OEM-CYCLE
OEM-CYCLE HOME
About Us
Contact Us
Site Map
Used Dirt Bike Parts
ATK Used Parts
Bultaco Used Parts
Honda Used Parts
Husaberg Used Parts
Husqvarna Used Parts
Kawasaki Used Parts
KTM Used Parts
Maico Used Parts
Suzuki Used Parts
Yamaha Used Parts
Misc Used Parts
Bike Identification
What year is my dirt bike
WORLD WIDE PICS CR125
WORLD WIDE PICS CR500
World Wide Pics Of KX500
WORLD WIDE PICS KX450F
WORLD WIDE PICS KX250
WORLD WIDE PICS RM250
WORLD WIDE PICS YZ250
Building our new shop
KX500 JETTING GUIDE
CRANK BEARING REMOVAL
SPLITTING YOUR CASES
BIKES IN DISASSEMBLY
Employees wasting time
Misc Parts
2006 Tundra rear brake re
Picture for 1997 Honda CR250R
Specs for Honda CR250R 1997
Engine
Configuration Liquid-cooled single cylinder two-stroke
with power-port system Lubrication
Bore & Stroke 66.4mm x 72mm Ignition Solid-state CD with electronic advance
Capacity 249cc Charging system
Compression Ratio 8:7:1 Starter
Maximum Power Transmission #520 chain; 13T/50T
Maximum Torque Gearbox Five-speed box
Fuel 38.3mm flat-slide
Four-petal reed valve Clutch
Chassis
Frame Wheels
Dimensions Weight: 213.8 pounds
Wheelbase: 58.4 inches
Length:
Seat Height: 36.7 inches
Ground Clearance: 12.8 in. Tyres Front: 80/100-21
Rear: 110/90-19
Front Suspension 47mm inverted Showa cartridge fork with 18-position rebound and 20-position
compression damping adjustability; 12.2 inches travel Brakes Front: Single disc with twin-piston calipers
Rear: disc
Rear suspension Pro-Link Showa single shock
with spring preload; 20-position rebound damping adjustability, and compression damping adjustability separated into low-speed (8 position) and high-speed (2 turns); 12.5 inches travel Fuel Capacity 2.0 gallons
