-06 KDX200, 97-05 KDX220, 27010-1350 FITS 94-02 KX125 KX250 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 2000 .85 LITER = .9 QUARTS FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 66.4MM BORE X 72MM STROKE INNER 21S, OUTER 20T - FITS 99-01 KX250 - 13097-1402 2000 FITS 99-02 KX125 KX250 39061-1262 FITS 99-02 KX125 KX250 39061-1263 FITS 99-02 KX125 KX250, LH 49089-1140-6W FITS 99-02 KX125 KX250, RH 49089-1141-6W 2000 FITS 97-05 KX125, 97-04 KX250 - 14037-1310-RZ FITS 93-02 KX125 KX250 - 41068-1343 2000 HYDRAULIC BRAKE FITS 00 KX125 & KX250 43041-1722 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F 1118 - FITS 97-02 KX125 KX250 - 14079-1111 2000 FITS 99-01 KX250 43095-1134 FITS 00-02 KX250 & KX125 - 13236-1339 FITS 97-01 KX125 KX250, 43015-1597   2000 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 FITS 00-02 KX125 KX250, 35023-1511-6W 2000 R-1287 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - FITS 99-02 KX125, 250 - 3 BRG 2000 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM FITS 2000 KX250  12021-1121 FITS 87-04 KX250 2000 FITS 00 KX125 KX250, LOW SEAT 53001-1918-NL, HIGH SEAT 53001-1919-NL FITS 99-02 KX125 KX250 FITS 97-02 KX250 - 13141-1200 - SM OD 13.91 - LG OD 24.96 - OAL 74.42 2000 SET FITS 96-01 KX250 13140-1248 13140-1249 13140-1250 SET FITS 96-00 KX250 - 49047-1092 - 49047-1093 - 11.89MM OD 2000 FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 FITS 00-02 KX250 - 13161-1265 2000 FITS 2000 KX250 - 45014-1735-8V - CLICK HERE FOR MEASUREMENTS 1277 - FITS 99-01 KX125 & KX250 - 39007-1277 FITS 97-01 KX125 KX250 - 46102-1404 - EYE TO EYE 123.5MM, 15MM ID - STAMPED 04 2000   WHITE - FITS 99-01 KX125 KX250, LH 36001-1627-6F WHITE - FITS 99-01 KX125 KX250,  RH 36001-1628-6F 2000   FITS 99-00 KX250 21003-1340 FITS 94-04 KX250 14031-1283 FITS 00-02 KX125, KX250 - 32160-1647-CC 2000 FITS 00-02 KX250 33001-1576-TX FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 FITS 92-05 KX125, 92-07 KX250 - ASY 2000 15T - FITS 99-02 KX250 - 13127-1267 2000     FITS 99-02 KX250 – 13128-1232     FITS 00-04 KX250 - 21066-1123 FITS 00-04 KX250 16142-1159 1082 - FITS 94-04 KX250 - 52014-1082 2000 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 92-00 KX250 - 13234-1096 FITS 00 KX125 KX250 - 26030-1676 2000 54.2LB WITH SPARK PLUG, KICK LEVER, REED, AND BOOT, NO CARB, NO OIL 2000
2001 KX250 KX250LE01XXXX FITS 00-01 KX250  - 14001-1282 - KAWI MAN SAYS 97-01 ALL INTERCHANGE JKAKXM----1A0----- JKAKX250LLA FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 99-02 KX125 KX250 11011-1557-6D 2001 1743 - FITS 99-02 KX250 - 14073-1743 FITS 99-04 KX250 - 54011-1389 HYDRAULIC FITS 99-03 KX125 KX250 - 54012-1598 2001 KEIHIN PWK G597 - 15003-1597 52  158 2001 FITS 99-02 KX250 - 16065-1358   92064-1130 JET-PILOT,#52 - 92063-1368 JET-MAIN,#160 - 16187-1161 NEEDLE-JET,NAFF - 16159-1058 JET-POWER,#48 2001 DENSO 071000-1770 - 21119-1573 - FITS 01 KX250  – 21119-1573 FITS 97-02 KX125 KX250 - 33040-1156 FITS 97-02 KX125 KX250 2001 FITS 99-03 KX125 KX250 12053-1422 FITS 99-04 KX250 13102-1154 FITS 99-01 KX250 13095-1368 2001 HO58 FITS 92-05 KX250 FITS 99-02 KX250 – 14032-1483 1542 – FITS 00-01 KX250 – 14032-1502 FITS 92-07 KX250 2001 1139 - FITS 97-07 KX250 – 13087-1168   FITS 01-02 KX250 - 13187-1087 2001   FITS 99-02 KX250 - 21121-1281 2001   FITS 92-04 KX250, 89-04 KX500, 91-94 KDX250 - 14026-1174 - PLASTIC FITS 01 KX250  13031-1482 FITS 00-01 KX250 - 13032-1263 66.4MM BORE X 72MM STROKE FITS 92-04 KX250 4017 N/A 2001 1938 FITS 01 KX250  11005-1938 BORE 66.40 STROKE 72MM 2001     2001 FITS 99-02 KX250 - 32190-1165 FITS 01 KX250  – 18120-1095   2001 22007 22006 N/A PK01250P - FITS 01 KX250 2001 FITS 01 KX250 - 49116-1192 FITS 99-04 KX250 - 12005-1284 FITS 99-04 KX250 - 12005-1285  1325 - FITS 01-03 KX250 - 14091-1325 FITS 93-04 KX250 - 14090-1249 FITS 93-03 KX250 - 14090-1226 DENSO 032000-9501 - FITS 01 KX250 - 21007-1383 FITS 97-01 KX125 & KX250 34028-1475-CE 34028-1476-CE   2001 USD - KYB - K312-L K312-R - CHROME OD 46MM - C/L 37.375" - UPPER 54.9MM - LOWER 58.4MM - BRAKE MOUNT C/L 102MM - AXLE 20MM & 25MM 46MM X 58MM X 10.5 2001               2001 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 FITS 01 KX125 KX250 – 44037-1415 FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 2001 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM   2001 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 2001 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  2001   FITS 99-03 KX125 & 250 – 41068-1406     2001 FITS 01 KX125 KX250 - 43041-1839 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 2001 FITS 01-03 KX125 KX250 - 43095-1212 FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 01-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2001 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W 2001 F-1249 - 20MM AXLE DIA - BRG TO BRG 90MM - ROTOR 4 BOLTS ON A 115MM BC- FITS 99-02 KX125 & 250 - 41034-1300 BLACK - 51001-1547 - FITS 99-02 KX125 KX250 - 51001-1547-6Z 2001 FITS 99-04 KX250, 99-05 KX125, 00-07 KX65, 01-05 KX85, 02-05 KLX110 - 51048-1124  FITS 00-01 KX250 - 59051-1381 - 49111-1062 - 13070-1343 - 49114-1074 27T - FITS 92-04 KX250 - 59051-1248 1425 FITS 95-02 KX250 - 11001-1425 FITS 93-04 KX250, 91-94 KDX250 - 52014-1077 FITS 92-04 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 2001 FITS 94-01 KX250 - 13064-1186   FITS 99-01 KX250 - 13066-1099 Verified, it will fit 98-01 FITS 95-02 KX125 KX250, 96-04 KX500, 95-06 KDX200, 97-05 KDX220, 27010-1350 FITS 94-02 KX125 KX250 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 2001   FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 66.4MM BORE X 72MM STROKE INNER 21S, OUTER 20T - FITS 99-01 KX250 - 13097-1402 2001 FITS 99-02 KX125 KX250 39061-1262 FITS 99-02 KX125 KX250 39061-1263 FITS 99-02 KX125 KX250, LH 49089-1140-6W FITS 99-02 KX125 KX250, RH 49089-1141-6W 2001 FITS 97-05 KX125, 97-04 KX250 - 14037-1310-RZ FITS 93-02 KX125 KX250 - 41068-1343 2001 HYDRAULIC BRAKE FITS 01-02 KX125 KX250 43041-1826 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F 1118 - FITS 97-02 KX125 KX250 - 14079-1111 2001 FITS 99-01 KX250 43095-1134 FITS 00-02 KX250 & KX125 - 13236-1339 FITS 97-01 KX125 KX250, 43015-1597   2001 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 FITS 00-02 KX125 KX250, 35023-1511-6W 2001 R-1287 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - FITS 99-02 KX125, 250 - 3 BRG 2001 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM FITS 01-02 KX250 - 12021-1124 FITS 87-04 KX250 2001   FITS 99-02 KX125 KX250 FITS 97-02 KX250 - 13141-1200 - SM OD 13.91 - LG OD 24.96 - OAL 74.42 2001 SET FITS 96-01 KX250 13140-1248 13140-1249 13140-1250 SET FITS 01-07 KX250 - 49047-1107 - 49047-1108 2001 FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 FITS 00-02 KX250 - 13161-1265 2001   1277 - FITS 99-01 KX125 & KX250 - 39007-1277 FITS 97-01 KX125 KX250 - 46102-1404 - EYE TO EYE 123.5MM, 15MM ID - STAMPED 04 2001   WHITE - FITS 99-01 KX125 KX250, LH 36001-1627-6F WHITE - FITS 99-01 KX125 KX250,  RH 36001-1628-6F 2001   FITS 01 KX250 - 21003-1371 FITS 94-04 KX250 14031-1283 FITS 00-02 KX125, KX250 - 32160-1647-CC 2001 FITS 00-02 KX250 33001-1576-TX FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 FITS 92-05 KX125, 92-07 KX250 - ASY 2001 15T - FITS 99-02 KX250 - 13127-1267 2001     FITS 99-02 KX250 – 13128-1232     FITS 00-04 KX250 - 21066-1123 FITS 00-04 KX250 16142-1159 1082 - FITS 94-04 KX250 - 52014-1082 2001 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 01-04 KX250 - 13234-1115   2001 kx250 01 ,a tad over 53lbs without carb and kickstarter.  2001
2002 KX250 KX250LE06XXXX FITS 2002 KX250  - 14001-1293 - KAWI MAN SAYS CAN INTERCHANGE WITH 97-01 PARTS BUT USES LARGER MAIN BEARINGS JKAKXM----2A0----- JKAKX250LLA FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 99-02 KX125 KX250 11011-1557-6D 2002 1743 - FITS 99-02 KX250 - 14073-1743 FITS 99-04 KX250 - 54011-1389 HYDRAULIC FITS 99-03 KX125 KX250 - 54012-1598 2002 KEIHIN PWK G667 - FITS 02 KX250 -  2002 FITS 99-02 KX250 - 16065-1358   92064-1145 JET-PILOT,#55 - 92063-1370 JET-MAIN,#165 - 16187-1161 NEEDLE-JET,NAFF - 16159-1058 JET-POWER,#48 2002 DENSO 071000-2010 21119-1595 - Timing 13* BTDC @ 7000 RPM FITS 97-02 KX125 KX250 - 33040-1156 FITS 97-02 KX125 KX250 2002 FITS 99-03 KX125 KX250 12053-1422 FITS 99-04 KX250 13102-1154 FITS 02 KX250  13095-1405 2002 HO58 FITS 92-05 KX250 FITS 99-02 KX250 – 14032-1483 1542 FITS 02-03 KX250 – 14032-1526 FITS 92-07 KX250 2002 1139 - FITS 97-07 KX250 – 13087-1168   FITS 01-02 KX250 - 13187-1087 2002   FITS 99-02 KX250 - 21121-1281 2002   FITS 92-04 KX250, 89-04 KX500, 91-94 KDX250 - 14026-1174 - PLASTIC FITS 02-03 KX250 13031-1495 FITS 02-07 KX250 - 13032-1279 66.4MM BORE X 72MM STROKE FITS 92-04 KX250 4017 FITS 91-94 KDX250, 02-07 KX250 2002 1959 FITS 02 KX250  11005-1959 BORE 66.40 STROKE 72MM 2002     2002 FITS 99-02 KX250 - 32190-1165 FITS 02 KX250  – 18120-1117   2002 22007 22006 N/A PK02250P - FITS 02 KX250 2002   FITS 99-04 KX250 - 12005-1284 FITS 99-04 KX250 - 12005-1285  1325 - FITS 01-03 KX250 - 14091-1325 FITS 93-04 KX250 - 14090-1249 FITS 93-03 KX250 - 14090-1226 DENSO 032000-9750  FITS 02 KX250 - 21007-1403     2002 USD - CHROME OD 48MM - 56MM - 59.2MM - C/L 37.5" KYB 48MM X 58MM X 8.5/10 2002               2002 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250   FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 2002 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM   2002 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 2002 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  2002   FITS 99-03 KX125 & 250 – 41068-1406     2002 FITS 02 KX125 KX250 - 43041-1851 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 2002 FITS 01-03 KX125 KX250 - 43095-1212 FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 01-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2002 ROTOR OD 250MM ID 100.5MM - ROTOR BOLT CIRCLE 4 ON 115MM - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 GREEN - FITS 94-02 KX125 KX250, 94-04 KX500 - 35004-1318-6W 2002 F-1249 - 20MM AXLE DIA - BRG TO BRG 90MM - ROTOR 4 BOLTS ON A 115MM BC- FITS 99-02 KX125 & 250 - 41034-1300 BLACK - 51001-1547 - FITS 99-02 KX125 KX250 - 51001-1547-6Z 2002 FITS 99-04 KX250, 99-05 KX125, 00-07 KX65, 01-05 KX85, 02-05 KLX110 - 51048-1124    27T - FITS 92-04 KX250 - 59051-1248 1425 FITS 95-02 KX250 - 11001-1425 FITS 93-04 KX250, 91-94 KDX250 - 52014-1077 FITS 92-04 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 2002 FITS 02 KX250 - 13064-1202    FITS 02-07 KX250, 06 KX450F - 13066-1107 FITS 02-07 KX250 FITS 95-02 KX125 KX250, 96-04 KX500, 95-06 KDX200, 97-05 KDX220, 27010-1350 FITS 94-02 KX125 KX250 FITS 96-02 KX125 KX250 KX500 58029-1078-6F WHITE 2002   FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 66.4MM BORE X 72MM STROKE INNER 21S, OUTER 21T - FITS 02-04 KX250 - 13097-1429 2002 FITS 99-02 KX125 KX250 39061-1262 FITS 99-02 KX125 KX250 39061-1263 FITS 99-02 KX125 KX250, LH 49089-1140-6W FITS 99-02 KX125 KX250, RH 49089-1141-6W 2002 FITS 97-05 KX125, 97-04 KX250 - 14037-1310-RZ FITS 93-02 KX125 KX250 - 41068-1343 2002 HYDRAULIC BRAKE FITS 01-02 KX125 KX250 43041-1826 FITS 94-02 KX125 KX250 KX500, 95-02 KDX200, 97-02 KDX220 KLX300R, 96 KLX650R - 55020-1488-6F 1118 - FITS 97-02 KX125 KX250 - 14079-1111 2002   FITS 00-02 KX250 & KX125 - 13236-1339 FITS 02 KX125 KX250 - 43015-1692   2002 ROTOR OD IS 220MM - ROTOR BOLT CIRCLE 6 ON 115MM FITS 89-02 KX125 & KX250, 89-04 KX500, 89-94 KDX200 FITS 00-02 KX125 KX250, 35023-1511-6W 2002 R-1287 - GRAY - 20MM AXLE - BRG TO BRG 130MM - ROTOR OD 220MM - ROTOR BC 6X ON 116MM - 36 SPOKES - SPROCKET BC 6X ON 150MM - FITS 99-02 KX125, 250 - 3 BRG 2002 FITS 97-02 KX125 KX250, 97-04 KX500 92143-1905 - ID 20.3MM, MAJ OD 39.95MM, MINOR OD 24.92MM, LENGTH 19.84MM FITS 01-02 KX250 - 12021-1124 FITS 87-04 KX250 2002 FITS 02 KX125 KX250 FITS 99-02 KX125 KX250 FITS 97-02 KX250 - 13141-1200 - SM OD 13.91 - LG OD 24.96 - OAL 74.42 2002   SET FITS 01-07 KX250 - 49047-1107 - 49047-1108 2002 FITS 94-02 KX125 KX250, 94-04 KX500, 00-14 KX65 - 13156-1347 FITS 00-02 KX250 - 13161-1265 2002     FITS 02 KX125 KX250 - 39007-1301 FITS 02 KX125 KX250 - 46102-1289 2002   WHITE - FITS 02 KX125 KX250 WHITE - FITS 02 KX125 KX250 2002   175A FITS 94-04 KX250 14031-1283 FITS 00-02 KX125, KX250 - 32160-1647-CC 2002 FITS 00-02 KX250 33001-1576-TX FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 FITS 92-05 KX125, 92-07 KX250 - ASY 2002 15T - FITS 99-02 KX250 - 13127-1267 2002     FITS 99-02 KX250 – 13128-1232     FITS 00-04 KX250 - 21066-1123 FITS 00-04 KX250 16142-1159 1082 - FITS 94-04 KX250 - 52014-1082 2002 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 01-04 KX250 - 13234-1115   2002   2002
2003 KX250 KX250ME00XXXX FITS 2003 KX250 - 14001-1307 JKAKXMMC63A00XXXX JKAKX250MMA 1 FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 03 KX125 KX250 11011-1656 2003 FITS 03 KX250 - 14073-0004 FITS 99-04 KX250 - 54011-1389 HYDRAULIC FITS 99-03 KX125 KX250 - 54012-1598 2003 KEIHIN PWK G713 - FITS 03 KX250 - 15003-1713 2003 FITS 03 KX250 - 16065-1388   92064-1130 JET-PILOT,#52 - 92063-1370 JET-MAIN,#165 - 16187-1163 NEEDLE-JET,NAFH - 16159-1053 - JET-POWER,#50 2003 DENSO 071000-2140 21119-1619 - FITS 03 KX250 - 21119-1619    FITS 03-05 KX125, 03-08 KX250, 04-05 KX250F 12053-1468 2003 FITS 99-03 KX125 KX250 12053-1422 FITS 99-04 KX250 13102-1154 FITS 03-05 KX250 13095-1419 2003 HO58 FITS 92-05 KX250 FITS 03-04 KX250 – 14032-1538 1542 FITS 02-03 KX250 – 14032-1526 FITS 92-07 KX250 2003 1139 - FITS 97-07 KX250 – 13087-1168   FITS 03-07 KX250 - 13187-1090 2003   FITS 03-04 KX250 2003   FITS 92-04 KX250, 89-04 KX500, 91-94 KDX250 - 14026-1174 - PLASTIC FITS 02-03 KX250 13031-1495 FITS 02-07 KX250 - 13032-1279 66.4MM BORE X 72MM STROKE FITS 92-04 KX250 4017 FITS 91-94 KDX250, 02-07 KX250 2003 1979 FITS 03 KX250  11005-1979 BORE 66.40 STROKE 72MM 2003     2003 FITS 03-04 KX250 - 32190-1266 FITS 03 KX250  – 18120-0004   2003 22016 22015 N/A PK03250P - FITS 03 KX250 2003   FITS 99-04 KX250 - 12005-1284 FITS 99-04 KX250 - 12005-1285  1325 - FITS 01-03 KX250 - 14091-1325 FITS 93-04 KX250 - 14090-1249 FITS 93-03 KX250 - 14090-1226 1425 4.0 - FITS 03-07 KX250 - 21007-1425     2003 USD - CHROME OD 48MM - 56MM - 59.2MM - C/L 37.5" KYB 48MM X 58MM X 8.5/10 2003               2003 WHITE - FITS 94-95, 97-03 KX125 KX250, 97-04 KX500 - LH 55020-1492-RZ - RH 55020-1554-RZ FITS 97-04 KX500, 97-03 KX125 KX250 - 13070-1290-RZ -    FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 2003 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM   2003 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 2003 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  2003   FITS 99-03 KX125 & 250 – 41068-1406     2003 FITS 03 KX125 KX250 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 2003 FITS 01-03 KX125 KX250 - 43095-1212 FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 01-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2003     2003 20MM AXLE DIA - BRG TO BRG 90MM - FITS 03 KX125, KX250 - 41034-1346   2003 FITS 99-04 KX250, 99-05 KX125, 00-07 KX65, 01-05 KX85, 02-05 KLX110 - 51048-1124    27T - FITS 92-04 KX250 - 59051-1248 1574 FITS 03 KX250 - 11001-1574 FITS 93-04 KX250, 91-94 KDX250 - 52014-1077 FITS 92-04 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 2003 FITS 03 KX250 - 13064-0002   FITS 02-07 KX250, 06 KX450F - 13066-1107 FITS 02-07 KX250       2003   FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 66.4MM BORE X 72MM STROKE INNER 21S, OUTER 21T - FITS 02-04 KX250 - 13097-1429 2003 FITS 03 KX125 KX250 39061-1309 FITS 03 KX125 KX250 39061-1311     2003 FITS 97-05 KX125, 97-04 KX250 - 14037-1310-RZ FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 2003 HYDRAULIC BRAKE       2003         2003 FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514   2003 0003-1 / 0003-2 - 25MM AXLE DIA - BRG TO BRG 133.5MM - ROTOR OD 240MM - ROTOR BC 4 ON 133MM - SPROCKET BC 6 ON 150MM - FITS 03-05 KX125, 03-06 KX250, 04-06 KX250F, 06 KX450F - 41034-0004 2003 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM   FITS 87-04 KX250 2003       2003   SET FITS 01-07 KX250 - 49047-1107 - 49047-1108 2003     2003     FITS 03 KX125  KX250 - 39007-1306   2003       2003   FITS 03-04 KX250 - 21003-1400 FITS 94-04 KX250 14031-1283 FITS 03 KX125 KX250 - 32160-1787 2003 FITS 03 KX250 - 33001-1629-CE FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 FITS 92-05 KX125, 92-07 KX250 - ASY FITS 03-04 KX250 15T - FITS 03-07 KX250 - 13127-1303 2003     FITS 03-04 KX250 – 13128-1265     FITS 00-04 KX250 - 21066-1123 FITS 00-04 KX250 16142-1159 1082 - FITS 94-04 KX250 - 52014-1082 2003 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 01-04 KX250 - 13234-1115 FITS 03 KX250 - 26030-1962 2003   2003
2004 KX250 KX250ME00XXXX FITS 2004 KX250 - 14001-0014 JKAKXM---4A0----- JKAKX250MMA 1 FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 04-05 KX125, 04 KX250 11011-0012 2004 FITS 04 KX250 - 14073-0031 FITS 99-04 KX250 - 54011-1389 HYDRAULIC FITS 04 KX125 KX250 - 54012-0101 2004 KEIHIN PWK G009 - FITS 04 KX250 - 15003-0009 2004 FITS 04 KX250 - 16065-0002   92064-1130 JET-PILOT,#52 - 92063-1370 JET-MAIN,#165 - 16187-1156 NEEDLE-JET,NALF - 16159-1053 JET-POWER,#50 2004 FITS 04 KX250 - 21119-0007   FITS 03-05 KX125, 03-08 KX250, 04-05 KX250F 12053-1468 2004 FITS 04-05 KX125, 04-07 KX250 - 12053-0020 FITS 99-04 KX250 13102-1154 FITS 03-05 KX250 13095-1419 2004 HO58 FITS 92-05 KX250 FITS 03-04 KX250 – 14032-1538 FITS 04 KX250  – 14032-0019 FITS 92-07 KX250 2004 1139 - FITS 97-07 KX250 – 13087-1168   FITS 03-07 KX250 - 13187-1090 2004   FITS 03-04 KX250 2004   FITS 92-04 KX250, 89-04 KX500, 91-94 KDX250 - 14026-1174 - PLASTIC FITS 04 KX250  13031-0022 FITS 02-07 KX250 - 13032-1279 66.4MM BORE X 72MM STROKE FITS 92-04 KX250 4017 FITS 91-94 KDX250, 02-07 KX250 2004 0014 FITS 04 KX250  11005-0014 BORE 66.40 STROKE 72MM 2004     2004 FITS 03-04 KX250 - 32190-1266 FITS 04 KX250  – 18120-0008   2004 22041 22040 N/A PK04250P - FITS 04 KX250 2004   FITS 99-04 KX250 - 12005-1284 FITS 99-04 KX250 - 12005-1285    FITS 93-04 KX250 - 14090-1249   1425 4.0 - FITS 03-07 KX250 - 21007-1425     2004 USD - CHROME OD 48MM 48MM X 58MM X 8.5/10 2004               2004   FITS 04-05 KX125 04-06 KX250 - 13070-0025 - 13070-0027   FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 2004 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM   2004 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 2004 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  2004   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004     2004 04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 2004 FITS 04 KX125 KX250 KX250F - 43095-0054 FITS 00-05, 00-04 KX250, 04 KX500, 00-05 08-11 KX65, 01-05 08-09 11 KX100, 01-05 08-11 KX85, 04-11 KX250F, 06-11 KX450F - 13236-1346 NISSIN 304 - FITS 01-05 08-09 KX85 KX100, 01-05 KX125, 01-04 KX250, 04 KX500, 04-09 KX250F, 06-09 KX450F - 43015-1674  2004     2004 F-0012 - BRG ID 20MM - BRG TO BRG 90MM - 36 SPOKES - ROTOR BC 4X AT 116MM - FITS 04-05 KX125 KX250 KX250F - 41034-0018   2004 FITS 99-04 KX250, 99-05 KX125, 00-07 KX65, 01-05 KX85, 02-05 KLX110 - 51048-1124    27T - FITS 92-04 KX250 - 59051-1248 0024 FITS 04 KX250 - 11001-0024 FITS 93-04 KX250, 91-94 KDX250 - 52014-1077 FITS 92-04 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 2004 FITS 04 KX250 - 13064-0016   FITS 02-07 KX250, 06 KX450F - 13066-1107 FITS 02-07 KX250       2004   FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 66.4MM BORE X 72MM STROKE INNER 21S, OUTER 21T - FITS 02-04 KX250 - 13097-1429 2004 FITS 04-05 KX125, 04 KX250 39061-0012 FITS 04-05 KX125, 04 KX250 39061-0013     2004 FITS 97-05 KX125, 97-04 KX250 - 14037-1310-RZ FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 2004 HYDRAULIC BRAKE FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514     2004   FITS 04 KX250 ONLY 13236-0022     2004 FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514   2004 0003-1 / 0003-2 - 25MM AXLE DIA - BRG TO BRG 133.5MM - ROTOR OD 240MM - ROTOR BC 4 ON 133MM - SPROCKET BC 6 ON 150MM - FITS 03-05 KX125, 03-06 KX250, 04-06 KX250F, 06 KX450F - 41034-0004 2004 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM   FITS 87-04 KX250 2004       2004   SET FITS 01-07 KX250 - 49047-1107 - 49047-1108 2004     2004         2004       2004   FITS 03-04 KX250 - 21003-1400 FITS 94-04 KX250 14031-1283 FITS 04 KX125 KX250 - 32160-0015 2004 FITS 04 KX250 - 33001-1629-CE FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 FITS 92-05 KX125, 92-07 KX250 - ASY FITS 03-04 KX250 15T - FITS 03-07 KX250 - 13127-1303 2004     FITS 03-04 KX250 – 13128-1265     FITS 00-04 KX250 - 21066-1123 FITS 00-04 KX250 16142-1159 1082 - FITS 94-04 KX250 - 52014-1082 2004 FITS 91-05 KX125, 92-04 KX250, 87-04 KX500, 04-11 KX250F - 59256-1065 FITS 01-04 KX250 - 13234-1115   2004   2004
2005 KX250 KX250RE00XXXX FITS 2005 KX250 - 14001-5398 JKAKXM---5A0----- kx250rra00600 1 FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 05 KX125, 05-07 KX250 11011-0048 2005 FITS 05-07 KX250 - 14073-0075 FITS 05 KX250 - 54011-0041 HYDRAULIC FITS 05-07 KX250 - 54012-0149 2005 KEIHIN PWK G045 - FITS 05-07 KX250 - 15003-0045 2005 FITS 05-07 KX250 - 16065-0023   92064-1144 JET-PILOT,#50 - 92063-1368 JET-MAIN,#160 - 16187-0158 NEEDLE-JET,NFTG - 16159-1054 JET-POWER,#55 2005 DENSO 21119-0027 071000-2700 FITS 05-07   FITS 03-05 KX125, 03-08 KX250, 04-05 KX250F 12053-1468 2005 FITS 04-05 KX125, 04-07 KX250 - 12053-0020 FITS 05-07 KX250 13102-0014 FITS 03-05 KX250 13095-1419 2005 HO58 FITS 92-05 KX250 FITS 05-07 KX250 – 14032-0051 FITS 05 KX250  – 14032-0052 FITS 92-07 KX250 2005 1139 - FITS 97-07 KX250 – 13087-1168   FITS 03-07 KX250 - 13187-1090 2005   FITS 05-07 KX250 2005     FITS 05 KX250  13031-0025 FITS 02-07 KX250 - 13032-1279 66.4MM BORE X 72MM STROKE FITS 05 KX250 4057 FITS 91-94 KDX250, 02-07 KX250 2005 0027 FITS 05 KX250  11005-0027 BORE 66.40 STROKE 72MM 2005     2005 FITS 05-07 KX250 - 32190-0092 FITS 05 KX250  – 18120-0010   2005 22053 22052 22055 PK05250P - FITS 05-07 KX250 2005 FITS 05-07 KX250 - 49116-0007 FITS 05-07 KX250 - 12005-0019 FITS 05-07 KX250 - 12005-0019 FITS 05-07 KX250 - 14091-0217 FITS 05-07 KX250 - 14091-0215 N/A 1425 4.0 - FITS 03-07 KX250 - 21007-1425 FITS 05-07 KX250, 05-08 KX250F,07-08 KX450F, 08-13 KLX450 - LEFT 34028-0014 - RIGHT 34028-0015   2005 USD - KYB - 1021 & L 1021-R - CHROME OD 48MM -  C/L 37.5" - UPPER 55.9MM - LOWER 59.2MM - BRAKE MOUNT 102MM - AXLE CLAMP ID 20MM & 25MM 48MM X 58MM X 8.5/10 2005               2005   FITS 04-05 KX125 04-06 KX250 - 13070-0025 - 13070-0027 GOLD - FITS 05 KX250 KX250F - 44037-0031-D3 FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 2005 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM   2005 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 2005 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  2005   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004     2005 04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 2005 FITS 05 KX125 KX250, 05-06 KX250F - 43095-0060   FITS 05-07 KX250, 05 KX250F, 06-07 KX100, 06-07 KX85 - 43015-0041 2005     2005 F-0012 - BRG ID 20MM - BRG TO BRG 90MM - 36 SPOKES - ROTOR BC 4X AT 116MM - FITS 04-05 KX125 KX250 KX250F - 41034-0018   2005       0034 FITS 05-06 KX250 - 11001-0034   FITS 05-07 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 2005 FITS 05 KX250 - 13064-0022   FITS 02-07 KX250, 06 KX450F - 13066-1107 FITS 02-07 KX250       2005   FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 66.4MM BORE X 72MM STROKE INNER 21S, OUTER 21T 13097-0022 FITS 05 KX250  2005 FITS 05-07 KX250 39061-0024 FITS 05-07 KX250 39061-0025     2005   FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 2005 HYDRAULIC BRAKE FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514     2005     FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004   2005 FITS 03-05 KX125 KX250, 04-05 KX250F - 41080-1514   2005 0003-1 / 0003-2 - 25MM AXLE DIA - BRG TO BRG 133.5MM - ROTOR OD 240MM - ROTOR BC 4 ON 133MM - SPROCKET BC 6 ON 150MM - FITS 03-05 KX125, 03-06 KX250, 04-06 KX250F, 06 KX450F - 41034-0004 2005 FITS 03-05 KX125 KX250, 06-10 KX250F, 06-11 KX450F, 08-12 KLX650F - 92152-1473 - ID 25.1MM, MINOR OD 31.9MM, MAJOR OD 41.9MM, LENGTH 16.83MM   FITS 05-08 KX250 2005       2005   SET FITS 01-07 KX250 - 49047-1107 - 49047-1108 2005     2005         2005       2005   FITS 05-07 KX250 – 21003-0050 FITS 05-07 KX250 14031-0022 FITS 05 KX125 KX250 - 32160-0068 2005 FITS 2005 KX250 - 33001-1629-CE FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 FITS 92-05 KX125, 92-07 KX250 - ASY FITS 05-07 KX250 15T - FITS 03-07 KX250 - 13127-1303 2005     FITS 05-07 KX250 - 13128-0011       FITS 05-07 KX250 - 16142-0013   2005       2005   2005
2006 KX250 KX250RE00XXXX FITS 06-07 KX250 - 14001-0065 JKAKXM---6A0----- kx250tta011000 1 FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 05 KX125, 05-07 KX250 11011-0048 2006 FITS 05-07 KX250 - 14073-0075 FITS 06-07 KX250 - 54011-0047 HYDRAULIC FITS 05-07 KX250 - 54012-0149 2006 KEIHIN PWK G045 - FITS 05-07 KX250 - 15003-0045 2006 FITS 05-07 KX250 - 16065-0023   92064-1144 JET-PILOT,#50 - 92063-1368 JET-MAIN,#160 - 16187-0158 NEEDLE-JET,NFTG - 16159-1054 JET-POWER,#55 2006 DENSO 21119-0027 071000-2700 FITS 05-07   FITS 03-05 KX125, 03-08 KX250, 04-05 KX250F 12053-1468 2006 FITS 04-05 KX125, 04-07 KX250 - 12053-0020 FITS 05-07 KX250 13102-0014 FITS 06-07 KX250 13095-0048 2006 H266 FITS 06-07 KX250 FITS 05-07 KX250 – 14032-0051 FITS 06-07 KX250 - 14032-0063 FITS 92-07 KX250 2006 1139 - FITS 97-07 KX250 – 13087-1168   FITS 03-07 KX250 - 13187-1090 2006   FITS 05-07 KX250 2006     FITS 06-07 KX250 13031-0050 - 72mm stroke FITS 02-07 KX250 - 13032-1279 66.4MM BORE X 72MM STROKE N/A FITS 91-94 KDX250, 02-07 KX250 2006 0054 FITS 06-07 KX250 11005-0054 BORE 66.40 STROKE 72MM 2006     2006 FITS 05-07 KX250 - 32190-0092 FITS 06-07 KX250 – 18120-0014   2006 22053 22052 22055 PK05250P - FITS 05-07 KX250 2006 FITS 05-07 KX250 - 49116-0007 FITS 05-07 KX250 - 12005-0019 FITS 05-07 KX250 - 12005-0019 FITS 05-07 KX250 - 14091-0217 FITS 05-07 KX250 - 14091-0215 N/A 1425 4.0 - FITS 03-07 KX250 - 21007-1425 FITS 05-07 KX250, 05-08 KX250F,07-08 KX450F, 08-13 KLX450 - LEFT 34028-0014 - RIGHT 34028-0015   2006 USD - CHROME OD 48MM 48MM X 58MM X 8.5/10 2006               2006   FITS 04-05 KX125 04-06 KX250 - 13070-0025 - 13070-0027   FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 2006 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM   2006 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 2006 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  2006   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004     2006 04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 2006     FITS 05-07 KX250, 05 KX250F, 06-07 KX100, 06-07 KX85 - 43015-0041 2006     2006 FITS 06 KX250, KX250F, KX450F - 41034-0005 BLACK - FITS 06-07 KX250 - 51001-0080-6Z 2006       0034 FITS 05-06 KX250 - 11001-0034   FITS 05-07 KX250 26T – FITS 87-07 KX250, 91-94 KDX250 59051-1271 2006 FITS 06-07 KX250 - 13064-0036   FITS 02-07 KX250, 06 KX450F - 13066-1107 FITS 02-07 KX250       2006   FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 66.4MM BORE X 72MM STROKE OUTER 21T 13097-0022, FITS 06-07 KX250 2006 FITS 05-07 KX250 39061-0024 FITS 05-07 KX250 39061-0025     2006   FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 2006 HYDRAULIC BRAKE       2006     FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004   2006     2006 0003-1 / 0003-2 - 25MM AXLE DIA - BRG TO BRG 133.5MM - ROTOR OD 240MM - ROTOR BC 4 ON 133MM - SPROCKET BC 6 ON 150MM - FITS 03-05 KX125, 03-06 KX250, 04-06 KX250F, 06 KX450F - 41034-0004 2006     FITS 05-08 KX250 2006       2006   SET FITS 01-07 KX250 - 49047-1107 - 49047-1108 2006     2006         2006       2006   FITS 05-07 KX250 – 21003-0050 FITS 05-07 KX250 14031-0022 FITS 06-07 KX250 - 32160-0164 2006 FITS 06-07 KX250 - 33001-0065-458 FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 FITS 92-05 KX125, 92-07 KX250 - ASY FITS 05-07 KX250 15T - FITS 03-07 KX250 - 13127-1303 2006     FITS 05-07 KX250 - 13128-0011       FITS 05-07 KX250 - 16142-0013   2006       2006   2006
2007 KX250 KX250RE00XXXX FITS 06-07 KX250 - 14001-0065 JKAKXM---7A0----- kx250tta026000 1 FITS 91 KX125 KX250, 94-05 kx125, 94-07 kx250 - 13091-1708 FITS 05 KX125, 05-07 KX250 11011-0048 2007 FITS 05-07 KX250 - 14073-0075 FITS 06-07 KX250 - 54011-0047 HYDRAULIC FITS 05-07 KX250 - 54012-0149 2007 KEIHIN PWK G045 - FITS 05-07 KX250 - 15003-0045 2007 FITS 05-07 KX250 - 16065-0023   92064-1144 JET-PILOT,#50 - 92063-1368 JET-MAIN,#160 - 16187-0158 NEEDLE-JET,NFTG - 16159-1054 JET-POWER,#55 2007 DENSO 21119-0027 071000-2700 FITS 05-07   FITS 03-05 KX125, 03-08 KX250, 04-05 KX250F 12053-1468 2007 FITS 04-05 KX125, 04-07 KX250 - 12053-0020 FITS 05-07 KX250 13102-0014 FITS 06-07 KX250 13095-0048 2007 H266 FITS 06-07 KX250 FITS 05-07 KX250 – 14032-0051 FITS 06-07 KX250 - 14032-0063 FITS 92-07 KX250 2007 1139 - FITS 97-07 KX250 – 13087-1168   FITS 03-07 KX250 - 13187-1090 2007   FITS 05-07 KX250 2007     FITS 06-07 KX250 13031-0050 - 72mm stroke FITS 02-07 KX250 - 13032-1279 66.4MM BORE X 72MM STROKE N/A FITS 91-94 KDX250, 02-07 KX250 2007 0054 FITS 06-07 KX250 11005-0054 BORE 66.40 STROKE 72MM 2007     2007 FITS 05-07 KX250 - 32190-0092 FITS 06-07 KX250 – 18120-0014   2007 22053 22052 22055 PK05250P - FITS 05-07 KX250 2007 FITS 05-07 KX250 - 49116-0007 FITS 05-07 KX250 - 12005-0019 FITS 05-07 KX250 - 12005-0019 FITS 05-07 KX250 - 14091-0217 FITS 05-07 KX250 - 14091-0215 N/A 1425 4.0 - FITS 03-07 KX250 - 21007-1425 FITS 05-07 KX250, 05-08 KX250F,07-08 KX450F, 08-13 KLX450 - LEFT 34028-0014 - RIGHT 34028-0015   2007 USD - CHROME OD 48MM 48MM X 58MM X 8.5/10 2007               2007   FITS 04-05 KX125 04-06 KX250 - 13070-0025 - 13070-0027   FITS 92-05 KX125, 92-07 KX250, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 91-94 KDX250, 94-96 KLX250, 06-07 09 10 KLX250S 2007 LOWER BEARING 92116-1069, MAJOR DIAMETER APPROX 51.4MM, MINOR OD APPROX 45MM, ID 30MM   2007 FITS 92-05 KX125, 92-07 KX250, 04-11 KX250F, 06-11 450F, 08-09 KLX450F 2007 UPPER BEARING 92116-1076 MAJOR DIAMETER APPROX 48.5MM, MINOR OD APPROX 43.4MM, ID 27.95MM  2007   FITS 04-05 KX125, 04-07 KX250, 04-12 KX250F 06-12 KX450F, 08-12 KLX450R - 41068-0004     2007 04-05 KX125, 04-07 KX250, 04-08 KX250F, 06-08 KX450F - 43080-0006 NISSIN 555 - FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 - 14079-1097 2007 FITS 07 KX250, 07-11 KX250F KX450F - 43095-0286   FITS 05-07 KX250, 05 KX250F, 06-07 KX100, 06-07 KX85 - 43015-0041 2007     2007 FITS 07-08 KX250F KX450F, 07 KX250 BLACK - FITS 06-07 KX250 - 51001-0080-6Z 2007       107 and 108 FITS 07 KX250 - 11001-0107 opt  11001-0108   FITS 05-07 KX250 26T – FITS 87 93-07 KX250, 91-94 KDX250 59051-1271 2007 FITS 06-07 KX250 - 13064-0036   FITS 02-07 KX250, 06 KX450F - 13066-1107 FITS 02-07 KX250       2007   FITS 92-04 KX500, 96-07 KX250, 96-05 KX125, 01-12 KX100 KX85, 00-12 KX65, 04-12 KX250F - 92066-1437 66.4MM BORE X 72MM STROKE OUTER 21T 13097-0022, FITS 06-07 KX250 2007 FITS 05-07 KX250 39061-0024 FITS 05-07 KX250 39061-0025     2007   FITS 03-05 KX125, 03-07 KX250, 04-12 KX250F, 06-12 450F - 41068-1466 2007 HYDRAULIC BRAKE       2007     FITS 05-07 KX250, 04-09 KX250F, 06-10 KX450F, 08-09 12 KLX450R - 43015-0004   2007     2007   2007     FITS 05-08 KX250 2007       2007   SET FITS 01-07 KX250 - 49047-1107 - 49047-1108 2007     2007         2007       2007   FITS 05-07 KX250 – 21003-0050 FITS 05-07 KX250 14031-0022 FITS 06-07 KX250 - 32160-0164 2007 FITS 06-07 KX250 - 33001-0065-458 FITS 98-05 KX125, 98-07 KX250, 04-05 KX250F - 33032-1189 FITS 92-05 KX125, 92-07 KX250 - ASY FITS 05-07 KX250 15T - FITS 03-07 KX250 - 13127-1303 2007     FITS 05-07 KX250 - 13128-0011       FITS 05-07 KX250 - 16142-0013   2007       2007   2007
YEAR TYPE ENGINE ID ENGINE CASES VIN FRAME USA  VIN FRAME EUROPE AIR BOX CAGE ELEMENT HOLDER AIR BOX NO BOOT YEAR AIR BOX TO CARBURETOR BOOT CABLE CLUTCH CABLE FRONT BRAKE CABLE THROTTLE YEAR CARBURETOR YEAR CARBURETOR BOOT CARBURETOR FLOAT VALVE CARBURETOR JETTING STOCK YEAR CDI CHAIN ADJUSTMENT BLOCKS CHAIN GUIDE YEAR CHAIN SLIDE CLUTCH ARM CLUTCH BASKET YEAR CLUTCH BASKET HINSON CLUTCH COVER CLUTCH COVER INNER CLUTCH FRICTION PLATES YEAR CLUTCH HUB (INNER) CLUTCH PERCH CLUTCH PRESSURE PLATE YEAR CLUTCH PUSH ROD COIL YEAR COMPRESSION COUNTER SPROCKET GUARD CRANK SHAFT CRANK SHAFT CONNECTING ROD CRANK CONNECTING ROD STROKE CRANK SHAFT HOT RODS CRANK SHAFT CONNECTING ROD HOT RODS YEAR CYLINDER YEAR CYLINDER WATER NECK ELBOW ENGINE MOUNTS FRONT YEAR ENGINE MOUNTS UPPER EXHAUST PIPE STOCK EXHAUST MUFFLER STOCK YEAR EXHAUST PIPE FMF GNARLY EXHAUST PIPE FMF FATTY EXHAUST PIPE FACTORY FATTY EXHAUST PIPE PRO CIRCUIT PLATINUM YEAR EXHAUST VALVE CENTER EXHAUST VALVE LEFT EXHAUST VALVE RIGHT EXHAUST VALVE COVER FRONT EXHAUST VALVE COVER RIGHT EXHAUST VALVE COVER LEFT (RESONATOR) FLY WHEEL / ROTOR FOOT PEGS FOOT PEG SPRINGS YEAR FORK INFO FORK SEAL SIZE YEAR FORK CYLINDER INTERNAL FORK OIL FORK PIPE INNER CHROME LEFT FORK PIPE INNER CHROME RIGHT FORK PIPE OUTER UPPER FORK SPRING GUIDE PLASTIC FORK SPRING SEAT TOP CAP YEAR FORK GUARDS FORK GUARD SLIDER MOUNTS FORK UNDER HOLDER (STEERING STEM LOWER TRIPLE CLAMP) FORK UNDER HOLDER BEARING (STEERING STEM) YEAR FORK UNDER HOLDER BEARING MEASUREMENTS (STEERING STEM) FORK UPPER HOLDER (TOP CLAMP) YEAR FORK UPPER HOLDER BEARING(TOP CLAMP) YEAR FORK UPPER HOLDER BEARING MEASUREMENTS(TOP CLAMP) YEAR FORK VALVE ADJUSTER BOTTOM FRONT AXLE FRONT AXLE COLLARS SPACERS & CAPS FRONT AXLE HOLDER YEAR FRONT BRAKE CALIPER FRONT BRAKE CALIPER MOUNT YEAR FRONT BRAKE HOSE FRONT BRAKE LEVER FRONT BRAKE MASTER CYLINDER YEAR FRONT BRAKE ROTOR FRONT FENDER YEAR FRONT HUB GAS TANK YEAR GAS TANK CAP GOVERNOR GOVERNOR SPUR GEAR HEAD HEAD WATER ELBOW NECK IMPELLER & SHAFT KICK IDLER GEAR YEAR KICK LEVER KICK LEVER BOSS KICK LEVER SHAFT KICK LEVER SHAFT ASY KILL ENGINE STOP SWITCH MUD FLAP NUMBER PLATE YEAR OIL CAPACITY OIL DRAIN PLUG PISTON STD BORE AND STROKE PRIMARY CRANK GEAR YEAR RADIATOR LEFT RADIATOR RIGHT RADIATOR SHROUD LEFT RADIATOR SHROUD RIGHT YEAR RADIATOR SCREENS REAR AXLE YEAR REAR BRAKE BACKING PLATE REAR BRAKE CALIPER REAR BRAKE CALIPER GUARD REAR BRAKE CALIPER MOUNT YEAR REAR BRAKE HOSE REAR BRAKE LEVER REAR BRAKE MASTER CYLINDER REAR BRAKE MASTER CYLINDER GUARD YEAR REAR BRAKE ROTOR REAR FENDER YEAR REAR HUB YEAR REAR WHEEL SPACERS (WHEEL COLLARS) REED VALVE ASY REED VALVE V-FORCE 3 YEAR SEAT SEAT SDG SHIFT DRUM YEAR SHIFT FORKS SHIFT FORK ROD GUIDE SHAFTS YEAR SHIFT LEVER SHIFT SHAFT YEAR SHOCK SHOCK BRACKETS SHOCK ARM UNI TRAK SHOCK ARM LINKAGE (ARMS OR RODS) YEAR SHOCK SPRING SIDE COVERS SIDE COVER RIGHT YEAR SPROCKET COLLAR STATOR STATOR COVER SUB FRAME YEAR SWING ARM SWING ARM PIVOT PIN THROTTLE TRANSMISSION GEARING TRANSMISSION INPUT SHAFT YEAR TRANSMISSION INPUT 2ND GEAR TRANSMISSION INPUT 3RD GEAR TRANSMISSION OUTPUT SHAFT TRANSMISSION OUTPUT SHAFT 1ST GEAR TRANSMISSION OUTPUT SHAFT 2ND GEAR VOLTAGE REGULATOR WATER PUMP COVER WATER PUMP NECK ELBOW YEAR WATER PUMP IMPELLER WATER PUMP SHAFT WIRE HARNESS YEAR ENGINE WEIGHT YEAR
