Picture for Honda CRF450R 2002
Specs for Honda CRF450R 2002
Engine and transmission
Displacement: 449.00 ccm (27.40 cubic inches)
Engine type: Single cylinder
Stroke: 4
Compression: 11.5:1
Bore x stroke: 96.0 x 62.1 mm (3.8 x 2.4 inches)
Valves per cylinder: 4
Fuel control: SOHC
Cooling system: Liquid
Gearbox: 5-speed
Stroke: 4
Compression: 11.5:1
Fuel control: SOHC
Gearbox: 5-speed
Transmission type
final drive: Chain
Physical measures
Dry weight: 102.0 kg (224.9 pounds)
Seat height: 726 mm (28.6 inches) If adjustable, lowest setting.
Ground clearance: 330 mm (13.0 inches)
Wheelbase: 1,509 mm (59.4 inches)
Chassis and dimensions
Front suspension travel: 305 mm (12.0 inches)
Rear suspension travel: 315 mm (12.4 inches)
Front tyre dimensions: 80/100-21
Rear tyre dimensions: 110/90-19
Front brakes: Single disc
Front brakes diameter: 240 mm (9.4 inches)
Rear brakes: Single disc
Rear brakes diameter: 240 mm (9.4 inches)
Fuel capacity: 9.10 litres (2.40 gallons
This page last modified: Thursday, 09-Aug-2012 22:51:35 PDT
