| YEAR | TYPE | VIN FRAME USA ONLY | ENGINE ID | ENGINE CASES | AIR BOX | CAM SHAFT EXHAUST | CAM SHAFT INTAKE | CARBURETOR | YEAR | TYPE | CARB BOOT AND REED BOLT PATTERN | CDI | CHAIN GUIDE | CLUTCH ARM | YEAR | TYPE | CLUTCH COVER | CLUTCH COVER INNER | CLUTCH BASKET | COIL | CRANK SHAFT | CYLINDER | FLY WHEEL ROTOR | YEAR | TYPE | FORK | FORK GUARDS | YEAR | TYPE | FORK GUARD MOUNTS | FRONT AXLE | FRONT BRAKE CALIPER | YEAR | TYPE | FRONT BRAKE CALIPER MOUNT | FRONT BRAKE LEVER | FRONT BRAKE MASTER CYLINDER | YEAR | TYPE | FRONT BRAKE ROTOR | FRONT HUB | HEAD | KICK IDLER GEAR | YEAR | TYPE | ONE WAY CLUTCH GEAR | PISTON | REAR AXLE | STATOR | STATOR COVER | YEAR | TYPE | SHOCK ARM LINKAGE | RADIATOR SHROUDS | REAR HUB | YEAR | TYPE | SHIFT FORKS | REAR BRAKE BACKING PLATE | REAR BRAKE CALIPER | REAR BRAKE CALIPER MOUNT | REAR BRAKE HOSE | YEAR | TYPE | REAR BRAKE MASTER CYLINDER | REAR BRAKE ROTOR | REAR WHEEL SPACERS | YEAR | TYPE | SHOCK | SHOCK ARM LINKAGE | SIDE STAND | YEAR | TYPE | STATOR | STATOR COVER | SWING ARM | SWING ARM PIN / AXLE | YEAR | TYPE | TIMING CHAIN TENSIONER | TRANSMISSION | TRIPLE TREE BOTTOM | YEAR | TYPE | TRIPLE TREE TOP | VOLTAGE REGULATOR | WIRE HARNESS | YEAR | TYPE |
| 1985 | KLR250 | | | FITS 85-05 KLR250 | | FITS 85-86 KLR250 | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1985 | KLR250 | | | | | 1985 | KLR250 | | | | | | | | 1985 | KLR250 | | | 1985 | KLR250 | | | FITS 84-86 KL600, 85-90 KLR250 | 1985 | KLR250 | | | FITS 84-86 KL600, 85-90 KLR250 | 1985 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1985 | KLR250 | | | | | | 1985 | KLR250 | | | | 1985 | KLR250 | | | | | | 1985 | KLR250 | | | | 1985 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1985 | KLR250 | | | | | 1985 | KLR250 | | | | 1985 | KLR250 | | | | 1985 | KLR250 |
| 1986 | KLR250 | | KHI KL250DE------ | FITS 85-05 KLR250 | | FITS 85-86 KLR250 | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1986 | KLR250 | | | | | 1986 | KLR250 | | | | | | | | 1986 | KLR250 | | | 1986 | KLR250 | | | FITS 84-86 KL600, 85-90 KLR250 | 1986 | KLR250 | | | FITS 84-86 KL600, 85-90 KLR250 | 1986 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1986 | KLR250 | | | | | | 1986 | KLR250 | | | | 1986 | KLR250 | | | | | | 1986 | KLR250 | | | | 1986 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1986 | KLR250 | | | | | 1986 | KLR250 | | | | 1986 | KLR250 | | | | 1986 | KLR250 |
| 1987 | KLR250 | | | FITS 85-05 KLR250 | | | | KEIHIN CVK FITS 85-01 KLR250 | 1987 | KLR250 | | | | | 1987 | KLR250 | | | | | | | | 1987 | KLR250 | | | 1987 | KLR250 | | | FITS 84-86 KL600, 85-90 KLR250 | 1987 | KLR250 | | | FITS 84-86 KL600, 85-90 KLR250 | 1987 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1987 | KLR250 | | | | | | 1987 | KLR250 | | | | 1987 | KLR250 | | | | | | 1987 | KLR250 | | | | 1987 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1987 | KLR250 | | | | | 1987 | KLR250 | | | | 1987 | KLR250 | | | | 1987 | KLR250 |
| 1988 | KLR250 | | | FITS 85-05 KLR250 | | | | KEIHIN CVK FITS 85-01 KLR250 | 1988 | KLR250 | | | | | 1988 | KLR250 | | | | | | | | 1988 | KLR250 | | | 1988 | KLR250 | | | FITS 84-86 KL600, 85-90 KLR250 | 1988 | KLR250 | | | FITS 84-86 KL600, 85-90 KLR250 | 1988 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1988 | KLR250 | | | | | | 1988 | KLR250 | | | | 1988 | KLR250 | | | | | | 1988 | KLR250 | | | | 1988 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1988 | KLR250 | | | | | 1988 | KLR250 | | | | 1988 | KLR250 | | | | 1988 | KLR250 |
| 1989 | KLR250 | | | FITS 85-05 KLR250 | | | | KEIHIN CVK FITS 85-01 KLR250 | 1989 | KLR250 | | | | | 1989 | KLR250 | | | | | | | | 1989 | KLR250 | | | 1989 | KLR250 | | | FITS 84-86 KL600, 85-90 KLR250 | 1989 | KLR250 | | | FITS 84-86 KL600, 85-90 KLR250 | 1989 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1989 | KLR250 | | | | | | 1989 | KLR250 | | | | 1989 | KLR250 | | | | | | 1989 | KLR250 | | | | 1989 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1989 | KLR250 | | | | | 1989 | KLR250 | | | | 1989 | KLR250 | | | | 1989 | KLR250 |
| 1990 | KLR250 | | | FITS 85-05 KLR250 | | | | KEIHIN CVK FITS 85-01 KLR250 | 1990 | KLR250 | | | | | 1990 | KLR250 | | | | | | | | 1990 | KLR250 | | | 1990 | KLR250 | | | FITS 84-86 KL600, 85-90 KLR250 | 1990 | KLR250 | | | FITS 84-86 KL600, 85-90 KLR250 | 1990 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1990 | KLR250 | | | | | | 1990 | KLR250 | | | | 1990 | KLR250 | | | | | | 1990 | KLR250 | | | | 1990 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1990 | KLR250 | | | | | 1990 | KLR250 | | | | 1990 | KLR250 | | | | 1990 | KLR250 |
| 1991 | KLR250 | | | FITS 85-05 KLR250 | | | | KEIHIN CVK FITS 85-01 KLR250 | 1991 | KLR250 | | | | | 1991 | KLR250 | | | | | | | | 1991 | KLR250 | | | 1991 | KLR250 | | | | 1991 | KLR250 | | | | 1991 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1991 | KLR250 | | | | | | 1991 | KLR250 | | | | 1991 | KLR250 | | | | | | 1991 | KLR250 | | | | 1991 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1991 | KLR250 | | | | | 1991 | KLR250 | | | | 1991 | KLR250 | | | | 1991 | KLR250 |
| 1992 | KLR250 | | | FITS 85-05 KLR250 | | | | KEIHIN CVK FITS 85-01 KLR250 | 1992 | KLR250 | | | | | 1992 | KLR250 | | | | | | | | 1992 | KLR250 | | | 1992 | KLR250 | | | | 1992 | KLR250 | | | | 1992 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1992 | KLR250 | | | | | | 1992 | KLR250 | | | | 1992 | KLR250 | | | | | | 1992 | KLR250 | | | | 1992 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1992 | KLR250 | | | | | 1992 | KLR250 | | | | 1992 | KLR250 | | | | 1992 | KLR250 |
| 1993 | KLR250 | | | FITS 85-05 KLR250 | | | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1993 | KLR250 | | | | | 1993 | KLR250 | | | | | | | | 1993 | KLR250 | | | 1993 | KLR250 | | | | 1993 | KLR250 | | | | 1993 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1993 | KLR250 | | | | | | 1993 | KLR250 | | | | 1993 | KLR250 | | | | | | 1993 | KLR250 | | | | 1993 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1993 | KLR250 | | | | | 1993 | KLR250 | | | | 1993 | KLR250 | | | | 1993 | KLR250 |
| 1994 | KLR250 | | | FITS 85-05 KLR250 | | | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1994 | KLR250 | | | | | 1994 | KLR250 | | | | | | | | 1994 | KLR250 | | | 1994 | KLR250 | | | | 1994 | KLR250 | | | | 1994 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1994 | KLR250 | | | | | | 1994 | KLR250 | | | | 1994 | KLR250 | | | | | | 1994 | KLR250 | | | | 1994 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1994 | KLR250 | | | | | 1994 | KLR250 | | | | 1994 | KLR250 | | | | 1994 | KLR250 |
| 1995 | KLR250 | | | FITS 85-05 KLR250 | | | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1995 | KLR250 | | | | | 1995 | KLR250 | | | | | | | | 1995 | KLR250 | | | 1995 | KLR250 | | | | 1995 | KLR250 | | | | 1995 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1995 | KLR250 | | | | | | 1995 | KLR250 | | | | 1995 | KLR250 | | | | | | 1995 | KLR250 | | | | 1995 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1995 | KLR250 | | | | | 1995 | KLR250 | | | | 1995 | KLR250 | | | | 1995 | KLR250 |
| 1996 | KLR250 | | | FITS 85-05 KLR250 | | | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1996 | KLR250 | | | | | 1996 | KLR250 | | | | | | | | 1996 | KLR250 | | | 1996 | KLR250 | | | | 1996 | KLR250 | | | | 1996 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1996 | KLR250 | | | | | | 1996 | KLR250 | | | | 1996 | KLR250 | | | | | | 1996 | KLR250 | | | | 1996 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1996 | KLR250 | | | | | 1996 | KLR250 | | | | 1996 | KLR250 | | | | 1996 | KLR250 |
| 1997 | KLR250 | | | FITS 85-05 KLR250 | | | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1997 | KLR250 | | | | | 1997 | KLR250 | | | | | | | | 1997 | KLR250 | | | 1997 | KLR250 | | | | 1997 | KLR250 | | | | 1997 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1997 | KLR250 | | | | | | 1997 | KLR250 | | | | 1997 | KLR250 | | | | | | 1997 | KLR250 | | | | 1997 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1997 | KLR250 | | | | | 1997 | KLR250 | | | | 1997 | KLR250 | | | | 1997 | KLR250 |
| 1998 | KLR250 | | | FITS 85-05 KLR250 | | | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1998 | KLR250 | | | | | 1998 | KLR250 | | | | | | | | 1998 | KLR250 | | | 1998 | KLR250 | | | | 1998 | KLR250 | | | | 1998 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1998 | KLR250 | | | | | | 1998 | KLR250 | | | | 1998 | KLR250 | | | | | | 1998 | KLR250 | | | | 1998 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1998 | KLR250 | | | | | 1998 | KLR250 | | | | 1998 | KLR250 | | | | 1998 | KLR250 |
| 1999 | KLR250 | | | FITS 85-05 KLR250 | | | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 1999 | KLR250 | | | | | 1999 | KLR250 | | | | | | | | 1999 | KLR250 | | | 1999 | KLR250 | | | | 1999 | KLR250 | | | | 1999 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1999 | KLR250 | | | | | | 1999 | KLR250 | | | | 1999 | KLR250 | | | | | | 1999 | KLR250 | | | | 1999 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 1999 | KLR250 | | | | | 1999 | KLR250 | | | | 1999 | KLR250 | | | | 1999 | KLR250 |
| 2000 | KLR250 | | | FITS 85-05 KLR250 | | | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 2000 | KLR250 | | | | | 2000 | KLR250 | | | | | | | | 2000 | KLR250 | | | 2000 | KLR250 | | | | 2000 | KLR250 | | | | 2000 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 2000 | KLR250 | | | | | | 2000 | KLR250 | | | | 2000 | KLR250 | | | | | | 2000 | KLR250 | | | | 2000 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 2000 | KLR250 | | | | | 2000 | KLR250 | | | | 2000 | KLR250 | | | | 2000 | KLR250 |
| 2001 | KLR250 | | | FITS 85-05 KLR250 | | | FITS 85-86, 93-05 KLR250 | KEIHIN CVK FITS 85-01 KLR250 | 2001 | KLR250 | | | | | 2001 | KLR250 | | | | | | | | 2001 | KLR250 | | | 2001 | KLR250 | | | | 2001 | KLR250 | | | | 2001 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 2001 | KLR250 | | | | | | 2001 | KLR250 | | | | 2001 | KLR250 | | | | | | 2001 | KLR250 | | | | 2001 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 2001 | KLR250 | | | | | 2001 | KLR250 | | | | 2001 | KLR250 | | | | 2001 | KLR250 |
| 2002 | KLR250 | | | FITS 85-05 KLR250 | | | FITS 85-86, 93-05 KLR250 | | 2002 | KLR250 | | | | | 2002 | KLR250 | | | | | | | | 2002 | KLR250 | | | 2002 | KLR250 | | | | 2002 | KLR250 | | | | 2002 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 2002 | KLR250 | | | | | | 2002 | KLR250 | | | | 2002 | KLR250 | | | | | | 2002 | KLR250 | | | | 2002 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 2002 | KLR250 | | | | | 2002 | KLR250 | | | | 2002 | KLR250 | | | | 2002 | KLR250 |
| 2003 | KLR250 | | | FITS 85-05 KLR250 | | | FITS 85-86, 93-05 KLR250 | | 2003 | KLR250 | | | | | 2003 | KLR250 | | | | | | | | 2003 | KLR250 | | | 2003 | KLR250 | | | | 2003 | KLR250 | | | | 2003 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 2003 | KLR250 | | | | | | 2003 | KLR250 | | | | 2003 | KLR250 | | | | | | 2003 | KLR250 | | | | 2003 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 2003 | KLR250 | | | | | 2003 | KLR250 | | | | 2003 | KLR250 | | | | 2003 | KLR250 |
| 2004 | KLR250 | | | FITS 85-05 KLR250 | | | FITS 85-86, 93-05 KLR250 | | 2004 | KLR250 | | | | | 2004 | KLR250 | | | | | | | | 2004 | KLR250 | | | 2004 | KLR250 | | | | 2004 | KLR250 | | | | 2004 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 2004 | KLR250 | | | | | | 2004 | KLR250 | | | | 2004 | KLR250 | | | | | | 2004 | KLR250 | | | | 2004 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 2004 | KLR250 | | | | | 2004 | KLR250 | | | | 2004 | KLR250 | | | | 2004 | KLR250 |
| 2005 | KLR250 | | | FITS 85-05 KLR250 | | | FITS 85-86, 93-05 KLR250 | | 2005 | KLR250 | | | | | 2005 | KLR250 | | | | | | | | 2005 | KLR250 | | | 2005 | KLR250 | | | | 2005 | KLR250 | | | | 2005 | KLR250 | | | | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 2005 | KLR250 | | | | | | 2005 | KLR250 | | | | 2005 | KLR250 | | | | | | 2005 | KLR250 | | | | 2005 | KLR250 | | FITS 85-05 KLR250 39007-1059, 46102-1129 | | 2005 | KLR250 | | | | | 2005 | KLR250 | | | | 2005 | KLR250 | | | | 2005 | KLR250 |
| YEAR | TYPE | FRAME VIN | ENGINE ID | ENGINE CASES | AIR BOX | CAM SHAFT EXHAUST | CAM SHAFT INTAKE | CARBURETOR | YEAR | TYPE | CARB BOOT AND REED BOLT PATTERN | CDI | CHAIN GUIDE | CLUTCH ARM | YEAR | TYPE | CLUTCH COVER | INNER CLUTCH COVER | CLUTCH BASKET | COIL | CRANK SHAFT | CYLINDER | FLY WHEEL | YEAR | TYPE | FORK | FORK GUARDS | YEAR | TYPE | FORK GUARD MOUNTS | FRONT AXLE | FRONT BRAKE CALIPER | YEAR | TYPE | FRONT BRAKE CALIPER MOUNT | FRONT BRAKE LEVER | FRONT BRAKE MASTER CYLINDER | YEAR | TYPE | FRONT BRAKE ROTOR | FRONT HUB | HEAD | KICK IDLER GEAR | YEAR | TYPE | ONE WAY CLUTCH GEAR | PISTON | REAR AXLE | STATOR | STATOR COVER | YEAR | TYPE | SHOCK ARM LINKAGE | RADIATOR SHROUDS | REAR HUB | YEAR | TYPE | SHIFT FORKS | REAR BRAKE BACKING PLATE | REAR BRAKE CALIPER | REAR BRAKE CALIPER MOUNT | REAR BRAKE HOSE | YEAR | TYPE | REAR BRAKE MASTER CYLINDER | REAR BRAKE ROTOR | REAR WHEEL SPACERS | YEAR | TYPE | SHOCK | SHOCK ARM LINKAGE | SIDE STAND | YEAR | TYPE | STATOR | STATOR COVER | SWING ARM | SWING ARM PIN / AXLE | YEAR | TYPE | TIMING CHAIN TENSIONER | TRANSMISSION | TRIPLE TREE BOTTOM | YEAR | TYPE | TRIPLE TREE TOP | VOLTAGE REGULATOR | WIRE HARNESS | YEAR | TYPE |
| 1994 | KLX250R | | | | | | | KEIHIN CVK G188 32.5MM | 1994 | KLX250R | | | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 1994 | KLX250R | | | | | | | | 1994 | KLX250R | | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 1994 | KLX250R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 | | | 1994 | KLX250R | | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 1994 | KLX250R | OD: 9 7/8" - ID 4" - 4 HOLES ON A 4 9/16" BC - FITS KX125 AND 250 92-02 - KX500 94-04 - KLX650R 93-96 - KLX300R 97-07 | | FITS 94-96 KLX250R, 97-07 KLX300R | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1994 | KLX250R | | | | | | 1994 | KLX250R | | | | 1994 | KLX250R | | | FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R | | | 1994 | KLX250R | | | | 1994 | KLX250R | | | FITS 94-96 KLX250R, 97-98 KLX300R | 1994 | KLX250R | | | FITS 94-96 KLX250 | | 1994 | KLX250R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | | | 1994 | KLX250R | | | | 1994 | KLX250R |
| 1995 | KLX250R | JKALXMD12SA00---- | LX250DE111111 | | | | | KEIHIN CVK G188 32.5MM | 1995 | KLX250R | | 21119-1376 071000-0520 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 1995 | KLX250R | | | | | | | | 1995 | KLX250R | | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 1995 | KLX250R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 | | FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R | 1995 | KLX250R | | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 1995 | KLX250R | | | FITS 94-96 KLX250R, 97-07 KLX300R | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1995 | KLX250R | | | | | | 1995 | KLX250R | | | R-1237 - AXLE DIA 20MM - BRG TO BRG 128-129MM - ROTOR BC 6 ON 116MM - SPROCKET BC 6 ON 150MM - FITS 91-94 KDX250, 93-96 KLX650R, 94-96 KLX250R, 95-06 KDX200 | 1995 | KLX250R | | | | | | 1995 | KLX250R | | | | 1995 | KLX250R | | | FITS 94-96 KLX250R, 97-98 KLX300R | 1995 | KLX250R | | | FITS 94-96 KLX250 | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 1995 | KLX250R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | | | 1995 | KLX250R | | SH623-12 | | 1995 | KLX250R |
| 1996 | KLX250R | | | | | | | KEIHIN CVK G188 32.5MM | 1996 | KLX250R | | | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 1996 | KLX250R | | | | | | | | 1996 | KLX250R | USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 1996 | KLX250R | | | FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R | 1996 | KLX250R | | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | | 1996 | KLX250R | | | FITS 94-96 KLX250R, 97-07 KLX300R | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1996 | KLX250R | | | | FITS 96 KLX250, 97-07 KLX300 | | 1996 | KLX250R | | | | 1996 | KLX250R | | | FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R | | | 1996 | KLX250R | | | | 1996 | KLX250R | | | FITS 94-96 KLX250R, 97-98 KLX300R | 1996 | KLX250R | FITS 96 KLX250, 97-07 KLX300 | | FITS 94-96 KLX250 | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 1996 | KLX250R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | | | 1996 | KLX250R | | | | 1996 | KLX250R |
| 1997 | KLX300R | | | | | | | | 1997 | KLX300R | | Denso 21119-1479 071000-1090 FITS 97-2007 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 1997 | KLX300R | | | | | | | | 1997 | KLX300R | USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 97-02 KLX300R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 1997 | KLX300R | | | FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 | 1997 | KLX300R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 1997 | KLX300R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1997 | KLX300R | | | | FITS 96 KLX250, 97-07 KLX300 | | 1997 | KLX300R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 1997 | KLX300R | | | FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R | | | 1997 | KLX300R | | | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 1997 | KLX300R | Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R | | FITS 94-96 KLX250R, 97-98 KLX300R | 1997 | KLX300R | FITS 96 KLX250, 97-07 KLX300 | | | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 1997 | KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 | | 1997 | KLX300R | | | | 1997 | KLX300R |
| 1998 | KLX300R | | | | | | | | 1998 | KLX300R | | Denso 21119-1479 071000-1090 FITS 97-2007 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 1998 | KLX300R | | | | | | | | 1998 | KLX300R | USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 97-02 KLX300R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 1998 | KLX300R | | | FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 | 1998 | KLX300R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 1998 | KLX300R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1998 | KLX300R | | | | FITS 96 KLX250, 97-07 KLX300 | | 1998 | KLX300R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 1998 | KLX300R | | | FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R | | | 1998 | KLX300R | | | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 1998 | KLX300R | Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R | | FITS 94-96 KLX250R, 97-98 KLX300R | 1998 | KLX300R | FITS 96 KLX250, 97-07 KLX300 | | | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 1998 | KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 | | 1998 | KLX300R | | | | 1998 | KLX300R |
| 1999 | KLX300R | | | | | | | | 1999 | KLX300R | | Denso 21119-1479 071000-1090 FITS 97-2007 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 1999 | KLX300R | | | 1119 1KX250D-A201 | | | | | 1999 | KLX300R | USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 97-02 KLX300R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 1999 | KLX300R | | | FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 | 1999 | KLX300R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 1999 | KLX300R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 1999 | KLX300R | | | | FITS 96 KLX250, 97-07 KLX300 | | 1999 | KLX300R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 1999 | KLX300R | | | FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R | | | 1999 | KLX300R | | | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 1999 | KLX300R | Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R | | | 1999 | KLX300R | FITS 96 KLX250, 97-07 KLX300 | | | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 1999 | KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 | | 1999 | KLX300R | | | | 1999 | KLX300R |
| 2000 | KLX300R | | | | | | | | 2000 | KLX300R | | Denso 21119-1479 071000-1090 FITS 97-2007 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 2000 | KLX300R | | | | | | | | 2000 | KLX300R | USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 97-02 KLX300R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 2000 | KLX300R | | | FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 | 2000 | KLX300R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 2000 | KLX300R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 2000 | KLX300R | | | FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S | FITS 96 KLX250, 97-07 KLX300 | | 2000 | KLX300R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 2000 | KLX300R | | | FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R | | | 2000 | KLX300R | | | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 2000 | KLX300R | Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R | | | 2000 | KLX300R | FITS 96 KLX250, 97-07 KLX300 | | | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 2000 | KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 | | 2000 | KLX300R | | | | 2000 | KLX300R |
| 2001 | KLX300R | | | | | | | | 2001 | KLX300R | | Denso 21119-1479 071000-1090 FITS 97-2007 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 2001 | KLX300R | | | | | | | | 2001 | KLX300R | USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 97-02 KLX300R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 2001 | KLX300R | | | FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 | 2001 | KLX300R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 2001 | KLX300R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 2001 | KLX300R | | | FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S | FITS 96 KLX250, 97-07 KLX300 | | 2001 | KLX300R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 2001 | KLX300R | | | FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R | | | 2001 | KLX300R | | | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 2001 | KLX300R | Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R | | | 2001 | KLX300R | FITS 96 KLX250, 97-07 KLX300 | | | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 2001 | KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 | | 2001 | KLX300R | | | | 2001 | KLX300R |
| 2002 | KLX300R | | | | | | | | 2002 | KLX300R | | Denso 21119-1479 071000-1090 FITS 97-2007 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 2002 | KLX300R | | | | | | | | 2002 | KLX300R | USD K328-L K328-R - 43MM CHROME OD - C/L 36" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE 22MM & 15MM - FITS 97-02 KLX300R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 2002 | KLX300R | | | FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 | 2002 | KLX300R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 2002 | KLX300R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R | FITS 85-05 KLR250, 94-96 KLX250, 97-02 KLX300 - 59051-1120 | 2002 | KLX300R | | | FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S | FITS 96 KLX250, 97-07 KLX300 | | 2002 | KLX300R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 2002 | KLX300R | | | FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R | | | 2002 | KLX300R | | | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 2002 | KLX300R | Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R | | | 2002 | KLX300R | FITS 96 KLX250, 97-07 KLX300 | | | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 2002 | KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 | | 2002 | KLX300R | | | | 2002 | KLX300R |
| 2003 | KLX300R | | | | | | | | 2003 | KLX300R | | Denso 21119-1479 071000-1090 FITS 97-2007 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 2003 | KLX300R | | | | | | | | 2003 | KLX300R | | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 2003 | KLX300R | | | FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 | 2003 | KLX300R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 2003 | KLX300R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R | | 2003 | KLX300R | | | FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S | FITS 96 KLX250, 97-07 KLX300 | | 2003 | KLX300R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 2003 | KLX300R | | | FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R | | | 2003 | KLX300R | | | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 2003 | KLX300R | Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R | | | 2003 | KLX300R | FITS 96 KLX250, 97-07 KLX300 | | | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 2003 | KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 | | 2003 | KLX300R | | | | 2003 | KLX300R |
| 2004 | KLX300R | | | | | | | | 2004 | KLX300R | | Denso 21119-1479 071000-1090 FITS 97-2007 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 2004 | KLX300R | | | | | | | | 2004 | KLX300R | | | 2004 | KLX300R | | | | 2004 | KLX300R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 2004 | KLX300R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R | | 2004 | KLX300R | | | FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S | FITS 96 KLX250, 97-07 KLX300 | | 2004 | KLX300R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 2004 | KLX300R | | | FITS 04-07 KLR300R, 4 KX500, 06-07 KLX250S | | | 2004 | KLX300R | | | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 2004 | KLX300R | Spring thickness: 11.5MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 250MM - Upper mount tab thickness: 27MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.6MM - Lower mount hole ID: 10MM - Eye to Eye: 430MM FITS 97-04 KLX300R | | SIDE STAND | 2004 | KLX300R | FITS 96 KLX250, 97-07 KLX300 | | | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 2004 | KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 | | 2004 | KLX300R | | | | 2004 | KLX300R |
| 2005 | KLX300R | | | | | | | | 2005 | KLX300R | | Denso 21119-1479 071000-1090 FITS 97-2007 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 2005 | KLX300R | | | | | | | | 2005 | KLX300R | | | 2005 | KLX300R | | | | 2005 | KLX300R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 2005 | KLX300R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R | | 2005 | KLX300R | | | FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S | FITS 96 KLX250, 97-07 KLX300 | | 2005 | KLX300R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 2005 | KLX300R | | | FITS 04-07 KLR300R, 4 KX500, 06-07 KLX250S | | | 2005 | KLX300R | | | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 2005 | KLX300R | | | | 2005 | KLX300R | FITS 96 KLX250, 97-07 KLX300 | | | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 2005 | KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 | | 2005 | KLX300R | | | | 2005 | KLX300R |
| 2006 | KLX300R | | | | | | | | 2006 | KLX300R | | Denso 21119-1479 071000-1090 FITS 97-2007 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 2006 | KLX300R | | | | | | | | 2006 | KLX300R | | | 2006 | KLX300R | | | | 2006 | KLX300R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 2006 | KLX300R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R | | 2006 | KLX300R | | | FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S | FITS 96 KLX250, 97-07 KLX300 | | 2006 | KLX300R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 2006 | KLX300R | | | FITS 04-07 KLR300R, 4 KX500, 06-07 KLX250S | | | 2006 | KLX300R | | | | 2006 | KLX300R | | | | 2006 | KLX300R | FITS 96 KLX250, 97-07 KLX300 | | | FITS 88-91 KX125 KX250, 88-04 KX500, 89-06 KDX200, 91-94 KDX250, 94-96 KLX250, 97-06 KLX300, 06-07 KLX 250S | 2006 | KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 | | 2006 | KLX300R | | | | 2006 | KLX300R |
| 2007 | KLX300R | | | | | | | | 2007 | KLX300R | | Denso 21119-1479 071000-1090 FITS 97-2007 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 2007 | KLX300R | | | | | | | | 2007 | KLX300R | | | 2007 | KLX300R | | | | 2007 | KLX300R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 2007 | KLX300R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R | | 2007 | KLX300R | | | FITS 99-05 KDX220, 00-06 KDX200, 00-07 KLX300R, 06-07 KLX250S | FITS 96 KLX250, 97-07 KLX300 | | 2007 | KLX300R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 2007 | KLX300R | | | FITS 04-07 KLR300R, 4 KX500, 06-07 KLX250S | | | 2007 | KLX300R | | | | 2007 | KLX300R | | | | 2007 | KLX300R | FITS 96 KLX250, 97-07 KLX300 | | | | 2007 | KLX300R | FITS 94-96 KLX250R, 97-07 KLX300R, 06-07 KLX250S | Everything fits 97-07 KLX300R except the output shaft which fits 97-2002 | | 2007 | KLX300R | | | | 2007 | KLX300R |
| 1993 | KLX650R | | LX650AE01XXXX | | FITS 93-96 KLX650R | | | | 1993 | KLX650R | | | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 1993 | KLX650R | | | | | | | | 1993 | KLX650R | KYB - USD - K328-L K328-R - CHROME OD 43MM - C/L 36 1/8" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE OD 15MM & 22MM - FITS 93-96 KLX650R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 1993 | KLX650R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 | | FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R | 1993 | KLX650R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 1993 | KLX650R | ROTOR OD 250MM - ROTOR BOLT CIRCLE 4 ON 116MM | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | | | 1993 | KLX650R | | | | | | 1993 | KLX650R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 1993 | KLX650R | | | FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R | | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | 1993 | KLX650R | FITS 91-93 KX125 KX250 KDX250, 93-95 KLX650R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 1993 | KLX650R | KYB - Spring thickness: 12.3MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 240MM - Upper mount tab thickness: 26.8MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.7MM - Lower mount hole ID: 10MM - Eye to Eye: 432MM - FITS 93-96 KLX650R | | | 1993 | KLX650R | | | | FITS 92-93 KX125 KX250, 93-96 KLX650R | 1993 | KLX650R | FITS 93-96 KLX650 C & R | | FITS 93-96 KLX650R (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650C 93-96) | 1993 | KLX650R | FITS 93-96 KLX650R (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT) | | | 1993 | KLX650R |
| 1994 | KLX650R | | LX650AE01XXXX | | FITS 93-96 KLX650R | | | | 1994 | KLX650R | | | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 1994 | KLX650R | | | | | | | | 1994 | KLX650R | KYB - USD - K328-L K328-R - CHROME OD 43MM - C/L 36 1/8" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE OD 15MM & 22MM - FITS 93-96 KLX650R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 1994 | KLX650R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 | | FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R | 1994 | KLX650R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 1994 | KLX650R | ROTOR OD 250MM - ROTOR BOLT CIRCLE 4 ON 116MM | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | | | 1994 | KLX650R | | | | | | 1994 | KLX650R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 1994 | KLX650R | | | FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R | | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | 1994 | KLX650R | FITS 91-93 KX125 KX250 KDX250, 93-95 KLX650R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 1994 | KLX650R | KYB - Spring thickness: 12.3MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 240MM - Upper mount tab thickness: 26.8MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.7MM - Lower mount hole ID: 10MM - Eye to Eye: 432MM - FITS 93-96 KLX650R | | | 1994 | KLX650R | | | | FITS 92-93 KX125 KX250, 93-96 KLX650R | 1994 | KLX650R | FITS 93-96 KLX650 C & R | | FITS 93-96 KLX650R (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650C 93-96) | 1994 | KLX650R | FITS 93-96 KLX650R (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT) | | | 1994 | KLX650R |
| 1995 | KLX650R | JKALXEA18SA00XXXX | LX650AE01XXXX | | FITS 93-96 KLX650R | | | KEIHIN CVK 792 A 116 40MM | 1995 | KLX650R | | DENSO 21119-1368/1361 070000-2410/071000-0510 | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 1995 | KLX650R | | | | 129700 | | | DENSO 0320008261 | 1995 | KLX650R | KYB - USD - K328-L K328-R - CHROME OD 43MM - C/L 36 1/8" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE OD 15MM & 22MM - FITS 93-96 KLX650R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 1995 | KLX650R | FITS 93-94 KDX200 KDX250, 93-95 KLX650R KLX250R, RH 13070-1264, LH 13070-1263 | | FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R | 1995 | KLX650R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | FITS 94-96 KX125 KX250 KX500 KX80 KLX250 KLX650, 95-06 KDX200, 97-05 KDX220, 95-96 KX100, KLX300 97-07, 46092-1186 | FITS 93-95 KLX650R, 94-95 KLX250R, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | 1995 | KLX650R | ROTOR OD 250MM - ROTOR BOLT CIRCLE 4 ON 116MM | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | | | 1995 | KLX650R | | | | | | 1995 | KLX650R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 1995 | KLX650R | | | FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R | | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | 1995 | KLX650R | FITS 91-93 KX125 KX250 KDX250, 93-95 KLX650R | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 1995 | KLX650R | KYB - Spring thickness: 12.3MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 240MM - Upper mount tab thickness: 26.8MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.7MM - Lower mount hole ID: 10MM - Eye to Eye: 432MM - FITS 93-96 KLX650R | | | 1995 | KLX650R | | | | FITS 92-93 KX125 KX250, 93-96 KLX650R | 1995 | KLX650R | FITS 93-96 KLX650 C & R | | FITS 93-96 KLX650R (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650C 93-96) | 1995 | KLX650R | FITS 93-96 KLX650R (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT) | | | 1995 | KLX650R |
| 1996 | KLX650R | | LX650AE01XXXX | | FITS 93-96 KLX650R | | | | 1996 | KLX650R | | | FITS 90-96 KX125 KX250, 90-04 KX500, 95-06 KDX200, 97-05 KDX220, 93-96 KLX650R, 94-96 KLX250, 97-07 KLX300 | | 1996 | KLX650R | | | | | | | | 1996 | KLX650R | KYB - USD - K328-L K328-R - CHROME OD 43MM - C/L 36 1/8" - UPPER 51.9MM - LOWER 56.6MM - BRAKE MOUNT C/L 102MM - AXLE OD 15MM & 22MM - FITS 93-96 KLX650R | | 1996 | KLX650R | | | FITS 94-96 KX125 KX250, 94-03 KX500, 95-03 KDX200, 96 KLX650R, 97-03 KDX220, 97-03 KLX300 | 1996 | KLX650R | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | | | 1996 | KLX650R | ROTOR OD 250MM - ROTOR BOLT CIRCLE 4 ON 116MM | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | | | 1996 | KLX650R | | | | | | 1996 | KLX650R | | | R-1237 20mm AXLE DIA - BRG TO BRG 129mm - FITS KDX200 95-06, KDX250 91-94, KLR650R 93-96, KLX250R 94-96, KLX300R 97-07, KDX220 97-05 | 1996 | KLX650R | | | FITS 95-96 KX125 & KX250, 96KLX650R, 96-03 KX500, 97-03 KLX300R | | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | 1996 | KLX650R | | 92-94 KDX250, 92-02 KX125 KX250, 93-96 KLX650R, 94-04 KX500, 95-96 KLX250R, 97-07 KLX300R | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 1996 | KLX650R | KYB - Spring thickness: 12.3MM OD - Spring Diameter: 88.5MM - Spring length as mounted: 240MM - Upper mount tab thickness: 26.8MM - Upper mount tab hole ID: 10MM - Lower Mount Internal Width: 22.7MM - Lower mount hole ID: 10MM - Eye to Eye: 432MM - FITS 93-96 KLX650R | | | 1996 | KLX650R | | | | FITS 92-93 KX125 KX250, 93-96 KLX650R | 1996 | KLX650R | FITS 93-96 KLX650 C & R | | FITS 93-96 KLX650R (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650C 93-96) | 1996 | KLX650R | FITS 93-96 KLX650R (THE KLX650C WILL ALSO FIT BUT IT HAS THE IGNITION MOUNT) | | | 1996 | KLX650R |
| 1993 | KLX650C | | LX650AE00XXXX | | | | | CVK V327 | 1993 | KLX650C | | | | | 1993 | KLX650C | | | FITS 93-96 KLX650C | | | | | 1993 | KLX650C | | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 1993 | KLX650C | | | FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R | 1993 | KLX650C | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | | | 1993 | KLX650C | ROTOR OD 290MM - ROTOR ID - 100MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-96 KLX650C | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | | FITS 93-96 KLX650R | 1993 | KLX650C | FITS KLX650C 1993-1996 | | | | | 1993 | KLX650C | | | R-1250 - AXLE DIA 20MM - BRG TO BRG 138MM - ROTOR 6 ON A 115MM BC - 36 SPOKES - FITS 93 KLX650C ONLY | 1993 | KLX650C | | | FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R | | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | 1993 | KLX650C | | ROTOR OD 230MM - ID 100MM - ROTOR 6 ON A 115MM BC | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 1993 | KLX650C | | | | 1993 | KLX650C | | | | | 1993 | KLX650C | FITS 93-96 KLX650 C & R | | FITS 93-96 KLX650C (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650R 93-96) | 1993 | KLX650C | FITS 93-96 KLX650C (THE KLX650R 93-96 WILL FIT BUT THERE IS NO IGNITION MOUNT) | | | 1993 | KLX650C |
| 1994 | KLX650C | | LX650AE00XXXX | | | | | | 1994 | KLX650C | | | | | 1994 | KLX650C | | | FITS 93-96 KLX650C | | | | | 1994 | KLX650C | | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 1994 | KLX650C | | | FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R | 1994 | KLX650C | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | | | 1994 | KLX650C | ROTOR OD 290MM - ROTOR ID - 100MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-96 KLX650C | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | | FITS 93-96 KLX650R | 1994 | KLX650C | FITS KLX650C 1993-1996 | | | | | 1994 | KLX650C | | | | 1994 | KLX650C | | | FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R | | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | 1994 | KLX650C | | | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 1994 | KLX650C | | | | 1994 | KLX650C | | | | | 1994 | KLX650C | FITS 93-96 KLX650 C & R | | FITS 93-96 KLX650C (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650R 93-96) | 1994 | KLX650C | FITS 93-96 KLX650C (THE KLX650R 93-96 WILL FIT BUT THERE IS NO IGNITION MOUNT) | | | 1994 | KLX650C |
| 1995 | KLX650C | | LX650AE00XXXX | | | | | | 1995 | KLX650C | | | | | 1995 | KLX650C | | | FITS 93-96 KLX650C | | | | | 1995 | KLX650C | | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 1995 | KLX650C | | | FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R | 1995 | KLX650C | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | | | 1995 | KLX650C | ROTOR OD 290MM - ROTOR ID - 100MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-96 KLX650C | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | | FITS 93-96 KLX650R | 1995 | KLX650C | FITS KLX650C 1993-1996 | | | | | 1995 | KLX650C | | | | 1995 | KLX650C | | | FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R | | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | 1995 | KLX650C | | | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 1995 | KLX650C | | | | 1995 | KLX650C | | | | | 1995 | KLX650C | FITS 93-96 KLX650 C & R | | FITS 93-96 KLX650C (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650R 93-96) | 1995 | KLX650C | FITS 93-96 KLX650C (THE KLX650R 93-96 WILL FIT BUT THERE IS NO IGNITION MOUNT) | | | 1995 | KLX650C |
| 1996 | KLX650C | | LX650AE00XXXX | | | | | | 1996 | KLX650C | | DENSO 21119-1368 07000-2410 | | | 1996 | KLX650C | | | FITS 93-96 KLX650C | | | | 32000-8020 10NX | 1996 | KLX650C | | FITS 93-94 KDX200 KDX250, 93-95 KLX650R, 93-96 KLX650C, 94-96 KLX250R, 97-03 KLX300R, LH 55020-1363-RZ, RH 55020-1423-RZ | 1996 | KLX650C | | | FITS 93-95 KLX650R, 93-96 KLX650C, 95-96 KLX250R | 1996 | KLX650C | FITS 94-05 KX125, 94-07 KX250, 94-04 KX500, 04-08 KX250F, 06-08 KX450F, 93-96 KLX650R KLX650C, 95-06 KDX200, 97-05 KDX220, 97-07 KLX300 | | | 1996 | KLX650C | ROTOR OD 290MM - ROTOR ID - 100MM - ROTOR BOLT CIRCLE 4 ON 116MM - FITS 93-96 KLX650C | F-1240 - AXLE OD 15MM - BRG TO BRG 97MM - FITS 92-94 KDX250, 93-94 KDX200, 93-96 KLX650R, 93-96 KLX650C, KLX250R, 97-07 KLX300R | | FITS 93-96 KLX650R | 1996 | KLX650C | FITS KLX650C 1993-1996 | | | | | 1996 | KLX650C | | | | 1996 | KLX650C | | | FITS 93-96 KLX650C, 93-95 KLX650R, 94 & 96 KLX250R | | FITS 90-96 KX125 KX250, 91-94 KDX250, 93-96 KLX650C KLX650R, 95-06 KDX200, 97-05 KDX220 43059-1561 | 1996 | KLX650C | | | 20MM AXLE HOLE X WIDTH 21.5MM FITS 89 KX125 KX250 KX500, 89-05 KDX200, 91-94 KDX250, 93-96 KLX650 C & R, 94-96 KLX250R, 97-05 KLX300R KDX220R | 1996 | KLX650C | | | | 1996 | KLX650C | | | | | 1996 | KLX650C | FITS 93-96 KLX650 C & R | | FITS 93-96 KLX650C (I SEE VERY LITTLE DIFFERENCE IN THIS BOTTOM AND THE KLX650R 93-96) | 1996 | KLX650C | FITS 93-96 KLX650C (THE KLX650R 93-96 WILL FIT BUT THERE IS NO IGNITION MOUNT) | | | 1996 | KLX650C |
| YEAR | TYPE | FRAME VIN | ENGINE ID | ENGINE CASES | AIR BOX | CAM SHAFT EXHAUST | CAM SHAFT INTAKE | CARBURETOR | YEAR | TYPE | CARB BOOT AND REED BOLT PATTERN | CDI | CHAIN GUIDE | CLUTCH ARM | YEAR | TYPE | CLUTCH COVER | INNER CLUTCH COVER | CLUTCH BASKET | COIL | CRANK SHAFT | CYLINDER | FLY WHEEL | YEAR | TYPE | FORK | FORK GUARDS | YEAR | TYPE | FORK GUARD MOUNTS | FRONT AXLE | FRONT BRAKE CALIPER | YEAR | TYPE | FRONT BRAKE CALIPER MOUNT | FRONT BRAKE LEVER | FRONT BRAKE MASTER CYLINDER | YEAR | TYPE | FRONT BRAKE ROTOR | FRONT HUB | HEAD | KICK IDLER GEAR | YEAR | TYPE | | PISTON | | STATOR | STATOR COVER | YEAR | TYPE | SHOCK ARM LINKAGE | | REAR HUB | YEAR | TYPE | SHIFT FORKS | REAR BRAKE BACKING PLATE | REAR BRAKE CALIPER | REAR BRAKE CALIPER MOUNT | REAR BRAKE HOSE | YEAR | TYPE | | REAR BRAKE ROTOR | | YEAR | TYPE | SHOCK | | | YEAR | TYPE | STATOR | STATOR COVER | | SWING ARM PIN / AXLE | YEAR | TYPE | | TRANSMISSION | TRIPLE TREE BOTTOM | YEAR | TYPE | TRIPLE TREE TOP | VOLTAGE REGULATOR | | YEAR | TYPE |
| 1984 | KL600 | | | | | | | | 1984 | KL600 | | | | | 1984 | KL600 | | | | | | | | 1984 | KL600 | | | 1984 | KL600 | | | FITS 84-86 KL600, 85-90 KLR250 | 1984 | KL600 | | | FITS 84-86 KL600, 85-90 KLR250 | 1984 | KL600 | | | | | 1984 | KL600 | | | | | | 1984 | KL600 | | | | 1984 | KL600 | | | | | | 1984 | KL600 | | | | 1984 | KL600 | | FITS 84-86 KL600 39007-1057, 46102-1115 | | 1984 | KL600 | | | | | 1984 | KL600 | | OUTPUT SHAFT FITS 84-86 KLR600, 87-89 KLR650 | | 1984 | KL600 | | | | 1984 | KL600 |
| 1985 | KL600 | | | | | | | | 1985 | KL600 | | | | | 1985 | KL600 | | | | | | | | 1985 | KL600 | CONVENTIONAL - CHROME OD 38 - C/L 36 5/8" - BRAKE MOUNT C/L 45MM - AXLE HOLES 15MM | | 1985 | KL600 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 84-86 KL600, 85-90 KLR250 | 1985 | KL600 | | | FITS 84-86 KL600, 85-90 KLR250 | 1985 | KL600 | | | | | 1985 | KL600 | | | | | | 1985 | KL600 | | | | 1985 | KL600 | | | | | | 1985 | KL600 | | | | 1985 | KL600 | | FITS 84-86 KL600 39007-1057, 46102-1115 | | 1985 | KL600 | | | | | 1985 | KL600 | | OUTPUT SHAFT FITS 84-86 KLR600, 87-89 KLR650 | | 1985 | KL600 | | FITS 85-86 KL600, 87-07 KLR650 | | 1985 | KL600 |
| 1986 | KL600 | | | | | | | | 1986 | KL600 | | | | | 1986 | KL600 | | | | | | | | 1986 | KL600 | CONVENTIONAL - CHROME OD 38 - C/L 36 5/8" - BRAKE MOUNT C/L 45MM - AXLE HOLES 15MM | | 1986 | KL600 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 84-86 KL600, 85-90 KLR250 | 1986 | KL600 | | | FITS 84-86 KL600, 85-90 KLR250 | 1986 | KL600 | | | | | 1986 | KL600 | | | | | | 1986 | KL600 | | | | 1986 | KL600 | | | | | | 1986 | KL600 | | | | 1986 | KL600 | | FITS 84-86 KL600 39007-1057, 46102-1115 | | 1986 | KL600 | | | | | 1986 | KL600 | | OUTPUT SHAFT FITS 84-86 KLR600, 87-89 KLR650 | | 1986 | KL600 | | FITS 85-86 KL600, 87-07 KLR650 | | 1986 | KL600 |
| 1987 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 1987 | KLR650 | | FITS 87-89 KLR650 | | | 1987 | KLR650 | | | FITS 87-95 KLR650 | | | | | 1987 | KLR650 | | | 1987 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | | 1987 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1987 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 1987 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 1987 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1987 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 1987 | KLR650 | | FITS 87-07 KLR650 | | 1987 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1987 | KLR650 | | | | FITS 87-10 KLR650 | 1987 | KLR650 | | INPUT SHAFT FITS 87-11 KLR650 – OUTPUT SHAFT FITS 87-89 KLR650 - GEARS FIT 87-96 KLR650 | FITS 87-07 KLR650 | 1987 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | | 1987 | KLR650 |
| 1988 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 1988 | KLR650 | | FITS 87-89 KLR650 | | | 1988 | KLR650 | | | FITS 87-95 KLR650 | | | | | 1988 | KLR650 | | | 1988 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | | 1988 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1988 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 1988 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 1988 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1988 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 1988 | KLR650 | | FITS 87-07 KLR650 | | 1988 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1988 | KLR650 | | | | FITS 87-10 KLR650 | 1988 | KLR650 | | INPUT SHAFT FITS 87-11 KLR650 – OUTPUT SHAFT FITS 87-89 KLR650 - GEARS FIT 87-96 KLR650 | FITS 87-07 KLR650 | 1988 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | | 1988 | KLR650 |
| 1989 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 1989 | KLR650 | | FITS 87-89 KLR650 | | | 1989 | KLR650 | | | FITS 87-95 KLR650 | | | | | 1989 | KLR650 | | | 1989 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | | 1989 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1989 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 1989 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 1989 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1989 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 1989 | KLR650 | | FITS 87-07 KLR650 | | 1989 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1989 | KLR650 | | | | FITS 87-10 KLR650 | 1989 | KLR650 | | INPUT SHAFT FITS 87-11 KLR650 – OUTPUT SHAFT FITS 87-89 KLR650 - GEARS FIT 87-96 KLR650 | FITS 87-07 KLR650 | 1989 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | | 1989 | KLR650 |
| 1990 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 1990 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | | 1990 | KLR650 | | | FITS 87-95 KLR650 | | | | DENSO 032000-7061 FITS 90-07 KLR650 | 1990 | KLR650 | | | 1990 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | | 1990 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1990 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 1990 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 1990 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1990 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 1990 | KLR650 | | FITS 87-07 KLR650 | | 1990 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1990 | KLR650 | | | | FITS 87-10 KLR650 | 1990 | KLR650 | | INPUT SHAFT FITS 87-11 KLR650, OUTPUT SHAFT FITS 90-96 KLR650 - GEARS FIT 87-96 KLR650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 1990 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | FITS 90-02 KLR650 | 1990 | KLR650 |
| 1991 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 1991 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | | 1991 | KLR650 | | | FITS 87-95 KLR650 | | | | DENSO 032000-7061 FITS 90-07 KLR650 | 1991 | KLR650 | | | 1991 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1991 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1991 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 1991 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 1991 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1991 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 1991 | KLR650 | | FITS 87-07 KLR650 | | 1991 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1991 | KLR650 | | | | FITS 87-10 KLR650 | 1991 | KLR650 | | INPUT SHAFT FITS 87-11 KLR650, OUTPUT SHAFT FITS 90-96 KLR650 - GEARS FIT 87-96 KLR650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 1991 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | FITS 90-02 KLR650 | 1991 | KLR650 |
| 1992 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 1992 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | | 1992 | KLR650 | | | FITS 87-95 KLR650 | | | | DENSO 032000-7061 FITS 90-07 KLR650 | 1992 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 88.5MM – AXLE HOLE ID 15MM – FITS AT LEAST 92-93 KLR650 | | 1992 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1992 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1992 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 1992 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 1992 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1992 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 1992 | KLR650 | | FITS 87-07 KLR650 | | 1992 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1992 | KLR650 | | | | FITS 87-10 KLR650 | 1992 | KLR650 | | INPUT SHAFT FITS 87-11 KLR650, OUTPUT SHAFT FITS 90-96 KLR650 - GEARS FIT 87-96 KLR650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 1992 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | FITS 90-02 KLR650 | 1992 | KLR650 |
| 1993 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 1993 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | | 1993 | KLR650 | | | FITS 87-95 KLR650 | | | | DENSO 032000-7061 FITS 90-07 KLR650 | 1993 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 88.5MM – AXLE HOLE ID 15MM – FITS AT LEAST 92-93 KLR650 | | 1993 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1993 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1993 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 1993 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 1993 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1993 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 1993 | KLR650 | | FITS 87-07 KLR650 | | 1993 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1993 | KLR650 | | | | FITS 87-10 KLR650 | 1993 | KLR650 | | INPUT SHAFT FITS 87-11 KLR650 - OUTPUT SHAFT FITS 90-96 KLR650 - GEARS FIT 87-96 KLR650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 1993 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | FITS 90-02 KLR650 | 1993 | KLR650 |
| 1994 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 1994 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | | 1994 | KLR650 | | | FITS 87-95 KLR650 | | | | DENSO 032000-7061 FITS 90-07 KLR650 | 1994 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | | 1994 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1994 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1994 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 1994 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 1994 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1994 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 1994 | KLR650 | | FITS 87-07 KLR650 | | 1994 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1994 | KLR650 | | | | FITS 87-10 KLR650 | 1994 | KLR650 | | INPUT SHAFT FITS 87-11 KLR650 - OUTPUT SHAFT FITS 90-96 KLR650 - GEARS FIT 87-96 KLR650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 1994 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | FITS 90-02 KLR650 | 1994 | KLR650 |
| 1995 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 1995 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | | 1995 | KLR650 | | | FITS 87-95 KLR650 | | | | DENSO 032000-7061 FITS 90-07 KLR650 | 1995 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | | 1995 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1995 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1995 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 1995 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 1995 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1995 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 1995 | KLR650 | | FITS 87-07 KLR650 | | 1995 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1995 | KLR650 | | | | FITS 87-10 KLR650 | 1995 | KLR650 | | INPUT SHAFT FITS 87-11 KLR650 - OUTPUT SHAFT FITS 90-96 KLR650 - GEARS FIT 87-96 KLR650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 1995 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | FITS 90-02 KLR650 | 1995 | KLR650 |
| 1996 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 1996 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | FITS 96-08 KLR650 | 1996 | KLR650 | | | | | FITS 96-07 KLR650 | | DENSO 032000-7061 FITS 90-07 KLR650 | 1996 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | | 1996 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1996 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1996 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 1996 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 1996 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1996 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 1996 | KLR650 | | FITS 87-07 KLR650 | | 1996 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1996 | KLR650 | | | | FITS 87-10 KLR650 | 1996 | KLR650 | | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 1996 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | FITS 90-02 KLR650 | 1996 | KLR650 |
| 1997 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 1997 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | FITS 96-08 KLR650 | 1997 | KLR650 | | | | | FITS 96-07 KLR650 | | DENSO 032000-7061 FITS 90-07 KLR650 | 1997 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | | 1997 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1997 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1997 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 1997 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 1997 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1997 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 1997 | KLR650 | | FITS 87-07 KLR650 | | 1997 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1997 | KLR650 | | | | FITS 87-10 KLR650 | 1997 | KLR650 | | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 1997 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | FITS 90-02 KLR650 | 1997 | KLR650 |
| 1998 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 1998 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | FITS 96-08 KLR650 | 1998 | KLR650 | | | | | FITS 96-07 KLR650 | | DENSO 032000-7061 FITS 90-07 KLR650 | 1998 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | | 1998 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1998 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1998 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 1998 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 1998 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1998 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 1998 | KLR650 | | FITS 87-07 KLR650 | | 1998 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1998 | KLR650 | | | | FITS 87-10 KLR650 | 1998 | KLR650 | | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 1998 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | FITS 90-02 KLR650 | 1998 | KLR650 |
| 1999 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 1999 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | FITS 96-08 KLR650 | 1999 | KLR650 | | | | | FITS 96-07 KLR650 | | DENSO 032000-7061 FITS 90-07 KLR650 | 1999 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | | 1999 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 1999 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1999 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 1999 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 1999 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 1999 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 1999 | KLR650 | | FITS 87-07 KLR650 | | 1999 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 1999 | KLR650 | | | | FITS 87-10 KLR650 | 1999 | KLR650 | | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 1999 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | FITS 90-02 KLR650 | 1999 | KLR650 |
| 2000 | KLR650 | | | | | | | KEIHIN CVK V327 NKJ FITS 87-07 KLR650 15001-1327 40.5MM ID | 2000 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | FITS 96-08 KLR650 | 2000 | KLR650 | | | | | FITS 96-07 KLR650 | | DENSO 032000-7061 FITS 90-07 KLR650 | 2000 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | | 2000 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 91-00 KLR650 | 2000 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2000 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 2000 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 2000 | KLR650 | | FITS 00-03 KLR650 | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2000 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 2000 | KLR650 | | FITS 87-07 KLR650 | | 2000 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2000 | KLR650 | | | | FITS 87-10 KLR650 | 2000 | KLR650 | | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 2000 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | FITS 90-02 KLR650 | 2000 | KLR650 |
| 2001 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 2001 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | FITS 96-08 KLR650 | 2001 | KLR650 | | | | | FITS 96-07 KLR650 | | DENSO 032000-7061 FITS 90-07 KLR650 | 2001 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | | 2001 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 01 KLR650 | 2001 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2001 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 2001 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 2001 | KLR650 | | FITS 00-03 KLR650 | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2001 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 2001 | KLR650 | | FITS 87-07 KLR650 | | 2001 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2001 | KLR650 | | | | FITS 87-10 KLR650 | 2001 | KLR650 | | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 2001 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | FITS 90-02 KLR650 | 2001 | KLR650 |
| 2002 | KLR650 | | KHI KL650AE054XXX | | | | | FITS 87-07 KLR650 15001-1327 | 2002 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | FITS 96-08 KLR650 | 2002 | KLR650 | | | | | FITS 96-07 KLR650 | | DENSO 032000-7061 FITS 90-07 KLR650 | 2002 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | | 2002 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 02-03 KLR650 | 2002 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2002 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 2002 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 2002 | KLR650 | | FITS 00-03 KLR650 | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2002 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 2002 | KLR650 | | FITS 87-07 KLR650 | | 2002 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2002 | KLR650 | | | | FITS 87-10 KLR650 | 2002 | KLR650 | | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 2002 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | FITS 90-02 KLR650 | 2002 | KLR650 |
| 2003 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 2003 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | FITS 96-08 KLR650 | 2003 | KLR650 | | | | | FITS 96-07 KLR650 | | DENSO 032000-7061 FITS 90-07 KLR650 | 2003 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | | 2003 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 02-03 KLR650 | 2003 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2003 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 2003 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 2003 | KLR650 | | FITS 00-03 KLR650 | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2003 | KLR650 | | | FITS 87-03 KLR650 | FITS 87-07 KLR650 | | 2003 | KLR650 | | FITS 87-07 KLR650 | | 2003 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2003 | KLR650 | | | | FITS 87-10 KLR650 | 2003 | KLR650 | | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 2003 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | | 2003 | KLR650 |
| 2004 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 2004 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | FITS 96-08 KLR650 | 2004 | KLR650 | | | | | FITS 96-07 KLR650 | | DENSO 032000-7061 FITS 90-07 KLR650 | 2004 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | | 2004 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 04-07 KLR650 | 2004 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2004 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 2004 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 2004 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2004 | KLR650 | | | FITS 04-07 KLR650 | FITS 87-07 KLR650 | | 2004 | KLR650 | | FITS 87-07 KLR650 | | 2004 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2004 | KLR650 | | | | FITS 87-10 KLR650 | 2004 | KLR650 | | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 2004 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | | 2004 | KLR650 |
| 2005 | KLR650 | | KHI KL650AE017XXX | | | | | FITS 87-07 KLR650 15001-1327 | 2005 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | FITS 96-08 KLR650 | 2005 | KLR650 | | | | | FITS 96-07 KLR650 | | DENSO 032000-7061 FITS 90-07 KLR650 | 2005 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | | 2005 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 04-07 KLR650 | 2005 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2005 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 2005 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 2005 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2005 | KLR650 | | | FITS 04-07 KLR650 | FITS 87-07 KLR650 | | 2005 | KLR650 | | FITS 87-07 KLR650 | | 2005 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2005 | KLR650 | | | | FITS 87-10 KLR650 | 2005 | KLR650 | | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 2005 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | | 2005 | KLR650 |
| 2006 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 2006 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | FITS 96-08 KLR650 | 2006 | KLR650 | | | | | FITS 96-07 KLR650 | | DENSO 032000-7061 FITS 90-07 KLR650 | 2006 | KLR650 | KYB – CONVENTIONAL – CHROME OD 38MM – C/L 36 1/16” - BRAKE MOUNT C/L 89MM – AXLE HOLE ID 15MM – FITS AT LEAST 94-06 KLR650 | | 2006 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 04-07 KLR650 | 2006 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2006 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 2006 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 2006 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2006 | KLR650 | | | FITS 04-07 KLR650 | FITS 87-07 KLR650 | | 2006 | KLR650 | | FITS 87-07 KLR650 | | 2006 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2006 | KLR650 | | | | FITS 87-10 KLR650 | 2006 | KLR650 | | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 2006 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | | 2006 | KLR650 |
| 2007 | KLR650 | | | | | | | FITS 87-07 KLR650 15001-1327 | 2007 | KLR650 | | DENSO 21119-1272 070000-1970 - FITS 90-07 KLR650 | | FITS 96-08 KLR650 | 2007 | KLR650 | | | | | FITS 96-07 KLR650 | | DENSO 032000-7061 FITS 90-07 KLR650 | 2007 | KLR650 | | | 2007 | KLR650 | | FITS 85-89 KLR250, 90-05 KLR250, 85-86 KL600, 87-07 KLR650 | FITS 04-07 KLR650 | 2007 | KLR650 | FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2007 | KLR650 | FITS 87-07 KLR650 | F1146 - AXLE OD 17MM - BRG TO BRG 101-102MM - ROTOR OD 260MM - ID 130MM - 9X BC OF 145MM - 36 SPOKES - FITS 87-07 KLR650 | | | 2007 | KLR650 | | FITS 87-07 KLR650 | 87-07 KLR650 | | | 2007 | KLR650 | | | R-1175 - 20MM AXLE - BRG TO BRG 159MM - ROTOR BOLT 6 ON 135MM DIA - ROTOR ID 120.5MM OD 230MM - 36 SPOKES - Fits 87-2007 KLR650 | 2007 | KLR650 | | | FITS 04-07 KLR650 | FITS 87-07 KLR650 | | 2007 | KLR650 | | FITS 87-07 KLR650 | | 2007 | KLR650 | KAYABA - SPRING THICKNESS 10.5MM - SPRING DIAMETER 79MM - SPRING LENGTH AS MOUNTED 213MM - UPPER TAB THICKNESS 22MM - UPPER TAB MOUNT HOLE 12MM - LOWER MOUNT INTERNAL WIDTH 30MM - LOWER MOUNT HOLE 15MM - EYE TO EYE 403MM -FITS 87-07 KLR650 | | FITS 87-07 KLR650 | 2007 | KLR650 | | | | FITS 87-10 KLR650 | 2007 | KLR650 | | OUTPUT SHAFT FITS 96-07 KLR650 08-10 KL650, INPUT SHAFT FITS 87-07 KLR650, 93-96 KLX650, 08-10 KL650, GEARS FIT 96-07 KLR650, 08-10 KL650 - 96 OFFERED 2 DIFFERENT OUTPUT SHAFTS | FITS 87-07 KLR650 | 2007 | KLR650 | FITS 87-07 KLR650 | FITS 85-86 KL600, 87-07 KLR650 | | 2007 | KLR650 |
| 2008 | KLR650 | | | | | | | | 2008 | KLR650 | | | | FITS 96-08 KLR650 | 2008 | KLR650 | | | | | | | | 2008 | KLR650 | | | 2008 | KLR650 | | | | 2008 | KLR650 | | | | 2008 | KLR650 | | | | | 2008 | KLR650 | | | | | | 2008 | KLR650 | | | | 2008 | KLR650 | | | | | | 2008 | KLR650 | | | | 2008 | KLR650 | | | | 2008 | KLR650 | | | | FITS 87-10 KLR650 | 2008 | KLR650 | | | | 2008 | KLR650 | | | | 2008 | KLR650 |
| 2009 | KLR650 | | | | | | | | 2009 | KLR650 | | | | | 2009 | KLR650 | | | | | | | | 2009 | KLR650 | | | 2009 | KLR650 | | | | 2009 | KLR650 | | | | 2009 | KLR650 | | | | | 2009 | KLR650 | | | | | | 2009 | KLR650 | | | | 2009 | KLR650 | | | | | | 2009 | KLR650 | | | | 2009 | KLR650 | | | | 2009 | KLR650 | | | | FITS 87-10 KLR650 | 2009 | KLR650 | | | | 2009 | KLR650 | | | | 2009 | KLR650 |
| 2010 | KLR650 | | | | | | | | 2010 | KLR650 | | | | | 2010 | KLR650 | | | | | | | | 2010 | KLR650 | | | 2010 | KLR650 | | | | 2010 | KLR650 | | | | 2010 | KLR650 | | | | | 2010 | KLR650 | | | | | | 2010 | KLR650 | | | | 2010 | KLR650 | | | | | | 2010 | KLR650 | | | | 2010 | KLR650 | | | | 2010 | KLR650 | | | | FITS 87-10 KLR650 | 2010 | KLR650 | | | | 2010 | KLR650 | | | | 2010 | KLR650 |
