Kawasaki KLR ENGINE, PARTS, AND FRAME Identification
page
In an effort to help fellow bikers properly ID their bike I
have provided the following information on VIN ( Vehicle Identification Number )
, Engine ID and part identification.
If you find something that is not accurate, please let us know and we will fix
it.
This information is not intended for use outside of this web site or for
publication.
SCROLL TO THE RIGHT AS THERE IS A LOT OF DATA :-)
For KLR650 Service specifications, click here
OHM METERS MEASURE RESISTANCE A LITTLE DIFFERENT DUE TO THE INTERNAL RESISTANCE OF THE METER SO IF YOU’RE A LITTLE OUT OF SPEC YOUR PART MAY STILL BE GOOD | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
YEAR | TYPE | VIN FRAME USA ONLY | ENGINE ID | ENGINE CASES | AIR BOX | YEAR | TYPE | CABLE CLUTCH | CABLE SPEEDOMETER | CABLE STARTER (CHOKE) | CABLE THROTTLE CLOSE | CABLE THROTTLE OPEN | CAM SHAFT EXHAUST | CAM SHAFT INTAKE | CARBURETOR | YEAR | TYPE | CARB BOOT | CDI | CHAIN SLIDER | CLUTCH ARM | YEAR | TYPE | CLUTCH BASKET | CLUTCH COVER | YEAR | TYPE | CLUTCH PRESSURE PLATE | COIL (IGNITION) | COUNTER BALANCE CHAIN GUIDE FRONT | COUNTER BALANCE CHAIN GUIDE REAR | YEAR | TYPE | FR COUNTER BALANCE SHAFT | RR COUNTER BALANCE SHAFT | COUNTER SPROCKET GUARD | COWLING (Fairing) BRACKET | CRANK SHAFT | CYLINDER | YEAR | TYPE | ENGINE MOUNTS | EXHAUST MUFFLER | FLY WHEEL ROTOR | FOOT PEGS PASSENGER | FOOT PEG PASSENGER MOUNTS | YEAR | TYPE | FORK | YEAR | TYPE | FRONT AXLE | FRONT BRAKE CALIPER | YEAR | TYPE | FRONT BRAKE CALIPER MOUNT | FRONT BRAKE MASTER CYLINDER | YEAR | TYPE | FRONT BRAKE ROTOR | FRONT HUB | YEAR | TYPE | FRONT RIM | YEAR | TYPE | GAS CAP | HEAD | HEAD LIGHT | YEAR | TYPE | HEAD LAMP BODY | IGNITION SWITCH | KICK IDLER GEAR | KICK LEVER | KICK LEVER SHAFT | YEAR | TYPE | LEFT CONTROL SWITCH | YEAR | TYPE | OIL FILTER CAP | PISTON | ONE WAY CLUTCH BEARING | ONE WAY CLUTCH BEARING COUPLING | ONE WAY CLUTCH GEAR | PISTON | PRIMARY CRANK GEAR | YEAR | TYPE | RADIATOR LEFT | RADIATOR RIGHT | RADIATOR FAN | RADIATOR FAN SENDING UNIT | RADIATOR SHROUDS | REAR AXLE | YEAR | TYPE | REAR HUB | YEAR | TYPE | REAR RIM | YEAR | TYPE | REAR BRAKE CALIPER | REAR BRAKE CALIPER MOUNT | YEAR | TYPE | REAR BRAKE ROTOR | REAR FENDER | YEAR | TYPE | SHOCK | YEAR | TYPE | SEAT | SHOCK ARM LINKAGE - UNI TRAK | SHOCK ARM LINKAGE SHAFT/PIN | YEAR | TYPE | SIDE COVER LEFT | SIDE COVER RIGHT | SIDE STAND | SKID PLATE | SPEEDOMETER | YEAR | TYPE | STATOR | STATOR COVER | SUB FRAME | SWING ARM PIN / AXLE | YEAR | TYPE | TIMING CHAIN GUIDE FRONT | TIMING CHAIN GUIDE REAR | TIMING CHAIN TENSIONER | YEAR | TYPE | TRANSMISSION | YEAR | TYPE | TRANSMISSION INPUT SHAFT | TRANSMISSION INPUT 2ND GEAR | TRANSMISSION INPUT 3RD GEAR | YEAR | TYPE | TRANSMISSION INPUT 4TH GEAR | TRANSMISSION INPUT 5TH GEAR | TRANSMISSION INPUT 6TH GEAR | YEAR | TYPE | TRANSMISSION OUTPUT SHAFT | TRANSMISSION OUTPUT 1ST GEAR | YEAR | TYPE | TRANSMISSION OUTPUT 2ND GEAR | TRANSMISSION OUTPUT 3RD GEAR | YEAR | TYPE | TRANSMISSION OUTPUT 4TH GEAR | TRANSMISSION OUTPUT 5TH GEAR | TRANSMISSION OUTPUT 6TH GEAR | TRIPLE TREE BOTTOM | YEAR | TYPE | TRIPLE TREE TOP | TURN SIGNAL FRONT LEFT | TURN SIGNAL FRONT RIGHT | YEAR | TYPE | TURN SIGNAL REAR LEFT | TURN SIGNAL REAR RIGHT | YEAR | TYPE | VALVE (EXHAUST) | VALVE (INTAKE) | VOLTAGE REGULATOR | YEAR | TYPE | WIRE HARNESS | WATER PUMP IMPELLER | YEAR | TYPE |
1985 | KLR250 | FITS 85-05 KLR250 | 1985 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 85-86 KLR250 | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1985 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1985 | KLR250 | 1985 | KLR250 | 1985 | KLR250 | 1985 | KLR250 | FITS 85-86 KLR250 - 34003-1223 LH - 34003-1224 RH | 1985 | KLR250 | 1985 | KLR250 | FITS 84-86 KL600, 85-90 KLR250 | 1985 | KLR250 | FITS 84-86 KL600, 85-90 KLR250 | 1985 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1985 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1985 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1985 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | 1985 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1985 | KLR250 | 1985 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1985 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1985 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1985 | KLR250 | 1985 | KLR250 | 1985 | KLR250 | 1985 | KLR250 | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1985 | KLR250 | 1985 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 1985 | KLR250 | 1985 | KLR250 | 1985 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1985 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1985 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1985 | KLR250 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1985 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1985 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1985 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1985 | KLR250 | 1985 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1985 | KLR250 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1986 | KLR250 | JKAKLM013GA01#### | KHI KL250DE------ | FITS 85-05 KLR250 | 1986 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 85-86 KLR250 | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1986 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1986 | KLR250 | 1986 | KLR250 | 1986 | KLR250 | 1986 | KLR250 | FITS 85-86 KLR250 - 34003-1223 LH - 34003-1224 RH | 1986 | KLR250 | 1986 | KLR250 | FITS 84-86 KL600, 85-90 KLR250 | 1986 | KLR250 | FITS 84-86 KL600, 85-90 KLR250 | 1986 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1986 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1986 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1986 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | 1986 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1986 | KLR250 | 1986 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1986 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1986 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1986 | KLR250 | 1986 | KLR250 | 1986 | KLR250 | 1986 | KLR250 | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1986 | KLR250 | 1986 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 1986 | KLR250 | 1986 | KLR250 | 1986 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1986 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1986 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1986 | KLR250 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1986 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1986 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1986 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1986 | KLR250 | 1986 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1986 | KLR250 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1987 | KLR250 | FITS 85-05 KLR250 | 1987 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | KEIHIN CVK FITS 85-01 KLR250 | 1987 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1987 | KLR250 | 1987 | KLR250 | 1987 | KLR250 | 1987 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 87-93 KLR250 - 34003-1288 LH - 34003-1289 RH | 1987 | KLR250 | 1987 | KLR250 | FITS 84-86 KL600, 85-90 KLR250 | 1987 | KLR250 | FITS 84-86 KL600, 85-90 KLR250 | 1987 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1987 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1987 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1987 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | 1987 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1987 | KLR250 | 1987 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1987 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1987 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1987 | KLR250 | 1987 | KLR250 | 1987 | KLR250 | 1987 | KLR250 | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1987 | KLR250 | 1987 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 1987 | KLR250 | 1987 | KLR250 | 1987 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1987 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1987 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1987 | KLR250 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1987 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1987 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1987 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1987 | KLR250 | 1987 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1987 | KLR250 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1988 | KLR250 | FITS 85-05 KLR250 | 1988 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | KEIHIN CVK FITS 85-01 KLR250 | 1988 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1988 | KLR250 | 1988 | KLR250 | 1988 | KLR250 | 1988 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 87-93 KLR250 - 34003-1288 LH - 34003-1289 RH | 1988 | KLR250 | 1988 | KLR250 | FITS 84-86 KL600, 85-90 KLR250 | 1988 | KLR250 | FITS 84-86 KL600, 85-90 KLR250 | 1988 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1988 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1988 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1988 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | 1988 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1988 | KLR250 | 1988 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1988 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1988 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1988 | KLR250 | 1988 | KLR250 | 1988 | KLR250 | 1988 | KLR250 | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1988 | KLR250 | 1988 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 1988 | KLR250 | 1988 | KLR250 | 1988 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1988 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1988 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1988 | KLR250 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1988 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1988 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1988 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1988 | KLR250 | 1988 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1988 | KLR250 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1989 | KLR250 | FITS 85-05 KLR250 | 1989 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | KEIHIN CVK FITS 85-01 KLR250 | 1989 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1989 | KLR250 | 1989 | KLR250 | 1989 | KLR250 | 1989 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 87-93 KLR250 - 34003-1288 LH - 34003-1289 RH | 1989 | KLR250 | 1989 | KLR250 | FITS 84-86 KL600, 85-90 KLR250 | 1989 | KLR250 | FITS 84-86 KL600, 85-90 KLR250 | 1989 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1989 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1989 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1989 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | 1989 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1989 | KLR250 | 1989 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1989 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1989 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1989 | KLR250 | 1989 | KLR250 | 1989 | KLR250 | 1989 | KLR250 | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1989 | KLR250 | 1989 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 1989 | KLR250 | 1989 | KLR250 | 1989 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1989 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1989 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1989 | KLR250 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1989 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1989 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1989 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1989 | KLR250 | 1989 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1989 | KLR250 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1990 | KLR250 | FITS 85-05 KLR250 | 1990 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | KEIHIN CVK FITS 85-01 KLR250 | 1990 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1990 | KLR250 | 1990 | KLR250 | 1990 | KLR250 | 1990 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 87-93 KLR250 - 34003-1288 LH - 34003-1289 RH | 1990 | KLR250 | 1990 | KLR250 | FITS 84-86 KL600, 85-90 KLR250 | 1990 | KLR250 | FITS 84-86 KL600, 85-90 KLR250 | 1990 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1990 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1990 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1990 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | 1990 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1990 | KLR250 | 1990 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1990 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1990 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1990 | KLR250 | 1990 | KLR250 | 1990 | KLR250 | 1990 | KLR250 | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1990 | KLR250 | 1990 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 1990 | KLR250 | 1990 | KLR250 | 1990 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1990 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1990 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1990 | KLR250 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1990 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1990 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1990 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1990 | KLR250 | 1990 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1990 | KLR250 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1991 | KLR250 | FITS 85-05 KLR250 | 1991 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | KEIHIN CVK FITS 85-01 KLR250 | 1991 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1991 | KLR250 | 1991 | KLR250 | 1991 | KLR250 | 1991 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 87-93 KLR250 - 34003-1288 LH - 34003-1289 RH | 1991 | KLR250 | 1991 | KLR250 | 1991 | KLR250 | 1991 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1991 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1991 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1991 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | 1991 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1991 | KLR250 | 1991 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1991 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1991 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1991 | KLR250 | 1991 | KLR250 | 1991 | KLR250 | 1991 | KLR250 | fits 91-93 klr250 - 53001-1636-MZ | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1991 | KLR250 | 1991 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 1991 | KLR250 | 1991 | KLR250 | 1991 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1991 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1991 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1991 | KLR250 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1991 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1991 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1991 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1991 | KLR250 | 1991 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1991 | KLR250 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1992 | KLR250 | FITS 85-05 KLR250 | 1992 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | KEIHIN CVK FITS 85-01 KLR250 | 1992 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1992 | KLR250 | 1992 | KLR250 | 1992 | KLR250 | 1992 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 87-93 KLR250 - 34003-1288 LH - 34003-1289 RH | 1992 | KLR250 | 1992 | KLR250 | 1992 | KLR250 | 1992 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1992 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1992 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1992 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | 1992 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1992 | KLR250 | 1992 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1992 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1992 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1992 | KLR250 | 1992 | KLR250 | 1992 | KLR250 | 1992 | KLR250 | fits 91-93 klr250 - 53001-1636-MZ | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1992 | KLR250 | 1992 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 1992 | KLR250 | 1992 | KLR250 | 1992 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1992 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1992 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1992 | KLR250 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1992 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1992 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1992 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1992 | KLR250 | 1992 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1992 | KLR250 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1993 | KLR250 | FITS 85-05 KLR250 | 1993 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1993 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1993 | KLR250 | 1993 | KLR250 | 1993 | KLR250 | 1993 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 87-93 KLR250 - 34003-1288 LH - 34003-1289 RH | 1993 | KLR250 | 1993 | KLR250 | 1993 | KLR250 | 1993 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1993 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1993 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1993 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 | 1993 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1993 | KLR250 | 1993 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1993 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1993 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1993 | KLR250 | 1993 | KLR250 | 1993 | KLR250 | 1993 | KLR250 | fits 91-93 klr250 - 53001-1636-MZ | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1993 | KLR250 | 1993 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 1993 | KLR250 | 1993 | KLR250 | 1993 | KLR250 | 15T - FITS 93-05 KLR250R, 94-96 KLX250R, 97-07 KLX300R - 13260-1385 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1993 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 21T - FITS 93-05 KLR250, 97-07 KLX300R, 06-07 KLX250S - 13260-1595 | 1993 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1993 | KLR250 | 30T – FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-12 KLX250S – 13260-1386 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1993 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 21T – FITS 93-05 KLR250, 97-07 KLX300R – 13260-1596 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1993 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1993 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1993 | KLR250 | 1993 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1993 | KLR250 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1994 | KLR250 | FITS 85-05 KLR250 | 1994 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1994 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1994 | KLR250 | 1994 | KLR250 | 1994 | KLR250 | 1994 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 94-96 KLR250 - 34003-1396-45 LH - 34003-1397-45 RH | 1994 | KLR250 | KYB – CONVENTIONAL – K582R K582L – CHROME OD 36MM – C/L 34.75” - BRAKE MOUNT C/L 45MM – AXLE HOLES 15MM – FITS 94-04 KLR250 – 44070-5140 | 1994 | KLR250 | 1994 | KLR250 | 1994 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1994 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1994 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1994 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 | 1994 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1994 | KLR250 | 1994 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1994 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1994 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1994 | KLR250 | 1994 | KLR250 | 1994 | KLR250 | FITS 94-05 KLR250 – 45014-1565 | 1994 | KLR250 | FITS 94-96 KLR250 - 53001-1731-LW | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1994 | KLR250 | 1994 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | FITS 94-96 KLR250 - 32160-1328-45 | 1994 | KLR250 | 1994 | KLR250 | 1994 | KLR250 | 15T - FITS 93-05 KLR250R, 94-96 KLX250R, 97-07 KLX300R - 13260-1385 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1994 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 21T - FITS 93-05 KLR250, 97-07 KLX300R, 06-07 KLX250S - 13260-1595 | 1994 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1994 | KLR250 | 30T – FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-12 KLX250S – 13260-1386 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1994 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 21T – FITS 93-05 KLR250, 97-07 KLX300R – 13260-1596 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1994 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1994 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1994 | KLR250 | 1994 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1994 | KLR250 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1995 | KLR250 | FITS 85-05 KLR250 | 1995 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1995 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1995 | KLR250 | 1995 | KLR250 | 1995 | KLR250 | 1995 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 94-96 KLR250 - 34003-1396-45 LH - 34003-1397-45 RH | 1995 | KLR250 | KYB – CONVENTIONAL – K582R K582L – CHROME OD 36MM – C/L 34.75” - BRAKE MOUNT C/L 45MM – AXLE HOLES 15MM – FITS 94-04 KLR250 – 44070-5140 | 1995 | KLR250 | 1995 | KLR250 | 1995 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1995 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1995 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1995 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 | 1995 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1995 | KLR250 | 1995 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1995 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1995 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1995 | KLR250 | 1995 | KLR250 | 1995 | KLR250 | FITS 94-05 KLR250 – 45014-1565 | 1995 | KLR250 | FITS 94-96 KLR250 - 53001-1731-LW | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1995 | KLR250 | 1995 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | FITS 94-96 KLR250 - 32160-1328-45 | 1995 | KLR250 | 1995 | KLR250 | 1995 | KLR250 | 15T - FITS 93-05 KLR250R, 94-96 KLX250R, 97-07 KLX300R - 13260-1385 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1995 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 21T - FITS 93-05 KLR250, 97-07 KLX300R, 06-07 KLX250S - 13260-1595 | 1995 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1995 | KLR250 | 30T – FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-12 KLX250S – 13260-1386 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1995 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 21T – FITS 93-05 KLR250, 97-07 KLX300R – 13260-1596 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1995 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1995 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1995 | KLR250 | 1995 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1995 | KLR250 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1996 | KLR250 | FITS 85-05 KLR250 | 1996 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1996 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1996 | KLR250 | 1996 | KLR250 | 1996 | KLR250 | 1996 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 94-96 KLR250 - 34003-1396-45 LH - 34003-1397-45 RH | 1996 | KLR250 | KYB – CONVENTIONAL – K582R K582L – CHROME OD 36MM – C/L 34.75” - BRAKE MOUNT C/L 45MM – AXLE HOLES 15MM – FITS 94-04 KLR250 – 44070-5140 | 1996 | KLR250 | 1996 | KLR250 | 1996 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1996 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1996 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1996 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 | 1996 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1996 | KLR250 | 1996 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1996 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1996 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1996 | KLR250 | 1996 | KLR250 | 1996 | KLR250 | FITS 94-05 KLR250 – 45014-1565 | 1996 | KLR250 | FITS 94-96 KLR250 - 53001-1731-LW | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1996 | KLR250 | 1996 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | FITS 94-96 KLR250 - 32160-1328-45 | 1996 | KLR250 | 1996 | KLR250 | 1996 | KLR250 | 15T - FITS 93-05 KLR250R, 94-96 KLX250R, 97-07 KLX300R - 13260-1385 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1996 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 21T - FITS 93-05 KLR250, 97-07 KLX300R, 06-07 KLX250S - 13260-1595 | 1996 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1996 | KLR250 | 30T – FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-12 KLX250S – 13260-1386 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1996 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 21T – FITS 93-05 KLR250, 97-07 KLX300R – 13260-1596 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1996 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1996 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1996 | KLR250 | 1996 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1996 | KLR250 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1997 | KLR250 | FITS 85-05 KLR250 | 1997 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1997 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1997 | KLR250 | 1997 | KLR250 | 1997 | KLR250 | 1997 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 97-05 KLR250 - 34003-1396-CE RH - 34003-1397-CE LH | 1997 | KLR250 | KYB – CONVENTIONAL – K582R K582L – CHROME OD 36MM – C/L 34.75” - BRAKE MOUNT C/L 45MM – AXLE HOLES 15MM – FITS 94-04 KLR250 – 44070-5140 | 1997 | KLR250 | 1997 | KLR250 | 1997 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1997 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1997 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1997 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 | 1997 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1997 | KLR250 | 1997 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1997 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1997 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1997 | KLR250 | 1997 | KLR250 | 1997 | KLR250 | FITS 94-05 KLR250 – 45014-1565 | 1997 | KLR250 | FITS 97-00 KLR250 - 53001-1731-LJ | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1997 | KLR250 | 1997 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 1997 | KLR250 | 1997 | KLR250 | 1997 | KLR250 | 15T - FITS 93-05 KLR250R, 94-96 KLX250R, 97-07 KLX300R - 13260-1385 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1997 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 21T - FITS 93-05 KLR250, 97-07 KLX300R, 06-07 KLX250S - 13260-1595 | 1997 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1997 | KLR250 | 30T – FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-12 KLX250S – 13260-1386 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1997 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 21T – FITS 93-05 KLR250, 97-07 KLX300R – 13260-1596 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1997 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1997 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1997 | KLR250 | 1997 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1997 | KLR250 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1998 | KLR250 | FITS 85-05 KLR250 | 1998 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1998 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1998 | KLR250 | 1998 | KLR250 | 1998 | KLR250 | 1998 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 97-05 KLR250 - 34003-1396-CE RH - 34003-1397-CE LH | 1998 | KLR250 | KYB – CONVENTIONAL – K582R K582L – CHROME OD 36MM – C/L 34.75” - BRAKE MOUNT C/L 45MM – AXLE HOLES 15MM – FITS 94-04 KLR250 – 44070-5140 | 1998 | KLR250 | 1998 | KLR250 | 1998 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1998 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1998 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1998 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 | 1998 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1998 | KLR250 | 1998 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1998 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1998 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1998 | KLR250 | 1998 | KLR250 | 1998 | KLR250 | FITS 94-05 KLR250 – 45014-1565 | 1998 | KLR250 | FITS 97-00 KLR250 - 53001-1731-LJ | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1998 | KLR250 | 1998 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 1998 | KLR250 | 1998 | KLR250 | 1998 | KLR250 | 15T - FITS 93-05 KLR250R, 94-96 KLX250R, 97-07 KLX300R - 13260-1385 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1998 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 21T - FITS 93-05 KLR250, 97-07 KLX300R, 06-07 KLX250S - 13260-1595 | 1998 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1998 | KLR250 | 30T – FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-12 KLX250S – 13260-1386 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1998 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 21T – FITS 93-05 KLR250, 97-07 KLX300R – 13260-1596 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1998 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1998 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1998 | KLR250 | 1998 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1998 | KLR250 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1999 | KLR250 | FITS 85-05 KLR250 | 1999 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1999 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 1999 | KLR250 | 1999 | KLR250 | 1999 | KLR250 | 1999 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 97-05 KLR250 - 34003-1396-CE RH - 34003-1397-CE LH | 1999 | KLR250 | KYB – CONVENTIONAL – K582R K582L – CHROME OD 36MM – C/L 34.75” - BRAKE MOUNT C/L 45MM – AXLE HOLES 15MM – FITS 94-04 KLR250 – 44070-5140 | 1999 | KLR250 | 1999 | KLR250 | 1999 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1999 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1999 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | 1999 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 | 1999 | KLR250 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1999 | KLR250 | 1999 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 1999 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 1999 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 1999 | KLR250 | 1999 | KLR250 | 1999 | KLR250 | FITS 94-05 KLR250 – 45014-1565 | 1999 | KLR250 | FITS 97-00 KLR250 - 53001-1731-LJ | FITS 85-05 KLR250 39007-1059, 46102-1129 | 1999 | KLR250 | 1999 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 1999 | KLR250 | 1999 | KLR250 | 1999 | KLR250 | 15T - FITS 93-05 KLR250R, 94-96 KLX250R, 97-07 KLX300R - 13260-1385 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 1999 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 21T - FITS 93-05 KLR250, 97-07 KLX300R, 06-07 KLX250S - 13260-1595 | 1999 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 1999 | KLR250 | 30T – FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-12 KLX250S – 13260-1386 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 1999 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 21T – FITS 93-05 KLR250, 97-07 KLX300R – 13260-1596 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 1999 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1999 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 1999 | KLR250 | 1999 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1999 | KLR250 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2000 | KLR250 | JKAKLMD15YA10#### | KL250DE04#### | FITS 85-05 KLR250 | 2000 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 2000 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 2000 | KLR250 | 2000 | KLR250 | 2000 | KLR250 | 2000 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 97-05 KLR250 - 34003-1396-CE RH - 34003-1397-CE LH | 2000 | KLR250 | KYB – CONVENTIONAL – K582R K582L – CHROME OD 36MM – C/L 34.75” - BRAKE MOUNT C/L 45MM – AXLE HOLES 15MM – FITS 94-04 KLR250 – 44070-5140 | 2000 | KLR250 | 2000 | KLR250 | 2000 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 2000 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 2000 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2000 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 | 2000 | KLR250 | 2000 | KLR250 | 2000 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | FITS 00-03 KLR250 – 49089-1057-68 / 49089-1058-68 | 2000 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 2000 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 2000 | KLR250 | 2000 | KLR250 | 2000 | KLR250 | FITS 94-05 KLR250 – 45014-1565 | 2000 | KLR250 | FITS 97-00 KLR250 - 53001-1731-LJ | FITS 85-05 KLR250 39007-1059, 46102-1129 | 2000 | KLR250 | 2000 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 2000 | KLR250 | 2000 | KLR250 | 2000 | KLR250 | 15T - FITS 93-05 KLR250R, 94-96 KLX250R, 97-07 KLX300R - 13260-1385 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 2000 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 21T - FITS 93-05 KLR250, 97-07 KLX300R, 06-07 KLX250S - 13260-1595 | 2000 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 2000 | KLR250 | 30T – FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-12 KLX250S – 13260-1386 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 2000 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 21T – FITS 93-05 KLR250, 97-07 KLX300R – 13260-1596 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 2000 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 2000 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 2000 | KLR250 | 2000 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2000 | KLR250 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2001 | KLR250 | FITS 85-05 KLR250 | 2001 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 2001 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 2001 | KLR250 | 2001 | KLR250 | 2001 | KLR250 | 2001 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 97-05 KLR250 - 34003-1396-CE RH - 34003-1397-CE LH | 2001 | KLR250 | KYB – CONVENTIONAL – K582R K582L – CHROME OD 36MM – C/L 34.75” - BRAKE MOUNT C/L 45MM – AXLE HOLES 15MM – FITS 94-04 KLR250 – 44070-5140 | 2001 | KLR250 | 2001 | KLR250 | 2001 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 2001 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 2001 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2001 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 | 2001 | KLR250 | 2001 | KLR250 | 2001 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | FITS 00-03 KLR250 – 49089-1057-68 / 49089-1058-68 | 2001 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 2001 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 2001 | KLR250 | 2001 | KLR250 | 2001 | KLR250 | FITS 94-05 KLR250 – 45014-1565 | 2001 | KLR250 | FITS 85-05 KLR250 39007-1059, 46102-1129 | 2001 | KLR250 | 2001 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 2001 | KLR250 | 2001 | KLR250 | 2001 | KLR250 | 15T - FITS 93-05 KLR250R, 94-96 KLX250R, 97-07 KLX300R - 13260-1385 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 2001 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 21T - FITS 93-05 KLR250, 97-07 KLX300R, 06-07 KLX250S - 13260-1595 | 2001 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 2001 | KLR250 | 30T – FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-12 KLX250S – 13260-1386 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 2001 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 21T – FITS 93-05 KLR250, 97-07 KLX300R – 13260-1596 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 2001 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 2001 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 2001 | KLR250 | 2001 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2001 | KLR250 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2002 | KLR250 | FITS 85-05 KLR250 | 2002 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | FITS 85-86, 93-05 KLR250 | 2002 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 2002 | KLR250 | 2002 | KLR250 | 2002 | KLR250 | 2002 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 97-05 KLR250 - 34003-1396-CE RH - 34003-1397-CE LH | 2002 | KLR250 | KYB – CONVENTIONAL – K582R K582L – CHROME OD 36MM – C/L 34.75” - BRAKE MOUNT C/L 45MM – AXLE HOLES 15MM – FITS 94-04 KLR250 – 44070-5140 | 2002 | KLR250 | 2002 | KLR250 | 2002 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 2002 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 2002 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2002 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 | 2002 | KLR250 | 2002 | KLR250 | 2002 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | FITS 00-03 KLR250 – 49089-1057-68 / 49089-1058-68 | 2002 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 2002 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 2002 | KLR250 | 2002 | KLR250 | 2002 | KLR250 | FITS 94-05 KLR250 – 45014-1565 | 2002 | KLR250 | FITS 85-05 KLR250 39007-1059, 46102-1129 | 2002 | KLR250 | 2002 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 2002 | KLR250 | 2002 | KLR250 | 2002 | KLR250 | 15T - FITS 93-05 KLR250R, 94-96 KLX250R, 97-07 KLX300R - 13260-1385 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 2002 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 21T - FITS 93-05 KLR250, 97-07 KLX300R, 06-07 KLX250S - 13260-1595 | 2002 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 2002 | KLR250 | 30T – FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-12 KLX250S – 13260-1386 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 2002 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 21T – FITS 93-05 KLR250, 97-07 KLX300R – 13260-1596 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 2002 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 2002 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 2002 | KLR250 | 2002 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2002 | KLR250 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2003 | KLR250 | FITS 85-05 KLR250 | 2003 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | FITS 85-86, 93-05 KLR250 | 2003 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 2003 | KLR250 | 2003 | KLR250 | 2003 | KLR250 | 2003 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 97-05 KLR250 - 34003-1396-CE RH - 34003-1397-CE LH | 2003 | KLR250 | KYB – CONVENTIONAL – K582R K582L – CHROME OD 36MM – C/L 34.75” - BRAKE MOUNT C/L 45MM – AXLE HOLES 15MM – FITS 94-04 KLR250 – 44070-5140 | 2003 | KLR250 | 2003 | KLR250 | 2003 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 2003 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 2003 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2003 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 | 2003 | KLR250 | 2003 | KLR250 | 2003 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | FITS 00-03 KLR250 – 49089-1057-68 / 49089-1058-68 | 2003 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 2003 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 2003 | KLR250 | 2003 | KLR250 | 2003 | KLR250 | FITS 94-05 KLR250 – 45014-1565 | 2003 | KLR250 | FITS 85-05 KLR250 39007-1059, 46102-1129 | 2003 | KLR250 | 2003 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 2003 | KLR250 | 2003 | KLR250 | 2003 | KLR250 | 15T - FITS 93-05 KLR250R, 94-96 KLX250R, 97-07 KLX300R - 13260-1385 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 2003 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 21T - FITS 93-05 KLR250, 97-07 KLX300R, 06-07 KLX250S - 13260-1595 | 2003 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 2003 | KLR250 | 30T – FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-12 KLX250S – 13260-1386 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 2003 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 21T – FITS 93-05 KLR250, 97-07 KLX300R – 13260-1596 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 2003 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 2003 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 2003 | KLR250 | 2003 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2003 | KLR250 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2004 | KLR250 | FITS 85-05 KLR250 | 2004 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 87-04 KLR250 - 54012-1239 | FITS 87-04 KLR250 - 54012-1238 | FITS 85-86, 93-05 KLR250 | 2004 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 2004 | KLR250 | 2004 | KLR250 | 2004 | KLR250 | 2004 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 97-05 KLR250 - 34003-1396-CE RH - 34003-1397-CE LH | 2004 | KLR250 | KYB – CONVENTIONAL – K582R K582L – CHROME OD 36MM – C/L 34.75” - BRAKE MOUNT C/L 45MM – AXLE HOLES 15MM – FITS 94-04 KLR250 – 44070-5140 | 2004 | KLR250 | 2004 | KLR250 | 2004 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 2004 | KLR250 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 2004 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2004 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 | 2004 | KLR250 | 2004 | KLR250 | 2004 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 2004 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 2004 | KLR250 | TAKASAGO - J 17X2.15 DOT 351 JAPAN 899 - FITS 85-04 KLR250 | 2004 | KLR250 | 2004 | KLR250 | 2004 | KLR250 | FITS 94-05 KLR250 – 45014-1565 | 2004 | KLR250 | FITS 85-05 KLR250 39007-1059, 46102-1129 | 2004 | KLR250 | 2004 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 2004 | KLR250 | 2004 | KLR250 | 2004 | KLR250 | 15T - FITS 93-05 KLR250R, 94-96 KLX250R, 97-07 KLX300R - 13260-1385 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 2004 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 21T - FITS 93-05 KLR250, 97-07 KLX300R, 06-07 KLX250S - 13260-1595 | 2004 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 2004 | KLR250 | 30T – FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-12 KLX250S – 13260-1386 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 2004 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 21T – FITS 93-05 KLR250, 97-07 KLX300R – 13260-1596 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 2004 | KLR250 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 2004 | KLR250 | FITS 85-04 KLR250 - 23037-1213 | FITS 85-04 KLR250 - 23037-1213 | 2004 | KLR250 | 2004 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2004 | KLR250 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2005 | KLR250 | FITS 85-05 KLR250 | 2005 | KLR250 | FITS 85-05 KLR250 - 54011-1225 | FITS 85-05 KLR250 - 54001-1112 | FITS 85-05 KLR250 - 54017-1058 | FITS 85-86, 93-05 KLR250 | 2005 | KLR250 | FITS 85-05 KLR250 - 16065-1143 | 2005 | KLR250 | 2005 | KLR250 | 2005 | KLR250 | 2005 | KLR250 | FITS 87-05 KLR250 - 92076-020 | FITS 97-05 KLR250 - 34003-1396-CE RH - 34003-1397-CE LH | 2005 | KLR250 | 2005 | KLR250 | 2005 | KLR250 | 2005 | KLR250 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 2005 | KLR250 | 2005 | KLR250 | FITS 85-05 KLR250, 87-96 KSF250 - 11008-1189 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2005 | KLR250 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | 28T - FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | FITS 85-05 KLR250 - 13064-1121 | FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13066-1088 | 2005 | KLR250 | 2005 | KLR250 | 2005 | KLR250 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | 2005 | KLR250 | DRUM STYLE – 120.75 MAX DIA – BLACK – AXLE OD 17MM – BRG TO BRG 108-109MM – 36 SPOKES - FITS 85-05 KLR250 – 41034-1113 | 2005 | KLR250 | 1 | 2005 | KLR250 | 2005 | KLR250 | 2005 | KLR250 | FITS 94-05 KLR250 – 45014-1565 | 2005 | KLR250 | FITS 85-05 KLR250 39007-1059, 46102-1129 | 2005 | KLR250 | 2005 | KLR250 | FITS 85-05 KLR250 - 21003-1121 | 2005 | KLR250 | 2005 | KLR250 | 2005 | KLR250 | 15T - FITS 93-05 KLR250R, 94-96 KLX250R, 97-07 KLX300R - 13260-1385 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 2005 | KLR250 | 18T & 20T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 13129-1602 | 21T - FITS 93-05 KLR250, 97-07 KLX300R, 06-07 KLX250S - 13260-1595 | 2005 | KLR250 | 30T - FITS 87-98 KSF250, 85-05 KLR250, 94-96 KLX250R, 97-02 KLX300R - 13129-1800 | 2005 | KLR250 | 30T – FITS 93-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-12 KLX250S – 13260-1386 | 27T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S – 13129-1650 | 2005 | KLR250 | 25T – FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX30R – 13129-1651 | 21T – FITS 93-05 KLR250, 97-07 KLX300R – 13260-1596 | 19T - FITS 85-05 KLR250, 94-96 KLX250R, 97-07 KLX300R - 06-07 KLX250S - 13129-1653 | 2005 | KLR250 | FITS 05 KLR250, 05-07 KLR650, 06-07 KLX250 - 23037-0027 | FITS 05 KLR250, 05-07 KLR650, 06-07 KLX250 - 23037-0027 | 2005 | KLR250 | 2005 | KLR250 | 2005 | KLR250 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2005 | KLR250 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
YEAR | TYPE | VIN FRAME USA ONLY | ENGINE ID | ENGINE CASES | AIR BOX | YEAR | TYPE | CABLE CLUTCH | CABLE SPEEDOMETER | CABLE STARTER (CHOKE) | CABLE THROTTLE CLOSE | CABLE THROTTLE OPEN | CAM SHAFT EXHAUST | CAM SHAFT INTAKE | CARBURETOR | YEAR | TYPE | CARB BOOT | CDI | CHAIN SLIDER | CLUTCH ARM | YEAR | TYPE | CLUTCH BASKET | CLUTCH COVER | YEAR | TYPE | CLUTCH PRESSURE PLATE | COIL (IGNITION) | COUNTER BALANCE CHAIN GUIDE FRONT | COUNTER BALANCE CHAIN GUIDE REAR | YEAR | TYPE | FR COUNTER BALANCE SHAFT | RR COUNTER BALANCE SHAFT | COUNTER SPROCKET GUARD | COWLING (Fairing) BRACKET | CRANK SHAFT | CYLINDER | YEAR | TYPE | ENGINE MOUNTS | EXHAUST MUFFLER | FLY WHEEL ROTOR | FOOT PEGS PASSENGER | FOOT PEG PASSENGER MOUNTS | YEAR | TYPE | FORK | YEAR | TYPE | FRONT AXLE | FRONT BRAKE CALIPER | YEAR | TYPE | FRONT BRAKE CALIPER MOUNT | FRONT BRAKE MASTER CYLINDER | YEAR | TYPE | FRONT BRAKE ROTOR | FRONT HUB | YEAR | TYPE | FRONT RIM | YEAR | TYPE | GAS CAP | HEAD | HEAD LIGHT | YEAR | TYPE | HEAD LAMP BODY | IGNITION SWITCH | KICK IDLER GEAR | KICK LEVER | KICK LEVER SHAFT | YEAR | TYPE | LEFT CONTROL SWITCH | YEAR | TYPE | OIL FILTER CAP | PISTON | ONE WAY CLUTCH BEARING | ONE WAY CLUTCH BEARING COUPLING | ONE WAY CLUTCH GEAR | PISTON | PRIMARY CRANK GEAR | YEAR | TYPE | RADIATOR LEFT | RADIATOR RIGHT | RADIATOR FAN | RADIATOR FAN SENDING UNIT | RADIATOR SHROUDS | REAR AXLE | YEAR | TYPE | REAR HUB | YEAR | TYPE | REAR RIM | YEAR | TYPE | REAR BRAKE CALIPER | REAR BRAKE CALIPER MOUNT | YEAR | TYPE | REAR BRAKE ROTOR | REAR FENDER | YEAR | TYPE | SHOCK | YEAR | TYPE | SEAT | SHOCK ARM LINKAGE - UNI TRAK | SHOCK ARM LINKAGE SHAFT/PIN | YEAR | TYPE | SIDE COVER LEFT | SIDE COVER RIGHT | SIDE STAND | SKID PLATE | SPEEDOMETER | YEAR | TYPE | STATOR | STATOR COVER | SUB FRAME | SWING ARM PIN / AXLE | YEAR | TYPE | TIMING CHAIN GUIDE FRONT | TIMING CHAIN GUIDE REAR | TIMING CHAIN TENSIONER | YEAR | TYPE | TRANSMISSION | YEAR | TYPE | TRANSMISSION INPUT SHAFT | TRANSMISSION INPUT 2ND GEAR | TRANSMISSION INPUT 3RD GEAR | YEAR | TYPE | TRANSMISSION INPUT 4TH GEAR | TRANSMISSION INPUT 5TH GEAR | TRANSMISSION INPUT 6TH GEAR | YEAR | TYPE | TRANSMISSION OUTPUT SHAFT | TRANSMISSION OUTPUT 1ST GEAR | YEAR | TYPE | TRANSMISSION OUTPUT 2ND GEAR | TRANSMISSION OUTPUT 3RD GEAR | YEAR | TYPE | TRANSMISSION OUTPUT 4TH GEAR | TRANSMISSION OUTPUT 5TH GEAR | TRANSMISSION OUTPUT 6TH GEAR | TRIPLE TREE BOTTOM | YEAR | TYPE | TRIPLE TREE TOP | TURN SIGNAL FRONT LEFT | TURN SIGNAL FRONT RIGHT | YEAR | TYPE | TURN SIGNAL REAR LEFT | TURN SIGNAL REAR RIGHT | YEAR | TYPE | VALVE (EXHAUST) | VALVE (INTAKE) | VOLTAGE REGULATOR | YEAR | TYPE | WIRE HARNESS | WATER PUMP IMPELLER | YEAR | TYPE |
1984 | KLR600 | FITS 84 KL600 - 14001-5267 | FITS 84 KL600 - 11011-1160 | 1984 | KLR600 | FITS 84-86 KL600 - 54001-1116 | FITS 84-86 KL600, 87-95 KLR650 12044-1197 | FITS 84 KL600, 87-95 KLR650 12044-1114 | 1984 | KLR600 | FITS 84-86 KLR600 - 21119-1252 | 1984 | KLR600 | 1984 | KLR600 | FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1984 | KLR600 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 84 KL600 - 13031-1175 | 1984 | KLR600 | FITS 84-86 KL600 - RH 32029-1309, LH 32029-1334 | FITS 84-86 KL600 - 18002-1597 | FITS 84 KL600 - 21050-1104 | 1984 | KLR600 | 1984 | KLR600 | FITS 84-86 KL600, 85-90 KLR250 | 1984 | KLR600 | FITS 84-86 KL600, 85-90 KLR250 | 1984 | KLR600 | FITS 84 KL600 41034-1106 | 1984 | KLR600 | 1984 | KLR600 | FITS 84-86 KL600 – 11008-1157 | FITS 84-86 KL600 - 23004-1251 | 1984 | KLR600 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 84-86 KLR600 - 13064-1102 | FITS 84-86 KLR600, 87-95 KLR650 - 13066-1058 | 1984 | KLR600 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1984 | KLR600 | 1984 | KLR600 | FITS 84-86 KL600 - 39060-1055 | FITS 84-86 KL600 - 39060-1056 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | 1984 | KLR600 | Fits 84-86 kl600 41034-1107 | 1984 | KLR600 | 1984 | KLR600 | 1984 | KLR600 | 1984 | KLR600 | 1984 | KLR600 | FITS 84-86 KL600 39007-1057, 46102-1115 | 1984 | KLR600 | 1984 | KLR600 | FITS 84 KL600 - 21003-1110 | 1984 | KLR600 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | 1984 | KLR600 | OUTPUT SHAFT FITS 84-86 KLR600, 87-89 KLR650 | 1984 | KLR600 | FITS 84-86 KL600 - 13127-1107 | 17T - FITS 84-86 KL600, 87-96 KLR650, 93 KLX650R KLX650C - 13129-1518 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1519 | 1984 | KLR600 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1520 | 24T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1984 | KLR600 | FITS 84-86 KL600, 87-89 KLR650 - 13128-1104 | 39T - FITS 84-86 KL600 - 13129-1522 | 1984 | KLR600 | 26T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1523 | 26T - FITS 84-86KL600, 87-96 KLR650 - 13129-1524 | 1984 | KLR600 | 21T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1525 | 19T- FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1984 | KLR600 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1984 | KLR600 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1984 | KLR600 | 1984 | KLR600 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1984 | KLR600 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
1985 | KLR600 | FITS 85-86 KL600 - 14001-5187 | FITS 85-86 KL600 - 11011-1261 | 1985 | KLR600 | FITS 84-86 KL600 - 54001-1116 | FITS 84-86 KL600, 87-95 KLR650 12044-1197 | FITS 85-86 KL600 - 15001-1223 | 1985 | KLR600 | FITS 84-86 KLR600 - 21119-1252 | FITS 85-86 KL600, 87-95 KLR650 - 13102-1074 | 1985 | KLR600 | FITS 85-86 KL600 - 13095-1124 | FITS 85-86 KL600 - 14032-1187 | 1985 | KLR600 | FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1985 | KLR600 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 85-86 KL600- 13031-1186 | 1985 | KLR600 | FITS 84-86 KL600 - RH 32029-1309, LH 32029-1334 | FITS 84-86 KL600 - 18002-1597 | 1985 | KLR600 | CONVENTIONAL - CHROME OD 38 - C/L 36 5/8" - BRAKE MOUNT C/L 45MM - AXLE HOLES 15MM | 1985 | KLR600 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 84-86 KL600, 85-90 KLR250 | 1985 | KLR600 | FITS 84-86 KL600, 85-90 KLR250 | 1985 | KLR600 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1985 | KLR600 | 1985 | KLR600 | FITS 84-86 KL600 – 11008-1157 | FITS 84-86 KL600 - 23004-1251 | 1985 | KLR600 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 84-86 KLR600 - 13064-1102 | FITS 84-86 KLR600, 87-95 KLR650 - 13066-1058 | 1985 | KLR600 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1985 | KLR600 | 1985 | KLR600 | FITS 84-86 KL600 - 39060-1055 | FITS 84-86 KL600 - 39060-1056 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 85-86 KL600 KLR600 - 41068-1184 CLICK HERE FOR MEASUREMENTS | 1985 | KLR600 | Fits 84-86 kl600 41034-1107 | 1985 | KLR600 | 1985 | KLR600 | 1985 | KLR600 | 1985 | KLR600 | 1985 | KLR600 | FITS 84-86 KL600 39007-1057, 46102-1115 | 1985 | KLR600 | FITS 85-86 KL600 - 34024-1193 | 1985 | KLR600 | FITS 85-86 KL600 - 21003-1130 | 1985 | KLR600 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | 1985 | KLR600 | OUTPUT SHAFT FITS 84-86 KLR600, 87-89 KLR650 | 1985 | KLR600 | FITS 84-86 KL600 - 13127-1107 | 17T - FITS 84-86 KL600, 87-96 KLR650, 93 KLX650R KLX650C - 13129-1518 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1519 | 1985 | KLR600 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1520 | 24T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1985 | KLR600 | FITS 84-86 KL600, 87-89 KLR650 - 13128-1104 | 39T - FITS 84-86 KL600 - 13129-1522 | 1985 | KLR600 | 26T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1523 | 26T - FITS 84-86KL600, 87-96 KLR650 - 13129-1524 | 1985 | KLR600 | 21T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1525 | 19T- FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1985 | KLR600 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1985 | KLR600 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1985 | KLR600 | FITS 85-86 KL600, 87-07 KLR650 | 1985 | KLR600 | FITS 85-86 KL600 - 26001-1693 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1985 | KLR600 | ||||||||||||||||||||||||||||||||||||||||||||||||||
1986 | KLR600 | JKAKL4B10GA01#### | KHI KL600AE02#### | FITS 85-86 KL600 - 14001-5187 | FITS 85-86 KL600 - 11011-1261 | 1986 | KLR600 | FITS 84-86 KL600 - 54001-1116 | FITS 84-86 KL600, 87-95 KLR650 12044-1197 | FITS 85-86 KL600 - 15001-1223 | 1986 | KLR600 | FITS 84-86 KLR600 - 21119-1252 | FITS 85-86 KL600, 87-95 KLR650 - 13102-1074 | 1986 | KLR600 | FITS 85-86 KL600 - 13095-1124 | FITS 85-86 KL600 - 14032-1187 | 1986 | KLR600 | FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1986 | KLR600 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 85-86 KL600- 13031-1186 | 1986 | KLR600 | FITS 84-86 KL600 - RH 32029-1309, LH 32029-1334 | FITS 84-86 KL600 - 18002-1597 | 1986 | KLR600 | CONVENTIONAL - CHROME OD 38 - C/L 36 5/8" - BRAKE MOUNT C/L 45MM - AXLE HOLES 15MM | 1986 | KLR600 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 84-86 KL600, 85-90 KLR250 | 1986 | KLR600 | FITS 84-86 KL600, 85-90 KLR250 | 1986 | KLR600 | F1146 – BLACK – AXLE OD 15MM – BRG TP BRG 101-102MM – ROTOR OD 240MM – ID 130MM – 9X BC OF 145MM – 36 SPOKES - FITS 85-05 KLR250, 85-86 KL600 – 41034-1128 | 1986 | KLR600 | 1986 | KLR600 | FITS 84-86 KL600 – 11008-1157 | FITS 84-86 KL600 - 23004-1251 | 1986 | KLR600 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 84-86 KLR600 - 13064-1102 | FITS 84-86 KLR600, 87-95 KLR650 - 13066-1058 | 1986 | KLR600 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1986 | KLR600 | 1986 | KLR600 | FITS 84-86 KL600 - 39060-1055 | FITS 84-86 KL600 - 39060-1056 | FITS 84-86 KL600, 85-05 KLR250 - 59502-1052 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 85-86 KL600 KLR600 - 41068-1184 CLICK HERE FOR MEASUREMENTS | 1986 | KLR600 | Fits 84-86 kl600 41034-1107 | 1986 | KLR600 | 1986 | KLR600 | 1986 | KLR600 | 1986 | KLR600 | SPRING WIRE OD 10.5MM, SPRING OD 78.5MM, SPRING LENGTH 263MM - BODY OD 45.6MM - UPPER MOUNT WIDTH 31.8MM, HOLE ID 12MM - LOWER MOUNT INTERNAL WIDTH 29.9MM, EXTERNAL WIDTH 49.5MM, HOLE ID 20MM - EYE TO EYE 445MM (17.5") FITS 85-86 KLR600 45014-1303 | 1986 | KLR600 | FITS 84-86 KL600 39007-1057, 46102-1115 | 1986 | KLR600 | FITS 85-86 KL600 - 34024-1193 | 1986 | KLR600 | FITS 85-86 KL600 - 21003-1130 | 1986 | KLR600 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | 1986 | KLR600 | OUTPUT SHAFT FITS 84-86 KLR600, 87-89 KLR650 | 1986 | KLR600 | FITS 84-86 KL600 - 13127-1107 | 17T - FITS 84-86 KL600, 87-96 KLR650, 93 KLX650R KLX650C - 13129-1518 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1519 | 1986 | KLR600 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1520 | 24T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1986 | KLR600 | FITS 84-86 KL600, 87-89 KLR650 - 13128-1104 | 39T - FITS 84-86 KL600 - 13129-1522 | 1986 | KLR600 | 26T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1523 | 26T - FITS 84-86KL600, 87-96 KLR650 - 13129-1524 | 1986 | KLR600 | 21T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1525 | 19T- FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1986 | KLR600 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1986 | KLR600 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1986 | KLR600 | FITS 85-86 KL600, 87-07 KLR650 | 1986 | KLR600 | FITS 85-86 KL600 - 26001-1693 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1986 | KLR600 | |||||||||||||||||||||||||||||||||||||||||||||||
1987 | KLR650 | JKAKLEA1HA000001 | KHI KL650AE01#### | FITS 87-88 KLR650 14001-5229 | FITS 87-95 KLR650 - 11011-1301 | 1987 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-95 KLR650 - 54001-1128 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 84-86 KL600, 87-95 KLR650 12044-1197 | FITS 84 KL600, 87-95 KLR650 12044-1114 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 1987 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | FITS 87-89 KLR650 | FITS 85-86 KL600, 87-95 KLR650 - 13102-1074 | 1987 | KLR650 | 75T, 18T, FITS 87-95 KLR650 - 13095-1157 | FITS 87-95 KLR650 - 14032-1230 | 1987 | KLR650 | FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1987 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-95 KLR650 - 14026-1131 | FITS 87-07 KLR650 - 11046-1036 | FITS 87 KLR650 - 13031-1235 | FITS 87-95 KLR650 - 11005-1511 | 1987 | KLR650 | FITS 87-91 KLR650 - 32029-1516 | FITS 87-06 KLR650 - 18002-1887 | FITS 87-89 KLR650 - 21050-1130 | 1987 | KLR650 | 1987 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | 1987 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 1987 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 1987 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1987 | KLR650 | FITS 87-95 KLR650 – 11008-1202 | 1987 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | FITS 87-95 KLR650 - 13064-1133 | FITS 84-86 KLR600, 87-95 KLR650 - 13066-1058 | 1987 | KLR650 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1987 | KLR650 | FITS 87-07 KLR650 - 13001-1284 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 87-95 KLR650, 93-95 KLX650R - 13097-1185 | 1987 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 1987 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1987 | KLR650 | 1987 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 1987 | KLR650 | FITS 87-07 KLR650 | 1987 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 1987 | KLR650 | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 1987 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 1987 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 87-10 KLR650 | 1987 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | 1987 | KLR650 | INPUT SHAFT FITS 87-11 KLR650 – OUTPUT SHAFT FITS 87-89 KLR650 - GEARS FIT 87-96 KLR650 | 1987 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 17T - FITS 84-86 KL600, 87-96 KLR650, 93 KLX650R KLX650C - 13129-1518 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1519 | 1987 | KLR650 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1520 | 24T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1987 | KLR650 | FITS 84-86 KL600, 87-89 KLR650 - 13128-1104 | 34T - FITS 87-96 KLR650 - 13129-1838 | 1987 | KLR650 | 26T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1523 | 26T - FITS 84-86KL600, 87-96 KLR650 - 13129-1524 | 1987 | KLR650 | 21T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1525 | 19T- FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 1987 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1987 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1987 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 1987 | KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1987 | KLR650 | ||||||||||||||||||||||
1988 | KLR650 | JKAKLEA1JA008701 | FITS 87-88 KLR650 14001-5229 | FITS 87-95 KLR650 - 11011-1301 | 1988 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-95 KLR650 - 54001-1128 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 84-86 KL600, 87-95 KLR650 12044-1197 | FITS 84 KL600, 87-95 KLR650 12044-1114 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 1988 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | FITS 87-89 KLR650 | FITS 85-86 KL600, 87-95 KLR650 - 13102-1074 | 1988 | KLR650 | 75T, 18T, FITS 87-95 KLR650 - 13095-1157 | FITS 87-95 KLR650 - 14032-1230 | 1988 | KLR650 | FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1988 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-95 KLR650 - 14026-1131 | FITS 87-07 KLR650 - 11046-1036 | FITS 88-95 KLR650 - 13031-1276 | FITS 87-95 KLR650 - 11005-1511 | 1988 | KLR650 | FITS 87-91 KLR650 - 32029-1516 | FITS 87-06 KLR650 - 18002-1887 | FITS 87-89 KLR650 - 21050-1130 | 1988 | KLR650 | 1988 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | 1988 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 1988 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 1988 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1988 | KLR650 | FITS 87-95 KLR650 – 11008-1202 | 1988 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | FITS 87-95 KLR650 - 13064-1133 | FITS 84-86 KLR600, 87-95 KLR650 - 13066-1058 | 1988 | KLR650 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1988 | KLR650 | FITS 87-07 KLR650 - 13001-1284 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 87-95 KLR650, 93-95 KLX650R - 13097-1185 | 1988 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 1988 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1988 | KLR650 | 1988 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 1988 | KLR650 | FITS 87-07 KLR650 | 1988 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 1988 | KLR650 | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 1988 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 1988 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 87-10 KLR650 | 1988 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | 1988 | KLR650 | INPUT SHAFT FITS 87-11 KLR650 – OUTPUT SHAFT FITS 87-89 KLR650 - GEARS FIT 87-96 KLR650 | 1988 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 17T - FITS 84-86 KL600, 87-96 KLR650, 93 KLX650R KLX650C - 13129-1518 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1519 | 1988 | KLR650 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1520 | 24T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1988 | KLR650 | FITS 84-86 KL600, 87-89 KLR650 - 13128-1104 | 34T - FITS 87-96 KLR650 - 13129-1838 | 1988 | KLR650 | 26T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1523 | 26T - FITS 84-86KL600, 87-96 KLR650 - 13129-1524 | 1988 | KLR650 | 21T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1525 | 19T- FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 1988 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1988 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1988 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 1988 | KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1988 | KLR650 | |||||||||||||||||||||||
1989 | KLR650 | JKAKLEA1KA013601 | KHI KL650AE01#### | FITS 89-96 KLR650 14001-5251 | FITS 87-95 KLR650 - 11011-1301 | 1989 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-95 KLR650 - 54001-1128 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 84-86 KL600, 87-95 KLR650 12044-1197 | FITS 84 KL600, 87-95 KLR650 12044-1114 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 1989 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | FITS 87-89 KLR650 | FITS 85-86 KL600, 87-95 KLR650 - 13102-1074 | 1989 | KLR650 | 75T, 18T, FITS 87-95 KLR650 - 13095-1157 | FITS 87-95 KLR650 - 14032-1230 | 1989 | KLR650 | FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1989 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-95 KLR650 - 14026-1131 | FITS 87-07 KLR650 - 11046-1036 | FITS 88-95 KLR650 - 13031-1276 | FITS 87-95 KLR650 - 11005-1511 | 1989 | KLR650 | FITS 87-91 KLR650 - 32029-1516 | FITS 87-06 KLR650 - 18002-1887 | FITS 87-89 KLR650 - 21050-1130 | 1989 | KLR650 | 1989 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | 1989 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 1989 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 1989 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1989 | KLR650 | FITS 87-95 KLR650 – 11008-1202 | 1989 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | FITS 87-95 KLR650 - 13064-1133 | FITS 84-86 KLR600, 87-95 KLR650 - 13066-1058 | 1989 | KLR650 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1989 | KLR650 | FITS 87-07 KLR650 - 13001-1284 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 87-95 KLR650, 93-95 KLX650R - 13097-1185 | 1989 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 1989 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1989 | KLR650 | 1989 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 1989 | KLR650 | FITS 87-07 KLR650 | 1989 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 1989 | KLR650 | FITS 89-90 KLR650 - 53001-1564-MD | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 1989 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 1989 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 87-10 KLR650 | 1989 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | 1989 | KLR650 | INPUT SHAFT FITS 87-11 KLR650 – OUTPUT SHAFT FITS 87-89 KLR650 - GEARS FIT 87-96 KLR650 | 1989 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 17T - FITS 84-86 KL600, 87-96 KLR650, 93 KLX650R KLX650C - 13129-1518 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1519 | 1989 | KLR650 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1520 | 24T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1989 | KLR650 | FITS 84-86 KL600, 87-89 KLR650 - 13128-1104 | 34T - FITS 87-96 KLR650 - 13129-1838 | 1989 | KLR650 | 26T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1523 | 26T - FITS 84-86KL600, 87-96 KLR650 - 13129-1524 | 1989 | KLR650 | 21T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1525 | 19T- FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 1989 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1989 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1989 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 1989 | KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1989 | KLR650 | |||||||||||||||||||||
1990 | KLR650 | JKAKLEA1LA016001 | FITS 89-96 KLR650 14001-5251 | FITS 87-95 KLR650 - 11011-1301 | 1990 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-95 KLR650 - 54001-1128 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 84-86 KL600, 87-95 KLR650 12044-1197 | FITS 84 KL600, 87-95 KLR650 12044-1114 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 1990 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 85-86 KL600, 87-95 KLR650 - 13102-1074 | 1990 | KLR650 | 75T, 18T, FITS 87-95 KLR650 - 13095-1157 | FITS 87-95 KLR650 - 14032-1230 | 1990 | KLR650 | FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1990 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-95 KLR650 - 14026-1131 | FITS 87-07 KLR650 - 11046-1036 | FITS 88-95 KLR650 - 13031-1276 | FITS 87-95 KLR650 - 11005-1511 | 1990 | KLR650 | FITS 87-91 KLR650 - 32029-1516 | FITS 87-06 KLR650 - 18002-1887 | FITS 90-95 KLR650, 90-91 Tengai - 21050-1139 | 1990 | KLR650 | 1990 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | 1990 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 1990 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 1990 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1990 | KLR650 | FITS 87-95 KLR650 – 11008-1202 | 1990 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | FITS 87-95 KLR650 - 13064-1133 | FITS 84-86 KLR600, 87-95 KLR650 - 13066-1058 | 1990 | KLR650 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1990 | KLR650 | FITS 90-91 97-07 KLR650 - 11012-1695 | FITS 87-07 KLR650 - 13001-1284 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 87-95 KLR650, 93-95 KLX650R - 13097-1185 | 1990 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 1990 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1990 | KLR650 | 1990 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 1990 | KLR650 | FITS 87-07 KLR650 | 1990 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 1990 | KLR650 | FITS 89-90 KLR650 - 53001-1564-MD | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 1990 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 1990 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 87-10 KLR650 | 1990 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 1990 | KLR650 | INPUT SHAFT FITS 87-11 KLR650, OUTPUT SHAFT FITS 90-96 KLR650 - GEARS FIT 87-96 KLR650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 1990 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 17T - FITS 84-86 KL600, 87-96 KLR650, 93 KLX650R KLX650C - 13129-1518 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1519 | 1990 | KLR650 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1520 | 24T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1990 | KLR650 | FITS 90-96 KLR650 - 13128-1175 | 34T - FITS 87-96 KLR650 - 13129-1838 | 1990 | KLR650 | 26T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1523 | 26T - FITS 84-86KL600, 87-96 KLR650 - 13129-1524 | 1990 | KLR650 | 21T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1525 | 19T- FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 1990 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1990 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1990 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 1990 | KLR650 | FITS 90-02 KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1990 | KLR650 | |||||||||||||||||||
1991 | KLR650 | JKAKLEA1MA018001 | FITS 89-96 KLR650 14001-5251 | FITS 87-95 KLR650 - 11011-1301 | 1991 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-95 KLR650 - 54001-1128 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 84-86 KL600, 87-95 KLR650 12044-1197 | FITS 84 KL600, 87-95 KLR650 12044-1114 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 1991 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 85-86 KL600, 87-95 KLR650 - 13102-1074 | 1991 | KLR650 | 75T, 18T, FITS 87-95 KLR650 - 13095-1157 | FITS 87-95 KLR650 - 14032-1230 | 1991 | KLR650 | FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1991 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-95 KLR650 - 14026-1131 | FITS 87-07 KLR650 - 11046-1036 | FITS 88-95 KLR650 - 13031-1276 | FITS 87-95 KLR650 - 11005-1511 | 1991 | KLR650 | FITS 87-91 KLR650 - 32029-1516 | FITS 87-06 KLR650 - 18002-1887 | FITS 90-95 KLR650, 90-91 Tengai - 21050-1139 | 1991 | KLR650 | 1991 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1991 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 1991 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 1991 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1991 | KLR650 | FITS 87-95 KLR650 – 11008-1202 | 1991 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | FITS 87-95 KLR650 - 13064-1133 | FITS 84-86 KLR600, 87-95 KLR650 - 13066-1058 | 1991 | KLR650 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1991 | KLR650 | FITS 90-91 97-07 KLR650 - 11012-1695 | FITS 87-07 KLR650 - 13001-1284 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 87-95 KLR650, 93-95 KLX650R - 13097-1185 | 1991 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 1991 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1991 | KLR650 | 1991 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 1991 | KLR650 | FITS 87-07 KLR650 | 1991 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 1991 | KLR650 | FITS 91-93 KLR650 - 53001-1634-MZ | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 1991 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 1991 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 87-10 KLR650 | 1991 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 1991 | KLR650 | INPUT SHAFT FITS 87-11 KLR650, OUTPUT SHAFT FITS 90-96 KLR650 - GEARS FIT 87-96 KLR650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 1991 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 17T - FITS 84-86 KL600, 87-96 KLR650, 93 KLX650R KLX650C - 13129-1518 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1519 | 1991 | KLR650 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1520 | 24T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1991 | KLR650 | FITS 90-96 KLR650 - 13128-1175 | 34T - FITS 87-96 KLR650 - 13129-1838 | 1991 | KLR650 | 26T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1523 | 26T - FITS 84-86KL600, 87-96 KLR650 - 13129-1524 | 1991 | KLR650 | 21T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1525 | 19T- FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 1991 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1991 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1991 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 1991 | KLR650 | FITS 90-02 KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1991 | KLR650 | ||||||||||||||||||
1992 | KLR650 | JKAKLEA14NA02#### | KHI KL650AE02#### | FITS 89-96 KLR650 14001-5251 | FITS 87-95 KLR650 - 11011-1301 | 1992 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-95 KLR650 - 54001-1128 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 84-86 KL600, 87-95 KLR650 12044-1197 | FITS 84 KL600, 87-95 KLR650 12044-1114 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 1992 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 85-86 KL600, 87-95 KLR650 - 13102-1074 | 1992 | KLR650 | 75T, 18T, FITS 87-95 KLR650 - 13095-1157 | FITS 87-95 KLR650 - 14032-1230 | 1992 | KLR650 | FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1992 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-95 KLR650 - 14026-1131 | FITS 87-07 KLR650 - 11046-1036 | FITS 88-95 KLR650 - 13031-1276 | FITS 87-95 KLR650 - 11005-1511 | 1992 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | FITS 90-95 KLR650, 90-91 Tengai - 21050-1139 | 1992 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 88.5MM – AXLE HOLE ID 15MM – FITS AT LEAST 92-93 KLR650 | 1992 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1992 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 1992 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 1992 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1992 | KLR650 | FITS 87-95 KLR650 – 11008-1202 | 1992 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | FITS 87-95 KLR650 - 13064-1133 | FITS 84-86 KLR600, 87-95 KLR650 - 13066-1058 | 1992 | KLR650 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1992 | KLR650 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 87-95 KLR650, 93-95 KLX650R - 13097-1185 | 1992 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 1992 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1992 | KLR650 | 1992 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 1992 | KLR650 | FITS 87-07 KLR650 | 1992 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 1992 | KLR650 | FITS 91-93 KLR650 - 53001-1634-MZ | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 1992 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 1992 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 87-10 KLR650 | 1992 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 1992 | KLR650 | INPUT SHAFT FITS 87-11 KLR650, OUTPUT SHAFT FITS 90-96 KLR650 - GEARS FIT 87-96 KLR650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 1992 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 17T - FITS 84-86 KL600, 87-96 KLR650, 93 KLX650R KLX650C - 13129-1518 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1519 | 1992 | KLR650 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1520 | 24T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1992 | KLR650 | FITS 90-96 KLR650 - 13128-1175 | 34T - FITS 87-96 KLR650 - 13129-1838 | 1992 | KLR650 | 26T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1523 | 26T - FITS 84-86KL600, 87-96 KLR650 - 13129-1524 | 1992 | KLR650 | 21T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1525 | 19T- FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 1992 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1992 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1992 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 1992 | KLR650 | FITS 90-02 KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1992 | KLR650 | ||||||||||||||||
1993 | KLR650 | FITS 89-96 KLR650 14001-5251 | FITS 87-95 KLR650 - 11011-1301 | 1993 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-95 KLR650 - 54001-1128 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 84-86 KL600, 87-95 KLR650 12044-1197 | FITS 84 KL600, 87-95 KLR650 12044-1114 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 1993 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 85-86 KL600, 87-95 KLR650 - 13102-1074 | 1993 | KLR650 | 75T, 18T, FITS 87-95 KLR650 - 13095-1157 | FITS 87-95 KLR650 - 14032-1230 | 1993 | KLR650 | FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1993 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-95 KLR650 - 14026-1131 | FITS 87-07 KLR650 - 11046-1036 | FITS 88-95 KLR650 - 13031-1276 | FITS 87-95 KLR650 - 11005-1511 | 1993 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | FITS 90-95 KLR650, 90-91 Tengai - 21050-1139 | 1993 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 88.5MM – AXLE HOLE ID 15MM – FITS AT LEAST 92-93 KLR650 | 1993 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1993 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 1993 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 1993 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1993 | KLR650 | FITS 87-95 KLR650 – 11008-1202 | 1993 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | FITS 87-95 KLR650 - 13064-1133 | FITS 84-86 KLR600, 87-95 KLR650 - 13066-1058 | 1993 | KLR650 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1993 | KLR650 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 87-95 KLR650, 93-95 KLX650R - 13097-1185 | 1993 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 1993 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1993 | KLR650 | 1993 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 1993 | KLR650 | FITS 87-07 KLR650 | 1993 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 1993 | KLR650 | FITS 91-93 KLR650 - 53001-1634-MZ | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 1993 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 1993 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 87-10 KLR650 | 1993 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 1993 | KLR650 | INPUT SHAFT FITS 87-11 KLR650 - OUTPUT SHAFT FITS 90-96 KLR650 - GEARS FIT 87-96 KLR650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 1993 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 17T - FITS 84-86 KL600, 87-96 KLR650, 93 KLX650R KLX650C - 13129-1518 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1519 | 1993 | KLR650 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1520 | 24T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1993 | KLR650 | FITS 90-96 KLR650 - 13128-1175 | 34T - FITS 87-96 KLR650 - 13129-1838 | 1993 | KLR650 | 26T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1523 | 26T - FITS 84-86KL600, 87-96 KLR650 - 13129-1524 | 1993 | KLR650 | 21T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1525 | 19T- FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 1993 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1993 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1993 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 1993 | KLR650 | FITS 90-02 KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1993 | KLR650 | ||||||||||||||||||
1994 | KLR650 | JKAKLEA15RA03#### | KHI KL650AE02#### | FITS 89-96 KLR650 14001-5251 | FITS 87-95 KLR650 - 11011-1301 | 1994 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-95 KLR650 - 54001-1128 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 84-86 KL600, 87-95 KLR650 12044-1197 | FITS 84 KL600, 87-95 KLR650 12044-1114 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 1994 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 85-86 KL600, 87-95 KLR650 - 13102-1074 | 1994 | KLR650 | 75T, 18T, FITS 87-95 KLR650 - 13095-1157 | FITS 87-95 KLR650 - 14032-1230 | 1994 | KLR650 | FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1994 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-95 KLR650 - 14026-1131 | FITS 87-07 KLR650 - 11046-1036 | FITS 88-95 KLR650 - 13031-1276 | FITS 87-95 KLR650 - 11005-1511 | 1994 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | FITS 90-95 KLR650, 90-91 Tengai - 21050-1139 | 1994 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | 1994 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1994 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 1994 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 1994 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1994 | KLR650 | FITS 87-95 KLR650 – 11008-1202 | 1994 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | FITS 87-95 KLR650 - 13064-1133 | FITS 84-86 KLR600, 87-95 KLR650 - 13066-1058 | 1994 | KLR650 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1994 | KLR650 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 87-95 KLR650, 93-95 KLX650R - 13097-1185 | 1994 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 1994 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1994 | KLR650 | 1994 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 1994 | KLR650 | FITS 87-07 KLR650 | 1994 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 1994 | KLR650 | FITS 94-95 KLR650 - 53001-1492-LW | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 1994 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 1994 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 87-10 KLR650 | 1994 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 1994 | KLR650 | INPUT SHAFT FITS 87-11 KLR650 - OUTPUT SHAFT FITS 90-96 KLR650 - GEARS FIT 87-96 KLR650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 1994 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 17T - FITS 84-86 KL600, 87-96 KLR650, 93 KLX650R KLX650C - 13129-1518 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1519 | 1994 | KLR650 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1520 | 24T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1994 | KLR650 | FITS 90-96 KLR650 - 13128-1175 | 34T - FITS 87-96 KLR650 - 13129-1838 | 1994 | KLR650 | 26T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1523 | 26T - FITS 84-86KL600, 87-96 KLR650 - 13129-1524 | 1994 | KLR650 | 21T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1525 | 19T- FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 1994 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1994 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1994 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 1994 | KLR650 | FITS 90-02 KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1994 | KLR650 | ||||||||||||||||
1995 | KLR650 | FITS 89-96 KLR650 14001-5251 | FITS 87-95 KLR650 - 11011-1301 | 1995 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-95 KLR650 - 54001-1128 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 84-86 KL600, 87-95 KLR650 12044-1197 | FITS 84 KL600, 87-95 KLR650 12044-1114 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 1995 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 85-86 KL600, 87-95 KLR650 - 13102-1074 | 1995 | KLR650 | 75T, 18T, FITS 87-95 KLR650 - 13095-1157 | FITS 87-95 KLR650 - 14032-1230 | 1995 | KLR650 | FITS 92-00 KX250, 84-86 kl600, 87-95 klr650, 93-96 klx650r KLX650C - 13187-1012 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1995 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-95 KLR650 - 14026-1131 | FITS 87-07 KLR650 - 11046-1036 | FITS 88-95 KLR650 - 13031-1276 | FITS 87-95 KLR650 - 11005-1511 | 1995 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | FITS 90-95 KLR650, 90-91 Tengai - 21050-1139 | 1995 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | 1995 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1995 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 1995 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 1995 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1995 | KLR650 | FITS 87-95 KLR650 – 11008-1202 | 1995 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | FITS 87-95 KLR650 - 13064-1133 | FITS 84-86 KLR600, 87-95 KLR650 - 13066-1058 | 1995 | KLR650 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1995 | KLR650 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 87-95 KLR650, 93-95 KLX650R - 13097-1185 | 1995 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 1995 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1995 | KLR650 | 1995 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 1995 | KLR650 | FITS 87-07 KLR650 | 1995 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 1995 | KLR650 | FITS 94-95 KLR650 - 53001-1492-LW | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 1995 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 1995 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 87-10 KLR650 | 1995 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 1995 | KLR650 | INPUT SHAFT FITS 87-11 KLR650 - OUTPUT SHAFT FITS 90-96 KLR650 - GEARS FIT 87-96 KLR650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 1995 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 17T - FITS 84-86 KL600, 87-96 KLR650, 93 KLX650R KLX650C - 13129-1518 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1519 | 1995 | KLR650 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1520 | 24T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1995 | KLR650 | FITS 90-96 KLR650 - 13128-1175 | 34T - FITS 87-96 KLR650 - 13129-1838 | 1995 | KLR650 | 26T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1523 | 26T - FITS 84-86KL600, 87-96 KLR650 - 13129-1524 | 1995 | KLR650 | 21T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1525 | 19T- FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 1995 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1995 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1995 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 1995 | KLR650 | FITS 90-02 KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1995 | KLR650 | ||||||||||||||||||
1996 | KLR650 | FITS 89-96 KLR650 14001-5251 | FITS 96-07 KLR650 - 11011-1457 | 1996 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 96-07 KLR650 12044-1370 | FITS 96-11 KLR650 12044-1372 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 1996 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 96-07 KLR650 - 12053-1360 | FITS 96-10 KLR650 - 13095-1311 | 1996 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 96 KLR650 - 14032-1487 | 1996 | KLR650 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1996 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-07 KLR650 - 11046-1036 | FITS 96-07 KLR650 - 13031-1396 | FITS 96 KLR650 - 11005-1784 | 1996 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | DENSO 032000-7061 FITS 96-07 KLR650 - 21007-1283 | 1996 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | 1996 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1996 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 1996 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 1996 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1996 | KLR650 | FITS 96 KLR650 – 11008-1295 | 1996 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | N/A | N/A | 1996 | KLR650 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1996 | KLR650 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 1996 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 1996 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1996 | KLR650 | 1996 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 1996 | KLR650 | FITS 87-07 KLR650 | FITS 96-07 KLR650 - 35023-1432 | 1996 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 1996 | KLR650 | FITS 96-00 KLR650 - 53001-1492-LJ | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 1996 | KLR650 | GREEN - FITS 96-99 KLR650 - 36001-1346-59 | GREEN - FITS 96-99 KLR650 - 36001-1537-59 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 1996 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 87-10 KLR650 | 1996 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 1996 | KLR650 | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 1996 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 17T - FITS 84-86 KL600, 87-96 KLR650, 93 KLX650R KLX650C - 13129-1518 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1519 | 1996 | KLR650 | 22T - FITS 84-86 KL600, 87-86 KLR650 - 13129-1520 | 24T - FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | 1996 | KLR650 | FITS 90-96 KLR650 - 13128-1175 | 34T - FITS 87-96 KLR650 - 13129-1838 | 1996 | KLR650 | 26T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1523 | 26T - FITS 84-86KL600, 87-96 KLR650 - 13129-1524 | 1996 | KLR650 | 21T - FITS 84-86 KL600, 87-96 KLR650 - 13129-1525 | 19T- FITS 84-86 KL600, 87-96 KLR650, 88-04 KX500 - 13129-1575 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 1996 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1996 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1996 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 1996 | KLR650 | FITS 90-02 KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1996 | KLR650 | |||||||||||||||||
1997 | KLR650 | FITS 97-07 KLR650 14001-5340 | FITS 96-07 KLR650 - 11011-1457 | 1997 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 96-07 KLR650 12044-1370 | FITS 96-11 KLR650 12044-1372 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 1997 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 96-07 KLR650 - 12053-1360 | FITS 96-10 KLR650 - 13095-1311 | 1997 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 95-05 KLR650 - 14032-1488 | 1997 | KLR650 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1997 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-07 KLR650 - 11046-1036 | FITS 96-07 KLR650 - 13031-1396 | FITS 97-07 KLR650 - 11005-1781 | 1997 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | DENSO 032000-7061 FITS 96-07 KLR650 - 21007-1283 | 1997 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | 1997 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1997 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 1997 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 1997 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1997 | KLR650 | FITS 97-07 KLR650 – 11008-1297 | 1997 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | N/A | N/A | 1997 | KLR650 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1997 | KLR650 | FITS 90-91 97-07 KLR650 - 11012-1695 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 1997 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 1997 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1997 | KLR650 | 1997 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 1997 | KLR650 | FITS 87-07 KLR650 | FITS 96-07 KLR650 - 35023-1432 | 1997 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 1997 | KLR650 | FITS 96-00 KLR650 - 53001-1492-LJ | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 1997 | KLR650 | GREEN - FITS 96-99 KLR650 - 36001-1346-59 | GREEN - FITS 96-99 KLR650 - 36001-1537-59 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 1997 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 97-05 KLR650 - 14031-1305 | FITS 87-10 KLR650 | 1997 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 1997 | KLR650 | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 1997 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 1997 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 1997 | KLR650 | FITS 96-07 KLR650 - 13128-1203 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 1997 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 1997 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 1997 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1997 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1997 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 1997 | KLR650 | FITS 90-02 KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1997 | KLR650 | |||||||||||||||
1998 | KLR650 | JKAKLEA11WA04#### | KHI KL650AE03#### | FITS 97-07 KLR650 14001-5340 | FITS 96-07 KLR650 - 11011-1457 | 1998 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 96-07 KLR650 12044-1370 | FITS 96-11 KLR650 12044-1372 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 1998 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 96-07 KLR650 - 12053-1360 | FITS 96-10 KLR650 - 13095-1311 | 1998 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 95-05 KLR650 - 14032-1488 | 1998 | KLR650 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1998 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-07 KLR650 - 11046-1036 | FITS 96-07 KLR650 - 13031-1396 | FITS 97-07 KLR650 - 11005-1781 | 1998 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | DENSO 032000-7061 FITS 96-07 KLR650 - 21007-1283 | 1998 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | 1998 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1998 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 1998 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 1998 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1998 | KLR650 | FITS 97-07 KLR650 – 11008-1297 | 1998 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | N/A | N/A | 1998 | KLR650 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1998 | KLR650 | FITS 90-91 97-07 KLR650 - 11012-1695 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 1998 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 1998 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1998 | KLR650 | 1998 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 1998 | KLR650 | FITS 87-07 KLR650 | FITS 96-07 KLR650 - 35023-1432 | 1998 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 1998 | KLR650 | FITS 96-00 KLR650 - 53001-1492-LJ | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 1998 | KLR650 | GREEN - FITS 96-99 KLR650 - 36001-1346-59 | GREEN - FITS 96-99 KLR650 - 36001-1537-59 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 1998 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 97-05 KLR650 - 14031-1305 | FITS 87-10 KLR650 | 1998 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 1998 | KLR650 | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 1998 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 1998 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 1998 | KLR650 | FITS 96-07 KLR650 - 13128-1203 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 1998 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 1998 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 1998 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1998 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1998 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 1998 | KLR650 | FITS 90-02 KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1998 | KLR650 | |||||||||||||
1999 | KLR650 | JKAKLEA14XA05#### | KHI KL650AE03#### | FITS 97-07 KLR650 14001-5340 | FITS 96-07 KLR650 - 11011-1457 | 1999 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 96-07 KLR650 12044-1370 | FITS 96-11 KLR650 12044-1372 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 1999 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 96-07 KLR650 - 12053-1360 | FITS 96-10 KLR650 - 13095-1311 | 1999 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 95-05 KLR650 - 14032-1488 | 1999 | KLR650 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 1999 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-07 KLR650 - 11046-1036 | FITS 96-07 KLR650 - 13031-1396 | FITS 97-07 KLR650 - 11005-1781 | 1999 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | DENSO 032000-7061 FITS 96-07 KLR650 - 21007-1283 | 1999 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | 1999 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1999 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 1999 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 1999 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 1999 | KLR650 | FITS 97-07 KLR650 – 11008-1297 | 1999 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | N/A | N/A | 1999 | KLR650 | FITS 84-86 KL600, 87-99 KLR650, 85-99 KLR250 - 46091-1309 | 1999 | KLR650 | FITS 90-91 97-07 KLR650 - 11012-1695 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 1999 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 1999 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1999 | KLR650 | 1999 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 1999 | KLR650 | FITS 87-07 KLR650 | FITS 96-07 KLR650 - 35023-1432 | 1999 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 1999 | KLR650 | FITS 96-00 KLR650 - 53001-1492-LJ | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 1999 | KLR650 | GREEN - FITS 96-99 KLR650 - 36001-1346-59 | GREEN - FITS 96-99 KLR650 - 36001-1537-59 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 1999 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 97-05 KLR650 - 14031-1305 | FITS 87-10 KLR650 | 1999 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 1999 | KLR650 | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 1999 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 1999 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 1999 | KLR650 | FITS 96-07 KLR650 - 13128-1203 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 1999 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 1999 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 1999 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 1999 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 1999 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 1999 | KLR650 | FITS 90-02 KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 1999 | KLR650 | |||||||||||||
2000 | KLR650 | JKAKLEA18YZ5##### | KHI KL650AE04#### | FITS 97-07 KLR650 14001-5340 | FITS 96-07 KLR650 - 11011-1457 | 2000 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 96-07 KLR650 12044-1370 | FITS 96-11 KLR650 12044-1372 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 2000 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 96-07 KLR650 - 12053-1360 | FITS 96-10 KLR650 - 13095-1311 | 2000 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 95-05 KLR650 - 14032-1488 | 2000 | KLR650 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 2000 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-07 KLR650 - 11046-1036 | FITS 96-07 KLR650 - 13031-1396 | FITS 97-07 KLR650 - 11005-1781 | 2000 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | DENSO 032000-7061 FITS 96-07 KLR650 - 21007-1283 | 2000 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | 2000 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 2000 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 2000 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 2000 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 2000 | KLR650 | FITS 97-07 KLR650 – 11008-1297 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2000 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | N/A | N/A | 2000 | KLR650 | 2000 | KLR650 | FITS 90-91 97-07 KLR650 - 11012-1695 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 2000 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 00-03 KLR650 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 2000 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2000 | KLR650 | 2000 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 2000 | KLR650 | FITS 87-07 KLR650 | FITS 96-07 KLR650 - 35023-1432 | 2000 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 2000 | KLR650 | FITS 96-00 KLR650 - 53001-1492-LJ | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 2000 | KLR650 | GREEN - FITS 00-02 KLR650 - 36001-1346-68 | GREEN - FITS 00-02 KLR650 - 36001-1537-68 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 2000 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 97-05 KLR650 - 14031-1305 | FITS 87-10 KLR650 | 2000 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 2000 | KLR650 | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 2000 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 2000 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 2000 | KLR650 | FITS 96-07 KLR650 - 13128-1203 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 2000 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 2000 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 2000 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 2000 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 2000 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 2000 | KLR650 | FITS 90-02 KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2000 | KLR650 | ||||||||||||
2001 | KLR650 | FITS 97-07 KLR650 14001-5340 | FITS 96-07 KLR650 - 11011-1457 | 2001 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 96-07 KLR650 12044-1370 | FITS 96-11 KLR650 12044-1372 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 2001 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 96-07 KLR650 - 12053-1360 | FITS 96-10 KLR650 - 13095-1311 | 2001 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 95-05 KLR650 - 14032-1488 | 2001 | KLR650 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 2001 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-07 KLR650 - 11046-1036 | FITS 96-07 KLR650 - 13031-1396 | FITS 97-07 KLR650 - 11005-1781 | 2001 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | DENSO 032000-7061 FITS 96-07 KLR650 - 21007-1283 | 2001 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | 2001 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 01 KLR650 | 2001 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 2001 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 2001 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 2001 | KLR650 | FITS 97-07 KLR650 – 11008-1297 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2001 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | N/A | N/A | 2001 | KLR650 | 2001 | KLR650 | FITS 90-91 97-07 KLR650 - 11012-1695 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 2001 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 00-03 KLR650 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 2001 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2001 | KLR650 | 2001 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 2001 | KLR650 | FITS 87-07 KLR650 | FITS 96-07 KLR650 - 35023-1432 | 2001 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 2001 | KLR650 | FITS 01-02 KLR650 - 53001-1492-K7 | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 2001 | KLR650 | GREEN - FITS 00-02 KLR650 - 36001-1346-68 | GREEN - FITS 00-02 KLR650 - 36001-1537-68 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 2001 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 97-05 KLR650 - 14031-1305 | FITS 87-10 KLR650 | 2001 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 2001 | KLR650 | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 2001 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 2001 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 2001 | KLR650 | FITS 96-07 KLR650 - 13128-1203 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 2001 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 2001 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 2001 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 2001 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 2001 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 2001 | KLR650 | FITS 90-02 KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2001 | KLR650 | ||||||||||||||
2002 | KLR650 | KHI KL650AE05#### | FITS 97-07 KLR650 14001-5340 | FITS 96-07 KLR650 - 11011-1457 | 2002 | KLR650 | FITS 87-02 KLR650 - 54011-1257 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 96-07 KLR650 12044-1370 | FITS 96-11 KLR650 12044-1372 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 2002 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 96-07 KLR650 - 12053-1360 | FITS 96-10 KLR650 - 13095-1311 | 2002 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 95-05 KLR650 - 14032-1488 | 2002 | KLR650 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 2002 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-07 KLR650 - 11046-1036 | FITS 96-07 KLR650 - 13031-1396 | FITS 97-07 KLR650 - 11005-1781 | 2002 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | DENSO 032000-7061 FITS 96-07 KLR650 - 21007-1283 | 2002 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | 2002 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 02-03 KLR650 | 2002 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 2002 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 2002 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 2002 | KLR650 | FITS 97-07 KLR650 – 11008-1297 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2002 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | N/A | N/A | 2002 | KLR650 | 2002 | KLR650 | FITS 90-91 97-07 KLR650 - 11012-1695 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 2002 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 00-03 KLR650 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 2002 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2002 | KLR650 | 2002 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 2002 | KLR650 | FITS 87-07 KLR650 | FITS 96-07 KLR650 - 35023-1432 | 2002 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 2002 | KLR650 | FITS 01-02 KLR650 - 53001-1492-K7 | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 2002 | KLR650 | GREEN - FITS 00-02 KLR650 - 36001-1346-68 | GREEN - FITS 00-02 KLR650 - 36001-1537-68 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 2002 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 97-05 KLR650 - 14031-1305 | FITS 87-10 KLR650 | 2002 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 2002 | KLR650 | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 2002 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 2002 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 2002 | KLR650 | FITS 96-07 KLR650 - 13128-1203 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 2002 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 2002 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 2002 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 2002 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 2002 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 2002 | KLR650 | FITS 90-02 KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2002 | KLR650 | |||||||||||||
2003 | KLR650 | JKAKLEA123DA0#### | FITS 97-07 KLR650 14001-5340 | FITS 96-07 KLR650 - 11011-1457 | 2003 | KLR650 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 96-07 KLR650 12044-1370 | FITS 96-11 KLR650 12044-1372 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 2003 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 96-07 KLR650 - 12053-1360 | FITS 96-10 KLR650 - 13095-1311 | 2003 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 95-05 KLR650 - 14032-1488 | 2003 | KLR650 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 2003 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-07 KLR650 - 11046-1036 | FITS 96-07 KLR650 - 13031-1396 | FITS 97-07 KLR650 - 11005-1781 | 2003 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | DENSO 032000-7061 FITS 96-07 KLR650 - 21007-1283 | 2003 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | 2003 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 02-03 KLR650 | 2003 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 2003 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 2003 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 2003 | KLR650 | FITS 97-07 KLR650 – 11008-1297 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2003 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | N/A | N/A | 2003 | KLR650 | 2003 | KLR650 | FITS 90-91 97-07 KLR650 - 11012-1695 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 2003 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 00-03 KLR650 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 2003 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2003 | KLR650 | 2003 | KLR650 | FITS 87-03 KLR650 | FITS 87-07 KLR650 | 2003 | KLR650 | FITS 87-07 KLR650 | FITS 96-07 KLR650 - 35023-1432 | 2003 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 2003 | KLR650 | FITS 03-07 KLR650 - 53066-1062-MW | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 2003 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 2003 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 97-05 KLR650 - 14031-1305 | FITS 87-10 KLR650 | 2003 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 2003 | KLR650 | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 2003 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 2003 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 2003 | KLR650 | FITS 96-07 KLR650 - 13128-1203 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 2003 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 2003 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 2003 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 2003 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 2003 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 2003 | KLR650 | FITS 03-07 KLR650 - 26030-1979 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2003 | KLR650 | ||||||||||||||||
2004 | KLR650 | FITS 97-07 KLR650 14001-5340 | FITS 96-07 KLR650 - 11011-1457 | 2004 | KLR650 | FITS 87-07 KLR650 - 54017-1090 | FITS 87-04 KLR650 - 54012-1328 | FITS 87-04 KLR650 - 54012-1327 | FITS 96-07 KLR650 12044-1370 | FITS 96-11 KLR650 12044-1372 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 2004 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 96-07 KLR650 - 12053-1360 | FITS 96-10 KLR650 - 13095-1311 | 2004 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 95-05 KLR650 - 14032-1488 | 2004 | KLR650 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 2004 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-07 KLR650 - 11046-1036 | FITS 96-07 KLR650 - 13031-1396 | FITS 97-07 KLR650 - 11005-1781 | 2004 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | DENSO 032000-7061 FITS 96-07 KLR650 - 21007-1283 | 2004 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | 2004 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 04-07 KLR650 | 2004 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 2004 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 2004 | KLR650 | TAKASAGO J 21X1.6 DOT 355 JAPAN 899 – 36 SPOKES - FITS 85-04 KLR250, 87-04 KLR650 – 41025-1112 | 2004 | KLR650 | FITS 97-07 KLR650 – 11008-1297 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2004 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | N/A | N/A | 2004 | KLR650 | 2004 | KLR650 | FITS 90-91 97-07 KLR650 - 11012-1695 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 2004 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 2004 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2004 | KLR650 | 2004 | KLR650 | FITS 04-07 KLR650 | FITS 87-07 KLR650 | 2004 | KLR650 | FITS 87-07 KLR650 | FITS 96-07 KLR650 - 35023-1432 | 2004 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 2004 | KLR650 | FITS 03-07 KLR650 - 53066-1062-MW | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 2004 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 2004 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 97-05 KLR650 - 14031-1305 | FITS 87-10 KLR650 | 2004 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 2004 | KLR650 | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 2004 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 2004 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 2004 | KLR650 | FITS 96-07 KLR650 - 13128-1203 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 2004 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 2004 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 2004 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | FITS 84-86 KL600, 85-04 KLR250, 87-04 KLR650 - 23037-1201 | 2004 | KLR650 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | FITS 84-86 KL600, 87-04 KLR650 - 23037-1202 | 2004 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 2004 | KLR650 | FITS 03-07 KLR650 - 26030-1979 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2004 | KLR650 | ||||||||||||||||||
2005 | KLR650 | JKAKLEA145SA1#### | KHI KL650AEA1#### | FITS 97-07 KLR650 14001-5340 | FITS 96-07 KLR650 - 11011-1457 | 2005 | KLR650 | FITS 87-07 KLR650 - 54017-1090 | FITS 96-07 KLR650 12044-1370 | FITS 96-11 KLR650 12044-1372 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 2005 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 96-07 KLR650 - 12053-1360 | FITS 96-10 KLR650 - 13095-1311 | 2005 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 95-05 KLR650 - 14032-1488 | 2005 | KLR650 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 2005 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-07 KLR650 - 11046-1036 | FITS 96-07 KLR650 - 13031-1396 | FITS 97-07 KLR650 - 11005-1781 | 2005 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | DENSO 032000-7061 FITS 96-07 KLR650 - 21007-1283 | 2005 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | 2005 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 04-07 KLR650 | 2005 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 2005 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 2005 | KLR650 | 2005 | KLR650 | FITS 97-07 KLR650 – 11008-1297 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2005 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | N/A | N/A | 2005 | KLR650 | 2005 | KLR650 | FITS 90-91 97-07 KLR650 - 11012-1695 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 2005 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 2005 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2005 | KLR650 | 2005 | KLR650 | FITS 04-07 KLR650 | FITS 87-07 KLR650 | 2005 | KLR650 | FITS 87-07 KLR650 | FITS 96-07 KLR650 - 35023-1432 | 2005 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 2005 | KLR650 | FITS 03-07 KLR650 - 53066-1062-MW | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 2005 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 2005 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 97-05 KLR650 - 14031-1305 | FITS 87-10 KLR650 | 2005 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 2005 | KLR650 | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 2005 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 2005 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 2005 | KLR650 | FITS 96-07 KLR650 - 13128-1203 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 2005 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 2005 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 2005 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 05 KLR250, 05-07 KLR650, 06-07 KLX250 - 23037-0027 | FITS 05 KLR250, 05-07 KLR650, 06-07 KLX250 - 23037-0027 | 2005 | KLR650 | FITS 05-07 KLR650 - 23037-0028 | FITS 05-07 KLR650 - 23037-0028 | 2005 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 2005 | KLR650 | FITS 03-07 KLR650 - 26030-1979 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2005 | KLR650 | |||||||||||||||||||
2006 | KLR650 | FITS 97-07 KLR650 14001-5340 | FITS 96-07 KLR650 - 11011-1457 | 2006 | KLR650 | FITS 87-07 KLR650 - 54017-1090 | FITS 96-07 KLR650 12044-1370 | FITS 96-11 KLR650 12044-1372 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 2006 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 96-07 KLR650 - 12053-1360 | FITS 96-10 KLR650 - 13095-1311 | 2006 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 06-07 KLR650 - 14032-0022 | 2006 | KLR650 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 2006 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-07 KLR650 - 11046-1036 | FITS 96-07 KLR650 - 13031-1396 | FITS 97-07 KLR650 - 11005-1781 | 2006 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | FITS 87-06 KLR650 - 18002-1887 | DENSO 032000-7061 FITS 96-07 KLR650 - 21007-1283 | 2006 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | 2006 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 04-07 KLR650 | 2006 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 2006 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 2006 | KLR650 | 2006 | KLR650 | FITS 97-07 KLR650 – 11008-1297 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2006 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | N/A | N/A | 2006 | KLR650 | 2006 | KLR650 | FITS 90-91 97-07 KLR650 - 11012-1695 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 2006 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 2006 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2006 | KLR650 | 2006 | KLR650 | FITS 04-07 KLR650 | FITS 87-07 KLR650 | 2006 | KLR650 | FITS 87-07 KLR650 | FITS 96-07 KLR650 - 35023-1432 | 2006 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 2006 | KLR650 | FITS 03-07 KLR650 - 53066-1062-MW | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 2006 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 2006 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 87-10 KLR650 | 2006 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 2006 | KLR650 | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 2006 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 2006 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 2006 | KLR650 | FITS 96-07 KLR650 - 13128-1203 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 2006 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 2006 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 2006 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 05 KLR250, 05-07 KLR650, 06-07 KLX250 - 23037-0027 | FITS 05 KLR250, 05-07 KLR650, 06-07 KLX250 - 23037-0027 | 2006 | KLR650 | FITS 05-07 KLR650 - 23037-0028 | FITS 05-07 KLR650 - 23037-0028 | 2006 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 2006 | KLR650 | FITS 03-07 KLR650 - 26030-1979 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2006 | KLR650 | ||||||||||||||||||||||
2007 | KLR650 | JKAKLEA187DA3#### | KHI KL650AEA3#### | FITS 97-07 KLR650 14001-5340 | FITS 96-07 KLR650 - 11011-1457 | 2007 | KLR650 | FITS 87-07 KLR650 - 54017-1090 | FITS 96-07 KLR650 12044-1370 | FITS 96-11 KLR650 12044-1372 | KEIHIN CVK V327 – FITS 87-07 KLR650 15001-1327 – 145 MAIN, 40 PILOT, 40MM ID | 2007 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | FITS 96-07 KLR650 - 12053-1360 | FITS 96-10 KLR650 - 13095-1311 | 2007 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 06-07 KLR650 - 14032-0022 | 2007 | KLR650 | 129700 - FITS 87-07 KLR650, 93-96 KLX650R KLX650C, 94-96 KLX250R, 97-07 KLX300R - 21121-1152 - PRIMARY .15-.21 OHM (MY METER CONSISTANTLY READS .3), SECONDARY NO CAP 3.8-5.8K OHMS | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 2007 | KLR650 | 13234-1058 - FITS 85-86 KL600, 87-07 KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 87-07 KLR650 - 11046-1036 | FITS 96-07 KLR650 - 13031-1396 | FITS 97-07 KLR650 - 11005-1781 | 2007 | KLR650 | FITS 92-07 KLR650 - 32029-1805 | DENSO 032000-7061 FITS 96-07 KLR650 - 21007-1283 | 2007 | KLR650 | KYB - CONVENTIONAL - CHROME OD 38MM - C/L 36 7/16" - BRAKE MOUNT C/L 89MM - AXLE HOLE ID 15MM - FITS 07 KLR650 | 2007 | KLR650 | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 04-07 KLR650 | 2007 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 | 2007 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | 2007 | KLR650 | 2007 | KLR650 | FITS 97-07 KLR650 – 11008-1297 | FITS 00-05 KLR250, 00-07 KLR650 - 23007-1364 | 2007 | KLR650 | FITS 84-86 KL600, 87-07 KLR650, 85-05 KLR250, 09-10 KL250, 93-96 KLX650C - 23005-1052 | FITS 87-07 KLR650 - 27004-5322 | N/A | N/A | 2007 | KLR650 | 2007 | KLR650 | FITS 90-91 97-07 KLR650 - 11012-1695 | FITS 87-07 KLR650 - 13001-1284 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | FITS 87-07 KLR650 - 13001-1284 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 2007 | KLR650 | FITS 87-07 KLR650 - 59502-1082 | FITS 84-86 KL600, 88-07 KLR650 - 27010-1167 | FITS 87-07 KLR650 - 41068-1237 CLICK HERE FOR MEASUREMENTS | 2007 | KLR650 | R-1175 - 20MM AXLE - BRG TO BRG W/ CUSH PLATE 159-160MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2007 | KLR650 | 2007 | KLR650 | FITS 04-07 KLR650 | FITS 87-07 KLR650 | 2007 | KLR650 | FITS 87-07 KLR650 | FITS 96-07 KLR650 - 35023-1432 | 2007 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | 2007 | KLR650 | FITS 03-07 KLR650 - 53066-1062-MW | FITS 87-07 KLR650 - 39007-1119 | FITS 87-07 KLR650 - 33032-1129 | 2007 | KLR650 | FITS 87-07 KLR650 | FITS 87-07 KLR650 - 55020-1249-6Z | FITS 87-07 KLR650 - 25005-1341 | 2007 | KLR650 | FITS 87-07 KLR650 - 21003-1170 - 200W OUTPUT - | FITS 87-10 KLR650 | 2007 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | FITS 90-07 KLR650 - 12048-1094 | 2007 | KLR650 | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | 2007 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 2007 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 2007 | KLR650 | FITS 96-07 KLR650 - 13128-1203 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 2007 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 2007 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | 2007 | KLR650 | FITS 87-07 KLR650 - C/L OF THE FORK TUBES 185MM | FITS 05 KLR250, 05-07 KLR650, 06-07 KLX250 - 23037-0027 | FITS 05 KLR250, 05-07 KLR650, 06-07 KLX250 - 23037-0027 | 2007 | KLR650 | FITS 05-07 KLR650 - 23037-0028 | FITS 05-07 KLR650 - 23037-0028 | 2007 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | FITS 85-86 KL600, 87-07 KLR650 | 2007 | KLR650 | FITS 03-07 KLR650 - 26030-1979 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2007 | KLR650 | |||||||||||||||||||||
2008 | KLR650 | KL650AEA5#### | FITS 08-10 KLR650 14001-5406 - MORE REFINED CASTING AND DIFFERENT COLOR THEN 07 AND OLDER | FITS 08-10 KLR650 - 11011-0076 | 2008 | KLR650 | FITS 08-11 KLR650 12044-0166 | FITS 96-11 KLR650 12044-1372 | FITS 08-09 KLR650 - 15003-0118 | 2008 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | FITS 08-12 KLR650 - 21119-0095 | FITS 96-10 KLR650 - 13095-1311 | 2008 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 08-09 KLR650 14032-0090 | 2008 | KLR650 | FITS 08-12 KLR650 - 21121-0029 | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 2008 | KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 08-10 KLR650 13031-0093 | 2008 | KLR650 | DENSO 037000-7160 | 2008 | KLR650 | 2008 | KLR650 | 2008 | KLR650 | 2008 | KLR650 | 2008 | KLR650 | 2008 | KLR650 | FITS 08-10 KLR650 – 11008-0129 | 2008 | KLR650 | N/A | N/A | 2008 | KLR650 | 2008 | KLR650 | FITS 08-10 KLR650 - 13001-0092 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 2008 | KLR650 | 2008 | KLR650 | 2008 | KLR650 | 2008 | KLR650 | 2008 | KLR650 | 2008 | KLR650 | 2008 | KLR650 | FITS 08-10 KLR650 - 53066-0144-339 | 2008 | KLR650 | 2008 | KLR650 | FITS 08-10 KLR650 21003-0045 | FITS 08-10 KLR650 14031-0117 | FITS 87-10 KLR650 | 2008 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | 2008 | KLR650 | 2008 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 2008 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 2008 | KLR650 | FITS 08-10 KLR650 - 13128-0041 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 2008 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 2008 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | 2008 | KLR650 | 2008 | KLR650 | 2008 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | 2008 | KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2008 | KLR650 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2009 | KLR650 | FITS 08-10 KLR650 14001-5406 - MORE REFINED CASTING AND DIFFERENT COLOR THEN 07 AND OLDER | FITS 08-10 KLR650 - 11011-0076 | 2009 | KLR650 | FITS 08-11 KLR650 12044-0166 | FITS 96-11 KLR650 12044-1372 | FITS 08-09 KLR650 - 15003-0118 | 2009 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | FITS 08-12 KLR650 - 21119-0095 | FITS 96-10 KLR650 - 13095-1311 | 2009 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 08-09 KLR650 14032-0090 | 2009 | KLR650 | FITS 08-12 KLR650 - 21121-0029 | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 2009 | KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 08-10 KLR650 13031-0093 | 2009 | KLR650 | DENSO 037000-7160 | 2009 | KLR650 | 2009 | KLR650 | 2009 | KLR650 | 2009 | KLR650 | 2009 | KLR650 | 2009 | KLR650 | FITS 08-10 KLR650 – 11008-0129 | 2009 | KLR650 | N/A | N/A | 2009 | KLR650 | 2009 | KLR650 | FITS 08-10 KLR650 - 13001-0092 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 2009 | KLR650 | 2009 | KLR650 | 2009 | KLR650 | 2009 | KLR650 | 2009 | KLR650 | 2009 | KLR650 | 2009 | KLR650 | FITS 08-10 KLR650 - 53066-0144-339 | 2009 | KLR650 | 2009 | KLR650 | FITS 08-10 KLR650 21003-0045 | FITS 08-10 KLR650 14031-0117 | FITS 87-10 KLR650 | 2009 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | 2009 | KLR650 | 2009 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 2009 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 2009 | KLR650 | FITS 08-10 KLR650 - 13128-0041 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 2009 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 2009 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | 2009 | KLR650 | 2009 | KLR650 | 2009 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | 2009 | KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2009 | KLR650 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2010 | KLR650 | FITS 08-10 KLR650 14001-5406 - MORE REFINED CASTING AND DIFFERENT COLOR THEN 07 AND OLDER | FITS 08-10 KLR650 - 11011-0076 | 2010 | KLR650 | FITS 08-11 KLR650 12044-0166 | FITS 96-11 KLR650 12044-1372 | FITS 10-12 KLR650 - 15004-0072 | 2010 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | FITS 08-12 KLR650 - 21119-0095 | FITS 96-10 KLR650 - 13095-1311 | 2010 | KLR650 | FITS 96-10 KLR650 13095-1311 | FITS 10 KLR650 - 14032-0145 | 2010 | KLR650 | FITS 08-12 KLR650 - 21121-0029 | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 2010 | KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | FITS 08-10 KLR650 13031-0093 | 2010 | KLR650 | DENSO 037000-7160 | 2010 | KLR650 | 2010 | KLR650 | 2010 | KLR650 | 2010 | KLR650 | 2010 | KLR650 | 2010 | KLR650 | FITS 08-10 KLR650 – 11008-0129 | 2010 | KLR650 | N/A | N/A | 2010 | KLR650 | 2010 | KLR650 | FITS 08-10 KLR650 - 13001-0092 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | FITS 87-10 KLR650 - 16085-1205 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 2010 | KLR650 | 2010 | KLR650 | 2010 | KLR650 | 2010 | KLR650 | 2010 | KLR650 | 2010 | KLR650 | 2010 | KLR650 | FITS 08-10 KLR650 - 53066-0144-339 | 2010 | KLR650 | 2010 | KLR650 | FITS 08-10 KLR650 21003-0045 | FITS 08-10 KLR650 14031-0117 | FITS 87-10 KLR650 | 2010 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | 2010 | KLR650 | 2010 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 2010 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 2010 | KLR650 | FITS 08-10 KLR650 - 13128-0041 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 2010 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 2010 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | 2010 | KLR650 | 2010 | KLR650 | 2010 | KLR650 | FITS 87-10 KLR650 - 12005-1085 | FITS 87-10 KLR650 - 12004-1087 | 2010 | KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2010 | KLR650 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2011 | KLR650 | FITS 11-12 KLR650 - 14001-5421 | FITS 11-12 KLR650 - 11011-0159 | 2011 | KLR650 | FITS 08-11 KLR650 12044-0166 | FITS 96-11 KLR650 12044-1372 | FITS 10-12 KLR650 - 15004-0072 | 2011 | KLR650 | FITS 87-11 KLR650 - 16065-1151 | FITS 08-12 KLR650 - 21119-0095 | 2011 | KLR650 | 2011 | KLR650 | FITS 08-12 KLR650 - 21121-0029 | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 2011 | KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | 2011 | KLR650 | DENSO 037000-7160 | 2011 | KLR650 | 2011 | KLR650 | 2011 | KLR650 | 2011 | KLR650 | 2011 | KLR650 | 2011 | KLR650 | 2011 | KLR650 | N/A | N/A | 2011 | KLR650 | 2011 | KLR650 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 2011 | KLR650 | 2011 | KLR650 | 2011 | KLR650 | 2011 | KLR650 | 2011 | KLR650 | 2011 | KLR650 | 2011 | KLR650 | FITS 11-12 KLR650 - 53066-0278-339 | 2011 | KLR650 | 2011 | KLR650 | 2011 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | 2011 | KLR650 | 2011 | KLR650 | 15T - FITS 87-11 KLR650, 93-96 KLX650C - 13127-1147 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 2011 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 2011 | KLR650 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 2011 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 2011 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | 2011 | KLR650 | 2011 | KLR650 | 2011 | KLR650 | 2011 | KLR650 | FITS 85-05 KLR250, 84-86 KL600, 87-11 KLR650 - 59256-1055 | 2011 | KLR650 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
2012 | KLR650 | FITS 11-12 KLR650 - 14001-5421 | FITS 11-12 KLR650 - 11011-0159 | 2012 | KLR650 | FITS 10-12 KLR650 - 15004-0072 | 2012 | KLR650 | FITS 08-12 KLR650 - 21119-0095 | 2012 | KLR650 | 2012 | KLR650 | FITS 08-12 KLR650 - 21121-0029 | FITS 85-86 KL600, 87-12 KLR650 - 12053-1175 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1111 | 2012 | KLR650 | 13107-1104 - FITS 84-86 KL600, 87-12 KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | FITS 92-12 KLR650 - 13194-1089 | FITS 87-12 KLR650 - 42034-1094 | 33T - FITS 96-13 KLR650, 93-96 KLX650C, 96 KLX650R - 13097-1333 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | FITS 11-12 KLR650 - 53066-0278-339 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1223 | FITS 84-86 KL600, 87-12 KLR650 - 12053-1222 | 2012 | KLR650 | 2012 | KLR650 | 18T - FITS 96-12 KLR650 - 13260-1464 | 22T - FITS 96-12 KLR650 - 13260-1518 | 2012 | KLR650 | 22T - FITS 96-12 KLR650 - 13260-1519 | 24T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1326 | N/A | 2012 | KLR650 | 34T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1327 | 2012 | KLR650 | 26T - FITS 96-12 KLR650 - 13260-1465 | 25T - FITS 96-12 KLR650 - 13260-1467 | 2012 | KLR650 | 21T - FITS 96-12 KLR650 - 13260-1520 | 19T - FITS 93-96 KLX650C KLX650R, 96-12 KLR650 - 13260-1331 | N/A | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | 2012 | KLR650 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
YEAR | TYPE | VIN FRAME USA ONLY | ENGINE ID | ENGINE CASES | AIR BOX | YEAR | TYPE | CABLE CLUTCH | CABLE SPEEDOMETER | CABLE STARTER (CHOKE) | CABLE THROTTLE CLOSE | CABLE THROTTLE OPEN | CAM SHAFT EXHAUST | CAM SHAFT INTAKE | CARBURETOR | YEAR | TYPE | CARB BOOT | CDI | CHAIN SLIDER | CLUTCH ARM | YEAR | TYPE | CLUTCH BASKET | CLUTCH COVER | YEAR | TYPE | CLUTCH PRESSURE PLATE | COIL (IGNITION) | COUNTER BALANCE CHAIN GUIDE FRONT | COUNTER BALANCE CHAIN GUIDE REAR | YEAR | TYPE | FR COUNTER BALANCE SHAFT | RR COUNTER BALANCE SHAFT | COUNTER SPROCKET GUARD | COWLING (Fairing) BRACKET | CRANK SHAFT | CYLINDER | YEAR | TYPE | ENGINE MOUNTS | EXHAUST MUFFLER | FLY WHEEL ROTOR | FOOT PEGS PASSENGER | FOOT PEG PASSENGER MOUNTS | YEAR | TYPE | FORK | YEAR | TYPE | FRONT AXLE | FRONT BRAKE CALIPER | YEAR | TYPE | FRONT BRAKE CALIPER MOUNT | FRONT BRAKE MASTER CYLINDER | YEAR | TYPE | FRONT BRAKE ROTOR | FRONT HUB | YEAR | TYPE | FRONT RIM | YEAR | TYPE | GAS CAP | HEAD | HEAD LIGHT | YEAR | TYPE | HEAD LAMP BODY | IGNITION SWITCH | KICK IDLER GEAR | KICK LEVER | KICK LEVER SHAFT | YEAR | TYPE | LEFT CONTROL SWITCH | YEAR | TYPE | OIL FILTER CAP | PISTON | ONE WAY CLUTCH BEARING | ONE WAY CLUTCH BEARING COUPLING | ONE WAY CLUTCH GEAR | PISTON | PRIMARY CRANK GEAR | YEAR | TYPE | RADIATOR LEFT | RADIATOR RIGHT | RADIATOR FAN | RADIATOR FAN SENDING UNIT | RADIATOR SHROUDS | REAR AXLE | YEAR | TYPE | REAR HUB | YEAR | TYPE | REAR RIM | YEAR | TYPE | REAR BRAKE CALIPER | REAR BRAKE CALIPER MOUNT | YEAR | TYPE | REAR BRAKE ROTOR | REAR FENDER | YEAR | TYPE | SHOCK | YEAR | TYPE | SEAT | SHOCK ARM LINKAGE - UNI TRAK | SHOCK ARM LINKAGE SHAFT/PIN | YEAR | TYPE | SIDE COVER LEFT | SIDE COVER RIGHT | SIDE STAND | SKID PLATE | SPEEDOMETER | YEAR | TYPE | STATOR | STATOR COVER | SUB FRAME | SWING ARM PIN / AXLE | YEAR | TYPE | TIMING CHAIN GUIDE FRONT | TIMING CHAIN GUIDE REAR | TIMING CHAIN TENSIONER | YEAR | TYPE | TRANSMISSION | YEAR | TYPE | TRANSMISSION INPUT SHAFT | TRANSMISSION INPUT 2ND GEAR | TRANSMISSION INPUT 3RD GEAR | YEAR | TYPE | TRANSMISSION INPUT 4TH GEAR | TRANSMISSION INPUT 5TH GEAR | TRANSMISSION INPUT 6TH GEAR | YEAR | TYPE | TRANSMISSION OUTPUT SHAFT | TRANSMISSION OUTPUT 1ST GEAR | YEAR | TYPE | TRANSMISSION OUTPUT 2ND GEAR | TRANSMISSION OUTPUT 3RD GEAR | YEAR | TYPE | TRANSMISSION OUTPUT 4TH GEAR | TRANSMISSION OUTPUT 5TH GEAR | TRANSMISSION OUTPUT 6TH GEAR | TRIPLE TREE BOTTOM | YEAR | TYPE | TRIPLE TREE TOP | TURN SIGNAL FRONT LEFT | TURN SIGNAL FRONT RIGHT | YEAR | TYPE | TURN SIGNAL REAR LEFT | TURN SIGNAL REAR RIGHT | YEAR | TYPE | VALVE (EXHAUST) | VALVE (INTAKE) | VOLTAGE REGULATOR | YEAR | TYPE | WIRE HARNESS | WATER PUMP IMPELLER | YEAR | TYPE |
This page last modified: Wednesday, 18-Jun-2014 10:11:11 PDT
